Kubota Tractor M4072DTHC DUAL SPEED 36 SPEED Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M4072DTHC DUAL SPEED 36 SPEED Tractor
Number of Pages: 352 Pages
Itens Usados Frequentemente / Frequently U Sed Items
Bloco Motor / Crankcase
Tampao [Ec] [Spa] / Oil Fill Er Pulg [Ec] [Spa]
Carter Oleo [Ec] / Oil Pan [ Ec]
Vareta Nivel E Guia / Dipsti Ck
Cabeça Motor [Velho] / Cylin Der Head [Old]
Cabeça Motor [Novo] / Cylind Er Head [New]
Valvula Admissao E Escape / Inlet Valve And Exhaust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Cobertura Frontal / Front Co Ver
Piston E Cambota / Piston An D Crankshaft
Arvore Cames E Veio / Camsha Ft And Idle Gear Shaft
Compensador / Balancer
Volante Motor / Flywheel
Bomba Alimentacao / Supply P Ump
Filtro Gasoleo [Ec] / Fuel F Ilter [Ec]
Injector E Vela Aquecimento / Injector And Glow Plug
Tubo Injector / Injection Pi Pe
Trilho Comum / Common Rail
Bomba Agua E Termostacto / W Ater Flange And Thermostat
Bomba Agua / Water Pump
Flange Filtro Ar / Air Clean Er Flange And Throttle Valve
Colector Escape / Exhaust Ma Nifold
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Coole R
Tubo Agua Valvula Egr / Egr Water Piping
Turbo Compressor / Turbo Cha Rger
Filtro Ar / Air Cleaner
Tubo Aspiracao / Inlet Pipe
Panela Escape [Ec] / Muffler Pipe [Ec]
Silenciador Do Filtro De Par Tículas Diesel / Diesel Particulate Filter Muffler
Silenciador Do Filtro De Par Tículas Diesel [Peças Componentes] / Diesel Particu Late Filter Muffler [Component Parts]
Sensor Escape / Muffler Sens Or
Tubo Pressao / Pressure Pipe
Separador De Óleo / Oil Sepa Rator
Separador De Óleo [Peças Com Ponentes] / Oil Separator [Component Parts]
Tubo Do Separador De Óleo / Oil Separator Pipe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Charger)
Radiador Oleo / Oil Cooler
Componentes Electricos Motor (Sensor) / Engine Electrical Parts (Sensor)
Componentes Electricos Motor (Ecu) / Engine Electrical Parts (Ecu)
Pedal Acelarador / Accelerat Or Pedal
Tirante Do Acelerador / Acce Lerator Rod
Deposi To Combustivel / Fuel Tank
Tubo C Ombustivel (Bomba Do Combustível) [Velho] / Fuel P Ipe (Fuel Pump) [Old]
Tubo C Ombustivel (Bomba Do Combustível) [Novo] / Fuel Pi Pe (Fuel Pump) [New]
Tubo C Ombustivel (Separador) / Fuel Pipe (Separator)
Tubo C Ombustivel (Arrefecedor Gasoleo) / Fuel Pipe (Fuel Cooler)
Separa Dor / Separator
Separa Dor [Peças Componentes] / Separator [Component Part S]
Suporte Ventilador / Fan Bracket
Ventoinha / Fan
Tubo Agua / Water Pipe
Alter Nador / Alternator
Alter Nador [Peças Componentes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Componentes] / Starter [Component Parts]
Bater Ia / Battery
Inter Ruptor/Sensor / Switch/Sensor
Inter Ruptor/Sensor (Traseira) [Com Travao Reboque] / Swi Tch/Sensor (Rear) [With Trailer Brake]
Inter Ruptor/Sensor (Carter Embraiagem) [Ec] / Switch/Sen Sor (Clutch Housing) [Ec]
Inter Ruptor (Quadro Do Painel) / Switch (Panel Board)
Inter Ruptor (Cobertura Do Guarda-Lamas/Tejadilho Interio R) / Switch (Fender Cover/Inner Roof)
Inter Ruptor (Guarda Lamas) / Switch (Fender)
Inter Ruptor (Direcção) [Ec] / Switch (Steering) [Ec]
