Kubota Tractor M4062DTHC 18 SPEED Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M4062DTHC 18 SPEED Tractor
Number of Pages: 389 Pages
It Ens Usados Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Tampao [Ec] [Spa] / Oil Filler Pulg [Ec ] [Spa]
Carter Oleo / Oil Pan
Vareta Nivel E Guia [Ec] [Spa] / Dipsti Ck [Ec] [Spa]
Cabeça Motor [Velho] / Cylinder Head [O Ld]
Cabeça Motor [Novo] / Cylinder Head [Ne W]
Valvula Admissao E Escape / Inlet Valve And Exhaust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Piston E Cambota / Piston And Crankshaf T
Compensador / Balancer
Volante Motor / Flywheel
Filtro Gasoleo [Velho] / Fuel Filter [O Ld]
Filtro Gasoleo [Novo] / Fuel Filter [Ne W]
Injector E Vela Aquecimento / Injector And Glow Plug
Trilho Comum / Common Rail
Bomba Agua / Water Pump
Flange Filtro Ar / Air Cleaner Flange A Nd Throttle Valve
Valvula Egr / Egr Valve And Egr Cooler
Refrigerador Egr / Egr Cooler
Tubo Agua Valvula Egr / Egr Water Pipin G
Filtro Ar [Peças Componentes] / Air Cle Aner [Component Parts]
Tubo Aspiracao / Inlet Pipe
Panela Escape [Ec] [Spa] / Muffler Pipe [Ec] [Spa]
Silenciador Do Filtro De Partículas Die Sel / Diesel Particulate Filter Muffler
Silenciador Do Filtro De Partículas Die Sel [Peças Componentes] / Diesel Particulate Filter Muffler [Component Parts]
Sensor Escape / Muffler Sensor
Tubo Pressao / Pressure Pipe
Separador De Óleo [Peças Componentes] / Oil Separator [Component Parts]
Tubo Do Separador De Óleo / Oil Separat Or Pipe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Charger)
Radiador Oleo / Oil Cooler
Componentes Electricos Motor (Sensor) / Engine Electrical Parts (Sensor)
Componentes Electricos Motor (Ecu) / En Gine Electrical Parts (Ecu)
Deposito Combusti Vel / Fuel Tank
Fornecimento Comb Ustivel / Fuel Supply
Tubo Do Combustív El (Bomba Do Combustível) [Velho] / Fuel Pipe (Fuel Pump) [Old]
Tubo Combustivel (Separador) / Fuel Pipe (Separator)
Separador / Separ Ator
Suporte Ventilador / Fan Bracket
Ventoinha / Fan
Tubo Agua / Water Pipe
Alternador / Alt Ernator
Alternador [Peça S Componentes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [ Peças Componentes] / Starter [Component Parts]
Bateria / Batter Y
Interruptor/Sens Or (Frente) / Switch/Sensor (Front)
Interruptor/Sens Or (Traseira) [Sem Travao Reboque] / Switch/Sensor (Rear) [Without Trailer Brake]
Interruptor/Sens Or (Traseira) [Com Travao Reboque] / Switch/Sensor (Rear) [With Trailer Brake]
Interruptor/Sens Or (Carter Embraiagem) / Switch/Sensor (Clutch Hous Ing)
Interruptor (Qua Dro Do Painel) / Switch (Panel Board)
Interruptor (Gua Rda Lamas) / Switch (Fender)
Interruptor (Dir Ecção) / Switch (Steering)
Interruptor / Re Le / Relay
Unidade Control Electrico (Bloco Motor) / Electronic Control Unit ( Engine)
