Kubota Tractor M135GXDTC24-3 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M135GXDTC24-3 Tractor
Number of Pages: 400 Pages
Itens Uso Freque Nte / Frequently Used Items
Bloco Motor (Superior) / Crankcase (Upper)
Bloco Motor (Inferior) / Crankcase (Lower)
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And E Xhaust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Piston/Cambota / Piston/Crankshaft
Compensador / Balancer
Volante Motor / Flywheel
Filtro Gasoleo / Fuel Filter
Injector E Vela Aquecimento / Injector And Gl Ow Plug
Common Rail / Common Rail
Bomba Agua E Termostacto / Water Flange And T Hermostat
Bomba Agua / Water Pump
Radiador Oleo / Oil Cooler
Separador De Óleo [Peças Componentes] / Oil S Eparator [Component Parts]
Tubo Do Separador De Óleo / Oil Separator Pip E
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turb O Charger)
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [ Component Parts]
Tubo De Entrada (Filtro De Ar) / Inlet Pipe ( Air Cleaner)
Intercooler / Inter Cooler
Flange Filtro Ar E Valvula Acelarador / Air C Leaner Flange And Throttle Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Tubos De Água Egr / Egr Water Piping
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Partículas Diesel / Diesel Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [P Eças Componentes] / Diesel Particulate Filter Muffl Er [Component Parts]
Tubo Pressao / Pressure Pipe
Panela Escape (Filtro Do Filtro De Partículas Diesel) / Muffler Pipe (Diesel Particulate Filter)
Silenciador Da Redução Catalítica Seletiva / Selective Catalytic Reduction Muffler
Placa De Isolamento (Silenciador Da Redução C Atalítica Seletiva) / Insulation Plate (Selective C Atalytic Reduction Muffler)
Estrutura Da Redução Catalítica Seletiva / Se Lective Catalytic Reduction Frame
Resguardo Da Redução Catalítica Seletiva / Se Lective Catalytic Reduction Cover
Indicador Resguardo Da Redução Catalítica Sel Etiva / Selective Catalytic Reduction Injector Cove R
Estrutura Da Redução Catalítica Seletiva / Se Lective Catalytic Reduction Main Frame
Bomba Do Fluido De Escape De Diesel / Diesel Exhaust Fluid Pump
Depósito Do Fluido De Escape De Diesel / Dies El Exhaust Fluid Tank
Depósito Do Fluido De Escape De Diesel [Peças Componentes] / Diesel Exhaust Fluid Tank [Componen T Parts]
Depósito Do Fluido De Escape De Diesel Tubo / Diesel Exhaust Fluid Hose
Válvula Egr (Sistema De Redução Catalítica Se Letiva) / Egr Valve (Selective Catalytic Reduction System)
Sistema De Arrefecimento Egr (Sistema De Redu Ção Catalítica Seletiva) / Egr Cooler (Selective Ca Talytic Reduction System)
Tubo Egr (Sistema De Redução Catalítica Selet Iva) / Egr Pipe (Selective Catalytic Reduction Syst Em)
Tubos De Água Egr (Sistema De Redução Catalít Ica Seletiva) / Egr Water Piping (Selective Catalyt Ic Reduction System)
Componentes Electricos Motor (Sensor/Ecu) / E Ngine Electrical Parts (Sensor/Ecu)
Componentes Electricos Motor (Panela Escape) / Engine Electrical Parts (Muffler)
Motor Elétrica Peças De Montagem / Engine Ele Ctrical Mounting Parts
Suporte Deposito Combus Tivel / Fuel Tank Bracket
Suporte Do Depósito De Combustível / Fuel Tank Support
Deposito Combustivel (E Sq) / Fuel Tank Lh
Tubo Combustivel (Depós Ito Do Fluido De Escape De Diesel De Respiro) / Fue L Pipe (Diesel Exhaust Fluid Breather)
Tubo Combustivel (Depos Ito Combustivel) / Fuel Pipe (Fuel Tank)
Tubo Do Combustível (En Chimento Do Combustível) / Fuel Pipe (Fuel Filter)
