Kubota Tractor M135GXDTC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M135GXDTC Tractor
Number of Pages: 468 Pages
Bloco Motor (Superior) [Velho] / Crankcase (Upper ) [Old]
Bloco Motor (Superior) [Novo] / Crankcase (Upper) [New]
Bloco Motor (Inferior) [Velho] / Crankcase (Lower ) [Old]
Bloco Motor (Inferior) [Novo] / Crankcase (Lower) [New]
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhau St Valve
Braço [Velho] / Rocker Arm Shaft [Old]
Braço [Novo] / Rocker Arm Shaft [New]
Tampa Cabeça / Head Cover
Arvore Cames E Veio / Camshaft And Idle Gear Shaf T
Compensador / Balancer
Volante Motor [Exclua [Dtsc]] / Flywheel [Except [Dtsc]]
Filtro Gasoleo / Fuel Filter
Injector E Vela Aquecimento / Injector And Glow P Lug
Common Rail / Common Rail
Bomba Agua E Termostacto / Water Flange And Therm Ostat
Bomba Agua / Water Pump
Flange Filtro Ar / Air Cleaner Flange And Throttl E Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Tubo Agua Valvula Egr / Egr Water Piping
Filtro Ar [Exclua [Dtsc]] / Air Cleaner [Except [ Dtsc]]
Filtro Ar [Peças Componentes] / Air Cleaner [Comp Onent Parts]
Tubo Aspiracao (Filtro Ar) / Inlet Pipe (Air Clea Ner)
Panela Escape / Muffler Pipe
Tampa Tubo Colector / Muffler Pipe Cover
Silenciador Do Filtro De Partículas Diesel / Dies El Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [Peças Componentes] / Diesel Particulate Filter Muffler [ Component Parts]
Sensor Particulas Combustivel / Muffler Sensor
Tubo Pressao / Pressure Pipe
Tubo Oleo (Turbo) / Oil Pipe (Turbo Charger)
Intercooler / Inter Cooler
Radiador Oleo / Oil Cooler
Componentes Electricos Motor / Engine Electrical Parts
Motor Elétrica Peças De Montagem / Engine Electri Cal Mounting Parts
Deposito Combustivel / Fuel Ta Nk
Suporte Deposito Combustivel / Fuel Tank Bracket
Tubo Combustivel (Filtro) / Fu El Pipe (Fuel Filler)
Tubo Combustivel (Bomba) / Fue L Pipe (Fuel Pump)
Arrefecedor Gasoleo / Fuel Coo Ler
Separador / Separator
Bomba Gasoleo / Fuel Pump
Bomba Gasoleo [Peças Component Es] / Fuel Pump [Component Parts]
Filtro Gasoleo [Peças Componen Tes] / Fuel Filter [Component Parts]
Suporte V Entilador / Fan Bracket
Ventoinha / Fan
Tubo Agua / Water Pipe
Radiador [Velho] / Radiator [Old]
Radiador [Novo] / Radiator [New]
Alternador / Alternator
Alternador [Peças Componen Tes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Comp Onentes] / Starter [Component Parts]
Interruptor/Sensor (Maquin A (Esq)) / Switch/Sensor (Engine Lh)
Interruptor/Sensor (Maquin A (Drt)/Panela Escape) / Switch/Sensor (Engine Rh/M Uffler)
Componenetes Electricos Res Guardo / Electrical Parts Cover
Interruptor/Sensor (Frente ) / Switch/Sensor (Front)
Interruptor/Sensor (Corpo) / Switch/Sensor (Body)
Interruptor/Sensor (Trasei Ra) / Switch/Sensor (Rear)
Interruptor / Switch (Oper Ation)
Interruptor Principal / Ma In Switch/Lever Control Switch
Rele / Relay
Unidade Control Electrico (Bloco Motor) / Electronic Control Unit (Engine)
Unidade Control Electrico (Corpo) [Exclua [Dtsc]] / Electronic Control Unit ( Body) [Except [Dtsc]]
