Kubota Tractor M4900DT Australia Parts Catalog
Model: Kubota M4900DT Tractor
Region: Australia
Number of Pages: 400 Pages
Engine Crankcase
Engine Oil Pan
Engine Cylinder Head [Rops Type]
Engine Gear Case
Engine Head Cover [Old Type] ## S.No.;A =3u0371
Engine Head Cover [New Type] ## S.No.;A =3w0001
Engine Main Bearing Case
Engine Camshaft And Idle Gear Shaft
Engine Piston And Crankshaft ## Note Order By Ref.No.010 And 040 New Parts.
Engine Flywheel
Engine Fuel Camshaft
Engine Engine Stop Lever
Engine Injection Pump
Engine Governor
Engine Speed Control Plate
Engine Nozzle Holder And Glow Plug [Rops Type]
Engine Nozzle Holder [Component Parts]
Engine Water Flange And Thermostat [Rops Type]
Engine Water Pump
Engine Valve And Rocker Arm
Engine Inlet Manifold
Engine Exhaust Manifold [Rops Type]
Engine Air Cleaner [Rops Type]
Engine Air Cleaner [Component Parts]
Engine Muffler [Rops Type]
Engine Upper Gasket Kit
Engine Lower Gasket Kit
Engine Hand Accelerator Lever [Rops Type]
Engine Stop Solenoid Engine Stop Wire [Rops Type]
Fuel System Fuel Tank [Rops Type]
Fuel System Fuel Pipe 1 (Rear) [Rops Type]
Fuel System Fuel Filter [Rops Type]
Fuel System Fuel Filter [Component Parts] [Rops Type]
Cooling Water System Fan [Rops Type]
Cooling Water System Water Pipe [Rops Type]
Cooling Water System Radiator [Rops Type]
Cooling Water System Reserve Tank [Rops Type]
Electrical System Alternator [Rops Type]
Electrical System Alternator [Component Parts] [Rops Type]
Electrical System Starter
Electrical System Starter [Component Parts]
Electrical System Battery [Rops Type]
Electrical System Switch Sensor [Rops Type]
Electrical System Switch(Panel Board) Relay [Rops Type]
Electrical System Panel Board [Rops Type]
Electrical System Panel Board [Component Parts] [Rops Type]
Electrical System Head Light
Electrical System Hazard Light Tail Light [Rops Type]
Electrical System Electrical Wiring 1 [Rops Type]
Clutch Transmission Clutch Housing [Rops Type]
Clutch Transmission Shuttle Gear Case
Clutch Transmission Transmission Case [Rops Type]
Clutch Transmission Transmission Case Rear Cover
Clutch Transmission Rear Axle Case
Clutch Transmission Front Drive Case
Clutch Transmission Clutch Release Fork [Rops Type]
Clutch Transmission Clutch Pedal [Rops Type]
Clutch Transmission Input Shaft
Clutch Transmission First Shaft
Clutch Transmission Second Shaft
Clutch Transmission Third Shaft [Rops Type]
Clutch Transmission Back Idle Shaft
Clutch Transmission Creep Shaft
Clutch Transmission Bevel Gear [Old Type] ## S.No.;A =52404
Clutch Transmission Bevel Gear [New Type] ## S.No.;A =52405
Clutch Transmission Differential Rear
Clutch Transmission PTO Propeller Shaft [Rops Type]
Clutch Transmission PTO Clutch
Clutch Transmission PTO Clutch [Component Parts]
Clutch Transmission PTO Clutch Valve
Clutch Transmission PTO Clutch Valve [Component Parts]
Clutch Transmission PTO Shaft
Clutch Transmission Front Propeller Shaft (Rear)
Speed Change Shift Fork Shift Lever Main Gear Shift Fork
Speed Change Shift Fork Shift Lever Shuttle Gear Shift Fork
Speed Change Shift Fork Shift Lever Range Gear Shift Fork Creep Gear Shift Fork [Rops Ty
Speed Change Shift Fork Shift Lever PTO Gear Shift Fork
Speed Change Shift Fork Shift Lever Rear Differential Lock Shift Fork
Speed Change Shift Fork Shift Lever Main Gear Shift Lever [Rops Type]
Speed Change Shift Fork Shift Lever Shuttle Shift Lever [Rops Type]
Speed Change Shift Fork Shift Lever Range Gear Shift Lever Creep Gear Shift Lever [Rops
Speed Change Shift Fork Shift Lever PTO Clutch Lever [Rops Type]
