Kubota Tractor M135GXDTSC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M135GXDTSC Tractor
Number of Pages: 483 Pages
Bloco Motor (Superior) [Velho] / Crankcase (Uppe R) [Old]
Bloco Motor (Superior) [Novo] / Crankcase (Upper ) [New]
Bloco Motor (Inferior) [Velho] / Crankcase (Lowe R) [Old]
Bloco Motor (Inferior) [Novo] / Crankcase (Lower ) [New]
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exha Ust Valve
Braço [Velho] / Rocker Arm Shaft [Old]
Braço [Novo] / Rocker Arm Shaft [New]
Tampa Cabeça / Head Cover
Compensador / Balancer
Volante Motor [Dtsc] / Flywheel [Dtsc]
Filtro Gasoleo / Fuel Filter
Injector E Vela Aquecimento / Injector And Glow Plug
Common Rail / Common Rail
Bomba Agua / Water Pump
Flange Filtro Ar / Air Cleaner Flange And Thrott Le Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Tubo Agua Valvula Egr / Egr Water Piping
Filtro Ar [Dtsc] / Air Cleaner [Dtsc]
Filtro Ar [Peças Componentes] / Air Cleaner [Com Ponent Parts]
Tubo Aspiracao (Filtro Ar) / Inlet Pipe (Air Cle Aner)
Panela Escape / Muffler Pipe
Tampa Tubo Colector / Muffler Pipe Cover
Silenciador Do Filtro De Partículas Diesel / Die Sel Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [Peça S Componentes] / Diesel Particulate Filter Muffler [Component Parts]
Sensor Particulas Combustivel / Muffler Sensor
Tubo Pressao / Pressure Pipe
Tubo Oleo (Turbo) / Oil Pipe (Turbo Charger)
Intercooler / Inter Cooler
Radiador Oleo / Oil Cooler
Componentes Electricos Motor / Engine Electrical Parts
Motor Elétrica Peças De Montagem / Engine Electr Ical Mounting Parts
Suporte Deposito Combustivel / Fuel Tank Bracket
Tubo Combustivel (Filtro) / F Uel Pipe (Fuel Filler)
Tubo Combustivel (Bomba) / Fu El Pipe (Fuel Pump)
Arrefecedor Gasoleo / Fuel Co Oler
Separador / Separator
Bomba Gasoleo / Fuel Pump
Bomba Gasoleo [Peças Componen Tes] / Fuel Pump [Component Parts]
Filtro Gasoleo [Peças Compone Ntes] / Fuel Filter [Component Parts]
Suporte Ventilador / Fan Bracket
Ventoinh A / Fan
Tubo Agu A / Water Pipe
Radiador [Velho] / Radiator [Old]
Radiador [Novo] / Radiator [New]
Alternador / Alternator
Alternador [Peças Compone Ntes] / Alternator [Component Parts]
Motor Arranque / Starter
Interruptor/Sensor (Maqui Na (Esq)) / Switch/Sensor (Engine Lh)
Interruptor/Sensor (Maqui Na (Drt)/Panela Escape) / Switch/Sensor (Engine Rh/ Muffler)
Componenetes Electricos Re Sguardo / Electrical Parts Cover
Interruptor/Sensor (Suspe Nsão) [Dtsc] / Switch/Sensor (Suspension) [Dtsc]
Interruptor/Sensor (Frent E) / Switch/Sensor (Front)
Interruptor/Sensor (Corpo ) / Switch/Sensor (Body)
Interruptor/Sensor (Trase Ira) / Switch/Sensor (Rear)
Interruptor / Switch (Ope Ration)
Interruptor Principal / M Ain Switch/Lever Control Switch
Rele / Relay
Unidade Control Electrico (Bloco Motor) / Electronic Control Unit (Engine)
Unidade Control Electrico (Corpo) [Dtsc] / Electronic Control Unit (Body) [D Tsc]
Painel / Panel Board
Painel Control [Dtsc] / C Ontrol Panel [Dtsc]
Painel Control [Peças Com Ponentes] / Control Panel [Component Parts]
Luzes Frente [Ec] [Velho] / Head Light [Ec] [Old]
