Kubota Tractor M4063DTHC 18 SPEED Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M4063DTHC 18 SPEED Tractor
Number of Pages: 320 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Vareta Nivel E Guia / Dipstick
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhaust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Piston E Cambota / Piston And Crankshaf T
Compensador / Balancer
Volante Motor / Flywheel
Tubo De Respiração (Motor Volante) / Br Eather Pipe (Flywheel)
Bomba De Abastecimento / Supply Pump
Filtro Gasoleo [Antiga] / Fuel Filter [ Old]
Filtro Gasoleo [Nova] / Fuel Filter [Ne W]
Injector E Vela Aquecimento / Injector And Glow Plug
Common Rail / Common Rail
Bomba Agua / Water Pump
Flange Filtro Ar E Valvula Acelarador / Air Cleaner Flange And Throttle Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Tubo Agua Valvula Egr / Egr Water Pipin G
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cle Aner [Component Parts]
Tubo Aspiracao / Inlet Pipe
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Partículas Die Sel / Diesel Particulate Filter Muffler
Silenciador Do Filtro De Partículas Die Sel [Peças Componentes] / Diesel Particulate Filter Muffler [Component Parts]
Sensor Escape / Muffler Sensor
Tubo Pressao / Pressure Pipe
Separador De Óleo [Peças Componentes] / Oil Separator [Component Parts]
Tubo Do Separador De Óleo / Oil Separat Or Pipe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Charger)
Radiador Oleo / Oil Cooler
Componentes Electricos Motor (Sensor) / Engine Electrical Parts (Sensor)
Componentes Electricos Motor (Ecu) / En Gine Electrical Parts (Ecu)
Deposito Combusti Vel / Fuel Tank
Fornecimento Comb Ustivel / Fuel Filler
Tubo Do Combustív El (Bomba Do Combustível) / Fuel Pipe (Fuel Pump)
Tubo Combustivel (Separador) / Fuel Pipe (Separator)
Separador / Separ Ator
Suporte Ventilador / Fan Bracket
Ventoinha / Fan
Tubo Agua / Water Pipe
Alternador / Alt Ernator
Alternador [Peça S Componentes] / Alternator [Component Parts]
Motor Arranque [ Peças Componentes] / Starter [Component Parts]
Bateria / Batter Y
Interruptor/Sens Or (Frente) / Switch/Sensor (Front)
Interruptor/Sens Or (Traseira) / Switch/Sensor (Rear)
Interruptor/Sens Or (Carter Embraiagem) / Switch/Sensor (Clutch Hous Ing)
Interruptor (Cob Ertura Do Guarda-Lamas/Tejadilho Interior) / Switch (Fender Cover/Inner Roof)
Interruptor (Gua Rda Lamas) / Switch (Fender)
Interruptor (Dir Ecção) / Switch (Steering)
Relé / Relay
Unidade Control Electrico (Bloco Motor) / Electronic Control Unit ( Engine)
Unidade Control Electrico (Corpo) / Electronic Control Unit (Body)
Painel / Panel B Oard
Luzes Frente / H Ead Light
Luzes Frente [Pe Ças Componentes] / Head Light [Component Parts]
Luzes Frontais / Front Combination Lamp
Luzes Trabalho / Working Light
Braco Traseiro / Rear Combination Lamp
Luz Interior / R Oom Light
Alta Voz Radio / Radio Speaker
Depósito De Lava Gem / Washer Tank
Escova Limpa Vid Ro Frontal / Front Wiper
Cablagem Electri Ca (Crs) / Electrical Wiring (Crs)
Cablagem Electri Ca (Injector) / Electrical Wiring (Injector)
Cablagem Electri Ca (Motor) / Electrical Wiring (Engine)
Cablagem Electri Ca (Principal/Dianteiro) / Electrical Wiring (Main/ Front)
Cablagem Electri Ca (Corpo) / Electrical Wiring (Body)
Cablagem Electri Ca (Cabine) / Electrical Wiring (Cab)
Carter Em Braiagem / Clutch Housing
Valvula I Nversor / Shuttle Valve
Carretos Inversor / Shuttle Gear Case
Tampa / S Hift Cover
Caixa Da Transmissão / Transmission Case
Carter Tr Ansmissao / Transmission Case Rear Cover
Carter Ei Xo Traseiro Drt / Rear Axle Case Rh
Carter Ei Xo Traseiro Esq / Rear Axle Case Lh
Disco Amo Rtecedor / Damper Disk
Pedal Emb Raiagem / Clutch Pedal
Cabo Embr Aiagem / Clutch Cable
Valvula A Lavanca (Embraiagem) / Valve Lever (Clutch)
Veio Prim Ario / Input Shaft
