702,650
Kubota Tractor M4700DT Australia Parts Catalog
Model: Kubota M4700DT Tractor
Region: Australia
Number of Pages: 405 Pages
Engine Crankcase
Engine Oil Pan
Engine Piston And Crankshaft ## Note Order By Ref.No.010 And 040 New Part.
Engine Main Bearing Case
Engine Flywheel
Engine Cylinder Head
Engine Valve And Rocker Arm
Engine Nozzle Holder Glow Plug
Engine Nozzle Holder [Component Parts]
Engine Cylinder Head Cover
Engine Inlet Manifold
Engine Air Cleaner (Double)
Engine Air Cleaner (Double) [Component Parts]
Engine Exhaust Manifold
Engine Muffler
Engine Under Muffler Pipe [Option]
Engine Camshaft
Engine Gear Case
Engine Water Pump
Engine Water Flange And Thermostat
Engine Fuel Camshaft
Engine Injection Pump
Engine Engine Stop Lever
Engine Speed Control Plate
Engine Governor
Engine Upper Gasket Kit
Engine Lower Gasket Kit
Engine Hand Accelerator Lever
Engine Engine Stop Wire
Fuel System Fuel Tank
Fuel System Fuel Filter Fuel Pipe
Fuel System Fuel Filter [Component Parts]
Cooling Water System Radiator
Cooling Water System Water Pipe
Cooling Water System Fan
Electrical System Alternator
Electrical System Alternator [Component Parts] [Old Type] ## S.No.; =61110
Electrical System Alternator [Component Parts] [New Type] ## S.No.; =80001
Electrical System Starter
Electrical System Starter [Component Parts]
Electrical System Battery
Electrical System Panel Board [Au]
Electrical System Panel Board [Except[Au]]
Electrical System Panel Board [Component Parts] [Au]
Electrical System Panel Board [Component Parts] [Except[Au]]
Electrical System Switch [Au]
Electrical System Switch [Except[Au]]
Electrical System Light
Electrical System Working Light [Old Type] [Sr] [Except[Sr]Option] ## S.No.; =60886
Electrical System Working Light [New Type] [Sr] [Except[Sr]Option] ## S.No.; =60887
Electrical System Trailer Socket Kit [Option]
Electrical System Electrical Wiring [Old Type] [Au] ## S.No. =80321 S.No.; =80321
Electrical System Electrical Wiring [New Type] [Au] ## S.No.; =80322
Electrical System Electrical Wiring [Except[Au]]
Clutch Clutch
Clutch Clutch Pedal
Clutch Clutch Housing
Transmission Transmission Case
Transmission Bearing Holder
Transmission Input Shaft First Shaft [With Creep] [Au]
Transmission Input Shaft First Shaft [W O Creep] [Except[Au]]
Transmission Second Shaft
Transmission Third Shaft [With Creep] [Au]
Transmission Third Shaft [W O Creep] [Except[Au]]
Transmission Creep [With Creep] [Au]
Transmission Creep Gear Kit [Except[Au]] [Option]
Transmission PTO Propeller Shaft
Transmission PTO Clutch
Transmission PTO Clutch Valve
Transmission PTO Clutch Valve [Component Parts]
Transmission PTO Shaft PTO Shaft Protector
Main Sp-Change Lever Main Gear Shift Lever
Main Sp-Change Lever Range Gear Shift Fork
Main Sp-Change Lever Range Gear Shift Lever
Main Sp-Change Lever PTO Gear Shift Lever
Main Sp-Change Lever PTO Clutch Control Lever [Old Type] ## S.No.; =61110
Main Sp-Change Lever PTO Clutch Control Lever [New Type] ## S.No.; =80001
Main Sp-Change Lever Bevel Gear (Rear)
Main Sp-Change Lever Differential (Rear)
Main Sp-Change Lever Differential Lock Pedal
Rear Axle Rear Wheel Rear Axle Case
Rear Axle Rear Wheel 72inch Tread Kit [Option]
Rear Axle Rear Wheel Rear Wheel (13.6-28) [Au]
Rear Axle Rear Wheel Rear Wheel (14.9-28) [Except[Sr]]
Brake Brake [Au]
Brake Brake [Except[Au]]
Brake Brake Pedal [Au]
Brake Brake Pedal [Except[Au]]
Brake Brake Rod
Brake Parking Brake [Au]
Front Axle Chassis Front Weight [Except[Au]] [[Au]Option]
Front Axle Chassis Front Axle Frame
Front Axle Chassis Front Wheel Drive Shaft
Front Axle Chassis Propeller Shaft [Old Type] ## S.No. =80708 S.No.; =80708
Front Axle Chassis Front Axle Bracket
Front Axle Chassis Differential (Front)
Front Axle Chassis Differential Gear Shaft
Front Axle Chassis Bevel Gear Case [Old Type] ## S.No.; =61110