Painel / Panel Board
Conta Rotaçoes Tdf/Velocim Etro / Pto Tachometer/Speedmeter
Painel Control [Exclua [Dt Sc]] / Control Panel [Except [Dtsc]]
Painel Control [Peças Comp Onentes] / Control Panel [Component Parts]
Luzes Frente [Ec] [Velho] / Head Light [Ec] [Old]
Luzes Frente [Ec] [Novo] / Head Light [Ec] [New]
Luzes Frente [Peças Compon Entes] [Ec] / Head Light [Component Parts] [Ec]
Luzes Frontais / Front Com Bination Light
Luzes Trabalho (Frente) [E C] / Work Light (Front) [Ec]
Farois Trabalho (Traseira) / Work Light (Rear)
Braco Traseiro / Rear Comb Ination Light
Ficha Reboque / Trailer So Cket
Luz Interior / Room Light
Radio Cd E Columnas / Cd-R Adio And Speaker
Deposito Limpa Parabrisas / Washer Tank
Escova Limpa Vidros [Velho ] / Wiper [Old]
Escova Limpa Vidros [Novo] / Wiper [New]
Cablagem Electrica (Crs)S [Velho] / Electrical Wiring (Crs) [Old]
Cablagem Electrica (Crs) [ Novo] / Electrical Wiring (Crs) [New]
Cablagem Electrica (Motor) / Electrical Wiring (Engine)
Cablagem Eletrica (Luzes F Rente) [Velho] / Electrical Wiring (Head Light) [Ol D]
Cablagem Electrica (Luzes Frente)[Velho] / Electrical Wiring (Head Light)[Old ]
Cablagem Electrica (Luzes Frente)[Novo] / Electrical Wiring (Head Light)[New]
Cablagem Eletrcia (Painel) [Velho] / Electrical Wiring (Panel) [Old]
Cablagem Eletrcia (Painel) [Novo] / Electrical Wiring (Panel) [New]
Cablagem Eletrcia (Traseir A) [Velho] / Electrical Wiring (Rear) [Old]
Cablagem Eletrcia (Traseir A) [Novo] / Electrical Wiring (Rear) [New]
Cablagem Eletrcia [Velho] / Electrical Wiring (3p Switch) [Old]
Cablagem Eletrcia [Novo] / Electrical Wiring (3p Switch) [New]
Cablagem Electrica (Apoio Braço) / Electrical Wiring (Armrest)
Cablagem Electrica (Corpo) / Electrical Wiring (Body)
Cabalagem Eletrica (Cabine ) [Ec] / Electrical Wiring (Cab) [Ec]
Valvula Powershif T / Power Shift Valve
Valvula Powershif T (Corpo) [Peças Componentes] / Power Shift Valve ( Body) [Component Parts]
Valvula Powershif T (Superior) [Peças Componentes] / Power Shift Valv E (Upper) [Component Parts]
Carter Embraiagem [Exclua [Dtsc]] / Clutch Housing Cover Lower [Exce Pt [Dtsc]]
Caixa Intermedia [Velho] / Mid Case [Old]
Caixa Intermedia [Novo] / Mid Case [New]
Caixa Da Transmis São [Velho] / Transmission Case [Old]
Caixa Velocidades [Novo] / Transmission Case [New]
Carter Transmissa O / Transmission Case Rear Cover
Carter Eixo Trase Iro (Esq) / Rear Axle Case Lh
Disco Amortecedor / Damper Disk
Tirante Embraiage M / Clutch Rod
Suporte Carreto / Gear Support
Veio Primario / I Nput Shaft
Veio Inversor / S Huttle Shaft
Primeira/Segunda Mudança / First/Second Shift Gear
Primeiro Veio / F Irst Shaft
Carreto Terceira/ Quarta / Third/Fourth Shift Gear
Veio Secundario / Countershaft
Carreto Principal E Veio Gamas Velocidades Inversor [Velho] / Main G Ear Shift Shaft And Range Gear Shaft [Old]
Carreto Principal E Veio Gamas Velocidades Inversor [Novo] / Main Ge Ar Shift Shaft And Range Gear Shaft [New]
Veio Gamas Veloci Dades Inversor (Frente) / Range Gear Shaft (Front)
