Kubota Tractor M135GXDTSC-2 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M135GXDTSC-2 Tractor
Number of Pages: 457 Pages
Itens Uso Frequen Te / Frequently Used Items
Bloco Motor (Superior) / Crankcase (Upper)
Bloco Motor (Inferior) / Crankcase (Lower)
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Ex Haust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Arvore Cames E Veio / Camshaft And Idle Gear S Haft
Compensador / Balancer
Volante Motor / Flywheel
Filtro Gasoleo / Fuel Filter
Injector E Vela Aquecimento / Injector And Glo W Plug
Common Rail / Common Rail
Bomba Agua E Termostacto / Water Flange And Th Ermostat
Bomba Agua / Water Pump
Flange Filtro Ar E Valvula Acelarador / Air Cl Eaner Flange And Throttle Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Tubo Agua Valvula Egr / Egr Water Piping
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [C Omponent Parts]
Tubo Aspiracao (Filtro Ar) / Inlet Pipe (Air C Leaner)
Tampa Tubo Colector / Muffler Pipe Cover
Silenciador Do Filtro De Partículas Diesel / D Iesel Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [Pe Ças Componentes] / Diesel Particulate Filter Muffle R [Component Parts]
Sensor Escape / Muffler Sensor
Tubo Pressao / Pressure Pipe
Tubo Oleo (Turbo Caricatore) / Oil Pipe (Turbo Charger)
Intercooler / Inter Cooler
Radiador Oleo / Oil Cooler
Componentes Electricos Motor / Engine Electric Al Parts
Motor Elétrica Peças De Montagem / Engine Elec Trical Mounting Parts
Deposito Combustivel [Ve Lho] / Fuel Tank [Old]
Deposito Combustivel [No Vo] / Fuel Tank [New]
Suporte Deposito Combust Ivel / Fuel Tank Bracket
Tubo Combustivel (Filtro ) / Fuel Pipe (Fuel Filler)
Tubo Combustivel (Bomba) [Velho] / Fuel Pipe (Fuel Pump) [Old]
Tubo Combustivel (Bomba) [Novo] / Fuel Pipe (Fuel Pump) [New]
Tubo Combustivel (Arrefe Cedor Gasoleo) [Velho] / Fuel Pipe (Fuel Cooler) [O Ld]
Tubo Combustivel (Arrefe Cedor Gasoleo) [Novo] / Fuel Pipe (Fuel Cooler) [Ne W]
Arrefecedor Gasoleo / Fu El Cooler
Separador / Separator
Separador [Peças Compone Ntes] / Separator [Component Parts]
Bomba Gasoleo / Fuel Pum P
Bomba Gasoleo [Peças Com Ponentes] / Fuel Pump [Component Parts]
Filtro Gasoleo / Fuel Fi Lter
Filtro Gasoleo [Peças Co Mponentes] / Fuel Filter [Component Parts]
Suport E Ventilador / Fan Bracket
Ventoi Nha / Fan
Tubo A Gua / Water Pipe
Radiad Or / Radiator
Deposi To Reserva / Reserve Tank
Alternador / Alternator
Alternador [Peças Compo Nentes] / Alternator [Component Parts]
Motor Arranque / Starte R
Motor Arranque [Peças C Omponentes] / Starter [Component Parts]
Interruptor/Sensor (Blo Co Motor Esquerda) / Switch/Sensor (Engine Lh)
Interruptor/Sensor (Maq Uina (Drt)/Panela Escape) / Switch/Sensor (Engine R H/Muffler)
Componenetes Electricos Resguardo / Electrical Parts Cover
Interruptor/Sensor (Sus Pensao) / Switch/Sensor (Suspension)
Interruptor/Sensor (Fre Nte) / Switch/Sensor (Front)
Interruptor/Sensor (Cor Po) / Switch/Sensor (Body)
Interruptor / Rele (Tra Seira) / Switch/Sensor (Rear)
