Kubota Tractor M135GXDTSC24-3 Spare Parts Catalog EN TR
Language: English, Turkish
Region: Turkey
Model: Kubota M135GXDTSC24-3 Tractor
Number of Pages: 735 Pages
Engine 400100 Crankcase (Upper)
Engine 400200 Crankcase (Lower)
Engine 401000 Oil Pan
Engine 402000 Cylinder Head
Engine 403000 Inlet Valve And Exhaust Valve
Engine 404000 Rocker Arm Shaft
Engine 405000 Head Cover
Engine 410000 Front Cover
Engine 411000 Piston Crankshaft Piston Crankshaft
Engine 412000 Camshaft And Idle Gear Shaft
Engine 413000 Balancer
Engine 415002 Flywheel
Engine 420000 Fuel Filter
Engine 421000 Supply Pump
Engine 425000 Injector And Glow Plug
Engine 426000 0Injection Pipe
Engine 428000 Common Rail
Engine 430000 Water Flange And Thermostat
Engine 431000 Water Pump
Engine 435000 Oil Cooler
Engine 436000 Oil Separator
Engine 436300 Oil Separator Component Parts Oil
Engine 436500 Oil Separator Pipe
Engine 437000 Oil Pipe (Turbo Charger)
Engine 440002 Air Cleaner Air Cleaner
Engine 440500 Air Cleaner Component Parts
Engine 442000 Turbo Charger
Engine 443000 Inter Cooler Inter Cooler
Engine 444000 Inlet Manifold
Engine 445000 Air Cleaner Flange And Throttle Valve
Engine 446000 EGR Valve
Engine 447000 EGR Cooler
Engine 448000 EGR Water Piping
Engine 450000 Exhaust Manifold
Engine 452000 Muffler Pipe
Engine 455000 Diesel Particulate Filter Muffler
Engine 455500 Diesel Particulate Filter Muffler Component Parts
Engine 457500 Pressure Pipe
Engine 459000 Muffler Pipe (Diesel Particulate Filter)
Engine 460000 Selective Catalytic Reduction Muffler
Engine 460500 Insulation Plate (Selective Catalytic Reduction Muffler)
Engine 462000 Selective Catalytic Reduction Frame
Engine 463000 Selective Catalytic Reduction Cover
Engine 467000 Selective Catalytic Reduction Injector Cover
Engine 468000 Selective Catalytic Reduction Main Frame
Engine 470000 Diesel Exhaust Fluid Pump Diesel
Engine 471000 Diesel Exhaust Fluid Tank Diesel
Engine 471500 Diesel Exhaust Fluid Tank Component Parts
Engine 472000 Diesel Exhaust Fluid Hose
Engine 473000 EGR Valve (Selective Catalytic Reduction System)
Engine 474000 EGR Cooler (Selective Catalytic Reduction System)
Engine 475000 EGR Pipe (Selective Catalytic Reduction System)
Engine 476000 EGR Water Piping (Selective Catalytic Reduction System)
Engine 495000 Engine Electrical Parts (Sensor ECu)
Engine 496000 Engine Electrical Parts (Muffler)
Engine 497000 Injector Harness
Engine 498000 Engine Electrical Mounting Parts
Engine A01000 Hand Accelerator Lever
Engine A03000 Accelerator Pedal
Fuel System A11500 Fuel Tank Bracket
Fuel System A11700 Fuel Tank Support
Fuel System A12000 Fuel Tank Rh
Fuel System A13000 Fuel Tank Lh
Fuel System A13800 Fuel Pipe (Diesel Exhaust Fluid Breather)
Fuel System A14000 Fuel Pipe (Fuel Tank)
Fuel System A14100 Fuel Pipe (Fuel Filter)
Fuel System A14200 Fuel Pipe (Fuel Pump)
Fuel System A14300 Fuel Pipe (Fuel Tank Breather)
Fuel System A14400 Fuel Pipe (Fuel Cooler)
Fuel System A14500 Fuel Cooler
Fuel System A15100 Separator
Fuel System A16100 Separator Component Parts
Fuel System A16500 Fuel Pump Fuel Pump
Fuel System A16600 Fuel Pump Component Parts
Fuel System A17000 Fuel Filter
Fuel System A18000 Fuel Filter Component Parts
Cooling Water System A40500 Fan Bracket Fan
Cooling Water System A41000 Fan
Cooling Water System A42000 Water Pipe Water
Cooling Water System A43002 Radiator Radiator
Cooling Water System A45000 Reserve Tank Reserve