Unidade Control Electrico (Corpo) / Electrical Control Unit (Body)
Painel / Panel B Oard
Luzes Frente / H Ead Light
Luzes Frente [Pe Ças Componentes] / Head Light [Component Parts]
Luzes Frontais / Front Combination Lamp
Luzes Trabalho / Working Light
Braco Traseiro / Rear Combination Lamp
Luz Interior / R Oom Light
Alta Voz Radio [ Ec] [Spa] [Ge] / Radio Speaker [Ec] [Spa] [Ge]
Depósito De Lava Gem / Washer Tank
Escova Limpa Vid Ro Frontal / Front Wiper
Cablagem Electri Ca (Crs) / Electrical Wiring (Crs)
Cablagem Electri Ca (Injector) / Electrical Wiring (Injector)
Cablagem Electri Ca (Motor) / Electrical Wiring (Engine)
Cablagem Electri Ca (Principal/Dianteiro) [Velho] / Electrical Wirin G (Main/Front) [Old]
Cablagem Electri Ca (Principal/Dianteiro) [Novo] / Electrical Wiring (Main/Front) [New]
Cablagem Electri Ca (Principal/Traseira) [Velho] / Electrical Wiring (Main/Rear) [Old]
Cablagem Electri Ca (Principal/Traseira) [Novo] / Electrical Wiring (Main/Rear) [New]
Cablagem Electri Ca (Corpo) [Sem Travao Reboque] / Electrical Wiring (Body) [Without Trailer Brake]
Cablagem Electri Ca (Corpo) [Com Travao Reboque] / Electrical Wiring (Body) [With Trailer Brake]
Cabalagem Eletri Ca (Cabine) [Ec] [Spa] [Ge] / Electrical Wiring (Ca B) [Ec] [Spa] [Ge]
Carter Em Braiagem / Clutch Housing
Valvula I Nversor / Shuttle Valve
Carretos Inversor / Shuttle Gear Case
Tampa / S Hift Cover
Caixa Da Transmissão [Sem Travao Reboque] / Transmission Cas E [Without Trailer Brake]
Caixa Da Transmissão [Com Travao Reboque] / Transmission Cas E [With Trailer Brake]
Carter Tr Ansmissao / Transmission Case Rear Cover
Carter Ei Xo Traseiro Certo [Sem Travao Reboque] / Rear Axle Case Rh [Without Trailer Brake]
Carter Ei Xo Traseiro Certo [Com Travao Reboque] / Rear Axle Case Rh [With Trailer Brake]
Carter Ei Xo Traseiro Esq / Rear Axle Case Lh
Disco Amo Rtecedor / Damper Disk
Pedal Emb Raiagem / Clutch Pedal
Cabo Embr Aiagem / Clutch Cable
Valvula A Lavanca (Embraiagem) / Valve Lever (Clutch)
Veio Prim Ario / Input Shaft
Kit Embra Iagem (Alto-Baixo) / Clutch Pack (Hi-Lo)
Veio Inve Rsor / Shuttle Shaft
Primeiro Veio / First Shaft
Secundari O Veio / Second Shaft
Terceiro Veio / Third Shaft
Veio Cree Per / Creep Shaft
Veio De A Cionamento / Drive Shaft
Grupo Con Ico / Bevel Gear
Diferenci Al Traseiro / Rear Differential
Veio Tdf / Pto Propeller Shaft
Embraiage M Tdf / Pto Clutch
Embraiage M Tdf [Peças Componentes] / Pto Clutch [Component Parts]
Valvula E Mbraiagem Tdf / Pto Clutch Valve
Valvula E Mbraiagem Tdf [Peças Componentes] / Pto Clutch Valv E [Component Parts]
Veio Tdf / Pto Shaft
Embraiage M Andamento / Front Drive Clutch
Embraiage M Andamento [Peças Componentes] / Front Drive Clutc H [Component Parts]
