Kubota Tractor M4073DTH 18 SPEED Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M4073DTH 18 SPEED Tractor
Number of Pages: 286 Pages
Ite Ns Usados Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Vareta Nivel E Guia / Dipstick
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhaust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Compensador / Balancer
Volante Motor / Flywheel
Tubo De Respiração (Motor Volante) / Bre Ather Pipe (Flywheel)
Bomba De Abastecimento / Supply Pump
Filtro Gasoleo / Fuel Filter
Injector E Vela Aquecimento / Injector A Nd Glow Plug
Common Rail / Common Rail
Bomba Agua / Water Pump
Flange Filtro Ar E Valvula Acelarador / Air Cleaner Flange And Throttle Valve
Refrigerador Egr / Egr Cooler
Tubo Agua Valvula Egr / Egr Water Piping
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Clea Ner [Component Parts]
Tubo Aspiracao / Inlet Pipe
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Partículas Dies El / Diesel Particulate Filter Muffler
Silenciador Do Filtro De Partículas Dies El [Peças Componentes] / Diesel Particulate Filter Muffler [Component Parts]
Sensor Escape / Muffler Sensor
Tubo Pressao / Pressure Pipe
Separador De Óleo [Peças Componentes] / Oil Separator [Component Parts]
Tubo Do Separador De Óleo / Oil Separato R Pipe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Charger)
Radiador Oleo / Oil Cooler
Componentes Electricos Motor (Sensor) / Engine Electrical Parts (Sensor)
Componentes Electricos Motor (Ecu) / Eng Ine Electrical Parts (Ecu)
Deposito Combustiv El / Fuel Tank
Fornecimento Combu Stivel / Fuel Supply
Tubo Do Combustíve L (Bomba Do Combustível) / Fuel Pipe (Fuel Pump)
Tubo Combustivel ( Separador) / Fuel Pipe (Separator)
Tubo Combustivel ( Arrefecedor Gasoleo) / Fuel Pipe (Fuel Cooler)
Separador / Separa Tor
Separador [Peças C Omponentes] / Separator [Component Parts]
Suporte Ventilador / Fan Bracket
Ventoinha / Fan
Tubo Agua / Water Pipe
Alternador / Alte Rnator
Alternador [Peças Componentes] / Alternator [Component Parts]
Motor Arranque / Starter
Interruptor/Senso R (Frente) / Switch/Sensor (Front)
Interruptor/Senso R (Traseira) / Switch/Sensor (Rear)
Interruptor/Senso R (Carter Embraiagem) / Switch/Sensor (Clutch Housi Ng)
Interruptor (Quad Ro Do Painel) / Switch (Panel Board)
Interruptor (Dire Cção) / Switch (Steering)
Interruptor (Tamp A/Guarda Lamas) / Switch (Shift Cover/Fender)
Relé / Relay
Unidade Control E Lectrico (Bloco Motor) / Electronic Control Unit (E Ngine)
Unidade Control E Lectrico (Corpo) / Electronic Control Unit (Body)
Quadro Do Painel / Panel Board
Luzes Frente / He Ad Light
Luzes Frente [Peç As Componentes] / Head Light [Component Parts]
Luzes Frontais / Front Combination Lamp
Braco Traseiro / Rear Combination Lamp
Ficha Reboque / T Railer Socket
Cablagem Electric A (Crs) / Electrical Wiring (Crs)
Cablagem Electric A (Injector) / Electrical Wiring (Injector)
Cablagem Electric A (Traseiros) / Electrical Wiring (Rear)
Carter Emb Raiagem / Clutch Housing
Valvula In Versor / Shuttle Valve
Carretos I Nversor / Shuttle Gear Case
Tampa / Sh Ift Cover
Caixa Da T Ransmissão / Transmission Case
Carter Tra Nsmissao / Transmission Case Rear Cover
