Kubota Tractor M4073DTHC DUAL SPEED 36 SPEED Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M4073DTHC DUAL SPEED 36 SPEED Tractor
Number of Pages: 309 Pages
Itens Usados Frequentemente / Frequently U Sed Items
Bloco Motor / Crankcase
Tampao / Oil Filler Pulg
Carter Oleo / Oil Pan
Vareta Nivel E Guia / Dipsti Ck
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhaust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Cobertura Frontal / Front Co Ver
Piston E Cambota / Piston An D Crankshaft
Arvore Cames E Veio / Camsha Ft And Idle Gear Shaft
Compensador / Balancer
Volante Motor / Flywheel
Tubo De Respiração (Motor Vo Lante) / Breather Pipe (Flywheel)
Bomba De Abastecimento / Sup Ply Pump
Injector E Vela Aquecimento / Injector And Glow Plug
Tubo Injector / Injection Pi Pe
Common Rail / Common Rail
Bomba Agua E Termostacto / W Ater Flange And Thermostat
Bomba Agua / Water Pump
Colector Admissao / Inlet Ma Nifold
Flange Filtro Ar E Valvula A Celarador / Air Cleaner Flange And Throttle Valve
Colector Escape / Exhaust Ma Nifold
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Coole R
Turbo Compressor / Turbo Cha Rger
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes ] / Air Cleaner [Component Parts]
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Par Tículas Diesel / Diesel Particulate Filter Muffler
Silenciador Do Filtro De Par Tículas Diesel [Peças Componentes] / Diesel Particu Late Filter Muffler [Component Parts]
Sensor Escape / Muffler Sens Or
Tubo Pressao / Pressure Pipe
Separador De Óleo / Oil Sepa Rator
Separador De Óleo [Peças Com Ponentes] / Oil Separator [Component Parts]
Tubo Do Separador De Óleo / Oil Separator Pipe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Charger)
Radiador Oleo / Oil Cooler
Componentes Electricos Motor (Ecu) / Engine Electrical Parts (Ecu)
Pedal Acelarador / Accelerat Or Pedal
Tirante Do Acelerador / Acce Lerator Rod
Deposi To Combustivel / Fuel Tank
Fornec Imento Combustivel / Fuel Filler
Tubo D O Combustível (Bomba Do Combustível) / Fuel Pipe (F Uel Pump)
Tubo C Ombustivel (Separador) / Fuel Pipe (Separator)
Tubo C Ombustivel (Arrefecedor Gasoleo) / Fuel Pipe (Fuel Cooler)
Separa Dor / Separator
Separa Dor [Peças Componentes] / Separator [Component Part S]
Suporte Ventilador / Fan Bracket
Ventoinha / Fan
Tubo Agua / Water Pipe
Alter Nador / Alternator
Alter Nador [Peças Componentes] / Alternator [Component Parts]
Motor Arranque [Peças Componentes] / Starter [Component Parts]
Inter Ruptor/Sensor (Frente) / Switch/Sensor (Front)
Inter Ruptor/Sensor (Traseira) / Switch/Sensor (Rear)
Inter Ruptor/Sensor (Carter Embraiagem) / Switch/Sensor ( Clutch Housing)
Inter Ruptor (Quadro Do Painel) / Switch (Panel Board)
Inter Ruptor (Cobertura Do Guarda-Lamas/Tejadilho Interio R) / Switch (Fender Cover/Inner Roof)
Inter Ruptor (Guarda Lamas) / Switch (Fender)
Inter Ruptor (Direcção) / Switch (Steering)
Relé / Relay