Cobertura Da Embraiagem De Transmissão Frontal / Front Drive Clutch Cover
Forqueta Velocidades / Range Gear Shift Fork
Bloqueio Diferencial De Forqueta / Differential L Ock Shift Fork
Tirante / Main Gear Shift Rod
Gama E Tirante Caixa Creep / Range And Creep Gear Shift Lever
Alavanca Tdf [Ec] [Spa] [Ge] / Pto Gear Shift Lev Er [Ec] [Spa] [Ge]
Alavanca De Mudança De Velocidades De Tomada De F Orça Tdf [Ec] [Spa] [Ge] / Pto Gear Shift Rod [Ec] [Spa] [Ge]
Eixo Traseiro / Rear Axle
Travao Drt [Se M Travao Reboque] / Brake Rh [Without Trailer Brake ]
Travao Drt [Co M Travao Reboque] / Brake Rh [With Trailer Brake]
Travao Esq [Se M Travao Reboque] / Brake Lh [Without Trailer Brake ]
Travao Esq [Co M Travao Reboque] / Brake Lh [With Trailer Brake]
Veio Bloqueio / Parking Brake Camshaft
Alavanca Trava O Mao / Parking Brake Lever
Travao Parque / Secondary Brake
Pedal Travao / Brake Pedal
Cilindro Trava O Principal / Brake Master Cylinder
Cilindro Trava O Principal [Peças Componentes] / Brake Master Cyli Nder [Component Parts]
Tubo Travao / Brake Pipe
Suporte Eix O Frente / Front Axle Bracket
Veio Primar Io / Propeller Shaft
Caixa Difer Encial Frente [Ec] [Uk] [Ge] / Front Differential C Ase [Ec] [Uk] [Ge]
Caixa Difer Encial Frente [Spa] / Front Differential Case [Spa]
Grupo Conic O (Frente) / Bevel Gear (Front)
Diferencial Frente / Differential Front
Caixas Engr Enagens Conica Drt [Ec] [Uk] [Ge] / Bevel Gear Case Rh [Ec] [Uk] [Ge]
Caixas Engr Enagens Conica Drt [Spa] / Bevel Gear Case Rh [Spa]
Caixas Engr Enagens Conica Esq [Ec] [Uk] [Ge] / Bevel Gear Case Lh [Ec] [Uk] [Ge]
Carter Eixo Frente Drt [Ec] [Uk] [Ge] / Front Axle Case Rh [Ec ] [Uk] [Ge]
Carter Eixo Frente Drt [Spa] / Front Axle Case Rh [Spa]
Carter Eixo Frente Esq [Spa] / Front Axle Case Lh [Spa]
Carreto Dif Erencial Drt [Ec] [Uk] [Ge] / Differential Gear Sha Ft Rh [Ec] [Uk] [Ge]
Carreto Dif Erencial Drt [Spa] / Differential Gear Shaft Rh [Sp A]
Carreto Dif Erencial Esq [Ec] [Uk] [Ge] / Differential Gear Sha Ft Lh [Ec] [Uk] [Ge]
Carreto Dif Erencial Esq [Spa] / Differential Gear Shaft Lh [Sp A]
Eixo Frente Esq / Front Axle Lh
Tampa Coluna Direccao / Steering P Ost Cover
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção / Steering C Ontroller
Distribuidor Direcção [Peças Compo Nentes] / Steering Controller [Component Parts]
Rotula/Cilindro Direcção [Ec] [Uk] [Ge] / Tie Rod/Steering Cylinder [Ec] [Uk] [Ge]
Rotula/Cilindro Direcção [Spa] / T Ie Rod/Steering Cylinder [Spa]
Cilindro Direcção [Peças Component Es] / Steering Cylinder [Component Parts]
Bomba Hidraulico [Peças Componentes] / Hydraulic Pump [Component Pa Rts]
Tubo Oleo (Entre Ga) [Sem Travao Reboque] / Hydraulic Pipe (Delivery ) [Without Trailer Brake]
