7,392
Kubota Tractor M4072DTH Dual Speed 36 Speed Parts Catalog EN DE
Language: German, English
Region: Germany, England
Model: Kubota M4072DTH Dual Speed 36 Speed Tractor
Number of Pages: 516 Pages
M4072dth(Dual Speed6 Speed)
Speed6 Speed) Frequently Used Items Frequently Used Items Häufig Verwendete Elemente
M4072dth(Dual Speed6 Speed) Motor Engine Kurbelghaeuse Crankcase
M4072dth(Dual Speed6 Speed) Motor Engine Oelwanne Oil Pan
M4072dth(Dual Speed6 Speed) Motor Engine Oelmessstab Dipstick
Speed) Motor Engine Zylinderkopf [Alter] Cylinder Head [Old] ## S.Nr. =8ktz999 S.No.; =
Speed) Motor Engine Zylinderkopf [Neu] Cylinder Head [New] ## S.Nr. =8ku0001 S.No.; =
M4072dth(Dual Speed6 Speed) Motor Engine Einlassventil Und Auslassventil Inlet Valve And
M4072dth(Dual Speed6 Speed) Motor Engine Kippenarmwelle Rocker Arm Shaft
M4072dth(Dual Speed6 Speed) Motor Engine Deckel Oben Head Cover
M4072dth(Dual Speed6 Speed) Motor Engine Vorderdeckel Front Cover
M4072dth(Dual Speed6 Speed) Motor Engine Abstuetzung Rechts Vorne Piston And
Dual Speed6 Speed) Motor Engine Nockenwelle Und Freilaufgetriebewelle Camshaft
M4072dth(Dual Speed6 Speed) Motor Engine Massennausgleich Balancer
M4072dth(Dual Speed6 Speed) Motor Engine Schwungrad Flywheel
M4072dth(Dual Speed6 Speed) Motor Engine Versorgungsmaterial-Pumpe Supply
Speed6 Speed) Motor Engine Kraftstoffilter [Alter] Fuel Filter [Old] ## S.Nr. =51062 S.No.; =
Speed6 Speed) Motor Engine Kraftstoffilter [Neu] Fuel Filter [New] ## S.Nr. =51063 S.No.; =
M4072dth(Dual Speed6 Speed) Motor Engine Injektor Und Gluehkerze Injector And
M4072dth(Dual Speed6 Speed) Motor Engine Einspritzung-Rohr Injection Pipe
M4072dth(Dual Speed6 Speed) Motor Engine Allgemeine Schiene Common Rail
M4072dth(Dual Speed6 Speed) Motor Engine Wasserflansch Und Thermostat Water Flange
M4072dth(Dual Speed6 Speed) Motor Engine Wasserpumpe Water Pump
M4072dth(Dual Speed6 Speed) Motor Engine Einlasskruemmer Inlet Manifold
Dual Speed6 Speed) Motor Engine Luftfilter-Flansch Und Drossel-Ventil Air Cleaner Flange
M4072dth(Dual Speed6 Speed) Motor Engine Auspuffrummer Exhaust Manifold
M4072dth(Dual Speed6 Speed) Motor Engine Egr Ventil Egr Valve
M4072dth(Dual Speed6 Speed) Motor Engine Egr Kuehlsystem Egr Cooler
M4072dth(Dual Speed6 Speed) Motor Engine Egr Wasser-Rohrleitung Egr Water
M4072dth(Dual Speed6 Speed) Motor Engine Turbineladung Turbo Charger
M4072dth(Dual Speed6 Speed) Motor Engine Luftfilter Air Cleaner
M4072dth(Dual Speed6 Speed) Motor Engine Luftfilter [Einzel-Teil] Air Cleaner [Component
M4072dth(Dual Speed6 Speed) Motor Engine Ansaugenrohr Inlet Pipe
M4072dth(Dual Speed6 Speed) Motor Engine Abblasdaempfer-Rohr Muffler Pipe
Dual Speed6 Speed) Motor Engine Dieselpartikelfilter Auspuffdämpfer Diesel Particulate
Speed) Motor Engine Dieselpartikelfilter Auspuffdämpfer [Einzel-Teil] Diesel Particulate
M4072dth(Dual Speed6 Speed) Motor Engine Sensor, Auspuff Muffler Sensor
M4072dth(Dual Speed6 Speed) Motor Engine Druck-Rohr Pressure Pipe
M4072dth(Dual Speed6 Speed) Motor Engine Ölabscheider Oil Separator
M4072dth(Dual Speed6 Speed) Motor Engine Ölabscheider [Einzel-Teil] Oil Separator [
M4072dth(Dual Speed6 Speed) Motor Engine Ölabscheiderrohr Oil Separator
M4072dth(Dual Speed6 Speed) Motor Engine Oelpomr (Turbineladung) Oil Pipe (Turbo
M4072dth(Dual Speed6 Speed) Motor Engine Oelkuehler Oil Cooler
Dual Speed6 Speed) Motor Engine Elektrische Teile F. Motor (Sensor) Engine Electrical
M4072dth(Dual Speed6 Speed) Motor Engine Elektrische Teile F. Motor (Ecu) Engine Electrical