Inter Ruptor / Rele / Relay
Unida De Control Electrico (Bloco Motor) / Electronic Con Trol Unit (Engine)
Unida De Control Electrico (Corpo) / Electrical Control U Nit (Body)
Quadr O Do Painel / Panel Board
Luzes Frente / Head Light
Luzes Frente [Peças Componentes] / Head Light [Component Parts]
Luzes Frontais / Front Combination Lamp
Luzes Trabalho / Working Light
Braco Traseiro / Rear Combination Lamp
Farol Matricula/Lâmpada Farol / License Lamp/Beacon Lamp
Luz I Nterior / Room Light
Alta Voz Radio / Radio Speaker
Depós Ito De Lavagem / Washer Tank
Escov A Limpa Vidro Frontal / Front Wiper
Cabla Gem Electrica (Crs) [Ec] / Electrical Wiring (Crs) [Ec]
Cabla Gem Electrica (Injector) / Electrical Wiring (Injec Tor)
Cabla Gem Electrica (Motor) / Electrical Wiring (Engine)
Cabla Gem Electrica (Principal/Dianteiro) [Ec] [Velho] / Electrical Wiring (Main/Front) [Ec] [Old]
Cabla Gem Electrica (Principal/Dianteiro) [Ec] [Novo] / E Lectrical Wiring (Main/Front) [Ec] [New]
Cabla Gem Electrica (Principal/Traseira) [Ec] [Velho] / E Lectrical Wiring (Main/Rear) [Ec] [Old]
Cabla Gem Electrica (Principal/Traseira) [Ec] [Novo] / El Ectrical Wiring (Main/Rear) [Ec] [New]
Cabla Gem Electrica (Corpo) [Com Travao Reboque] / Electr Ical Wiring (Body) [With Trailer Brake]
Cabal Agem Eletrica (Cabine) / Electrical Wiring (Cab)
Valvula Inversor / Shuttle Valve
Carretos Inversor / Shuttle Gear Case
Tampa / Shift Cover
Valva Dupla Velocidades / Dual Speed Valve
Caixa Da Transmissão [Com Travao Reboque] / Trans Mission Case [With Trailer Brake]
Carter Transmissao / Transmission Case Rear Cover
Carter Eixo Traseiro Certo [Com Travao Reboque] / Rear Axle Case Rh [With Trailer Brake]
Disco Amortecedor / Damper Disk
Cabo Embraiagem / Clutch Cable
Valvula Alavanca (Embraiagem) / Valve Lever (Clut Ch)
Veio Primario / Input Shaft
Kit Embraiagem (Alto-Baixo) [Peças Componentes] / Clutch Pack (Hi-Lo) [Component Parts]
Veio Inversor / Shuttle Shaft
Kit Embraiagem (Lançadeira) / Clutch Pack (Shuttl E)
Primeiro Veio / First Shaft
Terceiro Veio / Third Shaft
Veio Creeper / Creep Shaft
Veio De Acionamento / Drive Shaft
Grupo Conico [Ec] / Bevel Gear [Ec]
Diferencial Traseiro / Rear Differential
Veio Tdf / Pto Propeller Shaft
Embraiagem Tdf [Ec] / Pto Clutch [Ec]
Embraiagem Tdf [Peças Componentes] / Pto Clutch [ Component Parts]
Valvula Embraiagem Tdf / Pto Clutch Valve
Valvula Embraiagem Tdf [Peças Componentes] / Pto Clutch Valve [Component Parts]
Veio Tdf / Pto Shaft
Embraiagem Andamento [Ec] / Front Drive Clutch [E C]
Embraiagem Andamento [Peças Componentes] [Ec] / F Ront Drive Clutch [Component Parts] [Ec]
Cobertura Da Embraiagem De Transmissão Frontal / Front Drive Clutch Cover
Forqueta Velocidades / Range Gear Shif T Fork
Bloqueio Diferencial De Forqueta / Dif Ferential Lock Shift Fork
Alavanca Velocidades / Main Gear Shift Lever
Tirante / Main Gear Shift Rod
Alvanca Inversor [Ec] / Shuttle Shift Lever [Ec]
Gama E Tirante Caixa Creep / Range And Creep Gear Shift Lever
Alavanca De Mudança De Velocidades De Tomada De Força Tdf / Pto Gear Shift Rod
Eix O Traseiro / Rear Axle
Tra Vao Drt [Com Travao Reboque] / Brake Rh [With Trail Er Brake]
