Kubota Tractor M135GXDTC Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M135GXDTC Tractor
Number of Pages: 803 Pages
Frequently Used Items
Bloque Motor (Superior) [Antiguo] / Crankcase (Upper) [Old]
Bloque Motor (Superior) [Nuevo] / Crankcase (Upper) [New]
Bloque Motor (Bajar) [Antiguo] / Crankcase (Lower) [Old]
Bloque Motor (Bajar) [Nuevo] / Crankcase (Lower) [New]
Aceite Cacerola / Oil Pan
Eje Del Brazo Del Eje De Balancin [Antiguo] / Rocker Arm Shaft [Old]
Eje Del Brazo Del Eje De Balancin [Nuevo] / Rocker Arm Shaft [New]
Culata Cubierta / Head Cover
Compensador / Balancer
Volante [Excepto [Dtsc]] / Flywheel [Except [Dtsc]]
Carril Comun / Common Rail
Agua Bomba / Water Pump
Aire Limpiador Brida / Air Cleaner Flange And Throttle Valve
Valvula De Egr / Egr Valve
Tuberia Del Agua De Egr / Egr Water Piping
Aire Limpiador [Excepto [Dtsc]] / Air Cleaner [Except [Dtsc]]
Pipa De Entrada(Aire Limpiador) / Inlet Pipe (Air Cleaner)
Cubierta De La Pipa Del Silenciador / Muffler Pipe Cover
Sensor Del Muflfer / Muffler Sensor
Aceite Tubo(Turbo Cargador) / Oil Pipe (Turbo Charger)
Intercooler / Inter Cooler
Piezas Electricas Del Motor / Engine Electrical Parts
Motor Eléctrico Piezas De Montaja / Engine Electrical Mounting Parts
Combustible Deposito Soporte / Fuel Tank Bracket
Combustible Tubo (Limpiador) / Fuel Pipe (Fuel Filler)
Combustible Tubo (Bomba) / Fuel Pipe (Fuel Pump)
Combustble Tubo (Refrigerador Del Combustible) / Fuel Pipe (Fuel Cooler)
Separador / Separator
Combustible Bomba / Fuel Pump
Ventilador / Fan
Agua Tubo / Water Pipe
Radiador [Antiguo] / Radiator [Old]
Radiador [Nuevo] / Radiator [New]
Alternador / Alternator
Motor De Arranque / Starter
Conmutador/Sensor (Motor Derecho/Silenciador) / Switch/Sensor (Engine Rh/Muffler)
Electrico Piezas Cubierta / Electrical Parts Cover
Conmutador/Sensor (Fronte) / Switch/Sensor (Front)
Conmutador/Sensor (Cuerpo) / Switch/Sensor (Body)
Conmutador/Rele (Posterior) / Switch/Sensor (Rear)
Conmutador (Operacion) / Switch (Operation)
Interruptor Principal/Interruptor Del Mando / Main Switch/Lever Control Switch
Rele / Relay
Unidad De Control Electronico (Cuerpo) [Excepto [Dtsc]] / Electronic Control Unit (Body) [Except [Dtsc]]
Tablero Panel / Panel Board
Tacometro De Tdf/Velocimetro / Pto Tachometer/Speedmeter
Mando Panel [Excepto [Dtsc]] / Control Panel [Except [Dtsc]]
Mando Panel [Componente Piezas] / Control Panel [Component Parts]
Culata Luz [Ec] [Antiguo] / Head Light [Ec] [Old]
Culata Luz [Ec] [Nuevo] / Head Light [Ec] [New]
Faro Delantero [Componente Piezas] [Ec] / Head Light [Component Parts] [Ec]
Adelante Combinacion Luz / Front Combination Light
Trabajo Luz/Luz Del Faro (Adelante) [Ec] / Work Light (Front) [Ec]
Trabajo Luz (Posterior) / Work Light (Rear)
Trasero Combinacion Luz / Rear Combination Light
Altavoz De Cd-Radio / Cd-Radio And Speaker
Limpiaparabrisas [Antiguo] / Wiper [Old]
Limpiaparabrisas [Nuevo] / Wiper [New]
Instalacion Electrica (Crs) [Antiguo] / Electrical Wiring (Crs) [Old]
Instalacion Electrica (Crs) [Nuevo] / Electrical Wiring (Crs) [New]
Electrico Cableado (Motor) / Electrical Wiring (Engine)