Electrical System A54000 Alternator
Electrical System A55000 Alternator Component Parts
Electrical System A56000 Starter Starter
Electrical System A57000 Starter Component Parts Starter
Electrical System A58002 Battery Battery
Electrical System B00200 Switch Sensor (Engine Lh) Switch Sensor
Electrical System B00300 Switch Sensor (Engine Rh Muffler) Switch
Electrical System B00800 Electrical Parts Cover Electrical
Electrical System B01000 Selective Catalytic Reduction Sensor (Engine) Selective
Electrical System B01100 Selective Catalytic Reduction Sensor (Body) Selective
Electrical System B01500 Switch Sensor Switch Sensor
Electrical System B02000 Switch Sensor (Front)
Electrical System B03001 Switch Sensor (Body) EC Switch Sensor
Electrical System B03002 Switch Sensor (Body) Uk Switch Sensor
Electrical System B04000 Switch Sensor (Rear) Switch Sensor
Electrical System B11000 Switch (Operation) Switch (
Electrical System B12000 Main Switch Lever Control Switch
Electrical System B13000 Relay Relay
Electrical System B13300 ECu (Engine) ECu (Engine)
Electrical System B13402 ECu (Body) ECu (Body)
Electrical System B14000 Panel Board Panel Board
Electrical System B18000 PTO Tachometer Speedmeter PTO Tachometer
Electrical System B18502 Control Panel
Electrical System B18600 Control Panel Component
Electrical System B32001 Head Light EC Head Light
Electrical System B32002 Head Light Uk Head Light
Electrical System B32101 Head Light Component Parts EC Head Light
Electrical System B32102 Head Light Component Parts Uk Head Light
Electrical System B33900 Front Combination Light Front
Electrical System B35001 Working Light (Front) EC Working
Electrical System B35002 Working Light (Front) Uk Working Light
Electrical System B35100 Work Light (Rear) Work Light
Electrical System B36000 Rear Combination Light Rear
Electrical System B37000 Trailer Socket Trailer
Electrical System B41000 Room Light Room Light
Electrical System B42100 Cd-Radio And Speaker Cd-Radio And
Electrical System B43000 Washer Tank Washer Tank
Electrical System B44000 Wiper Wiper
Electrical System B50100 Electrical Wiring (Crs) Electrical
Electrical System B50200 Electrical Wiring (Scr) Electrical
Electrical System B50300 Electrical Wiring (Engine) Electrical
Electrical System B50400 Electrical Wiring (Head Light) Electrical
Electrical System B50500 Electrical Wiring (Panel) Electrical
Electrical System B50600 Electrical Wiring (Rear) Electrical
Electrical System B50700 Electrical Wiring (3p Switch) Electrical
Electrical System B51302 Electrical Wiring (Control Panel) Electrical
Electrical System B51400 Electrical Wiring (Armrest) Electrical
Electrical System B51501 Electrical Wiring (Body) EC Electrical
Electrical System B51502 Electrical Wiring (Body) Uk Electrical
Electrical System B51600 Electrical Wiring (Front Suspension Valve) Electrical
Electrical System B52001 Electrical Wiring (Cab) EC Electrical
Electrical System B52002 Electrical Wiring (Cab) Uk Electrical
Clutch Transmission C11000 Clutch Housing
Clutch Transmission C11700 Power Shift Valve Power
Clutch Transmission C11800 Power Shift Valve (Body) Component Parts Power
Clutch Transmission C11900 Power Shift Valve (Upper) Component Parts Power
Clutch Transmission C12002 Clutch Housing Cover (Lower) Clutch
Clutch Transmission C13000 Mid Case Mid Case
Clutch Transmission C14000 Transmission Case