Luzes Frente [Ec] [Novo] / Head Light [Ec] [New]
Luzes Frente [Peças Compo Nentes] [Ec] / Head Light [Component Parts] [Ec]
Luzes Frontais / Front Co Mbination Light
Luzes Trabalho (Frente) [ Ec] / Work Light (Front) [Ec]
Farois Trabalho (Traseira ) / Work Light (Rear)
Braco Traseiro / Rear Com Bination Light
Ficha Reboque / Trailer S Ocket
Luz Interior / Room Light
Radio Cd E Columnas / Cd- Radio And Speaker
Deposito Limpa Parabrisa S / Washer Tank
Escova Limpa Vidros [Velh O] / Wiper [Old]
Escova Limpa Vidros [Novo ] / Wiper [New]
Cablagem Electrica (Crs)S [Velho] / Electrical Wiring (Crs) [Old]
Cablagem Electrica (Crs) [Novo] / Electrical Wiring (Crs) [New]
Cablagem Electrica (Motor ) / Electrical Wiring (Engine)
Cablagem Eletrica (Luzes Frente) [Velho] / Electrical Wiring (Head Light) [O Ld]
Cablagem Electrica (Luzes Frente)[Velho] / Electrical Wiring (Head Light)[Ol D]
Cablagem Electrica (Luzes Frente)[Novo] / Electrical Wiring (Head Light)[New ]
Cablagem Eletrcia (Painel ) [Velho] / Electrical Wiring (Panel) [Old]
Cablagem Eletrcia (Painel ) [Novo] / Electrical Wiring (Panel) [New]
Cablagem Eletrcia (Trasei Ra) [Velho] / Electrical Wiring (Rear) [Old]
Cablagem Eletrcia (Trasei Ra) [Novo] / Electrical Wiring (Rear) [New]
Cablagem Eletrcia [Velho] / Electrical Wiring (3p Switch) [Old]
Cablagem Eletrcia [Novo] / Electrical Wiring (3p Switch) [New]
Cablagem Electrica (Paine L Contrl) [Dtsc] / Electrical Wiring (Control Panel ) [Dtsc]
Cablagem Electrica (Apoio Braço) / Electrical Wiring (Armrest)
Cablagem Electrica (Corpo ) / Electrical Wiring (Body)
Cablagem Electrica (Valvu Lasuspensao Frontal) [Dtsc] / Electrical Wiring (Fr Ont Suspension Valve) [Dtsc]
Cabalagem Eletrica (Cabin E) [Ec] / Electrical Wiring (Cab) [Ec]
Carter Embraiage M / Clutch Housing
Valvula Powershi Ft / Power Shift Valve
Valvula Powershi Ft (Corpo) [Peças Componentes] / Power Shift Valve (Body) [Component Parts]
Valvula Powershi Ft (Superior) [Peças Componentes] / Power Shift Val Ve (Upper) [Component Parts]
Carter Embraiage M [Dtsc] / Clutch Housing Cover Lower [Dtsc]
Caixa Intermedia [Velho] / Mid Case [Old]
Caixa Intermedia [Novo] / Mid Case [New]
Caixa Da Transmi Ssão [Velho] / Transmission Case [Old]
Caixa Velocidade S [Novo] / Transmission Case [New]
Carter Transmiss Ao / Transmission Case Rear Cover
Carter Eixo Tras Eiro (Drt) / Rear Axle Case Rh
Carter Eixo Tras Eiro (Esq) / Rear Axle Case Lh
Disco Amortecedo R / Damper Disk
Cobertura Fronta L / Front Cover
Suporte Carreto / Gear Support
Veio Primario / Input Shaft
Veio Inversor / Shuttle Shaft
Primeira/Segunda Mudança / First/Second Shift Gear
Primeiro Veio / First Shaft
Carreto Terceira /Quarta / Third/Fourth Shift Gear
Veio Secundario / Countershaft
Carreto Principa L E Veio Gamas Velocidades Inversor [Velho] / Main Gear Shift Shaft And Range Gear Shaft [Old]
Carreto Principa L E Veio Gamas Velocidades Inversor [Novo] / Main G Ear Shift Shaft And Range Gear Shaft [New]
Veio Gamas Veloc Idades Inversor (Frente) / Range Gear Shaft (Front)
Veio Gamas Veloc Idades Inversor (Traseira) / Range Gear Shaft (Rear )