Electrico Cableado (Culata Luz) [Antiguo] / Electrical Wiring (Head Light) [Old]
Electrico Cableado (Culata Luz) [Antiguo] / Electrical Wiring (Head Light)[Old]
Electrico Cableado (Culata Luz) [Nuevo] / Electrical Wiring (Head Light)[New]
Electrico Cableado (Panel) [Antiguo] / Electrical Wiring (Panel) [Old]
Instalacion Electrica (Principal/Motor) [Antiguo] / Electrical Wiring (Panel) [Old]
Electrico Cableado (Panel) [Nuevo] / Electrical Wiring (Panel) [New]
Electrico Cableado (Posterior) [Antiguo] / Electrical Wiring (Rear) [Old]
Instalacion Electrica (Principal/Motor) [Antiguo] / Electrical Wiring (Rear) [Old]
Electrico Cableado (Posterior) [Antiguo] / Electrical Wiring (Rear) [New]
Electrico Cableado (Interruptor) [Antiguo] / Electrical Wiring (3p Switch) [Old]
Electrico Cableado (Interruptor) [Nuevo] / Electrical Wiring (3p Switch) [New]
Cableado Electrico (Mando Panel) [Excepto [Dtsc]] / Electrical Wiring (Control Panel) [Except [Dtsc]]
Electrico Cableado (Apoyabrazo) / Electrical Wiring (Armrest)
Electrico Cableado (Cuerpo) / Electrical Wiring (Body)
Electrico Cableado (Cabina) [Ec] / Electrical Wiring (Cab) [Ec]
Potencia Cambio Valvula / Power Shift Valve
Potencia Cambio Valvula (Carroceria) [Componente Piezas] / Power Shift Valve (Body) [Component Parts]
Potencia Cambio Valvula (Superior) [Componente Piezas] / Power Shift Valve (Upper) [Component Parts]
Embrague Carcasa Cubierta [Excepto [Dtsc]] / Clutch Housing Cover Lower [Except [Dtsc]]
Caja Intermedia [Antiguo] / Mid Case [Old]
Caja Intermedia [Nuevo] / Mid Case [New]
Cajatransmision [Antiguo] / Transmission Case [Old]
Transmision Caja [Nuevo] / Transmission Case [New]
Varilla De Embrague / Clutch Rod
Engranaje Soporte / Gear Support
Entrada Eje / Input Shaft
Primero/Segundo Cambio Engranaje / First/Second Shift Gear
Primer Eje / First Shaft
Tercero/Cuarto Cambio Engranaje / Third/Fourth Shift Gear
Arbol Contrarrotante / Countershaft
Principal Engranaje Cambio Eje Y Gama Engranaje Eje [Antiguo] / Main Gear Shift Shaft And Range Gear Shaft [Old]
Principal Engranaje Cambio Eje Y Gama Engranaje Eje [Nuevo] / Main Gear Shift Shaft And Range Gear Shaft [New]
Gama Engranaje Eje (Adelante) / Range Gear Shaft (Front)
Gama Engranaje Eje (Posterior) / Range Gear Shaft (Rear)
Accionar Eje (Adelante) / Drive Shaft (Front)
Accionar Eje (Medio/Trasero) / Drive Shaft (Middle/Rear)
Caso De La Cambio De Hi-Lo / Hi-Lo Shift Case
Eje De Engranaje Diferencial / Bevel Gear
Trasero Diferencial Cerradura Embrague / Rear Differential Lock Clutch
Embrague Tdf / Pto Clutch
Tdf Embrague [Componente Piezas] [Antiguo] / Pto Clutch [Component Parts] [Old]
Pto Embrague [Componente Piezas] [Nuevo] / Pto Clutch [Component Parts] [New]
Pto Embrague Valvula [Componente Piezas] / Pto Clutch Valve [Component Parts]
Eje Motor De Tdf / Pto Drive Shaft
Tdf Eje / Pto Shaft
Embrague Hidraulico (Impulsion Delantera De La Rueda) [Excepto [Dtsc]] / Hydraulic Clutch (Bi-Speed Turn) [Except [Dtsc]]
Bi-Velocidad Girar Eje [Excepto [Dtsc]] / Bi-Speed Turn Shaft [Except [Dtsc]]
Bifurcacion Del Cambio De Engranaje De La Gama / Range Gear Shift Fork
Bifurcacion Del Cambio De Engranaje Del Tdf / Pto Shift Fork