Interruptor (Operação) / Switch (Operation)
Interruptor Principal/C Have De Controle Alavanca / Main Switch/Lever Contr Ol Switch
Relé / Relay
Ecu (Bloco Motor) / Ecu (Engine)
Ecu (Corpo) / Ecu (Body )
Painel / Panel Board
Conta Rotaçoes Tdf/Velo Cimetro / Pto Tachometer/Speedmeter
Painel Control / Contro L Panel
Lampada Cabeça [Ec] / H Ead Light [Ec]
Lampada Cabeça [Uk] / H Ead Light [Uk]
Lampada Cabeça [Tur] / Head Light [Tur]
Lampada Cabeça [Peças C Omponentes] [Ec] / Head Light [Component Parts] [Ec ]
Lampada Cabeça [Peças C Omponentes] [Uk] / Head Light [Component Parts] [Uk ]
Lampada Cabeça [Peças C Omponentes] [Tur] / Head Light [Component Parts] [T Ur]
Luzes Frontais / Front Combination Light
Luzes Trabalho (Frente) [Ec] / Work Light (Front) [Ec]
Luzes Trabalho (Frente) [Uk] / Work Light (Front) [Uk]
Luzes Trabalho (Frente) [Tur] / Work Light (Front) [Tur]
Farois Trabalho (Trasei Ros) / Work Light (Rear)
Braco Traseiro / Rear C Ombination Light
Luz Interior / Room Lig Ht
Radio Cd E Columnas / C D-Radio And Speaker
Deposito Limpa Parabri Sas / Washer Tank
Cablagem Electrica (Crs ) [Velho] / Electrical Wiring (Crs) [Old]
Cablagem Electrica (Crs ) [Novo] / Electrical Wiring (Crs) [New]
Cablagem Electrica (Mot Or) / Electrical Wiring (Engine)
Cablagem Electrica (Luz Es Frente) / Electrical Wiring (Head Light)
Cablagem Eletrcia (Pain El) [Velho] / Electrical Wiring (Panel) [Old]
Cablagem Eletrcia (Pain El) [Novo] / Electrical Wiring (Panel) [New]
Cablagem Eletrcia (Tras Eira) [Velho] / Electrical Wiring (Rear) [Old]
Cablagem Eletrcia (Tras Eira) [Novo] / Electrical Wiring (Rear) [New]
Cablagem Eletrcia (Botã O) / Electrical Wiring (3p Switch)
Cablagem Electrica (Pai Nel Contrl) / Electrical Wiring (Control Panel)
Cablagem Electrica (Bra Co) / Electrical Wiring (Armrest)
Cablagem Elétrica (Corp O) / Electrical Wiring (Body)
Cablagem Electrica (Val Vula Suspensao Frontal) / Electrical Wiring (Front Suspension Valve)
Cablagem Electrica (Cab Ine) [Ec] / Electrical Wiring (Cab) [Ec]
Cablagem Electrica (Cab Ine) [Uk] / Electrical Wiring (Cab) [Uk]
Cablagem Electrica (Cab Ine) [Tur] / Electrical Wiring (Cab) [Tur]
Carter Embraiage M / Clutch Housing
Valvula Powershi Ft / Power Shift Valve
Valvula Powershi Ft (Corpo) [Peças Componentes] / Power Shift Valve (Body) [Component Parts]
Valvula Powershi Ft (Superior) [Peças Componentes] / Power Shift Val Ve (Upper) [Component Parts]
Carter Embraiage M Cambota (Inferior) / Clutch Housing Cover (Lower)
Caixa Intermedia / Mid Case
Caixa Velocidade S / Transmission Case
Carter Transmiss Ao / Transmission Case Rear Cover
Caixa Do Eixo Tr Aseiro Direito / Rear Axle Case Rh
Caixa Do Eixo Tr Aseiro Esquerdo / Rear Axle Case Lh
Disco Amortecedo R / Damper Disk
Tirante Embraiag Em / Clutch Rod
Cobertura Fronta L / Front Cover
Suporte Carreto / Gear Support
Veio Primario / Input Shaft
Veio Inversor / Shuttle Shaft
Primeira/Segunda Mudança / First/Second Shift Gear
Primeiro Veio / First Shaft
Carreto Terceira /Quarta / Third/Fourth Shift Gear