M4072dth(Dual Speed6 Speed) Motor Engine Injektor-Kabelstrang Injector Harness
M4072dth(Dual Speed6 Speed) Motor Engine Beschleunigungshebel Accelerator
M4072dth(Dual Speed6 Speed) Motor Engine Beschleunigung-Pedal Accelerator
M4072dth(Dual Speed6 Speed) Motor Engine Beschleunigungsstange Accelerator
M4072dth(Dual Speed6 Speed) Brennstoff System Fuel System Kraftstofftank Fuel
M4072dth(Dual Speed6 Speed) Brennstoff System Fuel System Kraftstofffilter Fuel
System Fuel System Kraftstoffleitung (Kraftstoffpumpe) [Alter] Fuel Pipe (Fuel Pump)
System Fuel System Kraftstoffleitung (Kraftstoffpumpe) [Neu] Fuel Pipe (Fuel Pump) [
Dual Speed6 Speed) Brennstoff System Fuel System Kraftstoffrohr (Trennstueck)
Speed6 Speed) Brennstoff System Fuel System Kraftstoffrohr (Kraftstoff-Kuehlvorrichtung)
M4072dth(Dual Speed6 Speed) Brennstoff System Fuel System Wasserabscheider
Dual Speed6 Speed) Brennstoff System Fuel System Wasserabscheider [Einzel-Teil] Separator
M4072dth(Dual Speed6 Speed) Abkuehlung System Cooling Water System Ventilatorhaltewinkel
M4072dth(Dual Speed6 Speed) Abkuehlung System Cooling Water System Wasserrohr
M4072dth(Dual Speed6 Speed) Abkuehlung System Cooling Water System Kuehler
M4072dth(Dual Speed6 Speed) Abkuehlung System Cooling Water System Reservebehalter
M4072dth(Dual Speed6 Speed) Elektrisch System Electrical System Lichtmaschine
Dual Speed6 Speed) Elektrisch System Electrical System Lichtmaschine [Einzel-Teil]
M4072dth(Dual Speed6 Speed) Elektrisch System Electrical System Anlasser
Dual Speed6 Speed) Elektrisch System Electrical System Anlasser [Einzel-Teil] Starter
M4072dth(Dual Speed6 Speed) Elektrisch System Electrical System Batterie
Dual Speed6 Speed) Elektrisch System Electrical System Schalter Sensor (Vorder)
Elektrisch System Electrical System Schalter Sensor (Hinten) [Ohne Anhängerbrems]
Speed6 Speed) Elektrisch System Electrical System Schalter Sensor (Kupplungsgehäuse)
Dual Speed6 Speed) Elektrisch System Electrical System Schalter (Instrumentenbrett)
M4072dth(Dual Speed6 Speed) Elektrisch System Electrical System Schalter (Lenkung)
Speed6 Speed) Elektrisch System Electrical System Schalter (Schaltdeckel Kotfluegel)
M4072dth(Dual Speed6 Speed) Elektrisch System Electrical System Relais Relay
Speed6 Speed) Elektrisch System Electrical System Elektronische Steuereinheit (Motor)
Speed6 Speed) Elektrisch System Electrical System Elektronische Steuereinheit (Koerper)
M4072dth(Dual Speed6 Speed) Elektrisch System Electrical System Instrumentenbrett
M4072dth(Dual Speed6 Speed) Elektrisch System Electrical System Scheinwerfer
Dual Speed6 Speed) Elektrisch System Electrical System Scheinwerfer [Einzel-Teil] Head
Dual Speed6 Speed) Elektrisch System Electrical System Vorderseite Konbination-Licht
Dual Speed6 Speed) Elektrisch System Electrical System Hinter Kombination-Licht
M4072dth(Dual Speed6 Speed) Elektrisch System Electrical System Kennzeichenleuchte
M4072dth(Dual Speed6 Speed) Elektrisch System Electrical System Anhaengerkupplung
Dual Speed6 Speed) Elektrisch System Electrical System Elektrische Ausrustung (Crs)
Speed6 Speed) Elektrisch System Electrical System Elektrische Ausrustung (Einspritzventil)
Elektrisch System Electrical System Elektrische Ausrustung (Vorder) [Ohne Anhängerbrems]
Elektrisch System Electrical System Elektrische Ausrustung (Hinten) [Ohne Anhängerbrems]
M4072dth(Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Kupplung-Gehaeuse
Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Pendezugverkehr
Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Wechselventil Zahnradgehaeuse
M4072dth(Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Schaltdeckel
Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Doppelgeschwindigkeit
Kupplung Transmission Clutch Transmission Getriebe-Gehaeuse [Ohne Anhängerbrems]
Speed) Kupplung Transmission Clutch Transmission Deckel Des Getriebes Hintere Seite
Kupplung Transmission Clutch Transmission Hinterachse-Gehaeuse Rechts [Ohne Anhängerbrems]
Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Hinterachse-Gehaeuse
M4072dth(Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Daempfer Kupplung
M4072dth(Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Kupplung-Pedal
Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Ventilhebel (Kupplung)
M4072dth(Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Antriebswelle
Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Kupplung Satz (Hohe Niedrige)
M4072dth(Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Reversierwelle
Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Kupplung Satz (Schalthebel)
M4072dth(Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Erstewelle
M4072dth(Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Zweitewelle
M4072dth(Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Drittewelle
Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Kriechgang-Getriebewelle
M4072dth(Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Antriebwelle
Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Hinterachsen-Differential
Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Zapfpropellerwelle
M4072dth(Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Zapfwellekupplung
Speed6 Speed) Kupplung Transmission Clutch Transmission Zapfwellenkupplung [Einzel-Teil]
Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Zapfwellenschalthebel
Speed) Kupplung Transmission Clutch Transmission Zapfwellenschalthebel [Einzel-Teil]
Dual Speed6 Speed) Kupplung Transmission Clutch Transmission Vordere Antriebskupplung
Speed) Kupplung Transmission Clutch Transmission Vordere Antriebskupplung [Einzel-Teil]
Speed6 Speed) Kupplung Transmission Clutch Transmission Vordere Antriebskupplung Deckel
Speed) Getriebe Schaltgabel Schalthebel Speed Change Shift Fork Shift Lever
Getriebe Schaltgabel Schalthebel Speed Change Shift Fork Shift Lever Fourchette Fur
Speed) Getriebe Schaltgabel Schalthebel Speed Change Shift Fork Shift Lever Reversier-
Getriebe Schaltgabel Schalthebel Speed Change Shift Fork Shift Lever Kriechgang Und Schalthebel
M4072dth(Dual Speed6 Speed) Hinterradachse Bremse Rear Axle Brake Hinterradachse
Speed) Hinterradachse Bremse Rear Axle Brake Bremse Rechts [Ohne Anhängerbrems]
Speed6 Speed) Hinterradachse Bremse Rear Axle Brake Bremse Links [Ohne Anhängerbrems]
Dual Speed6 Speed) Hinterradachse Bremse Rear Axle Brake Handbremsnockenwelle
M4072dth(Dual Speed6 Speed) Hinterradachse Bremse Rear Axle Brake Handbremshebel
M4072dth(Dual Speed6 Speed) Hinterradachse Bremse Rear Axle Brake Sekundärbrems
M4072dth(Dual Speed6 Speed) Hinterradachse Bremse Rear Axle Brake Bremspedal
Dual Speed6 Speed) Hinterradachse Bremse Rear Axle Brake Bremse-Montagezylinder
Speed) Hinterradachse Bremse Rear Axle Brake Bremse Geberzylinder [Einzel-Teil] Brake
M4072dth(Dual Speed6 Speed) Hinterradachse Bremse Rear Axle Brake Bremsleitung
M4072dth(Dual Speed6 Speed) Vorderachse Rahmen Front Axle Chassis Vorderachse-Rahmen