Kit Embra Iagem (Alto-Baixo) / Clutch Pack (Hi-Lo)
Veio Inve Rsor / Shuttle Shaft
Primeiro Veio / First Shaft
Secundari O Veio / Second Shaft
Terceiro Veio / Third Shaft
Veio Cree Per / Creep Shaft
Veio De A Cionamento / Drive Shaft
Grupo Con Ico / Bevel Gear
Diferenci Al Traseiro / Rear Differential
Veio Tdf / Pto Propeller Shaft
Embraiage M Tdf / Pto Clutch
Embraiage M Tdf [Peças Componentes] / Pto Clutch [Component Parts]
Valvula E Mbraiagem Tdf / Pto Clutch Valve
Valvula E Mbraiagem Tdf [Peças Componentes] / Pto Clutch Valv E [Component Parts]
Veio Tdf / Pto Shaft
Embraiage M Andamento / Front Drive Clutch
Embraiage M Andamento [Peças Componentes] / Front Drive Clutc H [Component Parts]
Cobertura Da Embraiagem De Transmissão Frontal / Front Drive Clutch Cover
Forqueta Velocidades / Range Gear Shift Fork
Bloqueio Diferencial De Forqueta / Differential L Ock Shift Fork
Alavanca Velocidades / Main Gear Shift Lever
Tirante / Main Gear Shift Rod
Gama E Tirante Caixa Creep / Range And Creep Gear Shift Lever
Alavanca De Mudança De Velocidades De Tomada De F Orça Tdf / Pto Gear Shift Rod
Eixo Traseiro / Rear Axle
Travao Drt / B Rake Rh
Travao Esq / B Rake Lh
Veio Bloqueio / Parking Brake Camshaft
Alavanca Trava O Mao / Parking Brake Lever
Travao Parque / Secondary Brake
Pedal Travao / Brake Pedal
Cilindro Trava O Principal / Brake Master Cylinder
Cilindro Trava O Principal [Peças Componentes] / Brake Master Cyli Nder [Component Parts]
Suporte Eix O Frente / Front Axle Bracket
Veio Primar Io / Propeller Shaft
Caixa Difer Encial Frente / Front Differential Case
Grupo Conic O (Frente) / Bevel Gear (Front)
Diferencial Frente / Differential Front
Caixas Engr Enagens Conica Drt / Bevel Gear Case Rh
Caixas Engr Enagens Conica Esq / Bevel Gear Case Lh
Carter Eixo Frente Drt / Front Axle Case Rh
Carter Eixo Frente Esq / Front Axle Case Lh
Carreto Dif Erencial Drt / Differential Gear Shaft Rh
Carreto Dif Erencial Esq / Differential Gear Shaft Lh
Eixo Frente Esq / Front Axle Lh
Tampa Coluna Direccao / Steering P Ost Cover
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção / Steering C Ontroller
Rotula/Cilindro Direcção / Tie Rod /Steering Cylinder
Cilindro Direcção [Peças Component Es] / Steering Cylinder [Component Parts]
Bomba Hidraulico [Peças Componentes] / Hydraulic Pump [Component Pa Rts]
Tubo Oleo (Entre Ga) / Hydraulic Pipe (Delivery)
Tubo Hidraulico (Travao Reboque) / Hydraulic Pipe (Trailer Brake)
Tubo Oleo (Acopl Amento) / Hydraulic Oil Line (Coupler)
Valvula Travao R Eboque / Trailer Brake Valve
Circuito Oleo Ra Diador (Radiador Oleo) / Hydraulic Oil Line (Oil Co Oler)
Tubo Oleo (Inver Sor/Tdf) / Hydraulic Oil Line (Shuttle/Pto)
Tubo Direccao (E Ntrega) / Steering Hose (Delivery)
Hidráulico Tomad A Tubo / Hydraulic Outlet Pipe
Caixa Cilindro H Idraulico / Hydraulic Cylinder Case
Mangueira De Res Piro (Caixa Cilindro Hidraulico) / Breather Hose (H Ydraulic Cylinder Case)
Braco Hidraulico / Lift Arm
Valvula Seguranç A/Descarga Valvula / Safety Valve/Relief Valve
Trinco / Lowerin G Lock Lever
Suporte De Contr Olo De Posição / Position Control Bracket
Puxar E Posicion Ar Alavanca De Controlo / Draft And Position Contro L Lever
Veio Posicao Esf Orço / Position And Draft Shaft
Alavanca / Feed Back Lever
Válvula De Contr Olo Auxiliar / Auxiliary Control Valve
Valvula Auxiliar (Scd) [Peças Componentes] / Auxiliary Control Valv E (Scd) [Component Parts]
Valvula Auxiliar (Fd) [Peças Componentes] / Auxiliary Control Valve (Fd) [Component Parts]
Alavanca De Válv Ula De Controlo Auxiliar (1º) / Auxiliary Control V Alve Lever (1st)
Alavanca De Válv Ula De Controlo Auxiliar (2º) / Auxiliary Control V Alve Lever (2nd)
Cilindro Auxilia R De Elevacao Esq / 3p-Lift Assist Cylinder Lh
Cilindro Auxilia R De Elevacao Drt / 3p-Lift Assist Cylinder Rh