Veio Gamas Veloci Dades Inversor (Traseira) / Range Gear Shaft (Rear)
Veio (Frente) / D Rive Shaft (Front)
Veio (Meio/Trasei Ro) / Drive Shaft (Middle/Rear)
Sistema Hi-Lo / H I-Lo Shift Case
Grupo Conico / Be Vel Gear
Diferencial Trase Iro / Rear Differential
Embraiagem Bloque Io Diferencial Traseiro / Rear Differential Lock Cl Utch
Veio Tdf / Pto Pr Opeller Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf [P Eças Componentes] [Velho] / Pto Clutch [Component Parts] [Old]
Embraiagem Tdf [P Eças Componentes] [Novo] / Pto Clutch [Component Pa Rts] [New]
Valvula Embraiage M Tdf / Pto Clutch Valve
Valvula Embraiage M Tdf [Peças Componentes] / Pto Clutch Valve [Compo Nent Parts]
Veio Principal Td F / Pto Drive Shaft
Veio Tdf / Pto Sh Aft
Embraiagem Hidrau Lica (Bi Speed) [Exclua [Dtsc]] / Hydraulic Clutch (Bi-Speed Turn) [Except [Dtsc]]
Veio Bi-Speed [Ex Clua [Dtsc]] / Bi-Speed Turn Shaft [Except [Dtsc]]
Forquet A Velocidades / Range Gear Shift Fork
Alvanca Tdf / Pto Shift Fork
Alavanc A Velocidades / Main Gear Shift Lever
Cabo Em Braiagem / Range Gear Shift Cable
Alavanc A Tdf / Pto Gear Shift Lever
Eixo Traseiro / Rear A Xle Shaft
Travoes / Brake
Travao Parque / Parkin G Brake
Pedal Travao / Brake P Edal
Cilindro Travao Princi Pal / Brake Master Cylinder
Cilindro Travao Princi Pal [Peças Componentes] / Brake Master Cylinder [Co Mponent Parts]
Tubo Travao / Brake Pi Pe
Tubo Travao / Brake Ma Ster Cylinder Pipe
Suporte Eixo Frente [Exclua [Dtsc]] / Front Axle Frame [Except [Dtsc]]
Suporte Eixo Dianteiro [Excl Ua [Dtsc]] / Front Axle Bracket [Except [Dtsc]]
Veio Primario [Exclua [Dtsc] ] / Propeller Shaft [Except [Dtsc]]
Caixa Diferencial Dianteiro [Exclua [Dtsc]] / Front Differential Case [Except [ Dtsc]]
Grupo Conico Frente (Frente) [Exclua [Dtsc]] / Bevel Gear (Front) [Except [Dtsc ]]
Bloqueio Diferencial Frente [Exclua [Dtsc]] / Front Differential Lock Clutch [E Xcept [Dtsc]]
Caixas Engrenagens Conica (D Rt) / Bevel Gear Case Rh
Caixas Engrenagens Conica (E Sq) / Bevel Gear Case Lh
Carter Eixo Frente / Front A Xle Case
Eixo Dianteiro / Front Axle
Veio Difrencial [Exclua [Dts C]] / Differential Gear Shaft [Except [Dtsc]]
Tampa Coluna Direccao / Steering Post Cover
Alavanca / Tilt Lever
Placa Telescopio / Telescope Lever
Distribuidor Direcção / Steering Controller
Distribuidor Direcção [Peças Componentes] / Steering Controller [Component Parts]
Rotula/Cilindro Direcção [Exclua [Dtsc]] / T Ie Rod/Steering Cylinder [Except [Dtsc]]
Cilindro Direcção [Peças Componentes] / Stee Ring Cylinder [Component Parts]
Bomba Hidraulico / Hydraul Ic Pump
Bomba Hidraulico [Peças Co Mponentes] / Hydraulic Pump [Component Parts]
Valvula Reguladora / Regul Ater Valve
Valvula Reguladora [Peças Componentes] / Regulater Valve [Component Parts]
Linha Aspiração / Hydrauli C Pipe (Suction)
Tubo Oleo (Entrege) / Hydr Aulic Oil Line (Delivery)
Tubo Hidraulico / Hydrauli C Oil Line
Valvula Travao Reboque / T Railer Brake Valve
Valvula Segurança / Safety Valve
Circuito Oleo Hidraulico / Hydraulic Oil Line (Rear Diff.)