Veio (Frente) / Drive Shaft (Front)
Veio (Meio/Trase Iro) / Drive Shaft (Middle/Rear)
Sistema Hi-Lo / Hi-Lo Shift Case
Grupo Conico / B Evel Gear
Diferencial Tras Eiro / Rear Differential
Embraiagem Bloqu Eio Diferencial Traseiro / Rear Differential Lock C Lutch
Veio Tdf / Pto P Ropeller Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf [ Peças Componentes] [Velho] / Pto Clutch [Component Parts] [Old]
Embraiagem Tdf [ Peças Componentes] [Novo] / Pto Clutch [Component Parts] [New]
Valvula Embraiag Em Tdf / Pto Clutch Valve
Valvula Embraiag Em Tdf [Peças Componentes] / Pto Clutch Valve [Comp Onent Parts]
Veio Principal T Df / Pto Drive Shaft
Veio Tdf / Pto S Haft
Embraiagem Hidra Ulica (Bi Speed) [Dtsc] / Hydraulic Clutch (Bi-Spee D Turn) [Dtsc]
Veio Bi-Speed [D Tsc] / Bi-Speed Turn Shaft [Dtsc]
Forque Ta Velocidades / Range Gear Shift Fork
Alvanc A Tdf / Pto Shift Fork
Alavan Ca Velocidades / Main Gear Shift Lever
Alvanc A Inversor / Shuttle Shift Lever
Cabo E Mbraiagem / Range Gear Shift Cable
Alavan Ca Tdf / Pto Gear Shift Lever
Pedal Bloqueio Difere Ncial Traseiro / Rear Differential Lock Pedal
Eixo Traseiro / Rear Axle Shaft
Travoes / Brake
Travao Parque / Parki Ng Brake
Pedal Travao / Brake Pedal
Cilindro Travao Princ Ipal / Brake Master Cylinder
Cilindro Travao Princ Ipal [Peças Componentes] / Brake Master Cylinder [C Omponent Parts]
Tubo Travao / Brake P Ipe
Tubo Travao / Brake M Aster Cylinder Pipe
Suporte Eixo Frente [Dtsc] [Velho] / Front Axle Frame [Dtsc] [Old]
Suporte Eixo Frente [Dtsc] [Novo] / Front Axle Frame [Dtsc] [New]
Suporte Eixo Dianteiro [Dts C] / Front Axle Bracket [Dtsc]
Veio Primario [Dtsc] / Prop Eller Shaft [Dtsc]
Veio Primario [Peças Compon Entes] [Dtsc] / Mid Propeller Shaft [Component Part S] [Dtsc]
Caixa Diferencial Dianteiro [Dtsc] / Front Differential Case [Dtsc]
Grupo Conico Frente (Frente ) [Dtsc] / Bevel Gear (Front) [Dtsc]
Diferencial Dianteiro [Dtsc ] / Differential Front [Dtsc]
Bloqueio Diferencial Frente [Dtsc] / Front Differential Lock Clutch [Dtsc]
Caixas Engrenagens Conica ( Drt) / Bevel Gear Case Rh
Caixas Engrenagens Conica ( Esq) / Bevel Gear Case Lh
Eixo Dianteiro / Front Axle
Veio Difrencial [Dtsc] / Di Fferential Gear Shaft [Dtsc]
Tampa Coluna Direccao / Steering Post Cover
Alavanca / Tilt Lever
Placa Telescopio / Telescope Lever
Distribuidor Direcção / Steering Controller
Distribuidor Direcção [Peças Componentes] / Steering Controller [Component Parts]
Rotula/Cilindro Direcção [Dtsc] / Tie Rod/S Teering Cylinder [Dtsc]
Cilindro Direcção [Peças Componentes] / Ste Ering Cylinder [Component Parts]
Bomba Hidraulico / Hydrau Lic Pump
Bomba Hidraulico [Peças C Omponentes] / Hydraulic Pump [Component Parts]
Valvula Reguladora / Regu Later Valve
Valvula Reguladora [Peças Componentes] / Regulater Valve [Component Parts]
Linha Aspiração / Hydraul Ic Pipe (Suction)
Tubo Oleo (Entrege) / Hyd Raulic Oil Line (Delivery)
Tubo Hidraulico / Hydraul Ic Oil Line
Valvula Travao Reboque / Trailer Brake Valve
Valvula Segurança / Safet Y Valve
Circuito Oleo Hidraulico / Hydraulic Oil Line (Rear Diff.)