Speed Change Shift Fork Shift Lever PTO Gear Shift Lever
Speed Change Shift Fork Shift Lever Front Wheel Drive Lever [Rops Type]
Rear Axle Brake Rear Axle
Rear Axle Brake Brake
Rear Axle Brake Brake Rod [Rops Type]
Rear Axle Brake Parking Brake Lever [Rops Type]
Rear Axle Brake Parking Brake Rod [Rops Type] [Old Type] ## S.No.;A =53142
Rear Axle Brake Parking Brake Rod [Rops Type] [New Type] ## S.No.;A =53143
Rear Axle Brake Brake Pedal [Rops Type]
Rear Axle Brake Rear Differential Lock Pedal [Rops Type]
Front Axle Chassis Front Axle Frame [Rops Type]
Front Axle Chassis Front Axle Bracket
Front Axle Chassis Front Propeller Shaft [Rops Type]
Front Axle Chassis Front Differential Case
Front Axle Chassis Bevel Gear (Front)
Front Axle Chassis Differential Front
Front Axle Chassis Front Axle Case
Front Axle Chassis Differential Gear Shaft
Steering Steering Handle [Rops Type]
Steering Steering Controller [Rops Type]
Steering Steering Controller [Component Parts]
Hydraulic System Tie Rod Steering Cylinder
Hydraulic System Steering Cylinder [Component Parts]
Hydraulic System Hydraulic Pump
Hydraulic System Hydraulic Pump [Component Parts]
Hydraulic System Hydraulic Pipe (Suction) [Rops Type]
Hydraulic System Hydraulic Pipe (Delivery) [Rops Type]
Hydraulic System Hydraulic Oil Line (Steering PTO) [Rops Type]
Hydraulic System Steering Hose (Delivery) [Rops Type]
Hydraulic System Hydraulic Cylinder [Rops Type]
Hydraulic System Hydraulic Lift Arm
Hydraulic System Hydraulic Cylinder Cover [Rops Type]
Hydraulic System Control Valve
Hydraulic System Draft And Position Control Lever [Rops Type]
Hydraulic System Position Control Shaft
Hydraulic System Draft Control Shaft
Hydraulic System Feed Back Lever
Hydraulic System Auxiliary Control Valve [Rops Type]
Hydraulic System Auxiliary Control Valve [Component Parts] [Rops Type]
3-Point Linkage Drawbar Hitch Top Link Bracket [Rops Type]
3-Point Linkage Drawbar Hitch Top Link [Rops Type]
3-Point Linkage Drawbar Hitch Lower Link [Rops Type] [Old Type] ## S.No.;A =52915
3-Point Linkage Drawbar Hitch Lower Link [Rops Type] [New Type] ## S.No.;A =52916
3-Point Linkage Drawbar Hitch Lift Rod Rh [Rops Type]
3-Point Linkage Drawbar Hitch Lift Rod Lh [Rops Type]
3-Point Linkage Drawbar Hitch Swinging Drawbar [Rops Type]
3-Point Linkage Drawbar Hitch PTO Shaft Protector
Hood Bonnet Hood(Bonnet) Front [Rops Type]
Hood Bonnet Hood(Bonnet) Upper [Rops Type]
Hood Bonnet Hood(Bonnet) Side [Rops Type]
Hood Bonnet Hood(Bonnet) Side Cover [Rops Type]
Hood Bonnet Hood(Bonnet) Rear [Rops Type]
Hood Bonnet Rearview Mirror [Rops Type]
Hood Bonnet Fender [Rops Type]
Hood Bonnet Floor Seat [Rops Type]
Hood Bonnet Step [Rops Type]
Hood Bonnet Seat [Rops Type]
Hood Bonnet Tool Box [Rops Type]
Rops Rops [Old Type] ## S.No.;A =51684
Rops Rops [New Type] ## S.No.;A =51685
Front Rear Tire Front Wheel (9.5-22)
Front Rear Tire Rear Wheel (14.9-28)
Labels Label 1 (Front) [Rops Type]
Labels Label 2 (Rear) [Rops Type]
Accessories Accessories And Service Parts
Option Under Muffler Kit [Rops Type] [Option]
Option Working Light Kit (W G No.M9551) [Rops Type] [Option]
Option Trailer Socket Kit [Rops Type] [Option]
Option Front Weight Bumper Kit [Option]
Option Front Bumper Kit [Option]
Option Auxiliary Control Valve Kit (Scd) [Rops Type] [Option]
Option Auxiliary Control Valve Kit (Fd) [Rops Type] [Option]
Option Auxiliary Control Valve [Component Parts] [Rops Type] [Option]
Option Step Support Kit [Option]
Region: Australia
Engine Crankcase
Engine Oil Pan
Engine Gear Case
Engine Flywheel
Engine Governor
Engine Water Pump