Veio Secundario / Counter Shaft
Carreto Principa L [Antigo] / Main Gear Shift Shaft And Range Gear S Haft [Old]
Carreto Principa L [Novo] / Main Gear Shift Shaft/Range Gear Shaft [ New]
Veio Gamas Veloc Idades Inversor (Frente) / Range Gear Shaft (Front)
Veio Gamas Veloc Idades (Traseira) [Antiga] / Range Gear Shaft (Rear ) [Old]
Veio Gamas Veloc Idades (Traseira) [Nova] / Range Gear Shaft (Rear) [New]
Veio (Frente) / Drive Shaft (Front)
Veio (Meio/Trase Iro) / Drive Shaft (Middle/Rear)
Sistema Hi-Lo / Hi-Lo Shift Case
Grupo Conico / B Evel Gear
Diferencial Tras Eiro / Rear Differential
Embraiagem Bloqu Eio Diferencial Traseiro / Rear Differential Lock C Lutch
Veio Tdf / Pto P Ropeller Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf [ Peças Componentes] / Pto Clutch [Component Parts]
Valvula Embraiag Em Tdf / Pto Clutch Valve
Valvula Embraiag Em Tdf [Peças Componentes] / Pto Clutch Valve [Comp Onent Parts]
Veio Principal T Df / Pto Drive Shaft
Veio Tdf / Pto S Haft
Embraiagem Hidra Ulica (Bi Speed) / Hydraulic Clutch (Bi-Speed Turn)
Veio Bi-Speed / Bi-Speed Turn Shaft
Forqu Eta Velocidades / Range Gear Shift Fork
Forqu Eta Tdf / Pto Shift Fork
Alava Nca Velocidades / Main Gear Shift Lever
Alvan Ca Inversor / Shuttle Shift Lever
Cabo Embraiagem / Range Gear Shift Cable
Alava Nca Tdf / Pto Gear Shift Lever
Pedal Bloqueio Difere Ncial Traseiro / Rear Differential Lock Pedal
Eixo Traseiro / Rear Axle Shaft
Travão / Brake
Travão Parque / Parki Ng Brake
Pedal Travao / Brake Pedal
Cilindro Travao Princ Ipal / Brake Master Cylinder
Cilindro Travao Princ Ipal [Peças Componentes] / Brake Master Cylinder [C Omponent Parts]
Tubo Travao / Brake P Ipe
Tubo Travao / Brake M Aster Cylinder Pipe
Suporte Eixo Frent E / Front Axle Frame
Suporte Eixo Diant Eiro / Front Axle Bracket
Veio Primario [Peç As Componentes] / Mid Propeller Shaft [Component Pa Rts]
Caixa Diferencial Dianteiro / Front Differential Case
Grupo Conico (Fren Te) / Bevel Gear (Front)
Diferencial Diante Iro / Differential Front
Bloqueio Diferenci Al Frente / Front Differential Lock Clutch
Caixas Engrenagens Conica Drt / Bevel Gear Case Rh
Caixas Engrenagens Conica Esq / Bevel Gear Case Lh
Eixo Dianteiro / F Ront Axle
Veio Carreto Difer Encial / Differential Gear Shaft
Tampa Coluna Direccao / Steering Post Cov Er
Placa Telescopio / Telescope Lever
Distribuidor Direcção / Steering Controll Er
Distribuidor Direcção [Peças Componentes] / Steering Controller [Component Parts]
Rotula/Cilindro Direcção / Tie Rod/Steeri Ng Cylinder
Cilindro Direcção [Peças Componentes] / S Teering Cylinder [Component Parts]
Bomba Hidraulico / Hydr Aulic Pump
Valvula Reguladora / Re Gulater Valve
Valvula Reguladora [Peç As Componentes] / Regulater Valve [Component Parts]
Tubo Oleo (Fornecimento ) / Hydraulic Oil Line (Delivery)
Tubo Hidraulico / Hydra Ulic Oil Line
Valvula Travao Reboque / Trailer Brake Valve
Valvula Segurança / Saf Ety Valve
Circuito Oleo Hidraulic O (Diferencial Traseiro) / Hydraulic Oil Line (Rear Diff.)