Dual Speed6 Speed) Vorderachse Rahmen Front Axle Chassis Vorderachse-Stuetze
M4072dth(Dual Speed6 Speed) Vorderachse Rahmen Front Axle Chassis Propellerwelle
Speed6 Speed) Vorderachse Rahmen Front Axle Chassis Vorderachsen-Diff.Gehaeuse [Ec]
Dual Speed6 Speed) Vorderachse Rahmen Front Axle Chassis Antriebskegelrad (Vorder)
M4072dth(Dual Speed6 Speed) Vorderachse Rahmen Front Axle Chassis Differential Vorder
Speed6 Speed) Vorderachse Rahmen Front Axle Chassis Kegelraedergehaeuse Rechts [
Dual Speed6 Speed) Vorderachse Rahmen Front Axle Chassis Kegelraedergehaeuse Links [
Speed6 Speed) Vorderachse Rahmen Front Axle Chassis Vorderachse-Gehaeuse Rechts [
Dual Speed6 Speed) Vorderachse Rahmen Front Axle Chassis Vorderachse-Gehaeuse Links [
Speed6 Speed) Vorderachse Rahmen Front Axle Chassis Diff.Getriebewelle Rechts [Ec]
Speed6 Speed) Vorderachse Rahmen Front Axle Chassis Diff.Getriebewelle Links [Ec]
M4072dth(Dual Speed6 Speed) Vorderachse Rahmen Front Axle Chassis Vorderachse Rechts
M4072dth(Dual Speed6 Speed) Vorderachse Rahmen Front Axle Chassis Vorderachse Links
M4072dth(Dual Speed6 Speed) Lenkung Steering Lenkrad Steering Wheel
M4072dth(Dual Speed6 Speed) Lenkung Steering Lenkpfosten-Abdeckung Steering Post
M4072dth(Dual Speed6 Speed) Lenkung Steering Lenkradverstellpedal Tilt Pedal
M4072dth(Dual Speed6 Speed) Lenkung Steering Steuerungverbindung Steering
M4072dth(Dual Speed6 Speed) Lenkung Steering Hilfskraftlenkung Steering
Dual Speed6 Speed) Lenkung Steering Hilfskraftlenkung [Einzel-Teil] Steering Controller
Dual Speed6 Speed) Lenkung Steering Verbindungssatange Lenkungszylinder [Ec] Tie Rod
Dual Speed6 Speed) Lenkung Steering Lenkungszylinder [Einzel-Teil] Steering Cylinder
M4072dth(Dual Speed6 Speed) Hydraulik System Hydraulic System Hydraulikpumpe
Speed6 Speed) Hydraulik System Hydraulic System Hydraulikpumpe [Einzel-Teil] Hydraulic
Hydraulik System Hydraulic System Hydraulik-Kreislauf (Zuleitung) [Ohne Anhängerbrems]
Speed6 Speed) Hydraulik System Hydraulic System Hydraulik-Kreislauf (Oelkuehler)
Hydraulic System Hydraulik-Kreislauf (Doppelgeschwindigkeit Ventil) [Ohne Anhängerbrems]
Speed) Hydraulik System Hydraulic System Hydraulik-Kreislauf (Steuerung Zapfwellenantrieb)
Speed) Hydraulik System Hydraulic System Hydraulik-Kreislauf (Doppelventilkegel Zapfwellenantrieb)
Dual Speed6 Speed) Hydraulik System Hydraulic System Steuerung Schlauch (Anlieferung)
Hydraulik System Hydraulic System Hydraulik Zylindergehaeuse [Ohne Anhängerbrems]
Hydraulik System Hydraulic System Entluefter-Schlauch (Hydraulik Zylindergehaeuse)
M4072dth(Dual Speed6 Speed) Hydraulik System Hydraulic System Hubarm Lift
Speed6 Speed) Hydraulik System Hydraulic System Sicherheitsventil Ueberdruckventil
Dual Speed6 Speed) Hydraulik System Hydraulic System Niederring-Verriegelungshebel
M4072dth(Dual Speed6 Speed) Hydraulik System Hydraulic System Regelungsventil
Dual Speed6 Speed) Hydraulik System Hydraulic System Positions Kontroll Bracket
Speed) Hydraulik System Hydraulic System Entwurf Und Position Betaetigungshebel
Dual Speed6 Speed) Hydraulik System Hydraulic System Position Welle Und Entwurfwelle
M4072dth(Dual Speed6 Speed) Hydraulik System Hydraulic System Wirken Sie Hebel Rueck
M4072dth(Dual Speed6 Speed) Hydraulik System Hydraulic System Zusatzsteuerventile Auxiliary
Speed) Hydraulik System Hydraulic System Zusatzsteuerventile (Scd) [Einzel-Teil] Auxiliary
Speed) Hydraulik System Hydraulic System Zusatzsteuerventile (Fd) [Einzel-Teil] Auxiliary
