Kubota Tractor M4072DTH DUAL SPEED 36 SPEED Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M4072DTH DUAL SPEED 36 SPEED Tractor
Number of Pages: 305 Pages
Itens Usados Frequentemente / Frequently Us Ed Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Vareta Nivel E Guia / Dipstic K
Cabeça Motor [Velho] / Cylind Er Head [Old]
Cabeça Motor [Novo] / Cylinde R Head [New]
Valvula Admissao E Escape / I Nlet Valve And Exhaust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Cobertura Frontal / Front Cov Er
Arvore Cames E Veio / Camshaf T And Idle Gear Shaft
Compensador / Balancer
Volante Motor / Flywheel
Bomba Alimentacao / Supply Pu Mp
Filtro Gasoleo [Velho] / Fuel Filter [Old]
Filtro Gasoleo [Novo] / Fuel Filter [New]
Injector E Vela Aquecimento / Injector And Glow Plug
Tubo Injector / Injection Pip E
Common Rail / Common Rail
Bomba Agua E Termostacto / Wa Ter Flange And Thermostat
Bomba Agua / Water Pump
Colector Admissao / Inlet Man Ifold
Flange Filtro Ar / Air Cleane R Flange And Throttle Valve
Colector Escape / Exhaust Man Ifold
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Tubo Agua Valvula Egr / Egr W Ater Piping
Turbo Compressor / Turbo Char Ger
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [Component Parts]
Tubo Aspiracao / Inlet Pipe
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Part Ículas Diesel / Diesel Particulate Filter Muffler
Silenciador Do Filtro De Part Ículas Diesel [Peças Componentes] / Diesel Particul Ate Filter Muffler [Component Parts]
Sensor Escape / Muffler Senso R
Tubo Pressao / Pressure Pipe
Separador De Óleo / Oil Separ Ator
Separador De Óleo [Peças Comp Onentes] / Oil Separator [Component Parts]
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Charger)
Radiador Oleo / Oil Cooler
Componentes Electricos Motor (Sensor) / Engine Electrical Parts (Sensor)
Componentes Electricos Motor (Ecu) / Engine Electrical Parts (Ecu)
Pedal Acelarador / Accelerato R Pedal
Tirante Do Acelerador / Accel Erator Rod
Deposit O Combustivel / Fuel Tank
Forneci Mento Combustivel / Fuel Supply
Tubo Do Combustível (Bomba Do Combustível) [Velho] / Fuel Pipe (Fuel Pump) [Old]
Tubo Do Combustível (Bomba Do Combustível) [Novo] / Fuel P Ipe (Fuel Pump) [New]
Tubo Co Mbustivel (Separador) / Fuel Pipe (Separator)
Tubo Co Mbustivel (Arrefecedor Gasoleo) / Fuel Pipe (Fuel C Ooler)
Separad Or [Peças Componentes] / Separator [Component Parts ]
Suporte Ventilador / Fan Bracket
Ventoinha / Fan
Tubo Agua / Water Pipe
Altern Ador / Alternator
Altern Ador [Peças Componentes] / Alternator [Component Pa Rts]
Motor Arranque / Starter
Motor Arranque [Peças Componentes] / Starter [Component Parts]
Bateri A / Battery
Interr Uptor/Sensor (Frente) / Switch/Sensor (Front)
Interr Uptor/Sensor (Traseira) [Com Travao Reboque] / Swit Ch/Sensor (Rear) [With Trailer Brake]
Interr Uptor/Sensor (Carter Embraiagem) / Switch/Sensor (C Lutch Housing)
Interr Uptor (Painel) / Switch (Panel Board)
Interr Uptor (Direcção) / Switch (Steering)
Interr Uptor (Tampa/Guarda Lamas) / Switch (Shift Cover/Fe Nder)
Interr Uptor / Rele / Relay
Unidad E Control Electrico (Bloco Motor) / Electronic Cont Rol Unit (Engine)
Unidad E Control Electrico (Corpo) / Electronic Control Un It (Body)
Painel / Panel Board
Luzes Frente / Head Light
Luzes Frente [Peças Componentes] / Head Light [Component Parts]
Luzes Frontais / Front Combination Lamp
Braco Traseiro / Rear Combination Lamp
Cablag Em Electrica (Crs) / Electrical Wiring (Crs)
Cablag Em Electrica (Injector) / Electrical Wiring (Inject Or)