Tubo Do Combustível (Bo Mba Do Combustível) / Fuel Pipe (Fuel Pump)
Tubo Combustivel (Depos Ito Combustivel Respiro) / Fuel Pipe (Fuel Tank Bre Ather)
Tubo Combustivel (Arref Ecedor Gasoleo) / Fuel Pipe (Fuel Cooler)
Arrefecedor Gasoleo / F Uel Cooler
Separador / Separator
Separador [Peças Compon Entes] / Separator [Component Parts]
Bomba Gasoleo / Fuel Pu Mp
Bomba Gasoleo [Peças Co Mponentes] / Fuel Pump [Component Parts]
Filtro Gasoleo / Fuel F Ilter
Supor Te Ventilador / Fan Bracket
Vento Inha / Fan
Tubo Agua / Water Pipe
Radia Dor / Radiator
Alternador / Alternato R
Alternador [Peças Comp Onentes] / Alternator [Component Parts]
Motor Arranque / Start Er
Motor Arranque [Peças Componentes] / Starter [Component Parts]
Interruptor/Sensor (Bl Oco Motor Esquerda) / Switch/Sensor (Engine Lh)
Interruptor/Sensor (Bl Oco Motor Direita) / Switch/Sensor (Engine Rh/Muffl Er)
Componenetes Electrico S Resguardo / Electrical Parts Cover
Sensor Da Redução Cata Lítica Seletiva (Bloco Motor) / Selective Catalytic Reduction Sensor (Engine)
Sensor Da Redução Cata Lítica Seletiva (Corpo) / Selective Catalytic Reduc Tion Sensor (Body)
Interruptor/Sensor (Fr Ente ) / Switch/Sensor (Front)
Interruptor/Sensor (Co Rpo) [Uk] / Switch/Sensor (Body) [Uk]
Interruptor/Sensor (Tr Aseira) / Switch/Sensor (Rear)
Interruptor (Operação) / Switch (Operation)
Interruptor Principal / Main Switch/Lever Control Switch
Rele / Relay
Ecu (Bloco Motor) / Ec U (Engine)
Ecu (Corpo) / Ecu (Bod Y)
Quadro Do Painel / Pan El Board
Conta Rotaçoes Tdf/Vel Ocimetro / Pto Tachometer/Speedmeter
Painel Control / Contr Ol Panel
Painel Control [Peças Componentes] / Control Panel [Component Parts]
Luzes Frente [Ec] / He Ad Light [Ec]
Luzes Frente [Uk] / He Ad Light [Uk]
Lampada Cabeça [Peças Componentes] [Ec] / Head Light [Component Parts] [E C]
Luzes Frontais / Front Combination Light
Luzes Trabalho (Frente ) [Ec] / Working Light (Front) [Ec]
Luzes Trabalho (Frente ) [Uk] / Working Light (Front) [Uk]
Farois Trabalho (Trase Iros) / Work Light (Rear)
Ficha Reboque / Traile R Socket
Luz Interior / Room Li Ght
Radio Cd E Columnas / Cd-Radio And Speaker
Escova / Wiper
Cablagem Electrica (Cr S) / Electrical Wiring (Crs)
Cablagem Electrica (Sc R) / Electrical Wiring (Scr)
Cablagem Electrica (Mo Tor) / Electrical Wiring (Engine)
Cablagem Electrica (Lu Zes Frente) / Electrical Wiring (Head Light)
Cablagem Electrica (Pa Inel) / Electrical Wiring (Panel)
Cablagem Electrica (Tr Aseira) / Electrical Wiring (Rear)
Cablagem Electrica (In Terruptor 3p) / Electrical Wiring (3p Switch)
Cablagem Electrica (Pa Inel Contrl) / Electrical Wiring (Control Panel)
Cablagem Electrica (Br Aco) / Electrical Wiring (Armrest)
Cabalagem Eletrica (Co Rpo) [Ec] / Electrical Wiring (Body) [Ec]
Cabalagem Eletrica (Co Rpo) [Uk] / Electrical Wiring (Body) [Uk]
Cabalagem Eletrica (Ca Bine) [Ec] / Electrical Wiring (Cab) [Ec]
Cabalagem Eletrica (Ca Bine) [Uk] / Electrical Wiring (Cab) [Uk]
Carter Embraiag Em / Clutch Housing
Valvula Powersh Ift / Power Shift Valve
Valvula Powersh Ift (Corpo) [Peças Componentes] / Power Shift Valve (Body) [Component Parts]
Valvula Powersh Ift (Superior) [Peças Componentes] / Power Shift Va Lve (Upper) [Component Parts]
Carter Embraiag Em Cambota (Inferior) / Clutch Housing Cover (Lower )
Caixa Intermedi A / Mid Case
Caixa Velocidad Es / Transmission Case
Carter Transmis Sao [Ec] / Transmission Case Rear Cover [Ec]
Carter Transmis Sao [Uk] / Transmission Case Rear Cover [Uk]
