Kubota Tractor M135GXDTSC-2 Spare Parts Catalog EN TR
Language: English, Turkish
Region: Turkey
Model: Kubota M135GXDTSC-2 Tractor
Number of Pages: 826 Pages
Engine 300100 Engine Block (Upper) Crankcase (Upper)
Engine 300200 Engine Block (Lower) Crankcase (Lower)
Engine 301000 Oil Pan
Engine 302000 Cylinder Head Note 150 And 160 Note Order
Engine 303000 Inlet Valve And Exhaust Valve
Engine 304000 Rocker Arm Shaft
Engine 305000 Head Cover
Engine 310000 Front Cover
Engine 311000 Piston And Crankshaft
Engine 312000 Camshaft And Idle Gear
Engine 313000 Balancer
Engine 315002 Flywheel
Engine 320500 Feed Pump Supply Pump
Engine 331000 Fuel Filter
Engine 340200 Injector And Glow Plug
Engine 345000 Injection Pipe
Engine 348000 Common Rail
Engine 360000 Thermostat Water Flange And Thermostat
Engine 361000 Water Pump
Engine 371000 Inlet Manifold
Engine 371200 Air Filter Flange And Throttle Valve And
Engine 372000 Exhaust Manifold
Engine 372200 EGR Valve
Engine 372300 EGR Cooler
Engine 372500 EGR Water Pipe System EGR Water Piping
Engine 372600 Turbocharge Turbo Charger
Engine 373002 Air Cleaner
Engine 373500 Air Cleaner Component Parts
Engine 374500 Inlet Pipe (Air Cleaner)
Engine 375500 Sound Absorber Pipe Muffler Pipe
Engine 376000 Intake Pipe Cover Muffler Pipe Cover
Engine 378000 Diesel Part Filter Absorber Diesel Particulate Filter
Engine 378200 Diesel Particulate Filter Absorber Component Parts Filter
Engine 378400 Absorber Sensor Muffler Sensor
Engine 378600 Pressure Pipe
Engine 380000 Oil Pipe (Turbo Charger)
Engine 381000 Inter Cooler Inter Cooler
Engine 382000 Oil Cooler
Engine 395002 Engine Electrical Parts Engine Electrical Parts
Engine 395200 Injector Harness
Engine 397000 Engine Electrical Mounting PartsMounting
Engine A01000 Accelerator Lever
Engine A03000 Accelerator Pedal
Fuel System A11000 Fuel Tank Old Fuel Tank Old Chassis No. 86757 S.No. 86757
Fuel System A11001 Fuel Tank New Fuel Tank New Chassis No. 86758 S.No. 86758
Fuel System A11500 Fuel Tank Bracket
Fuel System A14100 Fuel Pipe (Fuel Filter) Fuel Pipe (Fuel
System Fuel System A14200 Fuel Pipe (Fuel Pump) Old Fuel Pipe (Fuel Pump) Old Chassis No. 86757
System Fuel System A14201 Fuel Pipe (Fuel Pump) New Fuel Pipe (Fuel Pump) New Chassis No. 86758
Fuel System A14400 Fuel Pipe (Fuel Cooler) Old Fuel Pipe (Fuel Cooler) Old Chassis No.
Fuel System A14401 Fuel Pipe (Fuel Cooler) New Fuel Pipe (Fuel Cooler) New Chassis No.