Clutch Transmission C15001 Transmission Case Rear Cover EC Transmission
Clutch Transmission C15002 Transmission Case Rear Cover Uk Transmission
Clutch Transmission C17100 Rear Axle Case Rh Rear Axle
Clutch Transmission C17200 Rear Axle Case Lh Rear Axle
Clutch Transmission C22000 Damper Disk Damper
Clutch Transmission C24000 Clutch Pedal Clutch
Clutch Transmission C25000 Clutch Rod Clutch
Clutch Transmission D11000 Front Cover Front
Clutch Transmission D12000 Front Bearing Support Front
Clutch Transmission D21500 Input Shaft
Clutch Transmission D21700 Shuttle Shaft Shuttle
Clutch Transmission D22000 First Second Shift Gear First
Clutch Transmission D22500 First Shaft
Clutch Transmission D23000 Third Fourth Shift Gear Third
Clutch Transmission D24000 Counter Shaft Counter
Clutch Transmission D24500 Main Gear Shift Shaft
Clutch Transmission D25000 Range Gear Shaft (Front) Range
Clutch Transmission D25100 Range Gear Shaft (Rear) Range
Clutch Transmission D25400 Drive Shaft (Front) Drive Shaft
Clutch Transmission D25500 Drive Shaft (Middle Rear) Drive
Clutch Transmission D25700 Hi-Lo Shift Case Hi-Lo Shift
Clutch Transmission D26000 Bevel Gear Bevel Gear
Clutch Transmission D26200 Rear Differential Rear
Clutch Transmission D26300 Rear Differential Lock Clutch Rear
Clutch Transmission D26500 PTO Propeller Shaft Pto
Clutch Transmission D26600 PTO Clutch
Clutch Transmission D26700 PTO Clutch Component Parts
Clutch Transmission D26800 PTO Clutch Valve PTO Clutch
Clutch Transmission D26900 PTO Clutch Valve Component Parts
Clutch Transmission D27001 PTO Drive Shaft EC PTO Drive
Clutch Transmission D27002 PTO Drive Shaft Uk PTO Drive
Clutch Transmission D27501 PTO Shaft EC PTO Shaft
Clutch Transmission D27502 PTO Shaft Uk PTO Shaft
Clutch Transmission D36002 Bi-Speed Turn Clutch (Bi-Speed Turn) Bi-Speed
Clutch Transmission D36502 Bi-Speed Turn Shaft Bi-Speed
Speed Change Shift Fork D43000 Range Gear Shift
Speed Change Shift Fork D46000 PTO Gear Shift Fork
Speed Change Shift Fork F11000 Main Gear Shift
Speed Change Shift Fork F12500 Shuttle Shift
Speed Change Shift Fork F14100 Range Gear Shift
Speed Change Shift Fork F15000 PTO Gear Shift Lever
Rear Axle Brake F18000 Rear Differential Lock Pedal Rear Differential
Rear Axle Brake F20000 Rear Axle
Rear Axle Brake F20500 Brake Brake
Rear Axle Brake F22000 Parking Brake Lever Parking Brake
Rear Axle Brake F23000 Parking Brake
Rear Axle Brake F23500 Brake Pedal
Rear Axle Brake F31500 Brake Master Cylinder Brake Master
Rear Axle Brake F32000 Master Cylinder Component Parts Master Cylinder
Rear Axle Brake F33000 Brake Pipe Brake Pipe
Rear Axle Brake F33500 Brake Master Cylinder Pipe Brake Master
Front Axle Chassis G10502 Front Axle Frame Front Axle
Front Axle Chassis G11002 Front Axle Bracket Front Axle
Front Axle Chassis G14002 Propeller Shaft Propeller
Front Axle Chassis G14200 Mid Propeller Shaft Component Parts
Front Axle Chassis G15002 Front Differential Case Front
Front Axle Chassis G16002 Bevel Gear (Front) Bevel Gear
Front Axle Chassis G17002 Differential Front Differential
Front Axle Chassis G21502 Front Differential Lock Clutch Front
Front Axle Chassis G22100 Bevel Gear Case Rh
Front Axle Chassis G22200 Bevel Gear Case Lh
Front Axle Chassis G22500 Front Axle Case
Front Axle Chassis G22700 Front Axle
Front Axle Chassis G23002 Differential Gear Shaft Differential
Steering Handle Note Order By Ref.No.070 And Fig.No.H14000 Ref.No.020 New Parts.