Carter Eixo Tra Seiro Drt (Tipo Arco) / Rear Axle Case Rh
Carter Eixo Tra Seiro Esq (Tipo Arco) / Rear Axle Case Lh
Disco Amorteced Or / Damper Disk
Pedal Embraiage M / Clutch Pedal
Embraiagem / Cl Utch Rod
Cobertura Front Al / Front Cover
Rolamento Supor Te / Front Bearing Support
Veio Primario / Input Shaft
Veio Inversor / Shuttle Shaft
Primeira/Segund A Mudança / First/Second Shift Gear
Primeiro Veio / First Shaft
Carreto Terceir A/Quarta / Third/Fourth Shift Gear
Veio Secundario / Counter Shaft
Engrenagem Prin Cipal/Veio Gamas Velocidades / Main Gear Shift Shaf T/Range Gear Shaft
Veio Gamas Velo Cidades (Frente) / Range Gear Shaft (Front)
Veio Gamas Velo Cidades (Traseira) / Range Gear Shaft (Rear)
Veio (Frente) / Drive Shaft (Front)
Veio (Meio/Tras Eiro) / Drive Shaft (Middle/Rear)
Caixa De Mudanç As Alta-Baixa / Hi-Lo Shift Case
Diferencial Tra Seiro / Rear Differential
Embraiagem Bloq Ueio Diferencial Traseiro / Rear Differential Lock Clutch
Veio Tdf / Pto Propeller Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf [Peças Componentes] / Pto Clutch [Component Parts]
Valvula Embraia Gem Tdf / Pto Clutch Valve
Valvula Embraia Gem Tdf [Peças Componentes] / Pto Clutch Valve [Com Ponent Parts]
Veio Principal Tdf [Ec] / Pto Drive Shaft [Ec]
Veio Principal Tdf [Uk] / Pto Drive Shaft [Uk]
Veio Tdf [Ec] / Pto Shaft [Ec]
Veio Tdf [Uk] / Pto Shaft [Uk]
Duplicador Velo Cidade / Bi-Speed Turn Clutch (Bi-Speed Turn)
Veio Bi-Speed / Bi-Speed Turn Shaft
Forq Ueta Velocidades / Range Gear Shift Fork
Alva Nca Tdf [Ec] / Pto Gear Shift Fork [Ec]
Alav Anca Velocidades / Main Gear Shift Lever
Alva Nca Inversor / Shuttle Shift Lever
Cabo Embraiagem / Range Gear Shift Cable
Alav Anca Tdf [Ec] / Pto Gear Shift Lever [Ec]
Eixo Traseiro / Rear Axle
Travão / Brake
Pedal Travao / Brake Pedal
Cilindro Travao Prin Cipal / Brake Master Cylinder
Cilindro Travao Prin Cipal [Peças Componentes] / Master Cylinder [Compon Ent Parts]
Tubo Travao / Brake Pipe
Tubo Travao / Brake Master Cylinder Pipe
Suporte Eixo Fren Te / Front Axle Frame
Suporte Eixo Fren Te / Front Axle Bracket
Veio Primario / P Ropeller Shaft
Caixa Diferencial Frente / Front Differential Case
Grupo Conico (Fre Nte) / Bevel Gear (Front)
Diferencial Frent E / Differential Front
Embraiagem Bloque Io Diferencial Frente / Front Differential Lock Clu Tch
Caixas Engrenagen S Conica Drt / Bevel Gear Case Rh
Caixas Engrenagen S Conica Esq / Bevel Gear Case Lh
Carter Eixo Frent E / Front Axle Case
Eixo Frente / Fro Nt Axle
Veio Carreto Dife Rencial / Differential Gear Shaft
Tampa Coluna Direccao / Steering Post Co Ver
Alavanca / Tilt Lever
Placa Telescopio / Telescope Lever
Distribuidor Direcção / Steering Control Ler
Distribuidor Direcção [Peças Componentes ] / Steering Controller [Component Parts]
Rotula/Cilindro Direcção / Tie Rod/Steer Ing Cylinder
Bomba Hidraulico / Hyd Raulic Pump
Bomba Hidraulico [Peça S Componentes] / Hydraulic Pump [Component Parts]
Valvula Reguladora / R Egulater Valve
Valvula Reguladora [Pe Ças Componentes] / Regulater Valve [Component Parts ]
Circuito Oleo Direcção (Sucção) / Hydraulic Oil Line (Suction)
Circuito Oleo Direcção (Entrega) / Hydraulic Oil Line (Delivery)
Carregador Dianteiro T Ubo / Front Loader Pipe
Tubo Hidraulico / Hydr Aulic Oil Line
Valvula Travao Reboque / Trailer Brake Valve
Valvula Segurança / Sa Fety Valve
Circuito Oleo Hidrauli Co (Bi Speed) / Hydraulic Oil Line (Bi-Speed Turn/R Ear Diff.)