Fuel System A14500 Fuel Cooler
Fuel System A15100 Separator
Fuel System A16100 Separator Component Parts
Fuel System A16500 Fuel Pump Fuel Pump
Fuel System A16600 Fuel Pump Component Parts Fuel Pump
Fuel System A17000 Fuel Filter
Fuel System A18000 Fuel Filter Component Parts
Cooling Water System A40500 Fan Bracket Fan Bracket
Cooling Water System A41000 Fan
Cooling Water System A42000 Water Pipe
Cooling Water System A43001 Radiator
Cooling Water System A45000 Reserve Tank Reserve
Electrical System A54000 Alternator
Electrical System A55000 Alternator Component Parts
Electrical System A56000 Starter
Electrical System A57000 Starter Component Parts
Electrical System A58000 Battery
Electrical System B00200 Switch Sensor (Engine Left Side) Switch
Electrical System B00300 Switch Sensor (Engine Right Side) Switch Sensor
Electrical System B00800 Electrical Part Cover Electrical
Electrical System B01500 Switch Sensor (Suspension)
Electrical System B02000 Switch Sensor (Front)
Electrical System B03001 Switch Sensor (Body)
Electrical System B04000 Switch Sensor (Rear) Switch Sensor
Electrical System B11000 Switch (Use) Switch (Operation)
Electrical System B12000 Main Switch Lever Control Switch
Electrical System B13001 Relay
Electrical System B13300 ECu (Engine) ECu (Engine)
Electrical System B13402 Electronic Control Unit (Body) ECu
Electrical System B14000 Dashboard Panel Board
Electrical System B18000 PTO Revolution Indicator Speed Indicators Pto
Electrical System B18502 Control Panel Panel
Electrical System B18600 Control Panel Component Panel
Electrical System B32001 Exterior Lighting EC Head Light
Electrical System B32002 Exterior Lighting Uk Head Light
Electrical System B32003 Exterior Lighting Tur Head Light
Electrical System B32101 Exterior Lighting Component Parts EC Head Light
Electrical System B32102 Exterior Lighting Component Parts Uk Head Light
Electrical System B32103 Exterior Lighting Component Parts Tur Head Light
Electrical System B33900 Front Combination Headlight Front Combination
Electrical System B35001 Work Lighting Flashlight (Front) EC Work
Electrical System B35002 Work Lighting Flashlight (Front) Uk Work
Electrical System B35003 Work Lighting Flashlight (Front) Tur Work
Electrical System B35100 Work Light (Rear) Work Light (
Electrical System B36000 Rear Combination Headlight
Electrical System B37000 Trailer Socket
Electrical System B41000 Indoor Room Light
Electrical System B42100 Cd-Radio And Speaker Cd-Radio And
Electrical System B43000 Washer Tank Washer Tank
Electrical System B44001 Wiper Old Chassis No. 86409 S.No. 86409
Electrical System B44002 Wiper New Wiper New Chassis No. 86410 S.No. 86410
Harness (Crs) Old Electrical Wiring (Crs) Old Chassis No. 86061 Note Order Fig.No.B50102-010 And Fig.No.B50400-
Old Electrical Wiring (Crs) Old Chassis No.86062to86409 Note Order 1 Fig.No.B50103-010, 2 Fig.No.B50104-
Electrical System B50105 Wire Harness (Crs) New Electrical Wiring (Crs) New Chassis No. 86410
Electrical System B50301 Wire Harness (Motor) Electrical Wiring
Electrical System B50400 Electrical Cables (Outdoor Lighting) Electrical
Harness (Panel) Old Electrical Wiring (Panel) Old Chassis No. 86464 Note 010 And Fig.No.B50700-
Electrical System B50502 Wire Harness (Panel) New Electrical Wiring (Panel) New Chassis No.
Harness (Rear) Old Electrical Wiring (Rear) Old Chassis No. 86464 Note 010 And Fig.No.B50700-
Electrical System B50602 Wire Harness (Rear) New Electrical Wiring (Rear) New Chassis No.