Circuito Oleo Hidraulico (Diferencial Frente) [Dtsc] / Hydraulic Oil Line (F Ront Differential) [Dtsc]
Radiador Oleo / Oil Coole R
Circuito Oleo Radiador / Hydraulic Oil Line (Oil Cooler)
Circuito Oleo Direcção (D Ireccao/Tdf) [Dtsc] / Hydraulic Oil Line (Steering/ Pto) [Dtsc]
Tubo Direccao (Entrega) [ Dtsc] / Steering Hose (Delivery) [Dtsc]
Valvulasuspensao Frontal [Dtsc] / Front Suspension Valve [Dtsc]
Valvula Suspensao Frontal [Peças Componentes] [Dtsc] / Front Suspension Valv E (Relief/Check) [Component Parts] [Dtsc]
Valvula Suspensao Frontal [Peças Componentes] [Dtsc] / Front Suspension Valv E (Safety) [Component Parts] [Dtsc]
Valvula Suspensao Frontal [Peças Componentes] [Dtsc] / Front Suspension Valv E (Joint) [Component Parts] [Dtsc]
Tubo Valve Suspensao Fren Te [Dtsc] / Front Suspension Valve Hose [Dtsc]
Cilindro Suspensao Fronta L [Dtsc] / Front Suspension Cylinder [Dtsc]
Cilindro Suspensao Fronta L [Peças Componentes] [Dtsc] / Front Suspension Cyl Inder [Component Parts] [Dtsc]
Valvula [Dtsc] / Branch F Low Valve [Dtsc]
Valvula [Peças Componente S] [Dtsc] / Branch Flow Valve [Component Parts] [Dt Sc]
Caixa Valvula Hidraulico / Hydraulic Valve Case
Valvula Base / Valve
Base Valvula / Valve Base
Hidraulico Braços / Hydra Ulic Lift Arm
Valvula Descarga / Relief Valve/Check Valve
Trinco / Lowering Lock Le Ver
Barra Deflectora (Suport E) / Detector Bar (Bar/Bar Support)
Barra Deflectora / Detect Or Bar (Draft Link)
Alavanca Control Posicao / Position Control Lever
Valvula Contol Automatico / Auto Control Valve
Valvula Control Automatic O [Peças Componentes] / Auto Control Valve [Compone Nt Parts]
Distribuidor Auxiliar / A Uxiliary Control Valve
Valvula Auxiliar (Scd) [P Eças Componentes] / Auxiliary Control Valve (Scd) [ Component Parts]
Valvula Auxiliar (Fd) [Pe Ças Componentes] / Auxiliary Control Valve (Fd) [Co Mponent Parts]
Alavanca Valvula Auxiliar / Auxiliary Control Valve Lever
Cilindro Auxiliar De Elev Acao (Esq) / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De Elev Acao (Drt) / 3p-Lift Assist Cylinder Rh
Cilindro Auxiliar De Elev Acao [Peças Componentes] [Velho] / 3p-Lift Assist C Ylinder [Component Parts] [Old]
Cilindro Auxiliar De Elev Acao [Peças Componentes] [Novo] / 3p-Lift Assist Cy Linder [Component Parts] [New]
Part E Superior / Top Link Bracket
Liga Cao Superior / Top Link
Liga Cao Inferior / Lower Link
Esta Bilizador / Stabilizer
Esta Bilizador (Drt) / Lift Rod Rh
Esta Bilizador (Esq) / Lift Rod Lh
Prot Eccao Tdf / Pto Protector
Grelha Frontal [Velho] / Front Grille [Old]
Grelha Frontal [Novo] / Front Grille [New]
Capot [Velho] / Hood (Bonnet) [Old]
Capot [Novo] / Hood (Bonnet) [New]
Capot (Absorvente Sao/Isolador) [Velho] / H Ood (Bonnet) (Sound Absorber/Insulator) [Old]