Circuito Oleo Hidrauli Co (Diferencial Frente) / Hydraulic Oil Line (Front Differential)
Radiador Oleo / Oil Co Oler
Circuito Oleo Radiador (Radiador Oleo) / Hydraulic Oil Line (Oil Cooler)
Circuito Oleo Direcção (Direcção/Tdf) / Hydraulic Oil Line (Steering/Pto)
Tubo Direccao (Entrega ) / Steering Hose (Delivery)
Caixa Cilindro Hidraul Ico / Hydraulic Cylinder Case
Casquilho Lampada / Va Lve
Braço De Elevação Hidr Áulico / Hydraulic Lift Arm
Valvula Descarga / Rel Ief Valve/Check Valve
Trinco / Lowering Lock Lever
Barra Deflectora (Barr A/Barra Suporte) / Detector Bar (Bar/Bar Support)
Barra Deflectora (Liga Ção) / Detector Bar (Draft Link)
Alavanca Control Posic Ao / Position Control Lever
Valvula Contol Automat Ico / Auto Control Valve
Valvula Control Automa Tico [Peças Componentes] / Auto Control Valve [Comp Onent Parts]
Auxiliar Do Válvula De Controlo (Com Controlo De Fluxo) / Auxiliary Contr Ol Valve (With Fc) Mounting
Válvula De Controlo Au Xiliar (Com Controlo De Fluxo) / Auxiliary Control Valve (With Fc)
Auxiliar Do Válvula De Controlo (Com Controlo De Fluxo) [Peças Componente S] / Auxiliary Control Valve (With Fc) Mounting [Co Mponent Parts]
Auxiliar Do Válvula De Controlo [Peças Componentes] (Scd Con Fc) / Auxili Ary Control Valve [Component Parts] (Scd With Fc)
Auxiliar Do Válvula De Controlo [Peças Componentes] (Fd Con Fc) / Auxilia Ry Control Valve [Component Parts] (Fd With Fc)
Auxiliar Do Válvula De Controlo (Com Controlo De Fluxo) Tampa/Deposito Re Serva / Auxiliary Control Valve (With Fc) Cap/Reser Ve Tank
Auxiliar Do Alavanca D E Válvula De Controlo (Com Controlo De Fluxo) / Aux Iliary Control Valve (With Fc)
Fluir Fio De Controle Da Auxiliar Do Valvula De Controlo / Auxiliary Cont Rol Flow Control Wire
Cilindro Auxiliar De E Levacao Esq / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De E Levacao Drt / 3p-Lift Assist Cylinder Rh
P Arte Superior / Top Link Bracket
L Igacao Superior / Top Link
L Igacao Inferior / Lower Link
E Stabilizador / Stabilizer
E Stabilizador Drt / Lift Rod Rh
E Stabilizador Esq / Lift Rod Lh
P Roteccao Tdf [Ec] / Protector [Ec]
P Roteccao Tdf [Uk] / Protector [Uk]
Grelha Frontal / Front Grille
Capot (Superior/Isolador) / Hood (Bonnet ) (Sound Absorber/Insulator)
Trico Capot / Bonnet Lock
Estrutura Capot / Bonnet Frame
Capot Inferior (Direito) / Hood (Bonnet) Side Lower Rh
Capot Inferior (Esquerdo) / Hood (Bonnet ) Side Lower Lh
Estrutura Cabine [Ec] / Cab Frame [Ec]
Estrutura Cabine [Uk] / Cab Frame [Uk]
Vidro Frente / Front Glass
Porta (Direito) / Door Rh
Porta (Esquerdo) / Door Lh