Circuito Oleo Hidraulico ( Diferencial Frente) [Exclua [Dtsc]] / Hydraulic Oil Line (Front Differential) [Except [Dtsc]]
Circuito Oleo Radiador / H Ydraulic Oil Line (Oil Cooler)
Circuito Oleo Direcção (Di Reccao/Tdf) [Exclua [Dtsc]] / Hydraulic Oil Line (S Teering/Pto) [Except [Dtsc]]
Tubo Direccao (Entrega) [E Xclua [Dtsc]] / Steering Hose (Delivery) [Except [D Tsc]]
Caixa Valvula Hidraulico / Hydraulic Valve Case
Valvula Base / Valve
Base Valvula / Valve Base
Hidraulico Braços / Hydrau Lic Lift Arm
Valvula Descarga / Relief Valve/Check Valve
Trinco / Lowering Lock Lev Er
Barra Deflectora (Suporte ) / Detector Bar (Bar/Bar Support)
Barra Deflectora / Detecto R Bar (Draft Link)
Alavanca Control Posicao / Position Control Lever
Valvula Contol Automatico / Auto Control Valve
Valvula Control Automatico [Peças Componentes] / Auto Control Valve [Componen T Parts]
Distribuidor Auxiliar / Au Xiliary Control Valve
Valvula Auxiliar (Scd) [Pe Ças Componentes] / Auxiliary Control Valve (Scd) [C Omponent Parts]
Valvula Auxiliar (Fd) [Peç As Componentes] / Auxiliary Control Valve (Fd) [Com Ponent Parts]
Alavanca Valvula Auxiliar / Auxiliary Control Valve Lever
Cilindro Auxiliar De Eleva Cao (Esq) / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De Eleva Cao (Drt) / 3p-Lift Assist Cylinder Rh
Cilindro Auxiliar De Eleva Cao [Peças Componentes] [Velho] / 3p-Lift Assist Cy Linder [Component Parts] [Old]
Cilindro Auxiliar De Eleva Cao [Peças Componentes] [Novo] / 3p-Lift Assist Cyl Inder [Component Parts] [New]
Parte Superior / Top Link Bracket
Ligac Ao Superior / Top Link
Estab Ilizador / Stabilizer
Estab Ilizador (Drt) / Lift Rod Rh
Estab Ilizador (Esq) / Lift Rod Lh
Prote Ccao Tdf / Pto Protector
Grelha Frontal [Velho] / Front Grille [Old]
Grelha Frontal [Novo] / Front Grille [New] # # N.º De Série>=70150 S.No.;>=70150 / S.No.>=70150 S.No.;>=70150
Capot [Velho] / Hood (Bonnet) [Old]
Capot [Novo] / Hood (Bonnet) [New]
Capot (Absorvente Sao/Isolador) [Velho] / Ho Od (Bonnet) (Sound Absorber/Insulator) [Old]
Capot (Absorvente Sao/Isolador) [Novo] / Hoo D (Bonnet) (Sound Absorber/Insulator) [New]
Trico Capot [Velho] / Bonnet Lock [Old]
Trico Capot [Novo] / Bonnet Lock [New]
Estrutura Capot [Velho] / Bonnet Frame [Old]
Estrutura Capot [Novo] / Bonnet Frame [New]
Capot Inferior (Direito) / Hood (Bonnet) Sid E Lower Rh
Capot Inferior (Esquerdo) / Hood (Bonnet) Si De Lower Lh
Estrutura Cabine / Cab Frame
Para Brisas / Front Glass
Porta (Drt) / Door Rh
Porta (Esq) / Door Lh
Trinco Porta (Esq) / Door Lock Lh