Capot (Absorvente Sao/Isolador) [Novo] / Ho Od (Bonnet) (Sound Absorber/Insulator) [New]
Trico Capot [Velho] / Bonnet Lock [Old]
Trico Capot [Novo] / Bonnet Lock [New]
Estrutura Capot [Velho] / Bonnet Frame [Old ]
Estrutura Capot [Novo] / Bonnet Frame [New]
Capot Inferior (Direito) / Hood (Bonnet) Si De Lower Rh
Capot Inferior (Esquerdo) / Hood (Bonnet) S Ide Lower Lh
Para Brisas / Front Glass
Porta (Drt) / Door Rh
Porta (Esq) / Door Lh
Trinco Porta (Drt) / Door Lock Rh
Trinco Porta (Esq) / Door Lock Lh
Vidro Traseiro (Superior) / Rear Window (Upper)
Tejadilho / Sun Roof
Espelho Retrovisor [Ec] [Velho] / Rearview Mirror [Ec] [Old]
Espelho Retrovisor [Ec] [Novo] / Rearview Mirror [ Ec] [New]
Tecto Interior [Velho] / Inner Roof [Old]
Tecto Interior [Novo] / Inner Roof [New]
Tejadilho Exterior / Outer Roof
Banco / Seat
Banco [Peças Componentes] / Seat [Component Parts] [Old]
Banco [Peças Componentes] / Seat [Component Parts] [New]
Apoio Braço / Armrest
Piso / Floor Mat
Isolante / Soundproof Material
Chapa Inspecção (Frente) / Inspection Plate (Front )
Chapa Inspecção (Traseira) / Inspection Plate (Rea R)
Tampa / Shift Cover
Cobertura Gurada Lamas (Esq) / Fender Cover Lh
Guarda Lamas (Drt) / Fender Rh
Guarda Lamas (Esq) / Fender Lh
Suporte Cabine (Dianteiro) / Cab Bracket Front
Suporte Cabine (Traseiro) / Cab Bracket Rear
Caixa Ferramenta / Tool Box
Air Condicionado / Air Condi Tioner
Cuberto Tubo Air Condicionad O / Air Conditioner Duct Cover
Tubo Ar Condicionado (Diante Iro) / Air Conditioner Duct (Front)
Tubo Ar Condicionado (Trasei Ro) / Air Conditioner Duct (Rear)
Modo Caixa / Mode Case
Entradas Ar Painel Instrumen Tos / Dashboard Air Outlets
Circulaçao Ar Interior / Inn Er Air Recirculation
Tubo Aquecimento / Heater Ho Se
Condesador / Condenser [Old]
Condesador / Condenser [New]
Tubo Ar Condicionado/Tubo Co Ndensador / Air Conditioner Hose/Condenser Hose
Compressor / Compressor
Etiqueta (Parte Traseira/Cab) / Label (Rear/ Cab)
Acessorios / Accessories
Kit Farios Trabalho [Opção] / Working Light Kit [Option]
Kit Farios Trabalho (Trseiros) [Opção] / Working Light (Rear) Kit [Option]
Desempanador [Opção] / Rear Defogger Kit [Option ]
Escova Limpa Vidro Frontal [Opção] / Front Wiper Kit [Option]
Kit Fusivel [Opção] / Fuse Kit [Option]
Kit Cobertuta Deposito Gasoleo [Opção] / Fuel Ta Nk Cover Kit [Option]
Kit Caixa Crepper [Opção] / Creep Speed Kit (Gea R Case) [Option]
Forqueta Caixa / Creeper [Opção] / Creep Speed K It (Shift Fork) [Option]
Alavanca Caixa Creper [Opção] / Creep Speed Kit (Lever) [Option]
Kit Conversao Tdf 540/540e (Engrenagem) [Opção] / Pto (540/540e) Conversion Kit (Gear) [Option]
Kit Conversao Tdf 540/1000 (Engrenagem Box) [Opç Ão] / Pto(540/1000) Conversion Kit (Gear Case) [Opt Ion]