Inversor Cambio Palanca / Shuttle Shift Lever
Cambio De Engran.De La Gama Cable / Range Gear Shift Cable
Palanca De Cambio De Engranaje Del Tdf / Pto Gear Shift Lever
Trasero Eje / Rear Axle Shaft
Freno / Brake
Estacionamiento Freno / Parking Brake
Freno Pedal / Brake Pedal
Freno Tubo / Brake Pipe
Pipa Del Distribuidor Del Freno / Brake Master Cylinder Pipe
Adelante Eje Bastidor [Excepto [Dtsc]] / Front Axle Frame [Except [Dtsc]]
Soporte De Eje Delantero [Excepto [Dtsc]] / Front Axle Bracket [Except [Dtsc]]
Adelante Helice Eje [Excepto [Dtsc]] / Propeller Shaft [Except [Dtsc]]
Adelante Diferencial Caja [Excepto [Dtsc]] / Front Differential Case [Except [Dtsc]]
Bisel Engranaje (Adelante) [Excepto [Dtsc]] / Bevel Gear (Front) [Except [Dtsc]]
Diferencial Adelante [Excepto [Dtsc]] / Differential Front [Except [Dtsc]]
Embrague De Bloqueo De Diferencial Delantero [Excepto [Dtsc]] / Front Differential Lock Clutch [Except [Dtsc]]
Caja De Engranaje Conico Dcha / Bevel Gear Case Rh
Caja De Engranaje Conico Izqd / Bevel Gear Case Lh
Adelante Eje / Front Axle
Diferencial Eje Del Engranaje [Excepto [Dtsc]] / Differential Gear Shaft [Except [Dtsc]]
Volante / Steering Wheel
Cubierta Del Poste De Manejo / Steering Post Cover
Palanca Del Telescopio / Telescope Lever
Direccion Controlador[Componente Piezas] / Steering Controller [Component Parts]
Atar Varilla/Direccion Cilindro [Excepto [Dtsc]] / Tie Rod/Steering Cylinder [Except [Dtsc]]
Regulador Valvula / Regulater Valve
Regulador Valvula[Componente Piezas] / Regulater Valve [Component Parts]
Hidraulico Aceite Linea (Aspiracion) / Hydraulic Pipe (Suction)
Linea De Aceite Hidraulico (Impulsion) / Hydraulic Oil Line (Delivery)
Pipa Hidraulica / Hydraulic Oil Line
Remolque Freno Valvula / Trailer Brake Valve
Seguridad Valvula / Safety Valve
Hidraulico Aceite Linea(Trasero Dfrncl) / Hydraulic Oil Line (Rear Diff.)
Hidraulico Aceite Linea(Adelante Diferencial) [Excepto [Dtsc]] / Hydraulic Oil Line (Front Differential) [Except [Dtsc]]
Linea De Aceite Hidraulico Radiador De Aceite / Oil Cooler
Linea De Aceite Hidraulico(Radiador De Aceite) / Hydraulic Oil Line (Oil Cooler)
Hidraulico Aceite Linea (Direccion/Tdf) [Excepto [Dtsc]] / Hydraulic Oil Line (Steering/Pto) [Except [Dtsc]]
Latiguillo De Direccion(Impulsion) [Excepto [Dtsc]] / Steering Hose (Delivery) [Except [Dtsc]]
Hidraulico Valvula Caja / Hydraulic Valve Case
Valvula / Valve
Base De La Valvula / Valve Base
Piston Hidraulico/Brazo De Elevacion / Hydraulic Lift Arm
Descarga Valvula/Cheque Valvula / Relief Valve/Check Valve
Detector Barra (Barra/Barra Soporte) / Detector Bar (Bar/Bar Support)
Detector Barra (Esfuerzo Vinculo) / Detector Bar (Draft Link)
Coloque La Palanca De Mando / Position Control Lever
Auto Control Valvula / Auto Control Valve
Auto Control Valvula[Componente Piezas] / Auto Control Valve [Component Parts]
Distribuidor De Servicios Externos / Auxiliary Control Valve
Auxiliar Control Valvula (Scd) [Componente Piezas] / Auxiliary Control Valve (Scd) [Component Parts]
Auxiliar Control Valvula (Fd) [Componente Piezas] / Auxiliary Control Valve (Fd) [Component Parts]
Auxiliar Control Valvula Palanca / Auxiliary Control Valve Lever