Vidro Traseiro (Superior) / Rear Window (Upper)
Tejadilho / Sun Roof
Espelho Retrovisor [Ec] [Velho] / Rearview Mirror [ Ec] [Old]
Espelho Retrovisor [Ec] [Novo] / Rearview Mirror [E C] [New]
Tecto Interior [Velho] / Inner Roof [Old]
Tecto Interior [Novo] / Inner Roof [New]
Tejadilho Exterior / Outer Roof
Banco / Seat
Banco [Peças Componentes] / Seat [Component Parts] [Old]
Banco [Peças Componentes] / Seat [Component Parts] [New]
Apoio Braço / Armrest
Piso / Floor Mat
Isolante / Soundproof Material
Chapa Inspecção (Frente) / Inspection Plate (Front)
Chapa Inspecção (Traseira) / Inspection Plate (Rear )
Tampa / Shift Cover
Cobertura Gurada Lamas (Esq) / Fender Cover Lh
Guarda Lamas (Drt) / Fender Rh
Guarda Lamas (Esq) / Fender Lh
Suporte Cabine (Dianteiro) / Cab Bracket Front
Suporte Cabine (Traseiro) / Cab Bracket Rear
Caixa Ferramenta / Tool Box
Air Condicionado / Air Condit Ioner
Cuberto Tubo Air Condicionado / Air Conditioner Duct Cover
Tubo Ar Condicionado (Diantei Ro) / Air Conditioner Duct (Front)
Tubo Ar Condicionado (Traseir O) / Air Conditioner Duct (Rear)
Entradas Ar Painel Instrument Os / Dashboard Air Outlets
Tubo Aquecimento / Heater Hos E
Condesador / Condenser [Old]
Condesador / Condenser [New]
Tubo Ar Condicionado/Tubo Con Densador / Air Conditioner Hose/Condenser Hose
Compressor / Compressor
Etiqueta (Parte Traseira/Cab) / Label (Rear/C Ab)
Acessorios / Accessories
Kit Ecu [Opção] / Ecu Kit [Option]
Kit Farios Trabalho [Opção] / Working Light Kit [ Option]
Kit Farios Trabalho (Trseiros) [Opção] / Working Light (Rear) Kit [Option]
Desempanador [Opção] / Rear Defogger Kit [Option]
Escova Limpa Vidro Frontal [Opção] / Front Wiper Kit [Option]
Kit Fusivel [Opção] / Fuse Kit [Option]
Kit Cobertuta Deposito Gasoleo [Opção] / Fuel Tan K Cover Kit [Option]
Bearing Support Replacement Kit [Except [Dtsc]] [ Option] / Bearing Support Replacement Kit [Except [ Dtsc]] [Option]
Kit Caixa Crepper [Opção] / Creep Speed Kit (Gear Case) [Option]
Forqueta Caixa / Creeper [Opção] / Creep Speed Ki T (Shift Fork) [Option]
Alavanca Caixa Creper [Opção] / Creep Speed Kit ( Lever) [Option]
Kit Conversao Tdf 540/540e (Engrenagem) [Opção] / Pto (540/540e) Conversion Kit (Gear) [Option]
Kit Conversao Tdf 540/1000 (Engrenagem Box) [Opçã O] / Pto(540/1000) Conversion Kit (Gear Case) [Opti On]
Kit Valvula Control Auxiliar (Scd) [Opção] / Auxi Liary Control Valve Kit (Scd) [Option]
Kit Valvula Control Auxiliar (Fd) [Opção] / Auxil Iary Control Valve Kit (Fd) [Option]