Tra Vao Esq [Com Travao Reboque] / Brake Lh [With Trail Er Brake]
Vei O Bloqueio / Parking Brake Camshaft
Tra Vao Parque / Secondary Brake
Ped Al Travao / Brake Pedal
Cil Indro Travao Principal / Brake Master Cylinder
Tub O Travao / Brake Pipe
Suporte Eixo Frente / Front Axle Bracket
Caixa Diferencial Frente / Front Differential Case
Grupo Conico (Frente) / Bevel Gear (Front)
Diferencial Frente / Differential Front
Caixas Engrenagens Conica Drt / Bevel Gear Case Rh
Caixas Engrenagens Conica Esq / Bevel Gear Case Lh
Carter Eixo Frente Drt / Front Axle Case Rh
Carter Eixo Frente Esq / Front Axle Case Lh
Carreto Diferencial Drt / Differential Gear Shaft R H
Carreto Diferencial Esq / Differential Gear Shaft L H
Eixo Frente Esq / Front Axle Lh
Punho Volante / Steerin G Wheel
Tampa Coluna Direccao / Steering Post Cover
Pedal Inclinacao / Tilt Pedal
Junta Direcção / Steeri Ng Joint
Distribuidor Direcção / Steering Controller
Rotula/Cilindro Direcçã O / Tie Rod/Steering Cylinder
Bomba Hidraulico [Peças Componentes] / Hydraulic Pump [C Omponent Parts]
Tubo Oleo (Entrega) [Com Travao Reboque] / Hydraulic Pip E (Delivery) [With Trailer Brake]
Tubo Hidraulico (Travao Reboque) [Com Travao Reboque] / Hydraulic Pipe (Trailer Brake) [With Trailer Brake]
Tubo Oleo (Acoplamento) [Com Travao Reboque] / Hydraulic Oil Line (Coupler) [With Trailer Brake]
Valvu La Travao Reboque [Com Travao Reboque] / Trailer Br Ake Valve [With Trailer Brake]
Circu Ito Oleo Radiador (Radiador Oleo) / Hydraulic Oil L Ine (Oil Cooler)
Tubo Oleo (Valva Dupla Velocidades) [Com Travao Reboque] / Hydraulic Oil Line (Dual Speed Valve) [With Trai Ler Brake]
Circu Ito Oleo Direcção (Direcção/Tdf) / Hydraulic Oil Li Ne (Steering/Pto)
Circu Ito Oleo Direcção (Inversor/Tdf) [Ec] / Hydraulic O Il Line (Shuttle/Pto) [Ec]
Tubo Direccao (Entrega) / Steering Hose (Delivery)
Caixa Cilindro Hidraulico [Com Travao Reboque] / Hydraul Ic Cylinder Case [With Trailer Brake]
Mangu Eira De Respiro (Caixa Cilindro Hidraulico) / Breat Her Hose (Hydraulic Cylinder Case)
Braco Hidraulico / Lift Arm
Valvu La Segurança/Descarga Valvula / Safety Valve/Relief Valve
Trinc O Alavanca / Lowering Lock Lever
Valvu La Control / Control Valve
Supor Te De Controlo De Posição / Position Control Bracke T
Puxar E Posicionar Alavanca De Controlo / Draft And Posi Tion Control Lever
Veio Posicao Esforço / Position And Draft Shaft
Válvu La De Controlo Auxiliar / Auxiliary Control Valve
Valvu La Auxiliar (Scd) [Peças Componentes] / Auxiliary C Ontrol Valve (Scd) [Component Parts]
Valvu La Auxiliar (Fd) [Peças Componentes] / Auxiliary Co Ntrol Valve (Fd) [Component Parts]
Alava Nca De Válvula De Controlo Auxiliar (1º) / Auxiliar Y Control Valve Lever (1st)
Alava Nca De Válvula De Controlo Auxiliar (2º) / Auxiliar Y Control Valve Lever (2nd)
Cilin Dro Auxiliar De Elevacao Esq / 3p-Lift Assist Cylin Der Lh
Cilin Dro Auxiliar De Elevacao Drt / 3p-Lift Assist Cylin Der Rh
Cilin Dro Auxiliar De Elevacao [Peças Componentes] / 3p-L Ift Assist Cylinder [Component Parts]
Parte Superior / Top Link Bracket
Estabilizador / Stabilizer
Estabilizador Esq / Lift Rod Lh