Cilindro Auxilia R De Elevacao [Peças Componentes] / 3p-Lift Assist Cylinder [Component Parts]
Parte Superior / Top Link Bracket
Ligacao Superior / Top Link
Estabilizador Drt / Lift Rod Rh
Estabilizador Esq / Lift Rod Lh
Puxo Barra / Drawbar Bracket
Proteccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot Superior / Hood (Bonnet) Upp Er
Capot Superior (Som Absorvedor/Iso Lador) / Hood (Bonnet) (Sound Absorber/Insulator)
Suporte Capot / Hood (Bonnet) Supp Ort
Estrutura Cabine / Cab Frame
Degrau / Step
Capot Traseira (Cabine) / Hood (Bonnet) R Ear (Cab)
Vidro Frente / Front Glass
Porta Drt / Door Rh
Porta Esq / Door Lh
Lado Vidro / Side Window
Vidro Traseiro Da Escotilha / Hatch Back Glass
Tecto Interior / Inner Roof
Cobertura Exterior Do Tejadilho / Outer R Oof
Składowanie Materiałów/Piso / Damp Materi Al/Floor Mat
Chapa Inspecção / Inspection Plate
Cobertura Guarda Lamas Drt / Fender Cover Rh
Cobertura Gurada Lamas Esq / Fender Cover Lh
Guarda Lamas / Fender
Suporte Cabine Frente / Cab Bracket Front
Suporte Cabine Traseira / Cab Bracket Rea R
Caixa Ferramenta / Tool Box
Ar Condicionado / Ai R Conditioner
Conduta Do Ar Condic Ionado / Air Conditioner Duct
Modo Caixa / Mode Ca Se
Entradas Ar Painel I Nstrumentos / Dashboard Air Outlets
Circulaçao Ar Interi Or / Inner Air Recirculation
Tubo Aquecimento / H Eater Hose
Condesador / Condens Er
Tubo Ar Condicionado /Tubo Condensador / Air Conditioner Hose/Condenser Hose
Compressor (Ar Condi Cionado) / Compressor (Air Conditioner)
Etiqueta (Capot) / Label (Hood (Bon Net))
Decalcomania (Cabine Interior) / La Bel (Cab Interior)
Decalcomania (Cabine Exterior) / La Bel (Cab Exterior)
Peça De Acessorio E Serviço P Eças / Accessories And Service Parts
Panela Escape [Opçao] / Upper Muffler K It [Option]
Kit Farios Trabalho (Led) [Opção] / Wor King Light Kit (Led) [Option]
Desempanador (Vidro) [Opção] / Rear Def Ogger Kit (Glass) [Option]
Kit Limpa Vidro Traseiros [Opção] / Rea R Wiper Kit [Option]
Kit Conversao Tdf (540/1000) [Opção] / Pto (540/1000) Conversion Kit [Option]
Válvula De Controle Alavanca Kit (Scd) [Opção] / Auxiliary Control Valve Kit (Scd) [Option ]
Válvula De Controle Alavanca Kit (Fd) [ Opção] / Auxiliary Control Valve Kit (Fd) [Option]
Válvula De Controle Alavanca Kit (Scd/F C) [Opção] / Auxiliary Control Valve Kit (Scd/Fc) [ Option]
Válvula De Controle Alavanca Kit (Fc) [ Opção] / Auxiliary Control Valve Kit (Fc) [Option]
Válvula De Controle Alavanca Kit (Scd) [Peças Componentes] [Opção] / Auxiliary Control Val Ve (Scd) [Component Parts] [Option]
Auxiliar Do Válvula De Controlo (Fd) [P Eças Componentes] [Opção] / Auxiliary Control Valve (Fd) [Component Parts] [Option]
Válvula De Controle Alavanca Kit (Scd/F C) [Peças Componentes] [Opção] / Auxiliary Control Valve (Scd/Fc) [Component Parts] [Option]
Válvula De Controle Alavanca Kit (Fc) [ Peças Componentes] [Opção] / Auxiliary Control Valv E (Fc) [Component Parts] [Option]
Auxiliar Do Alavanca De Válvula De Cont Rolo Kit (3ª) [Opção] / Auxiliary Control Valve Lev Er Kit (3rd) [Option]
Montagem Da Válvula Do Freio Do Reboque (Tubo) [Opção] / Trailer Brake Valve Mounting Kit (Pipe) [Option]
Montagem Da Válvula Do Freio Do Reboque (Valvula) [Opção] / Trailer Brake Valve Mounting K It (Valve) [Option]
Montagem Da Válvula Do Freio Do Reboque (Junta) [Opção] / Trailer Brake Valve Mounting Kit (Gasket) [Option]
Montagem Da Válvula Do Freio Do Reboque (Cablagem Electrica) [Opção] / Trailer Brake Valve Mounting Kit (Electrical Wiring) [Option]
Banco Passageiro (Banco) [Opção] / Inst Ructional Seat Kit (Seat) [Option]
Banco Passageiro (Suporte) [Opção] / In Structional Seat Kit (Bracket) [Option]
Kit De Espelho De Sala [Opção] / Room M Irror Kit [Option]
Ventoinha / Fan
Bateria / Batter Y
Relé / Relay
Degrau / Step
Porta Drt / Door Rh
Porta Esq / Door Lh