Front Axle Chassis Bevel Gear Case [New Type] ## S.No.;= 80001
Front Axle Chassis Front Axle [Old Type] ## S.No.; =61110
Front Axle Chassis Front Axle [New Type] ## S.No.;= 80001
Front Axle Chassis Front Wheel Drive Lever
Front Axle Chassis Front Wheel (8.3-24)
Front Axle Chassis Front Wheel (9.5-20) [Au]
Front Axle Chassis Front Wheel (9.5-22) [Au]
Steering Steering Linkage [Old Type] ## S.No.; =61110
Steering Steering Linkage [New Type] ## S.No.;= 80001
Steering Steering Cylinder [Component Parts] [Old Type] ## S.No.; =61110
Steering Steering Cylinder [Component Parts] [New Type] ## S.No.;= 80001
Steering Steering Handle Steering Controller [Old Type][Au] ## S.No.; =61110
Steering Steering Handle Steering Controller [New Type][Au] ## S.No.; =80001
Steering Steering Handle Steering Controller [New Type] ## [Except[Au]]
Steering Steering Controller [Component Parts] [Old Type] ## S.No. =61110 S.No.; =61110
Steering Steering Controller [Component Parts] [New Type] ## S.No.= 80001 S.No.;= 80001
Hydraulic System Hydraulic Oil Line (Steering PTO)
Hydraulic System Hydraulic Pump [Old Type] ## S.No.; =61110
Hydraulic System Hydraulic Pump [New Type] ## S.No.; =80001
Hydraulic System Hydraulic Pump [Component Parts] [Old Type] ## S.No.; =61110
Hydraulic System Hydraulic Pump [Component Parts] [New Type] ## S.No.; =80001
Hydraulic System Hydraulic Oil Line [Old Type] ## S.No.; =61110
Hydraulic System Hydraulic Oil Line [New Type] ## S.No.; =80001
Hydraulic System Hydraulic Cylinder
Hydraulic System Hydraulic Cylinder Cover [Old Type] ## S.No.; =80100
Hydraulic System Hydraulic Cylinder Cover [New Type] ## S.No.; =80101
Hydraulic System Safety Valve Relief Valve [Component Parts] ## S.No. =80100 [Old Type]
Hydraulic System Safety Valve Relief Valve [Component Parts] ## S.No.= 80101 [New Type]
Hydraulic System Hydraulic Lift Lever
Hydraulic System Control Valve
Hydraulic System Feed Back Lever 1
Hydraulic System Feed Back Lever 2
Hydraulic System Feed Back Lever 3
Hydraulic System Draft And Position Control Lever
Hydraulic System Auxiliary Control Valve
Hydraulic System Auxiliary Control Valve (Scd) [Option]
Hydraulic System Auxiliary Control Valve (Flowting) [Option]
Hydraulic System Auxiliary Control Valve [Component Parts]
Hydraulic System Auxiliary Control Valve (Scd) [Component Parts] ## [Old Type] [Option]
Hydraulic System Auxiliary Control Valve (Scd) [Component Parts] ## [New Type] [Option]
Hydraulic System Auxiliary Control Valve(Flowting)[Component Parts] ## [Option]
Hydraulic System Hydraulic Lift Link 1 (Top Link Lower Link) ## [Old Type][Except[Sr]]
Hydraulic System Hydraulic Lift Link 1 (Top Link Lower Link) ## [New Type][Except[Sr]]
Hydraulic System Hydraulic Lift Link 2 (Lift Rod) [Old Type] ## [Except[Sr]]
Hydraulic System Hydraulic Lift Link 2 (Lift Rod) [New Type] ## [Except[Sr]]
Hydraulic System Top Link Bracket [Except[Sr]]
3-Point Linkage Drawbar Hitch Swinging Drawbar [Except[Sr]]
Hood Bonnet Hood(Bonnet)Front
Hood Bonnet Hood(Bonnet)Upper
Hood Bonnet Hood(Bonnet)Side
Hood Bonnet Hood(Bonnet)Side Cover [Old Type] [Au] ## S.No.60527to61110 S.No
Hood Bonnet Hood(Bonnet)Side Cover [New Type] ## S.No.= 80001 S.No.;= 80001
Hood Bonnet Hood(Bonnet)Rear
Hood Bonnet Fender
Hood Bonnet Floor Seat [Au]
Hood Bonnet Floor Seat [Except[Au]]
Hood Bonnet Seat
Hood Bonnet Step
Hood Bonnet Rearview Mirror [Au]
Hood Bonnet Rearview Mirror [Except[Au]]
Hood Bonnet Tool Box [Except[Sr]Old Type] [Sr] ## S.No.; =61110
Hood Bonnet Tool Box [New Type] [Except[Sr]] ## S.No.; =80001
Hood Bonnet Rops [Au] [Old Type] ## S.No. =80714 S.No.; =80714
Hood Bonnet Rops [Au] [New Type] ## S.No. =80715 S.No.; =80715
Hood Bonnet Canopy [Except[Au]] [[Au]Option]
Labels Labels [Au]
Labels Labels [Except[Au]]
Accessories Accessories And Service Parts
Option Step Support Kit [Option]