Electrical System B50700 Wire Harness (Key) Electrical Wiring
Electrical System B51302 Electrical Cables (Control Panel) Electrical
Electrical System B51400 Electrical Cables (Armrest) Electrical
Electrical System B51501 Electrical Cables (Body) Electrical
Electrical System B51600 Wire Harness (Front Suspension Valve) Electrical Wiring
Electrical System B52001 Wire Harness (Cabin) EC Electrical Wiring
Electrical System B52002 Wire Harness (Cabin) Uk Electrical Wiring
Electrical System B52003 Wire Harness (Cabin) Tur Electrical Wiring
Clutch Gear Clutch Transmission C11001 Clutch Housing
Clutch Gear Clutch Transmission C11700 Valve Power Shift Power Shift
Clutch Gear Clutch Transmission C11800 Valve Power Shift (Frame) Component Parts Power Shift
Clutch Gear Clutch Transmission C11900 Valve Power Shift (Upper) Component Parts Power Shift
Clutch Gear Clutch Transmission C12003 Clutch Housing Cover (Lower) Clutch Housing
Clutch Gear Clutch Transmission C13000 Center Box Mid Case
Clutch Gear Clutch Transmission C14000 Transmission Box Transmission
Clutch Gear Clutch Transmission C15001 Gear Housing Rear Cover Transmission
Clutch Gear Clutch Transmission C17100 Rear Axle Housing Right Side Rear
Clutch Gear Clutch Transmission C17200 Rear Axle Housing Left Side Rear
Clutch Gear Clutch Transmission C22000 Damper Disc Damper Disc
Clutch Gear Clutch Transmission C24000 Clutch Pedal
Clutch Gear Clutch Transmission C25000 Clutch Rod
Clutch Gear Clutch Transmission D11000 Front Cover
Clutch Gear Clutch Transmission D12000 Support Gear Support
Clutch Gear Clutch Transmission D21500 Input Shaft
Clutch Gear Clutch Transmission D21700 Shuttle Shaft
Clutch Gear Clutch Transmission D22000 First Second Gear Transmission
Clutch Gear Clutch Transmission D22500 First Shaft
Clutch Gear Clutch Transmission D23000 Third Fourth Gear Transmission Third
Clutch Gear Clutch Transmission D24000 Counter Shaft
D24500 Main Transmission Shift Shaft And Range Shaft Transmission Old Main Gear Shift Shaft And Range
D24501 Main Transmission Shift Shaft And Range Shaft Transmission New Main Gear Shift Shaft Range Gear
Clutch Gear Clutch Transmission D25000 Shift Range Shaft (Front) Range Gear
Rear) Old Range Gear Shaft (Rear) Old Chassis No. 86620 Not 020,060,140 And Fig.No.D26000
Clutch Transmission D25102 Gear Range Shaft (Rear) New Range Gear Shaft (Rear) New Chassis
Clutch Gear Clutch Transmission D25400 Shaft Drive (Front) Drive Shaft (
Clutch Gear Clutch Transmission D25501 Shaft Drive (Center Rear) Drive Shaft (
Clutch Gear Clutch Transmission D25700 High-Low Gear Housing Hi-Lo
D26000 Bevel Gear Not 010 And Fig.No.D25100 Ref.No.020,060,140
Clutch Gear Clutch Transmission D26200 Rear Differential
Clutch Gear Clutch Transmission D26300 Rear Differential Lock Clutch Rear
Clutch Gear Clutch Transmission D26500 PTO Propeller Shaft
Clutch Gear Clutch Transmission D26600 PTO Clutch
Clutch Gear Clutch Transmission D26700 PTO Clutch Component Parts
Clutch Gear Clutch Transmission D26800 PTO Clutch Valve PTO Clutch
Clutch Gear Clutch Transmission D26900 PTO Clutch Valve Component Parts
Clutch Gear Clutch Transmission D27000 PTO Drive Shaft PTO Drive Shaft
Clutch Gear Clutch Transmission D27500 PTO Shaft
Clutch Gear Clutch Transmission D36002 Clutch Hydraulic Hydraulic Clutch (Bi-