Cilindro De Ayuda De Elevacion [Componente Piezas] [Antiguo] / 3p-Lift Assist Cylinder [Component Parts] [Old]
Cilindro De Ayuda De Elevacion [Componente Piezas] [Nuevo] / 3p-Lift Assist Cylinder [Component Parts] [New]
Bajar Vinculo / Lower Link
Estabilizador / Stabilizer
Ascenso Varilla Dcha / Lift Rod Rh
Tdf Protector / Pto Protector
Adelante Parrilla [Antiguo] / Front Grille [Old]
Adelante Parrilla [Nuevo] / Front Grille [New]
Capo [Antiguo] / Hood (Bonnet) [Old]
Capo [Nuevo] / Hood (Bonnet) [New]
Capo (Amortiguador Sano/Aislador) [Antiguo] / Hood (Bonnet) (Sound Absorber/Insulator) [Old]
Capo (Amortiguador Sano/Aislador) [Nuevo] / Hood (Bonnet) (Sound Absorber/Insulator) [New]
Cerradura De La Capo [Antiguo] / Bonnet Lock [Old]
Cerradura De La Capo [Nuevo] / Bonnet Lock [New]
Capo Bastidor [Antiguo] / Bonnet Frame [Old]
Capo Bastidor [Nuevo] / Bonnet Frame [New]
Capo Soporte / Bonnet Support
Capo Lado Bajar Izquierdo / Hood (Bonnet) Side Lower Lh
Cabina Bastidor / Cab Frame
Adelante Vidrio / Front Glass
Puerta Derecho / Door Rh
Puerta Izqd / Door Lh
Cerradura De Puerta Izqd / Door Lock Lh
Trasero Ventana (Superior) / Rear Window (Upper)
Azotea Del Sol / Sun Roof
Espejo Retrovisor [Ec] [Antiguo] / Rearview Mirror [Ec] [Old]
Espejo Retrovisor [Ec] [Nuevo] / Rearview Mirror [Ec] [New]
Interno Techo [Antiguo] / Inner Roof [Old]
Interno Techo [Nuevo] / Inner Roof [New]
Externo Techo / Outer Roof
Hoja / Seat
Asiento [Componente Piezas] [Antiguo] / Seat [Component Parts] [Old]
Asiento [Componente Piezas] [Nuevo] / Seat [Component Parts] [New]
Apoyabrazo / Armrest
Piso Estera / Floor Mat
Material Insonoro / Soundproof Material
Inspeccion Placa (Adelante) / Inspection Plate (Front)
Inspeccion Placa (Trasero) / Inspection Plate (Rear)
Cubierta De Guardabarros Izqd / Fender Cover Lh
Guardabarros Izqd / Fender Lh
Herramienta Caja / Tool Box
Cubierta Del Aire Acondicionador Conducto / Air Conditioner Duct Cover
Aire Acondicionador Conducto (Adelante) / Air Conditioner Duct (Front)
Aire Acondicionador Conducto (Posterior) / Air Conditioner Duct (Rear)
Modo Caso / Mode Case
Condensador [Antiguo] / Condenser [Old]
Condensador [Nuevo] / Condenser [New]
Compresor / Compressor
Etiqueta (Posterior/Cabina) / Label (Rear/Cab)
Accesorios Y Servicio Piezas / Accessories
Ecu Kit [Opcion] / Ecu Kit [Option]
Funcionamiento Luz (Posterior) Kit [Opcion] / Working Light (Rear) Kit [Option]
Trasero Desempanador Kit[Opcion] / Rear Defogger Kit [Option]
Limpiador Delantero [Opción] / Front Wiper Kit [Option]
Kit Fusible [Opcion] / Fuse Kit [Option]
Combustible Deposito Cubierta Kit [Opcion] / Fuel Tank Cover Kit [Option]
Teniento Kit De Sustitucion De Soporte [Excepto [Dtsc]] [Opcion] / Bearing Support Replacement Kit [Except [Dtsc]] [Option]
Marcha Muy Lenta Velocidad Kit (Engranaje Caja) [Opcion] / Creep Speed Kit (Gear Case) [Option]
Marcha Muy Lenta Velocidad Kit (Cambio Bfrccn) [Opcion] / Creep Speed Kit (Shift Fork) [Option]
Marcha Muy Lenta Velocidad Kit (Palanca) [Opcion] / Creep Speed Kit (Lever) [Option]
Tdf(540/540e) Conversion Kit (Engranaje) [Opcion] / Pto (540/540e) Conversion Kit (Gear) [Option]