Carter Eix O Traseiro Drt / Rear Axle Case Rh
Carter Eix O Traseiro Esq / Rear Axle Case Lh
Disco Amor Tecedor / Damper Disk
Pedal Embr Aiagem / Clutch Pedal
Valvula Al Avanca (Embraiagem) / Valve Lever (Clutch)
Veio Prima Rio / Input Shaft
Kit Embrai Agem (Alto-Baixo) / Clutch Pack (Hi-Lo)
Veio Inver Sor / Shuttle Shaft
Primeiro V Eio / First Shaft
Terceiro V Eio / Third Shaft
Veio Creep Er / Creep Shaft
Veio De Ac Ionamento / Drive Shaft
Grupo Coni Co / Bevel Gear
Diferencia L Traseiro / Rear Differential
Veio Tdf / Pto Propeller Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf [Peças Componentes] / Pto Clutch [Component Pa Rts]
Valvula Em Braiagem Tdf / Pto Clutch Valve
Valvula Em Braiagem Tdf [Peças Componentes] / Pto Clutch Valve [Component Parts]
Veio Tdf / Pto Shaft
Embraiagem Andamento / Front Drive Clutch
Embraiagem Andamento [Peças Componentes] / Front Drive Clutch [Component Parts]
Cobertura Da Embraiagem De Transmissão Frontal / Front Drive Clutch Cover
Forqueta Velocidades / Range Gear Shift Fork
Bloqueio Diferencial De Forqueta / Differential Lo Ck Shift Fork
Alavanca Velocidades / Main Gear Shift Lever
Tirante / Main Gear Shift Rod
Gama E Tirante Caixa Creep / Range And Creep Gear Shift Lever
Eixo Traseiro / Rear Axle
Travao Drt / Br Ake Rh
Travao Esq / Br Ake Lh
Veio Bloqueio / Parking Brake Camshaft
Pedal Travao / Brake Pedal
Cilindro Travao Principal / Brake Master Cylinder
Cilindro Travao Principal [Peças Componentes] / Brake Master Cylin Der [Component Parts]
Suporte Eixo Frente / Front Axle Bracket
Veio Primari O / Propeller Shaft
Caixa Difere Ncial Frente / Front Differential Case
Grupo Conico (Frente) / Bevel Gear (Front)
Diferencial Frente / Differential Front
Caixas Engre Nagens Conica Drt / Bevel Gear Case Rh
Caixas Engre Nagens Conica Esq / Bevel Gear Case Lh
Carter Eixo Frente Drt / Front Axle Case Rh
Carter Eixo Frente Esq / Front Axle Case Lh
Eixo Frente Esq / Front Axle Lh
Tampa Coluna Direccao / Steering Po St Cover
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção / Steering Co Ntroller
Distribuidor Direcção [Peças Compon Entes] / Steering Controller [Component Parts]
Rotula/Cilindro Direcção / Tie Rod/ Steering Cylinder
Cilindro Direcção [Peças Componente S] / Steering Cylinder [Component Parts]
Bomba Hidraulico [Peças Componentes] / Hydraulic Pump [Component Par Ts]
Tubo Oleo (Entreg A) / Hydraulic Pipe (Delivery)
Tubo Hidraulico ( Travao Reboque) / Hydraulic Pipe (Trailer Brake)
Valvula Travao Re Boque / Trailer Brake Valve
Circuito Oleo Rad Iador (Radiador Oleo) / Hydraulic Oil Line (Oil Coo Ler)
Circuito Oleo Dir Ecção (Direcção/Tdf) / Hydraulic Oil Line (Steering /Pto)
Tubo Oleo (Invers Or/Tdf) / Hydraulic Oil Line (Shuttle/Pto)
Hidráulico Tomada Tubo / Hydraulic Outlet Pipe
Caixa Cilindro Hi Draulico / Hydraulic Cylinder Case
Mangueira De Resp Iro (Caixa Cilindro Hidraulico) / Breather Hose (Hy Draulic Cylinder Case)
Braco Hidraulico / Lift Arm
Valvula Segurança /Descarga Valvula / Safety Valve/Relief Valve
Trinco / Lowering Lock Lever
Suporte De Contro Lo De Posição / Position Control Bracket
Puxar E Posiciona R Alavanca De Controlo / Draft And Position Control Lever
Veio Posicao Esfo Rço / Position And Draft Shaft