Unida De Control Electrico (Bloco Motor) / Electronic Con Trol Unit (Engine)
Unida De Control Electrico (Corpo) / Electronic Control U Nit (Body)
Quadr O Do Painel / Panel Board
Luzes Frente / Head Light
Luzes Frente [Peças Componentes] / Head Light [Component Parts]
Luzes Frontais / Front Combination Lamp
Luzes Trabalho / Working Light
Braco Traseiro / Rear Combination Lamp
Luz I Nterior / Room Light
Alta Voz Radio / Radio Speaker
Depós Ito De Lavagem / Washer Tank
Escov A Limpa Vidro Frontal / Front Wiper
Cabla Gem Electrica (Crs) / Electrical Wiring (Crs)
Cabla Gem Electrica (Injector) / Electrical Wiring (Injec Tor)
Cabla Gem Electrica (Motor) / Electrical Wiring (Engine)
Cabla Gem Electrica (Principal/Dianteiro) / Electrical Wi Ring (Main/Front)
Cabla Gem Electrica (Principal/Traseira) / Electrical Wir Ing (Main/Rear)
Cabla Gem Electrica (Corpo) / Electrical Wiring (Body)
Cabla Gem Electrica (Cabine) / Electrical Wiring (Cab)
Valvula Inversor / Shuttle Valve
Carretos Inversor / Shuttle Gear Case
Tampa / Shift Cover
Valva Dupla Velocidades / Dual Speed Valve
Caixa Da Transmissão / Transmission Case
Disco Amortecedor / Damper Disk
Cabo Embraiagem / Clutch Cable
Valvula Alavanca (Embraiagem/Inversor) / Valve Le Ver (Clutch)
Veio Primario / Input Shaft
Kit Embraiagem (Alto-Baixo) / Clutch Pack (Hi-Lo)
Veio Inversor / Shuttle Shaft
Kit Embraiagem (Lançadeira) / Clutch Pack (Shuttl E)
Primeiro Veio / First Shaft
Terceiro Veio / Third Shaft
Veio Creeper / Creep Shaft
Veio De Acionamento / Drive Shaft
Grupo Conico / Bevel Gear
Diferencial Traseiro / Rear Differential
Veio Tdf / Pto Propeller Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf [Peças Componentes] / Pto Clutch [ Component Parts]
Valvula Embraiagem Tdf / Pto Clutch Valve
Valvula Embraiagem Tdf [Peças Componentes] / Pto Clutch Valve [Component Parts]
Veio Tdf / Pto Shaft
Embraiagem Andamento / Front Drive Clutch
Embraiagem Andamento [Peças Componentes] / Front Drive Clutch [Component Parts]
Cobertura Da Embraiagem De Transmissão Frontal / Front Drive Clutch Cover
Forqueta Velocidades / Range Gear Shif T Fork
Bloqueio Diferencial De Forqueta / Dif Ferential Lock Shift Fork
Alavanca Velocidades / Main Gear Shift Lever
Tirante / Main Gear Shift Rod
Gama E Tirante Caixa Creep / Range And Creep Gear Shift Lever
Alavanca De Mudança De Velocidades De Tomada De Força Tdf / Pto Gear Shift Rod
Eix O Traseiro / Rear Axle
Tra Vao Drt / Brake Rh
Tra Vao Esq / Brake Lh
Vei O Bloqueio / Parking Brake Camshaft
Ala Vanca Travao Mao / Parking Brake Lever
Tra Vao Parque / Secondary Brake
Ped Al Travao / Brake Pedal
Cil Indro Travao Principal / Brake Master Cylinder
Cil Indro Travao Principal [Peças Componentes] / Brake Master Cylinder [Component Parts]
Tub O Travao / Brake Pipe
Suporte Eixo Frente / Front Axle Bracket
Caixa Diferencial Frente / Front Differential Case
Grupo Conico (Frente) / Bevel Gear (Front)
Diferencial Frente / Differential Front