Clutch Gear Clutch Transmission D36502 Hydraulic Shaft Bi-Speed Turn
Speed Change Shift Fork D43000 Range Transmission
Gear Speed Change Shift Fork D46000 PTO Transmission
Gear Speed Change Shift Fork F11000 Main Gear
Speed Change Shift Fork F12501 Transmission Shuttle
Speed Change Shift Fork F14100 Gear Range
Speed Change Shift Fork F15001 PTO Transmission
Rear Axle Brake F18000 Rear Differential Lock Pedal Rear Differential
Rear Axle Brake F20000 Rear Axle Shaft
Rear Axle Brake F20500 Brake
Rear Axle Brake F22000 Parking Brake Lever
Rear Axle Brake F23000 Parking Brake Parking Brake
Rear Axle Brake F23500 Brake Pedal
Rear Axle Brake F31500 Brake Master Cylinder Brake Master
Rear Axle Brake F32000 Brake Master Cylinder Component Parts Brake Master
Rear Axle Brake F33000 Brake Pipe Brake Pipe
Rear Axle Brake F33500 Brake Master Cylinder Pipe Brake Master
Front Axle Chassis G10502 Front Axle Frame Front Axle
Front Axle Chassis G11003 Front Axle Body Bracket Front Axle
Front Axle Chassis G14002 Propeller Shaft
Front Axle Chassis G14200 Center Propeller Shaft Component Parts Mid Propeller
Front Axle Chassis G15002 Front Differential Housing Front
Front Axle Chassis G16002 Sloping Transmission (Front) Bevel Gear (
Front Axle Chassis G17002 Front Differential Differential
Front Axle Chassis G21502 Front Differential Lock Clutch Front Differential
Front Axle Chassis G22101 Sloping Transmission Housing (Right Side) Bevel
Front Axle Chassis G22201 Sloping Transmission Housing (Left Side) Bevel
Front Axle Chassis G22500 Front Axle Housing Front Axle
Front Axle Chassis G22701 Front Axle
Front Axle Chassis G23000 Differential Transmission Shaft Differential
Steering Handle Not 070 And Fig.No.H14000 Ref.No.020
Steering H11300 Steering Part Cover Steering Post Cover
Steering H12300 Tilt Lever
Steering H12500 Telescopic Lever Telescope Lever
Steering H14000 Steering Control Steering Controller
Steering H15000 Steering Control Component Parts Steering Controller
Steering H16002 Tie Rod Steering Cylinder
Steering H16500 Steering Cylinder Component Parts
Hydraulic System J13000 Hydraulic Pump
Hydraulic System J13500 Hydraulic Pump
Hydraulic System J16000 Regulator Valve Regulator Valve
Hydraulic System J16500 Regulator Valve Component Parts Regulater Valve
Hydraulic System J21000 Hydraulic Oil Line (Suction) Hydraulic Pipe
Hydraulic System J22000 Hydraulic Oil Line (Feed) Oil
Hydraulic System J23500 Hydraulic Oil Line
Hydraulic System J23700 Trailer Brake Valve Trailer Brake
Hydraulic System J24000 Safety Valve Safety Valve
Hydraulic System J24500 Hydraulic Oil (Rear Differential) Hydraulic Oil
Hydraulic System J26003 Hydraulic Oil (Front Differential) Hydraulic Oil Line
Hydraulic System J26500 Pipe Oil Cooler
Hydraulic System J27001 Hydraulic Oil Line (Oil Cooler) Old Hydraulic Oil Line (Oil Cooler) Old
Hydraulic System J27002 Hydraulic Oil (Oil Cooler) New Hydraulic Oil Line (Oil Cooler) New Chassis
Hydraulic System J27502 Hydraulic Pipe (Steering,PTO) Hydraulic Oil
Hydraulic System J28002 Steering Hose Steering Hose (
Hydraulic System J29300 Front Suspension Valve Front Suspension
Hydraulic System J29401 Front Suspension Valve (Relief Control) Component Parts Front