Circuito Oleo Hidraulic O (Diferencial Frente) / Hydraulic Oil Line (Front Differential)
Radiador Oleo / Oil Coo Ler
Circuito Oleo Direcção (Radiador Oleo) [Antiga] / Hydraulic Oil Line (Oil Cooler)[Old]
Circuito Oleo Direcção (Radiador Oleo) [Nova] / Hydraulic Oil Line (Oil Co Oler)[New]
Circuito Oleo Direcção (Direcção/Tdf) / Hydraulic Oil Line (Steering/Pto)
Tubo Direccao (Entrega) / Steering Hose (Delivery)
Valvula Suspensao Front Al (Alívio/Verificação) [Peças Componentes] / Front Suspension Valve (Relief/Check) [Component Parts]
Valvula Suspensao Front Al (Segurança) [Peças Componentes] / Front Suspensi On Valve (Safety) [Component Parts]
Valvula Suspensao Front Al (Joint) [Peças Componentes] / Front Suspension V Alve (Joint) [Component Parts]
Tubo Da Suspensão Front Al Valvula / Front Suspension Valve Hose
Cilindro Da Suspensão F Rontal / Front Suspension Cylinder
Cilindro Da Suspensão F Rontal [Peças Componentes] / Front Suspension Cylin Der [Component Parts]
Valvula / Branch Flow V Alve
Valvula [Peças Componen Tes] / Branch Flow Valve [Component Parts]
Caixa Cilindro Hidrauli Co / Hydraulic Cylinder Case
Valvula Base / Valve
Base Valvula / Valve Ba Se
Hidraulico Braços / Hyd Raulic Lift Arm
Valvula Descarga/Valvul A Verificação / Relief Valve/Check Valve
Trinco / Lowering Lock Lever
Barra Deflectora (Barr A/Barra Suporte) / Detector Bar (Bar/Bar Support)
Barra Deflectora (Ligaç Ão) / Detector Bar (Draft Link)
Alavanca Control Posica O / Position Control Lever
Valvula Contol Automati Co / Auto Control Valve
Valvula Control Automat Ico [Peças Componentes] / Auto Control Valve [Compo Nent Parts]
Válvula De Controlo Aux Iliar (Com Fc) / Auxiliary Control Valve (With Fc) Mounting Base
Serviços Externos (Com Fc) [Peças Componentes] / Auxiliary Control Valve ( With Fc) (Mounting) [Component Parts]
Serviços Externos (Scd Com Fc) [Peças Componentes] / Auxiliary Control Val Ve (Scd With Fc) [Component Parts]
Serviços Externos (Fd C Om Fc) [Peças Componentes] / Auxiliary Control Valv E (Fd With Fc) [Component Parts]
Tampa Da Válvula De Con Trolo Auxiliar (Com Fc) Tampa/Depósito De Reserva / Auxiliary Control Valve (With Fc) Cap/Reserve Tank
Alavanca Da Válvula De Controlo Auxiliar (Com Fc) / Auxiliary Control Valv E (With Fc) Lever
Cilindro Auxiliar De El Evacao Esq / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De El Evacao Drt / 3p-Lift Assist Cylinder Rh
Cilindro Auxiliar De El Evacao [Peças Componentes] / 3p-Lift Assist Cylinde R [Component Parts]
Pa Rte Superior / Top Link Bracket
Li Gacao Inferior / Lower Link
Es Tabilizador / Stabilizer
Es Tabilizador Drt / Lift Rod Rh
Es Tabilizador Esq / Lift Rod Lh
Pr Oteccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot Superior (Som Absorvedor/Isolador) / Hood (Bonnet) (Sound Absorber/Insulator)
Amortecedor Capot / Hood(Bonnet) Damper
Trico Capot / Bonnet Lock
Estrutura Capot / Bonnet Frame
Suporte Capot / Hood (Bonnet) Support
Capot Inferior Direito / Hood (Bonnet) Si De Lower Rh
Capot Inferior Esquerdo / Hood (Bonnet) S Ide Lower Lh
Estrutura Cabine / Cab Frame
Vidro Frente / Front Glass
Porta Drt / Door Rh
Porta Esq / Door Lh