Steering H11300 Steering Post Cover Steering Post Cover
Steering H12300 Tilt Lever
Steering H12500 Telescope Lever
Steering H14000 Steering Controller
Steering H15000 Steering Controller Component Parts
Steering H16002 Tie Rod Steering Cylinder
Steering H16500 Steering Cylinder Component Parts
Hydraulic System J13000 Hydraulic Pump
Hydraulic System J13500 Hydraulic Pump Component Parts
Hydraulic System J16000 Regulater Valve
Hydraulic System J16500 Regulater Valve Component Parts Regulater
Hydraulic System J21000 Hydraulic Oil Line (Suction) Hydraulic
Hydraulic System J22000 Hydraulic Oil Line (Delivery) Hydraulic
Hydraulic System J23300 Front Loader Pipe Front Loader
Hydraulic System J23500 Hydraulic Oil Line Hydraulic Oil
Hydraulic System J23700 Trailer Brake Valve Trailer Brake
Hydraulic System J24000 Safety Valve Safety Valve
Hydraulic System J24500 Hydraulic Oil Line (Bi-Speed Turn Rear Diff.) Hydraulic
Hydraulic System J26002 Hydraulic Oil Line (Front Differential) Hydraulic
Hydraulic System J26500 Oil Cooler
Hydraulic System J27000 Hydraulic Oil Line (Oil Cooler) Hydraulic
Hydraulic System J27502 Hydraulic Oil Line (Steering PTO) Hydraulic
Hydraulic System J28002 Steering Hose (Delivery) Steering Hose
Hydraulic System J29300 Front Suspension Valve Front
System Hydraulic System J29401 Front Suspension Valve (Relief Check) Component Parts Front
System Hydraulic System J29402 Front Suspension Valve (Safety) Component Parts Front
System Hydraulic System J29403 Front Suspension Valve (Joint) Component Parts Front
Hydraulic System J29500 Front Suspension Valve Hose Front
Hydraulic System J29600 Front Suspension Cylinder Front
Hydraulic System J29700 Front Suspension Cylinder Component Parts Front
Hydraulic System J29800 Branch Flow Valve Branch Flow
Hydraulic System J29900 Branch Flow Valve Component Parts Branch Flow
Hydraulic System J30800 Hydraulic Cylinder Case Hydraulic
Hydraulic System J31300 Valve Valve
Hydraulic System J31400 Valve Base Valve Base
Hydraulic System J31500 Hydraulic Lift Arm Hydraulic
Hydraulic System J31900 Relief Valve Check Valve Relief Valve
Hydraulic System J32300 Lowering Lock Lever Lowering
Hydraulic System J33400 Detector Bar (Bar Bar Support) Detector Bar
Hydraulic System J33600 Detector Bar (Draft Link) Detector Bar
Hydraulic System J37800 Position Control Lever Position
Hydraulic System J41300 Auto Control Valve Auto Control
Hydraulic System J41500 Auto Control Valve Component Parts Auto Control
Hydraulic System J43200 Auxiliary Control Valve (With FC) Mounting Auxiliary
Hydraulic System J43400 Auxiliary Control Valve (With FC) Auxiliary
Hydraulic System J43501 Auxiliary Control Valve (With FC) Mounting Component Parts Auxiliary
System Hydraulic System J43502 Auxiliary Control Valve Component Parts (SCD With FC) Auxiliary
System Hydraulic System J43503 Auxiliary Control Valve Component Parts (Fd With FC) Auxiliary
System Hydraulic System J43600 Auxiliary Control Valve (With FC) Cap Reserve Tank Auxiliary
Hydraulic System J43700 Auxiliary Control Valve (With FC) Auxiliary
Hydraulic System J45600 Auxiliary Control Flow Control Wire Auxiliary
Hydraulic System J47100 3p-Lift Assist Cylinder Lh 3p-Lift Assist
Hydraulic System J47200 3p-Lift Assist Cylinder Rh 3p-Lift Assist
Hydraulic System J47300 3p-Lift Assist Cylinder Component Parts 3p-Lift Assist
3-Point Linkage Drawbar Hitch 3-Point Linkage Drawbar Hitch K10500 Top Link Bracket
3-Point Linkage Drawbar Hitch 3-Point Linkage Drawbar Hitch K11000 Top Link