Cablag Em Electrica (Dianteiro) [Com Travao Reboque] / Ele Ctrical Wiring (Front) [With Trailer Brake]
Cablag Em Electrica (Traseira) [Com Travao Reboque] / Elec Trical Wiring (Rear) [With Trailer Brake]
Valvula Inversor / Shuttle Valve
Carretos Inversor / Shuttle Gear Case
Tampa / Shift Cover
Valva Dupla Velocidades / Dual Speed Valve
Caixa Da Transmissão [Com Travao Reboque] / Transm Ission Case [With Trailer Brake]
Carter Transmissao / Transmission Case Rear Cover
Disco Amortecedor / Damper Disk
Valvula Alavanca (Embraiagem) / Valve Lever (Clutc H)
Veio Primario / Input Shaft
Kit Embraiagem (Alto-Baixo) / Clutch Pack (Hi-Lo)
Veio Inversor / Shuttle Shaft
Kit Embraiagem (Lançadeira) / Clutch Pack (Shuttle )
Primeiro Veio / First Shaft
Terceiro Veio / Third Shaft
Veio Creeper / Creep Shaft
Veio De Acionamento / Drive Shaft
Grupo Conico / Bevel Gear
Diferencial Traseiro / Rear Differential
Veio Tdf / Pto Propeller Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf [Peças Componentes] / Pto Clutch [C Omponent Parts]
Valvula Embraiagem Tdf / Pto Clutch Valve
Valvula Embraiagem Tdf [Peças Componentes] / Pto C Lutch Valve [Component Parts]
Veio Tdf / Pto Shaft
Embraiagem Andamento / Front Drive Clutch
Embraiagem Andamento [Peças Componentes] / Front D Rive Clutch [Component Parts]
Cobertura Da Embraiagem De Transmissão Frontal / F Ront Drive Clutch Cover
Forqueta Velocidades / Range Gear Shift Fork
Bloqueio Diferencial De Forqueta / Diff Erential Lock Shift Fork
Alavanca Velocidades / Main Gear Shift Lever
Tirante / Main Gear Shift Rod
Gama E Tirante Caixa Creep / Range And Creep Gear Shift Lever
Eixo Traseiro / Rear Axle
Trav Ao Drt [Com Travao Reboque] / Brake Rh [With Traile R Brake]
Trav Ao Esq [Com Travao Reboque] / Brake Lh [With Traile R Brake]
Veio Bloqueio / Parking Brake Camshaft
Alav Anca Travao Mao / Parking Brake Lever
Trav Ao Parque / Secondary Brake
Peda L Travao / Brake Pedal
Cili Ndro Travao Principal / Brake Master Cylinder
Cili Ndro Travao Principal [Peças Componentes] / Brake M Aster Cylinder [Component Parts]
Tubo Travao / Brake Pipe
Q Uadro Eixo Frente / Front Axle Frame
S Uporte Eixo Frente / Front Axle Bracket
V Eio Primario / Propeller Shaft
C Aixa Diferencial Frente [Spa] / Front Differential Case [Spa]
G Rupo Conico (Frente) / Bevel Gear (Front)
D Iferencial Frente / Differential Front
C Aixas Engrenagens Conica Drt [Spa] / Bevel Gear Cas E Rh [Spa]
C Aixas Engrenagens Conica Esq [Spa] / Bevel Gear Cas E Lh [Spa]
C Arter Eixo Frente Drt [Spa] / Front Axle Case Rh [S Pa]
C Arter Eixo Frente Esq [Spa] / Front Axle Case Lh [S Pa]
C Arreto Diferencial Esq [Spa] / Differential Gear Sh Aft Lh [Spa]
E Ixo Frente Drt / Front Axle Rh
E Ixo Frente Esq / Front Axle Lh
Tampa Coluna Direccao / Steering Post Cover
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção / Steering Controller
Distribuidor Direcção [P Eças Componentes] / Steering Controller [Component Parts]
Rotula/Cilindro Direcção [Spa] / Tie Rod/Steering Cylinder [Spa]
Cilindro Direcção [Peças Componentes] / Steering Cylinder [Component Parts]
Bomba Hidraulico [Peças Componentes] / Hydraulic Pump [Co Mponent Parts]
Tubo O Leo (Entrega) [Com Travao Reboque] / Hydraulic Pipe (Delivery) [With Trailer Brake]
Tubo H Idraulico (Travao Reboque) [Com Travao Reboque] / H Ydraulic Pipe (Trailer Brake) [With Trailer Brake]
Tubo O Leo (Acoplamento) [Com Travao Reboque] / Hydraulic Oil Line (Coupler) [With Trailer Brake]
Valvul A Travao Reboque [Com Travao Reboque] / Trailer Bra Ke Valve [With Trailer Brake]
Circui To Oleo Radiador (Radiador Oleo) / Hydraulic Oil Pi Pe (Oil Cooler)