Hydraulic System J29402 Front Suspension Valve (Safety) Component Parts Front Suspension
Hydraulic System J29403 Front Suspension Valve (Combined) Component Parts Front Suspension
Hydraulic System J29500 Front Suspension Valve Hose Front Suspension
Hydraulic System J29600 Front Suspension Cylinder Front Suspension
Hydraulic System J29700 Front Suspension Cylinder Component Parts Front Suspension
Hydraulic System J29800 Auxiliary Flow Valve Branch Flow
Hydraulic System J29900 Auxiliary Flow Valve Component Parts Branch Flow
Hydraulic System J30800 Hydraulic Cylinder Housing Hydraulic
Hydraulic System J31300 Valve Valve
Hydraulic System J31400 Valve Base
Hydraulic System J31500 Hydraulic Piston Lifting Arm Hydraulic
Hydraulic System J31900 Relief Valve Control Valve Relief Valve
Hydraulic System J32301 Lowering Adjustment Valve Lowering Lock
Hydraulic System J33400 Detector Lever (Bar Support) Detector Bar (
Hydraulic System J33600 Detector Lever (Link) Detector Bar (
Hydraulic System J37800 Position Control Lever Position Control
Hydraulic System J41300 Automatic Control Valve Auto Control
Hydraulic System J41500 Automatic Control Valve Component Parts Auto Control
Hydraulic System J43200 Spare Control Valve (FC) Mounting Base Auxiliary Control
Hydraulic System J43400 Spare Control Valve (FC) Auxiliary Control
Hydraulic System J43501 Spare Control Valve (FC) Component Parts Auxiliary Control Valve
Hydraulic System J43502 Spare Control Valve (FC With SCD) Component Parts Auxiliary Control
Hydraulic System J43503 Spare Control Valve (FC With Fd) Component Parts Auxiliary Control
Hydraulic System J43600 Spare Control Valve (FC) Cover Spare Tank Auxiliary Control
Hydraulic System J43701 Spare Control Valve (FC) Lever Auxiliary Control
Hydraulic System J47100 3p-Left Lift Support Cylinder 3p-Lift Assist
Hydraulic System J47200 3p-Right Lift Support Cylinder 3p-Lift Assist
Hydraulic System J47300 3p-Lift Support Cylinder Component Parts 3p-Lift Assist
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K10500 Top Link Bracket
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K11000 Top Link
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K12500 Bottom Link
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K13300 Stabilizer
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K14000 Right Draw Shaft
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K14300 Left Draw Shaft
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L17000 PTO Protector
Hood Bone M11000 Front Grille
Hood Bone M12000 Hood (Bonnet)
Hood Bone M12100 Hood (Bonnet) (Sound)
Hood Bone M12300 Hood (Bonnet) Damper
Kaput Bone Hood Bonnet M12400 Bone Lock Bonnet Lock
Kaput Bone Hood Bonnet M13700 Bone Frame Bonnet Frame
Hood Bone M14001 Bone Support Hood (Bonnet) Support
Bonnet Bone Hood Bonnet M15100 Bone Side Cover Right Side Hood (Bonnet) Side
Bonnet Bone Hood Bonnet M15200 Bone Side Cover Left Side Hood (Bonnet) Side
Cab N11001 Cab Frame Cab Frame
Cab N11700 Bonnet (Bonnet) Rear Hood (Bonnet) Rear
Cab N12000 Windshield Front Glass
Cab N12500 Door Right Side Door Rh
Cab N13000 Door Left Side Door Lh
Cab N13500 Door Lock Right Side Door Lock Rh
Cab N14000 Door Lock Left Side Door Lock Lh
Cab N15000 Rear Window (Upper) Rear Window (Upper)
Cab N15600 Sunroof Sun Roof