3-Point Linkage Drawbar Hitch 3-Point Linkage Drawbar Hitch K12500 Lower Link
3-Point Linkage Drawbar Hitch 3-Point Linkage Drawbar Hitch K13300 Stabilizer
3-Point Linkage Drawbar Hitch 3-Point Linkage Drawbar Hitch K14000 Lift Rod Rh
3-Point Linkage Drawbar Hitch 3-Point Linkage Drawbar Hitch K14300 Lift Rod Lh
3-Point Linkage Drawbar Hitch 3-Point Linkage Drawbar Hitch L17001 Protector EC
3-Point Linkage Drawbar Hitch 3-Point Linkage Drawbar Hitch L17002 Protector Uk
Hood Bonnet M11000 Front Grille Front Grille
Hood Bonnet M12000 Hood (Bonnet) Upper Hood (Bonnet) Upper
Hood Bonnet M12100 Hood (Bonnet) (Sound Absorber Insulator) Hood (Bonnet) (
Hood Bonnet M12300 Hood (Bonnet) Damper Hood (Bonnet)
Hood Bonnet M12400 Bonnet Lock Bonnet Lock
Hood Bonnet M13700 Bonnet Frame
Hood Bonnet M14000 Bonnet Support
Hood Bonnet M15100 Hood (Bonnet) Side Lower Rh Hood (Bonnet) Side
Hood Bonnet M15200 Hood (Bonnet) Side Lower Lh Hood (Bonnet) Side
Cab N11001 Cab Frame EC Cab Frame EC
Cab N11002 Cab Frame Uk Cab Frame Uk
Cab N11700 Hood (Bonnet) Rear Hood (Bonnet) Rear
Cab N12000 Front Glass Front Glass
Cab N12500 Door Rh
Cab N13000 Door Lh
Cab N13500 Door Lock Rh
Cab N14000 Door Lock Lh
Cab N15000 Rear Window
Cab N15600 Sun Roof
Cab N15801 Rearview Mirror EC
Cab N15802 Rearview Mirror Uk
Cab N16000 Inner Roof
Cab N16500 Outer Roof
Cab N17000 Seat
Cab N17100 Seat Component Parts
Cab N17200 Armrest
Cab N17400 Instructional Seat
Cab N17500 Floor Mat
Cab N17600 Soundproof Material
Cab N17800 Seat Mat
Cab N18000 Inspection Plate (Front)
Cab N18100 Inspection Plate (Rear)
Cab N18500 Shift Cover
Cab N21500 Fender Cover Lh
Cab N22500 Fender Rh
Cab N23000 Fender Lh
Cab N24000 Cab Bracket Front
Cab N24500 Cab Bracket Rear
Cab N25000 Tool Box
Air Conditioner P11500 Air Conditioner
Air Conditioner P13800 Air Conditioner Duct Cover
Air Conditioner P13900 Air Conditioner Duct (Front)
Air Conditioner P14000 Air Conditioner Duct (Rear)
Air Conditioner P14100 Mode Case Mode Case
Air Conditioner P14300 Dashboard Air Outlets
Air Conditioner P14700 Inner Air Recirculation
Air Conditioner P15000 Heater Hose
Air Conditioner P15500 Condenser
Air Conditioner P15700 Air Conditioner Hose Condenser Hose
Air Conditioner P16000 Compressor
Labels S12000 Label (Front)
Labels S13000 Label (Rear Cab)
Labels S14000 Label (Rear Cab)
Accessories And Service Parts Parts T11000 Accessories And Service Parts
Option U13000 Working Light Kit Option
Option U13300 Working Light Kit (Rear) Option
Option U14600 Working Light Kit (Led) Option
Option U14700 Working Light Kit (Rear) (Led) Option
Option U18000 Rear Defogger Kit Option
Option U25000 Fuel Tank Cover Kit Option
Option U32100 Creep Speed Kit (Gear Case) Option
Option U32200 Creep Speed Kit (Shift Fork) Option
Option U32300 Creep Speed Kit (Lever) Option
Option U34000 PTO (540 540e) Conversion Kit (Gear) Option PTO (540 540e) Conversion
Option U71401 Auxiliary Control Valve Kit (SCD With FC) Option Auxiliary Control Valve
Option U71402 Auxiliary Control Valve Kit (Fd With FC) Option Auxiliary Control Valve
Option U71801 Auxiliary Control Valve Kit (With FC) (3rd) Option Auxiliary Control Valve
Option U71802 Auxiliary Control Valve Kit (With FC) (4th) Option Auxiliary Control Valve
Option U94700 Sunshade Shield Kit Option Sunshade Shield Kit
Region: Turkey
Cab N12500 Door Rh
Cab N13000 Door Lh
Cab N15600 Sun Roof
Cab N17000 Seat
Cab N17200 Armrest
Cab N17800 Seat Mat
Cab N25000 Tool Box
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