Caixas Engrenagens Conica Drt / Bevel Gear Case Rh
Caixas Engrenagens Conica Esq / Bevel Gear Case Lh
Carter Eixo Frente Drt / Front Axle Case Rh
Carter Eixo Frente Esq / Front Axle Case Lh
Carreto Diferencial Drt / Differential Gear Shaft R H
Carreto Diferencial Esq / Differential Gear Shaft L H
Eixo Frente Esq / Front Axle Lh
Punho Volante / Steerin G Wheel
Tampa Coluna Direccao / Steering Post Cover
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção / Steering Controller
Distribuidor Direcção [ Peças Componentes] / Steering Controller [Component Parts]
Rotula/Cilindro Direcçã O / Tie Rod/Steering Cylinder
Cilindro Direcção [Peça S Componentes] / Steering Cylinder [Component Parts ]
Bomba Hidraulico [Peças Componentes] / Hydraulic Pump [C Omponent Parts]
Tubo Oleo (Entrega) / Hydraulic Pipe (Delivery)
Tubo Hidraulico (Travao Reboque) / Hydraulic Pipe (Trail Er Brake)
Tubo Oleo (Acoplamento) / Hydraulic Oil Line (Coupler)
Circu Ito Oleo Radiador (Radiador Oleo) / Hydraulic Oil L Ine (Oil Cooler)
Tubo Oleo (Valva Dupla Velocidades) / Hydraulic Oil Line (Dual Speed Valve)
Circu Ito Oleo Direcção (Direcção/Tdf) / Hydraulic Oil Li Ne (Steering/Pto)
Tubo Oleo (Inversor/Tdf) / Hydraulic Oil Line (Shuttle/P To)
Tubo Direccao (Fornecimento) / Steering Hose (Delivery)
Caixa Cilindro Hidraulico / Hydraulic Cylinder Case
Mangu Eira De Respiro (Caixa Cilindro Hidraulico) / Breat Her Hose (Hydraulic Cylinder Case)
Braco Hidraulico / Lift Arm
Valvu La Segurança/Descarga Valvula / Safety Valve/Relief Valve
Trinc O / Lowering Lock Lever
Valvu La Control / Control Valve
Supor Te De Controlo De Posição / Position Control Bracke T
Puxar E Posicionar Alavanca De Controlo / Draft And Posi Tion Control Lever
Veio Posicao Esforço / Position And Draft Shaft
Alava Nca / Feed Back Lever
Válvu La De Controlo Auxiliar / Auxiliary Control Valve
Valvu La Auxiliar (Scd) [Peças Componentes] / Auxiliary C Ontrol Valve (Scd) [Component Parts]
Valvu La Auxiliar (Fd) [Peças Componentes] / Auxiliary Co Ntrol Valve (Fd) [Component Parts]
Alava Nca De Válvula De Controlo Auxiliar (1º) / Auxiliar Y Control Valve Lever (1st)
Alava Nca De Válvula De Controlo Auxiliar (2º) / Auxiliar Y Control Valve Lever (2nd)
Cilin Dro Auxiliar De Elevacao Esq / 3p-Lift Assist Cylin Der Lh
Cilin Dro Auxiliar De Elevacao Drt / 3p-Lift Assist Cylin Der Rh
Parte Superior / Top Link Bracket
Ligacao Superior / Top Link
Estabilizador / Stabilizer
Estabilizador Drt / Lift Rod Rh
Estabilizador Esq / Lift Rod Lh
Puxo Barra / Drawbar Bracket
Proteccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot Superior / Hood ( Bonnet) Upper
Capot Superior (Som Abs Orvedor/Isolador) / Hood (Bonnet) (Sound Absorber/I Nsulator)
Amortecedor Capot / Hoo D (Bonnet) Damper
Trico Capot / Hood (Bon Net) Lock
Capot Lateral / Hood (B Onnet) Side Cover
Suporte Capot / Hood (B Onnet) Support
Estrutura Cabine / Cab Frame
Degrau / Step