Kit Valvula Control Auxiliar (Fc) [Opção] / Auxil Iary Control Valve Kit (Fc) [Option]
Kit Valvula Control Auxiliar (Scd/Fc) [Opção] / A Uxiliary Control Valve Kit (Scd/Fc) [Option]
Kit Distribuidor Serviços Externos (Scd/Fc)[Peças Componentes] [Opção] / Auxiliary Control Valve (Sc D/Fc) [Component Parts] [Option]
Kit Distribuidor Serviços Externos (Fc) [Peças Co Mponentes] [Opção] / Auxiliary Control Valve (Fc) [ Component Parts] [Option]
Kit Alavanca Serviços Externos (Quatra) [Opção] / Auxiliary Control Valve Lever Kit (4th) [Option]
Kit Alavanca Serviços Externos (Primeiro) [Opção] / Auxiliary Control Valve (With Fc) Mounting Kit ( 1st) [Option]
Kit Alavanca Serviços Externos (Segundo) [Opção] / Auxiliary Control Valve (With Fc) Mounting Kit (2 Nd) [Option]
Kit Serviços Externos (Scd/Fc) [Opção] / Auxiliar Y Control Valve Kit (Scd With Fc) [Option]
Kit Serviços Externos (Fd/Fc) [Opção] / Auxiliary Control Valve Kit (Fd With Fc) [Option]
Kit Serviços Externos (Fc) [Peças Componentes] [O Pção] / Auxiliary Control Valve (With Fc) (Mounting ) [Component Parts] [Option]
Kit Serviços Externos (Scd/Fc) [Peças Componentes ] [Opção] / Auxiliary Control Valve (Scd With Fc) [ Component Parts] [Option]
Kit Serviços Externos (Fd/Fc) [Peças Componentes] [Opção] / Auxiliary Control Valve (Fd With Fc) [Co Mponent Parts] [Option]
Kit Alavanca Serviços Externos (Fc) (Terceiro) [O Pção] / Auxiliary Control Valve Lever Kit (With Fc) (3rd) [Option]
Kit Alavanca Serviços Externos (Fc) (Quatra) [Opç Ão] / Auxiliary Control Valve Lever Kit (With Fc) ( 4th) [Option]
Kit De Tampas Do Acoplador Da Válvula De Controlo Auxiliar [Opção] / Auxiliary Control Valve Coupler Cap Kit [Option]
Banco Passageiro [Opção] / Instructional Seat Kit [Option]
Capot (Prato) [Opção] / Bonnet Kit (Shutter Plate ) [Option]
Capot (Cablagem Electrica) [Opção] / Bonnet Kit ( Electrical Wiring) [Option] [Old]
Capot (Cablagem Electrica) [Opção] / Bonnet Kit ( Electrical Wiring) [Option] [New]
Capot (Grelha Frontal) [Opção] / Bonnet Kit (Fron T Grille) [Option]
Capot (Absorvente Sao/Isolador) [Opção] / Bonnet Kit (Sound Absorber/Insulator) [Option] [Old]
Capot (Absorvente Sao/Isolador) [Opção] / Bonnet Kit (Sound Absorber/Insulator) [Option] [New]
Capot (Trico Capot) [Opção] / Bonnet Kit (Bonnet Lock) [Option]
Capot (Estrutura Capot) [Opção] / Bonnet Kit (Bon Net Frame) [Option]
Protetor De Para-Sol [Opção] / Sunshade Shield Ki T [Option]
Ventoinha / Fan
Rele / Relay
Travoes / Brake
Banco / Seat
Piso / Floor Mat
Tampa / Shift Cover