Tubo Oleo (Entre Ga) [Com Travao Reboque] / Hydraulic Pipe (Delivery ) [With Trailer Brake]
Tubo Hidraulico (Travao Reboque) [Com Travao Reboque] / Hydraulic P Ipe (Trailer Brake) [With Trailer Brake]
Tubo Oleo (Acopl Amento) [Com Travao Reboque] / Hydraulic Oil Line ( Coupler) [With Trailer Brake]
Valvula Travao R Eboque [Com Travao Reboque] / Trailer Brake Valve [ With Trailer Brake]
Circuito Oleo Di Recção (Direcção/Tdf) / Hydraulic Oil Line (Steerin G/Pto)
Circuito Oleo Di Recção (Inversor/Tdf) / Hydraulic Oil Line (Shuttle /Pto)
Tubo Direccao (E Ntrega) / Steering Hose (Delivery)
Tubo Da Saída Hi Dráulica [Sem Travao Reboque] / Hydraulic Outlet Pi Pe [Without Trailer Brake]
Tubo Da Saída Hi Dráulica [Com Travao Reboque] / Hydraulic Outlet Pi Pe [With Trailer Brake]
Caixa Cilindro H Idraulico [Com Travao Reboque] / Hydraulic Cylinder Case [With Trailer Brake]
Mangueira De Res Piro (Caixa Cilindro Hidraulico) / Breather Hose (H Ydraulic Cylinder Case)
Braco Hidraulico / Lift Arm
Valvula Seguranç A/Descarga Valvula / Safety Valve/Relief Valve
Trinco / Lowerin G Lock Lever
Suporte De Contr Olo De Posição [Ec] [Spa] [Ge] / Position Control B Racket [Ec] [Spa] [Ge]
Puxar E Posicion Ar Alavanca De Controlo / Draft And Position Contro L Lever
Veio Posicao Esf Orço / Position And Draft Shaft
Alavanca / Feed Back Lever
Válvula De Contr Olo Auxiliar / Auxiliary Control Valve
Valvula Auxiliar (Scd) [Peças Componentes] / Auxiliary Control Valv E (Scd) [Component Parts]
Valvula Auxiliar (Fd) [Peças Componentes] / Auxiliary Control Valve (Fd) [Component Parts]
Alavanca De Válv Ula De Controlo Auxiliar (2º) / Auxiliary Control V Alve Lever (2nd)
Cilindro Auxilia R De Elevacao Esq [Ec] [Ge] / 3p-Lift Assist Cylind Er Lh [Ec] [Ge]
Cilindro Auxilia R De Elevacao Esq [Spa] [Uk] / 3p-Lift Assist Cylin Der Lh [Spa] [Uk]
Cilindro Auxilia R De Elevacao Drt [Ec] [Ge] / 3p-Lift Assist Cylind Er Rh [Ec] [Ge]
Cilindro Auxilia R De Elevacao Drt [Spa] [Uk] / 3p-Lift Assist Cylin Der Rh [Spa] [Uk]
Cilindro Auxilia R De Elevacao [Peças Componentes] / 3p-Lift Assist Cylinder [Component Parts]
Parte Superior / Top Link Bracket
Ligacao Superior [Ec] [Spa] [Ge] / Top Link [E C] [Spa] [Ge]
Estabilizador / Stabilizer
Estabilizador Drt / Lift Rod Rh
Estabilizador Esq / Lift Rod Lh
Puxo Barra [Spa] / Drawbar Bracket [Spa]
Proteccao Tdf [Spa] / Pto Shaft Protector [Spa ]
Grelha Frontal / Front Grille
Capot Superior / Hood (Bonnet) Upp Er
Capot Superior (Som Absorvedor/Iso Lador) / Hood (Bonnet) (Sound Absorber/Insulator)
Suporte Capot / Hood (Bonnet) Supp Ort
Estrutura Cabine [Ec] [Spa] [Ge] / Cab Fr Ame [Ec] [Spa] [Ge]
Degrau / Step
Capot Traseira (Cabine) / Hood (Bonnet) R Ear (Cab)
Vidro Frente / Front Glass
Porta Drt / Door Rh
Porta Esq / Door Lh
Lado Vidro / Side Window