Trinco Porta (Direito) / Door Lock Rh
Trinco Porta (Esquerdo) / Door Lock Lh
Vidro Traseiro / Rear Window
Tejadilho / Sun Roof
Espelho Rectrovisor [Ec] / Rearview Mirror [Ec]
Espelho Rectrovisor [Uk] / Rearview Mirror [Uk]
Tecto Interior / Inner Roof
Tecto Abrir / Outer Roof
Banco / Seat
Banco [Peças Componentes] / Seat [Component Par Ts]
Apoio Braço / Armrest
Banco Passageiro / Instructional Seat
Tapete Do Piso / Floor Mat
Isolante / Soundproof Material
Banco Tapete / Seat Mat
Chapa Inspecção (Frente) / Inspection Plate (Fr Ont)
Tampa / Shift Cover
Cobertura Gurada Lamas (Esquerdo) / Fender Cove R Lh
Guarda Lamas (Direito) / Fender Rh
Guarda Lamas (Esquerda) / Fender Lh
Suporte Cabine (Frente) / Cab Bracket Front
Suporte Cabine (Traseira) / Cab Bracket Rear
Caixa Ferramenta / Tool Box
Air Condicionado / Air Co Nditioner
Cuberto Tubo Air Condicio Nado / Air Conditioner Duct Cover
Tubo Ar Condicionado (Fre Nte) / Air Conditioner Duct (Front)
Conduta Do Ar Condicionad O (Traseira) / Air Conditioner Duct (Rear)
Modo Caixa / Mode Case
Entradas Ar Painel Instru Mentos / Dashboard Air Outlets
Condesador / Condenser
Tubo Ar Condicionado/Tubo Condensador / Air Conditioner Hose/Condenser Hose
Compressor / Compressor
Etiqueta (Traseira/Cabine) / Label (Rear/C Ab)
Acessorios / Acce Ssories And Service Parts
Kit Farios Trabalho [Opção] / Working Light K It [Option]
Kit Farios Trabalho (Trseiros) [Opcao] / Work Ing Light Kit (Rear) [Option]
Kit Farios Trabalho (Led) [Opção] / Working L Ight Kit (Led) [Option]
Kit Farios Trabalho (Trseiros) (Led) [Opcao] / Working Light Kit (Rear) (Led) [Option]
Kit Cobertuta Deposito Gasoleo [Opção] / Fuel Tank Cover Kit [Option]
Crepper Kit (Caica De Carretos) [Opção] / Cre Ep Speed Kit (Gear Case) [Option]
Crepper Kit (Forqueta ) [Opção] / Creep Speed Kit (Shift Fork) [Option]
Crepper Kit (Alavanca) [Opção] / Creep Speed Kit (Lever) [Option]
Kit Conversao Tdf (540/540e) (Engrenagem) [Op Ção] / Pto (540/540e) Conversion Kit (Gear) [Option ]
Auxiliar Do Válvula De Controlo Kit (Scd Con Fc) [Opção] / Auxiliary Control Valve Kit (Scd With Fc) [Option]
Auxiliar Do Válvula De Controlo Kit (Fd Con F C) [Opção] / Auxiliary Control Valve Kit (Fd With F C) [Option]
Auxiliar Do Alavanca De Válvula De Controlo K It (Com Controlo De Fluxo) (Terceiro) [Opção] / Aux Iliary Control Valve Kit (With Fc) (3rd) [Option]
Auxiliar Do Alavanca De Válvula De Controlo K It (Com Controlo De Fluxo) (Quarto) [Opção] / Auxil Iary Control Valve Kit (With Fc) (4th) [Option]
Protetor De Para-Sol [Opção] / Sunshade Shiel D Kit [Option]