Capot Traseira (Cabine) / Hood (Bonnet) Rear (Cab)
Vidro Frente / Front Glass
Porta Drt / Door Rh
Porta Esq / Door Lh
Trinco Porta Drt / Door Lock R H
Trinco Porta Esq / Door Lock L H
Lado Vidro / Side Window
Tecto Interior / Inner Roof
Cobertura Exterior Do Tejadilh O / Outer Roof
Składowanie Materiałów/Piso / Damp Material/Floor Mat
Chapa Inspecção / Inspection P Late
Cobertura Guarda Lamas Drt / F Ender Cover Rh
Cobertura Gurada Lamas Esq / F Ender Cover Lh
Guarda Lamas / Fender
Suporte Cabine Frente / Cab Br Acket Front
Suporte Cabine Traseira / Cab Bracket Rear
Caixa Ferramenta / Tool Box
Ar Condic Ionado / Air Conditioner
Conduta D O Ar Condicionado / Air Conditioner Duct
Modo Caix A / Mode Case
Entradas Ar Painel Instrumentos / Dashboard Air Outlets
Tubo Aque Cimento / Heater Hose
Condesado R / Condenser
Tubo Ar C Ondicionado/Tubo Condensador / Air Conditioner Hose /Condenser Hose
Compresso R (Ar Condicionado) / Compressor (Air Conditioner)
Etiqueta (Frente) / Labe L (Front)
Decalcomania (Cabine Int Erior) / Label (Cab Interior)
Decalcomania (Cabine Ext Erior) / Label (Cab Exterior)
Peça De Acessorio E Serviço Peças / Accessories And Service Parts
Panela Escape [Opçao] / Uppe R Muffler Kit [Option]
Kit Farios Trabalho (Led) [O Pção] / Working Light Kit (Led) [Option]
Desempanador (Vidro) [Opção] / Rear Defogger Kit (Glass) [Option]
Kit Conversao Tdf (540/1000) (Engrenagem) / Pto (540/1000) Conversion Kit [Opti On]
Kit Apoio Peso Frente [Opção ] / Front Bumper Kit [Option]
Válvula De Controle Alavanca Kit (Scd) [Opção] / Auxiliary Control Valve Kit (S Cd) [Option]
Válvula De Controle Alavanca Kit (Fd) [Opção] / Auxiliary Control Valve Kit (Fd ) [Option]
Válvula De Controle Alavanca Kit (Scd/Fc) [Opção] / Auxiliary Control Valve Kit (Scd/Fc) [Option]
Válvula De Controle Alavanca Kit (Fc) [Opção] / Auxiliary Control Valve Kit (Fc ) [Option]
Válvula De Controle Alavanca Kit (Scd) [Peças Componentes] [Opção] / Auxiliary Control Valve (Scd) [Component Parts] [Option]
Auxiliar Do Válvula De Contr Olo (Fd) [Peças Componentes] [Opção] / Auxiliary Co Ntrol Valve (Fd) [Component Parts] [Option]
Auxiliar Do Alavanca De Válv Ula De Controlo Kit (3ª) [Opção] / Auxiliary Contro L Valve Lever Kit (3rd) [Option]
Montagem Da Válvula Do Freio Do Reboque (Tubo) [Opção] / Trailer Brake Valve Mo Unting Kit (Pipe) [Option]
Montagem Da Válvula Do Freio Do Reboque (Valvula) [Opção] / Trailer Brake Valve Mounting Kit (Valve) [Option]
Montagem Da Válvula Do Freio Do Reboque (Junta) [Opção] / Trailer Brake Valve M Ounting Kit (Gasket) [Option]
Montagem Da Válvula Do Freio Do Reboque (Cablagem Electrica) [Opção] / Trailer Brake Valve Mounting Kit (Electrical Wiring) [Optio N]
Banco Passageiro (Banco) [Op Ção] / Instructional Seat Kit (Seat) [Option]
Banco Passageiro (Suporte) [ Opção] / Instructional Seat Kit (Bracket) [Option]
Kit De Espelho De Sala [Opçã O] / Room Mirror Kit [Option]