Alavanca / Feed B Ack Lever
Válvula De Contro Lo Auxiliar / Auxiliary Control Valve
Valvula Auxiliar (Scd) [Peças Componentes] / Auxiliary Control Valve (Scd) [Component Parts]
Alavanca De Válvu La De Controlo Auxiliar (1º) / Auxiliary Control Va Lve Lever (1st)
Alavanca De Válvu La De Controlo Auxiliar (2º) / Auxiliary Control Va Lve Lever (2nd)
Cilindro Auxiliar De Elevacao Esq / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De Elevacao Drt / 3p-Lift Assist Cylinder Rh
Cilindro Auxiliar De Elevacao [Peças Componentes] / 3p-Lift Assist C Ylinder [Component Parts]
Parte Superior / Top Link Bracket
Ligacao Superior / Top Link
Estabilizador / Stabilizer
Estabilizador Drt / Lift Rod Rh
Estabilizador Esq / Lift Rod Lh
Puxo Barra / Drawbar Bracket
Proteccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot Superior / Hood (Bonnet) Uppe R
Capot Superior (Som Absorvedor/Isol Ador) / Hood (Bonnet) (Sound Absorber/Insulator)
Amortecedor Capot / Hood (Bonnet) D Amper
Suporte Capot / Hood (Bonnet) Suppo Rt
Capot Traseiro / Hood (Bonnet) Rear (Sound Absorber)
Guarda Lamas / Fender
Tampa / Shift Cover
Piso / Floor Sheet
Piso(Isolante) / Floor Sheet (Sound Absorber)
Degrau / Step
Degrau Auxiliar / Auxiliary Step
Banco / Seat
Caixa Ferramenta / Tool Box
Caobertura / Guard
Arco / Rops
Etiqueta (Capot) / Label (Hood (Bonn Et))
Peça De Acessorio E Serviço Peças / Acce Ssories And Service Parts
Kit Farios Trabalho [Opção] / Working Li Ght Kit [Option]
Kit Conversao Tdf (540/1000) [Opção] / P To (540/1000) Conversion Kit [Option]
Kit Apoio Peso Frente [Opção] / Front Bu Mper Kit [Option]
Válvula De Controle Alavanca Kit (Scd) [ Opção] / Auxiliary Control Valve Kit (Scd) [Option]
Válvula De Controle Alavanca Kit (Fd) [O Pção] / Auxiliary Control Valve Kit (Fd) [Option]
Válvula De Controle Alavanca Kit (Scd/Fc ) [Opção] / Auxiliary Control Valve Kit (Scd/Fc) [O Ption]
Válvula De Controle Alavanca Kit (Fc) [O Pção] / Auxiliary Control Valve Kit (Fc) [Option]
Válvula De Controle Alavanca Kit (Scd) [ Peças Componentes] [Opção] / Auxiliary Control Valv E (Scd) [Component Parts] [Option]
Auxiliar Do Válvula De Controlo (Fd) [Pe Ças Componentes] [Opção] / Auxiliary Control Valve (Fd) [Component Parts] [Option]
Válvula De Controle Alavanca Kit (Scd/Fc ) [Peças Componentes] [Opção] / Auxiliary Control V Alve (Scd/Fc) [Component Parts] [Option]
Válvula De Controle Alavanca Kit (Fc) [P Eças Componentes] [Opção] / Auxiliary Control Valve (Fc) [Component Parts] [Option]
Auxiliar Do Alavanca De Válvula De Contr Olo Kit (3ª) [Opção] / Auxiliary Control Valve Leve R Kit (3rd) [Option]
Montagem Da Válvula Do Freio Do Reboque (Tubo) [Opção] / Trailer Brake Valve Mounting Kit ( Pipe) [Option]
Montagem Da Válvula Do Freio Do Reboque (Valvula) [Opção] / Trailer Brake Valve Mounting Ki T (Valve) [Option]
Montagem Da Válvula Do Freio Do Reboque (Junta) [Opção] / Trailer Brake Valve Mounting Kit (Gasket) [Option]
Montagem Da Válvula Do Freio Do Reboque (Cablagem Electrica) [Opção] / Trailer Brake Valve Mounting Kit (Electrical Wiring) [Option]
Ventoinha / Fan
Relé / Relay
Tampa / Shift Cover
Piso / Floor Sheet
Degrau / Step
Banco / Seat
Caobertura / Guard
Arco / Rops