Vidro Traseiro Da Escotilha / Hatch Back Glass
Tecto Interior / Inner Roof
Tecto Abrir / Outer Roof
Składowanie Materiałów/Piso / Damp Materi Al/Floor Mat
Chapa Inspecção / Inspection Plate
Cobertura Guarda Lamas Drt / Fender Cover Rh
Cobertura Gurada Lamas Esq / Fender Cover Lh
Guarda Lamas / Fender
Suporte Cabine Frente / Cab Bracket Front
Suporte Cabine Traseira / Cab Bracket Rea R
Caixa Ferramenta / Tool Box
Ar Condicionado / Ai R Conditioner
Tubo Ar Condicionado / Air Conditioner Duct
Modo Caixa / Mode Ca Se
Entradas Ar Painel I Nstrumentos / Dashboard Air Outlets
Circulaçao Ar Interi Or / Inner Air Recirculation
Tubo Aquecimento / H Eater Hose
Condesador / Condens Er
Tubo Ar Condicionado /Tubo Condensador / Air Conditioner Hose/Condenser Hose
Compressor (Ar Condi Cionado) / Compressor (Air Conditioner)
Etiqueta (Capot) / Label (Hood (Bon Net))
Etiqueta (Cabine Interior) / Label (Cab Interior)
Etiqueta (Cabine Exterior) / Label (Cab Exterior)
Acessorios E Peças Serviço [Velho] / Accessori Es And Service Parts [Old]
Acessorios E Peças Serviço [Novo] / Accessorie S And Service Parts [New]
Panela Escape [Opçao] / Upper Muffler K It [Option]
Kit Farios Trabalho [Opção] / Working L Ight Kit [Option]
Desempanador (Vidro) [Opção] / Rear Def Ogger Kit (Glass) [Option]
Kit Limpa Vidro Traseiros [Opção] / Rea R Wiper Kit [Option]
Kit Conversao Tdf 540/1000 [Opção] / Pt O (540/1000) Conversion Kit [Option]
Kit Apoio Peso Frente [Opção] / Front B Umper Kit [Option]
Válvula De Controle Alavanca Kit (Scd) [Opção] / Auxiliary Control Valve Kit (Scd) [Option ]
Válvula De Controle Alavanca Kit (Fd) [ Opção] / Auxiliary Control Valve Kit (Fd) [Option]
Válvula De Controle Alavanca Kit (Scd/F C) [Opção] / Auxiliary Control Valve Kit (Scd/Fc) [ Option]
Válvula De Controle Alavanca Kit (Fc) [ Opção] / Auxiliary Control Valve Kit (Fc) [Option]
Válvula De Controle Alavanca Kit (Scd) [Peças Componentes] [Opção] / Auxiliary Control Val Ve (Scd) [Component Parts] [Option]
Válvula De Controle Alavanca Kit (Fc) [ Peças Componentes] [Opção] / Auxiliary Control Valv E (Fc) [Component Parts] [Option]
Auxiliar Do Alavanca De Válvula De Cont Rolo Kit (3ª) [Opção] / Auxiliary Control Valve Lev Er Kit (3rd) [Option]
Kit De Válvula Do Travão Do Reboque (Va Lvula) [Opção] / Trailer Brake Valve Kit (Valve) [O Ption]
Kit De Válvula Do Travão Do Reboque (Ac Oplamento) [Opção] / Trailer Brake Valve Kit (Coupl Er) [Option]
Kit De Válvula Do Travão Do Reboque (Tu Bo) [Opção] / Trailer Brake Valve Kit (Pipe) [Optio N]
Banco Passageiro (Banco) [Opção] / Inst Ructional Seat Kit (Seat) [Option]
Banco Passageiro (Suporte) [Opção] / In Structional Seat Kit (Bracket) [Option]
Kit De Espelho De Sala [Opção] / Room M Irror Kit [Option]