Speed) Hydraulik System Hydraulic System Zusatzsteuerventile-Schalthebel (Zuerst)
Speed) Hydraulik System Hydraulic System Zusatzsteuerventile-Schalthebel (Zweite)
Speed6 Speed) Hydraulik System Hydraulic System Aufzug-Beifahrerzylinder Links [Ec]
Speed6 Speed) Hydraulik System Hydraulic System Aufzug-Beifahrerzylinder Rechts [Ec]
Speed) Hydraulik System Hydraulic System Aufzug-Beifahrerzylinder [Einzel-Teil]P-Lift
Speed) Dreipunkt-Anhangerkupplung Anhangerku Vorderanhangung-Point Linkage Drawbar Hitch
M4072dth(Dual Speed6 Speed) Motorhaube Hood Bonnet Vorder-Gitter Front
M4072dth(Dual Speed6 Speed) Motorhaube Hood Bonnet Motorhaube Obere Hood (Bonnet)
Speed6 Speed) Motorhaube Hood Bonnet Motorhaube (Geraeuschdaemmung) Hood (Bonnet)
M4072dth(Dual Speed6 Speed) Motorhaube Hood Bonnet Motorhaube Daempfer Hood (
M4072dth(Dual Speed6 Speed) Motorhaube Hood Bonnet Muetze-Verriegelung Hood (
M4072dth(Dual Speed6 Speed) Motorhaube Hood Bonnet Motorhaube Seitendeckel Hood (
M4072dth(Dual Speed6 Speed) Motorhaube Hood Bonnet Motorhaubetragen Hood (Bonnet)
M4072dth(Dual Speed6 Speed) Motorhaube Hood Bonnet Motorhaube Hintere Hood (
Speed6 Speed) Motorhaube Hood Bonnet Motorhaube Hintere (Schalldaempfer) Hood (
M4072dth(Dual Speed6 Speed) Motorhaube Hood Bonnet Kotfluegel Fender
M4072dth(Dual Speed6 Speed) Motorhaube Hood Bonnet Schaltdeckel Shift Cover
M4072dth(Dual Speed6 Speed) Motorhaube Hood Bonnet Aufboden Floor Sheet
Dual Speed6 Speed) Motorhaube Hood Bonnet Bodenabdeckung (Schalldaemmung) Floor
M4072dth(Dual Speed6 Speed) Motorhaube Hood Bonnet Tritt Step
M4072dth(Dual Speed6 Speed) Motorhaube Hood Bonnet Hilfstritt Auxiliary Step
M4072dth(Dual Speed6 Speed) Motorhaube Hood Bonnet Sitzklammer [Ec] Seat Bracket
M4072dth(Dual Speed6 Speed) Motorhaube Hood Bonnet Werkzeugkasten Tool
M4072dth(Dual Speed6 Speed) Motorhaube Hood Bonnet Schutz Guard
M4072dth(Dual Speed6 Speed) Sicherheitsrahmen Rops Sicherheitsrahmen Rops
M4072dth(Dual Speed6 Speed) Aufkleber Labels Aufkleber (Vorder) Label (Front)
M4072dth(Dual Speed6 Speed) Aufkleber Labels Aufkleber (Motorhaube) Label (Hood (
Dual Speed6 Speed) Aufkleber Labels Aufkleber (Bodenabdeckung Kotfluegel) Label (
Sontiges Zubehoer Und Service Teile Accessories And Service Parts Sontiges Zubehoer Und
M4072dth(Dual Speed6 Speed) Option Option Obere Auspufftopf [Option] Upper Muffler
M4072dth(Dual Speed6 Speed) Option Option Arbeitsschinwerfer [Option] Working Light
Dual Speed6 Speed) Option Option P.T.O.(540000) Umwandlung [Option] Pto (540000)
M4072dth(Dual Speed6 Speed) Option Option Front-Stossstange [Option] Front Bumper
Hydraulikventil (Scd) [Option] Auxiliary Control Valve Kit (Scd) [Option] ## Notiz Sehen Sie No.
Hydraulikventil (Fd) [Option] Auxiliary Control Valve Kit (Fd) [Option] ## Note Refer To Fig.No.
Dual Speed6 Speed) Option Option Hydraulikventil (Scd Fc) [Option] Auxiliary Control
M4072dth(Dual Speed6 Speed) Option Option Hydraulikventil (Fc) [Option] Auxiliary Control
Speed) Option Option Hydraulikventil (Scd) [Einzel-Teil] [Option] Auxiliary Control Valve
Speed) Option Option Hydraulikventil (Fc) [Einzel-Teil] [Option] Auxiliary Control Valve
Speed6 Speed) Option Option Zusatzsteuerventile-Hebel Kit (3.) [Option] Auxiliary Control
Dual Speed6 Speed) Option Option Anhängerbremsventil-Kit (Ventil) [Option] Trailer Brake
Speed6 Speed) Option Option Anhängerbremsventil-Kit (Kuppler) [Option] Trailer Brake
Dual Speed6 Speed) Option Option Anhängerbremsventil-Kit (Rohr) [Option] Trailer Brake