Kit Conversao Tdf 540/1000 (Engrenagem) [Opção] / Pto(540/1000) Conversion Kit (Gear) [Option]
Kit Valvula Control Auxiliar (Scd) [Opção] / Aux Iliary Control Valve Kit (Scd) [Option]
Kit Valvula Control Auxiliar (Fd) [Opção] / Auxi Liary Control Valve Kit (Fd) [Option]
Kit Valvula Control Auxiliar (Fc) [Opção] / Auxi Liary Control Valve Kit (Fc) [Option]
Kit Valvula Control Auxiliar (Scd/Fc) [Opção] / Auxiliary Control Valve Kit (Scd/Fc) [Option]
Kit Distribuidor Serviços Externos (Scd/Fc)[Peça S Componentes] [Opção] / Auxiliary Control Valve (S Cd/Fc) [Component Parts] [Option]
Kit Distribuidor Serviços Externos (Fc) [Peças C Omponentes] [Opção] / Auxiliary Control Valve (Fc) [Component Parts] [Option]
Kit Alavanca Serviços Externos (Terceiro) [Opção ] / Auxiliary Control Valve Lever Kit (3rd) [Option ]
Kit Alavanca Serviços Externos (Quatra) [Opção] / Auxiliary Control Valve Lever Kit (4th) [Option]
Kit Alavanca Serviços Externos (Primeiro) [Opção ] / Auxiliary Control Valve (With Fc) Mounting Kit (1st) [Option]
Kit Alavanca Serviços Externos (Segundo) [Opção] / Auxiliary Control Valve (With Fc) Mounting Kit ( 2nd) [Option]
Kit Serviços Externos (Scd/Fc) [Opção] / Auxilia Ry Control Valve Kit (Scd With Fc) [Option]
Kit Serviços Externos (Fd/Fc) [Opção] / Auxiliar Y Control Valve Kit (Fd With Fc) [Option]
Kit Serviços Externos (Fc) [Peças Componentes] [ Opção] / Auxiliary Control Valve (With Fc) (Mountin G) [Component Parts] [Option]
Kit Serviços Externos (Scd/Fc) [Peças Componente S] [Opção] / Auxiliary Control Valve (Scd With Fc) [Component Parts] [Option]
Kit Serviços Externos (Fd/Fc) [Peças Componentes ] [Opção] / Auxiliary Control Valve (Fd With Fc) [C Omponent Parts] [Option]
Kit Alavanca Serviços Externos (Fc) (Terceiro) [ Opção] / Auxiliary Control Valve Lever Kit (With Fc ) (3rd) [Option]
Kit Alavanca Serviços Externos (Fc) (Quatra) [Op Ção] / Auxiliary Control Valve Lever Kit (With Fc) (4th) [Option]
Kit De Tampas Do Acoplador Da Válvula De Control O Auxiliar [Opção] / Auxiliary Control Valve Couple R Cap Kit [Option]
Capot (Capa Superior) [Opção] / Bonnet Kit (Hood (Bonnet)) [Option]
Capot (Prato) [Opção] / Bonnet Kit (Shutter Plat E) [Option]
Capot (Cablagem Electrica) [Opção] / Bonnet Kit (Electrical Wiring) [Option] [Old]
Capot (Cablagem Electrica) [Opção] / Bonnet Kit (Electrical Wiring) [Option] [New]
Capot (Grelha Frontal) [Opção] / Bonnet Kit (Fro Nt Grille) [Option]
Capot (Absorvente Sao/Isolador) [Opção] / Bonnet Kit (Sound Absorber/Insulator) [Option] [Old]
Capot (Absorvente Sao/Isolador) [Opção] / Bonnet Kit (Sound Absorber/Insulator) [Option] [New]
Capot (Trico Capot) [Opção] / Bonnet Kit (Bonnet Lock) [Option]
Capot (Estrutura Capot) [Opção] / Bonnet Kit (Bo Nnet Frame) [Option]
Protetor De Para-Sol [Opção] / Sunshade Shield K It [Option]