Tubo O Leo (Valva Dupla Velocidades) [Com Travao Reboque] / Hydraulic Oil Line (Dual Speed Valve) [With Trail Er Brake]
Circui To Oleo Direcção (Direcção/Tdf) / Hydraulic Oil Lin E (Steering/Pto)
Circui To Oleo Direcção (Inversor/Tdf) / Hydraulic Oil Pip E (Shuttle/Pto)
Tubo D Ireccao (Entrega) / Steering Hose (Delivery)
Caixa Cilindro Hidraulico [Com Travao Reboque] / Hydrauli C Cylinder Case [With Trailer Brake]
Mangue Ira De Respiro (Caixa Cilindro Hidraulico) / Breath Er Hose (Hydraulic Cylinder Case)
Braco Hidraulico / Lift Arm
Valvul A Segurança/Descarga Valvula / Safety Valve/Relief Valve
Trinco / Lowering Lock Lever
Valvul A Control / Control Valve
Suport E De Controlo De Posição / Position Control Bracket
Puxar E Posicionar Alavanca De Controlo / Draft And Posit Ion Control Lever
Veio P Osicao Esforço / Position And Draft Shaft
Alavan Ca / Feed Back Lever
Válvul A De Controlo Auxiliar / Auxiliary Control Valve
Valvul A Auxiliar (Scd) [Peças Componentes] / Auxiliary Co Ntrol Valve (Scd) [Component Parts]
Valvul A Auxiliar (Fd) [Peças Componentes] / Auxiliary Con Trol Valve (Fd) [Component Parts]
Alavan Ca De Válvula De Controlo Auxiliar (1º) / Auxiliary Control Valve Lever (1st)
Alavan Ca De Válvula De Controlo Auxiliar (2º) / Auxiliary Control Valve Lever (2nd)
Cilind Ro Auxiliar De Elevacao Esq [Spa] / 3p-Lift Assist Cylinder Lh [Spa]
Cilind Ro Auxiliar De Elevacao Drt [Spa] / 3p-Lift Assist Cylinder Rh [Spa]
Cilind Ro Auxiliar De Elevacao [Peças Componentes] / 3p-Li Ft Assist Cylinder [Component Parts]
Parte Superior / Top Link Bracket
Ligacao Superior / Top Link
Estabilizador / Stabilizer
Estabilizador Drt / Lift Rod Rh
Estabilizador Esq / Lift Rod Lh
Puxo Barra [Spa] / Drawbar Bracket [ Spa]
Proteccao Tdf [Spa] / Pto Shaft Prot Ector [Spa]
Grelha Frontal / Front G Rille
Capot Superior / Hood (B Onnet) Upper
Capot Superior (Som Abso Rvedor/Isolador) / Hood (Bonnet) (Sound Absorber/In Sulator)
Trico Capot / Hood (Bonn Et) Lock
Capot Lateral / Hood (Bo Nnet) Side Cover
Suporte Capot / Hood (Bo Nnet) Support
Capot Traseiro / Hood (B Onnet) Rear
Capot Traseiro / Hood (B Onnet) Rear (Sound Absorber)
Guarda Lamas / Fender
Piso / Floor Sheet
Piso(Isolante) / Floor S Heet (Sound Absorber)
Degrau / Step
Banco [Spa] / Seat [Spa]
Caixa Ferramenta / Tool Box
Caobertura / Guard
Arco / Rops
Decalcomania (Piso / Guar Da Lamas) / Label (Floor Sheet / Fender)
Acessorios E Peças Serviço / Accesso Ries And Service Parts
Panela Escape [Opçao] / Upper Muffler Kit [Option]
Kit Farios Trabalho [Opção] / Working Light Kit [Option]
Kit Conversao Tdf (540/1000) (Engrenagem) / Pto (540/1000) Conversion Kit [Optio N]
Kit Apoio Peso Frente [Opção] / Front Bumper Kit [Option]
Válvula De Controle Alavanca Kit (Scd) [Opção] / Auxiliary Control Valve Kit (Sc D) [Option]
Válvula De Controle Alavanca Kit (Fd) [Opção] / Auxiliary Control Valve Kit (Fd) [Option]
Válvula De Controle Alavanca Kit (Scd/Fc) [Opção] / Auxiliary Control Valve Kit (Scd/Fc) [Option]
Válvula De Controle Alavanca Kit (Fc) [Opção] / Auxiliary Control Valve Kit (Fc) [Option]
Válvula De Controle Alavanca Kit (Scd) [Peças Componentes] [Opção] / Auxiliary C Ontrol Valve (Scd) [Component Parts] [Option]
Válvula De Controle Alavanca Kit (Fc) [Peças Componentes] [Opção] / Auxiliary Co Ntrol Valve (Fc) [Component Parts] [Option]
Auxiliar Do Alavanca De Válvu La De Controlo Kit (3ª) [Opção] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Ventoinha / Fan
Bateri A / Battery
Tampa / Shift Cover
Piso / Floor Sheet
Degrau / Step
Caobertura / Guard
Arco / Rops