Vidro Traseiro (Superior) / Rear Window (Upper)
Tejadilho / Sun Roof
Espelho Rectrovisor [Uk] / Rearview Mirror [Uk]
Espelho Rectrovisor [Tur] / Rearview Mirror [Tur ]
Tecto Interior / Inner Roof
Cobertura Exterior Do Tejadilho / Outer Roof
Banco / Seat
Banco [Peças Componentes] / Seat [Component Part S]
Apoio Braço / Armrest
Banco Passageiro / Instructional Seat
Piso / Floor Mat
Isolante / Soundproof Material
Chapa Inspecção (Frente) / Inspection Plate (Fro Nt)
Chapa Inspecção (Traseira) / Inspection Plate (R Ear)
Tampa / Shift Cover
Cobertura Gurada Lamas Esq / Fender Cover Lh
Guarda Lamas Esq / Fender Lh
Suporte Cabine Dianteiro / Cab Bracket Front
Suporte Cabine Traseiro / Cab Bracket Rear
Caixa Ferramenta / Tool Box
Air Condicionado / Air Con Ditioner
Cuberto Tubo Air Condicion Ado / Air Conditioner Duct Cover
Tubo Ar Condicionado (Fren Te) / Air Conditioner Duct (Front)
Tubo Ar Condicionado (Tras Eira) / Air Conditioner Duct (Rear)
Modo Caixa / Mode Case
Entradas Ar Painel Instrum Entos / Dashboard Air Outlets
Circulaçao Ar Interior / I Nner Air Recirculation
Condesador / Condenser
Tubo Ar Condicionado/Tubo Condensador / Air Conditioner Hose/Condenser Hose
Compressor Do Ar Condicion Ado / Air Conditioner Compressor
Decalcomania (Frente) [Ec] [Uk] / Label (Fr Ont) [Ec] [Uk]
Decalcomania (Frente) [Tur] / Label (Front) [Tur]
Etiqueta (Traseira/Cabine) / Label (Rear/Ca B)
Acessorios E Peças De Serviço / Accessories And Se Rvice Parts
Kit Farios Trabalho [Opçao] / Working Light Ki T [Option]
Kit Farios Trabalho (Trseira) [Opçao] / Workin G Light Kit (Rear) [Option]
Kit Desempanador [Opçao] / Rear Defogger Kit [ Option]
Escova Limpa Vidro Frontal [Opção] / Front Wip Er Kit [Option]
Kit Fusivel [Opção] / Fuse Kit [Option]
Kit Cobertuta Deposito Gasoleo [Opçao] / Fuel Tank Cover Kit [Option]
Crepper Kit (Caica De Carretos) [Opção] / Cree P Speed Kit (Gear Case) [Option]
Kit Caixa Crepper (Forqueta) [Opçao] / Creep S Peed Kit (Shift Fork) [Option]
Kit Caixa Crepper (Alvanca) [Opçao] / Creep Sp Eed Kit (Lever) [Option]
Kit Substituição De Principal De Transmissão E Mbraiagem (Embraiagem) [Opção] / Main Gear Shift Cl Utch Replacement Kit (Clutch) [Option]
Kit Substituição De Principal De Transmissão E Mbraiagem (Suporte) [Opção] / Main Gear Shift Clutc H Replacement Kit (Support) [Option]
Kit Conversao Tdf 540/540e (Engrenagem) [Opçao ] / Pto (540/540e) Conversion Kit (Gear) [Option]
Kit Conversao Tdf 540/1000 (Engrenagem Box) [O Pção] / Pto (540/1000) Conversion Kit (Gear Case) [ Option]
Kit Conversao Tdf 540/1000 (Engrenagem) [Opção ] / Pto(540/1000) Conversion Kit (Gear) [Option]
80" Kit De Piso [Opção] / 80 Inch Tread Kit [O Ption]
Kit De Tubulação De Lubrificação De Óleo [Opçã O] / Oil Lubrication Pipe Kit [Option]
Kit Serviços Externos (Fd Com Fc) [Opção] / Au Xiliary Control Valve Kit (Fd With Fc) [Option]
Kit Alavanca Serviços Externos (Com Fc) (3rd) [Opção] / Auxiliary Control Valve Lever Kit (With F C) (3rd) [Option]
Kit Alavanca Serviços Externos (Com Fc) (4th) [Opção] / Auxiliary Control Valve Lever Kit (With F C) (4th) [Option]
Protetor De Para-Sol [Opção] / Sunshade Shield Kit [Option]