Proteccao Tdf / Pto Shaft Protector
Grelha Frontal [Ec] / F Ront Grille [Ec]
Capot Superior / Hood ( Bonnet) Upper
Capot Superior (Som Abs Orvedor/Isolador) / Hood (Bonnet) (Sound Absorber/I Nsulator)
Amortecedor Capot / Hoo D (Bonnet) Damper
Trico Capot / Hood (Bon Net) Lock
Capot Lateral / Hood (B Onnet) Side Cover
Suporte Capot / Hood (B Onnet) Support
Estrutura Cabine [Ec] / Cab Fr Ame [Ec]
Degrau / Step
Vidro Frente / Front Glass
Porta Drt / Door Rh
Porta Esq / Door Lh
Trinco Porta Drt / Door Lock R H
Lado Vidro / Side Window
Vidro Traseiro Da Escotilha / Hatch Back Glass
Tecto Interior / Inner Roof
Tecto Abrir / Outer Roof
Składowanie Materiałów/Piso [E C] / Damp Material/Floor Mat [Ec]
Chapa Inspecção [Ec] / Inspect Ion Plate [Ec]
Cobertura Guarda Lamas Drt / F Ender Cover Rh
Cobertura Gurada Lamas Esq / F Ender Cover Lh
Guarda Lamas / Fender
Suporte Cabine Frente [Ec] / C Ab Bracket Front [Ec]
Suporte Cabine Traseira / Cab Bracket Rear
Caixa Ferramenta / Tool Box
Ar Condic Ionado / Air Conditioner
Tubo Ar C Ondicionado / Air Conditioner Duct
Modo Caix A / Mode Case
Entradas Ar Painel Instrumentos / Dashboard Air Outlets
Circulaça O Ar Interior / Inner Air Recirculation
Tubo Aque Cimento / Heater Hose
Condesado R / Condenser
Tubo Ar C Ondicionado/Tubo Condensador / Air Conditioner Hose /Condenser Hose
Compresso R (Ar Condicionado) / Compressor (Air Conditioner)
Etiqueta (Frente) / Labe L (Front)
Etiqueta (Cabine Interio R) [Ec] / Label (Cab Interior) [Ec]
Etiqueta (Cabine Exterio R) / Label (Cab Exterior)
Acessorios E Peças Serviço [Velho] / Accessories And Service Parts [Old]
Acessorios E Peças Serviço [Novo] / Accessories And Service Parts [New]
Panela Escape [Opçao] [Ec] / Upper Muffler Kit [Option] [Ec]
Kit Farios Trabalho [Opção] / Working Light Kit [Option]
Desempanador (Vidro) [Opção] / Rear Defogger Kit (Glass) [Option]
Kit Limpa Vidro Traseiros [O Pção] / Rear Wiper Kit [Option]
Kit Conversao Tdf 540/1000 [ Opção] / Pto (540/1000) Conversion Kit [Option]
Kit Apoio Peso Frente [Opção ] / Front Bumper Kit [Option]
Válvula De Controle Alavanca Kit (Scd) [Opção] / Auxiliary Control Valve Kit (S Cd) [Option]
Válvula De Controle Alavanca Kit (Fd) [Opção] / Auxiliary Control Valve Kit (Fd ) [Option]
Válvula De Controle Alavanca Kit (Scd/Fc) [Opção] / Auxiliary Control Valve Kit (Scd/Fc) [Option]
Válvula De Controle Alavanca Kit (Fc) [Opção] / Auxiliary Control Valve Kit (Fc ) [Option]
Válvula De Controle Alavanca Kit (Scd) [Peças Componentes] [Opção] / Auxiliary Control Valve (Scd) [Component Parts] [Option]
Válvula De Controle Alavanca Kit (Fc) [Peças Componentes] [Opção] / Auxiliary C Ontrol Valve (Fc) [Component Parts] [Option]
Auxiliar Do Alavanca De Válv Ula De Controlo Kit (3ª) [Opção] / Auxiliary Contro L Valve Lever Kit (3rd) [Option]
Banco Passageiro (Banco) [Op Ção] [Ec] / Instructional Seat Kit (Seat) [Option] [Ec]
Banco Passageiro (Suporte) [ Opção] / Instructional Seat Kit (Bracket) [Option]
Kit De Espelho De Sala [Opçã O] / Room Mirror Kit [Option]
Ventoinha / Fan
Bater Ia / Battery
Tampa / Shift Cover
Degrau / Step
Porta Drt / Door Rh
Porta Esq / Door Lh