Cab N15802 Rearview Mirror Uk
Cab N15803 Rearview Mirror Tur Rearview Mirror Tur
Cab N16000 Inner Ceiling Inner Roof
Cab N16501 Outer Ceiling Outer Roof
Cab N17000 Seat
Cab N17100 Seat Component Parts
Cab N17200 Armrest
Cab N17400 Instructional Seat
Cab N17500 Floor Mat
Cab N17600 Soundproof Material
Cab N18000 Inspection Plate (Front)
Cab N18100 Inspection Plate (Rear)
Cab N18500 Sliding Cover Shift Cover
Cab N21500 Fender Cover Left Side Fender Cover Lh
Cab N22500 Fender Rh
Cab N23000 Fender Lh
Cab N24000 Cab Bracket Front
Cab N24500 Cab Bracket Rear
Cab N25000 Tool Box
Air Conditioner P11500 Air Conditioner
Air Conditioner P13800 Air Conditioner Tube Cover Air Conditioner Duct
Air Conditioner P13900 Air Conditioning Tube (Front) Air Conditioner Duct (
Air Conditioning Air Conditioner P14000 Air Conditioning Tube (Rear) Air Conditioner Duct
Air Conditioning Air Conditioner P14100 Mode Case
Air Conditioning Air Conditioner P14300 Air Outlets Indicator Dashboard Air
Air Conditioning Air Conditioner P14700 Inner Air Recirculation
Air Conditioning Air Conditioner P15000 Heater Hose
Air Conditioning Air Conditioner P15500 Condenser
Air Conditioning Air Conditioner P15700 Air Conditioning Hose Condenser Hose Air Conditioner
Air Conditioning Air Conditioner P16000 Compressor Air Conditioner Compressor
Labels S12001 Label (Front) EC Uk Label (Front) EC Uk
Labels S12002 Label (Front) Tur Label (Front) Tur
Labels S13000 Label (Back) Label (Rear)
Labels S14000 Label (Rear Cab)
Accessories Service Parts Accessories And Service Parts T11000 Accessories Service Parts Accessories
Option U13000 Working Light Kit Option
Option U13300 Working Light Kit (Rear) Option
Option U18000 Rear Defogger Kit Option Rear Defogger Kit
Option U18800 Front Wiper Kit (Option) Front Wiper Kit Option Chassis No. 86409 S.No.
Option U19200 Fuse Kit Option Fuse Kit Option
Option U25000 Cover Tank Fuel Kit Option Fuel Tank Cover Kit
Option U32100 Low Speed Kit (Gearbox) Option Creep Speed Kit (Gear
Option U32200 Low Speed Kit (Shift Fork) Option Creep Speed Kit (Shift
Option U32300 Low Speed Kit (Lever) Option Creep Speed Kit (Lever)
Transmission Clutch Replacement Kit (Clutch) Option Main Gear Shift Clutch Replacement Kit (Clutch)
Transmission Clutch Replacement Kit (Support) Option Main Gear Shift Clutch Replacement Kit (Support)
Option U34000 PTO (540 540e) Conversion Kit (Gear) Option PTO (540 540e) Conversion
Option U35001 PTO (540 1000) Conversion Kit (Gearbox) Option PTO (540 1000) Conversion
Option U35100 PTO (540 1000) Conversion Kit (Gear) Option Pto(540 1000) Conversion
Option U55200 80 Gear Kit Option 80 Inch Tread Kit Option
Option U65000 Oil Lubrication Pipe Kit Option Oil Lubrication Pipe Kit Option Chassis No. 86494 S.
Option U71401 Auxiliary Control Valve Coupler (FC With SCD) Option Auxiliary Control
Option U71402 Auxiliary Control Valve Coupler (FC With Fd) Option Auxiliary Control
Option U71801 Spare Control Valve Lever Kit (FC With) (3) Option Auxiliary Control Valve
Option U71802 Spare Control Valve Lever Kit (FC With) (4) Option Auxiliary Control Valve
Option U94700 Sunshade Shield Kit Option Sunshade Shield Kit
Region: Turkey
Cab N17000 Seat
Cab N17200 Armrest
Cab N25000 Tool Box
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