Tdf(540/1000) Conversion Kit (Engranaje Caja) [Opcion] / Pto(540/1000) Conversion Kit (Gear Case) [Option]
Tdf(540/1000) Conversion Kit (Engranaje) [Opcion] / Pto(540/1000) Conversion Kit (Gear) [Option]
Kit De Distribuidor De Servicios Externos (Scd) [Opcion] / Auxiliary Control Valve Kit (Scd) [Option]
Auxiliar Control Valvula (Fd) [Opcion] / Auxiliary Control Valve Kit (Fd) [Option]
Kit De Distribuidor De Servicios Externos (Fc) [Opcion] / Auxiliary Control Valve Kit (Fc) [Option]
Kit De Distribuidor De Servicios Externos (Scd/Fc) [Opcion] / Auxiliary Control Valve Kit (Scd/Fc) [Option]
Distribuidor De Servicios Externos (Scd/Fc) [Componente Piezas] [Opcion] / Auxiliary Control Valve (Scd/Fc) [Component Parts] [Option]
Distribuidor De Servicios Externos (Fc) [Componente Piezas] [Opcion] / Auxiliary Control Valve (Fc) [Component Parts] [Option]
Kit De Palanca De Distribuidor De Servicios Externos (Tercero) [Opcion] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Kit De Palanca De Distribuidor De Servicios Externos (Cuatro) [Opcion] / Auxiliary Control Valve Lever Kit (4th) [Option]
Montaje De Distribuidor De Servicios Externos (1r) (Con Fc) [Opcion] / Auxiliary Control Valve (With Fc) Mounting Kit (1st) [Option]
Montaje De Distribuidor De Servicios Externos (Con Fc) (2do) [Opcion] / Auxiliary Control Valve (With Fc) Mounting Kit (2nd) [Option]
Kit De Distribuidor De Servicios Externos (Fd Con Fc) [Opcion] / Auxiliary Control Valve Kit (Scd With Fc) [Option]
Kit De Distribuidor De Servicios Externos (Fd Con Fc) [Opcion] / Auxiliary Control Valve Kit (Fd With Fc) [Option]
Distribuidor De Servicios Externos (Con Fc) [Componente Piezas] [Opcion] / Auxiliary Control Valve (With Fc) (Mounting) [Component Parts] [Option]
Distribuidor De Servicios Externos (Scd Con Fc) [Componente Piezas] [Opcion] / Auxiliary Control Valve (Scd With Fc) [Component Parts] [Option]
Distribuidor De Servicios Externos (Fd Con Fc) [Componente Piezas] [Opcion] / Auxiliary Control Valve (Fd With Fc) [Component Parts] [Option]
Kit De Palanca De Distribuidor De Servicios Externos (Con Fc) (Tercero) [Opcion] / Auxiliary Control Valve Lever Kit (With Fc) (3rd) [Option]
Kit De Palanca De Distribuidor De Servicios Externos (Con Fc) (Cuatro) [Opcion] / Auxiliary Control Valve Lever Kit (With Fc) (4th) [Option]
Auxiliar Control Valvula Tapa Del Acoplador Kit [Opcion] / Auxiliary Control Valve Coupler Cap Kit [Option]
Asiento Del Instructor [Opcion] / Instructional Seat Kit [Option]
Capo (Capo Superior) [Opcion] / Bonnet Kit (Hood(Bonnet)) [Option]
Capo (Piastra) [Opcion] / Bonnet Kit (Shutter Plate) [Option]
Capo (Electrico Cableado) [Opcion] [Antiguo] / Bonnet Kit (Electrical Wiring) [Option] [Old]
Capo (Electrico Cableado) [Opcion] [Nuevo] / Bonnet Kit (Electrical Wiring) [Option] [New]
Capo (Adelante Parrilla) [Opcion] / Bonnet Kit (Front Grille) [Option]
Capo (Amortiguador Sano/Aislador) [Opcion] [Antiguo] / Bonnet Kit (Sound Absorber/Insulator) [Option] [Old]
Capo (Amortiguador Sano/Aislador) [Opcion] [Nuevo] / Bonnet Kit (Sound Absorber/Insulator) [Option] [New]
Capo (Cerradura De La Capo) [Opcion] / Bonnet Kit (Bonnet Lock) [Option]
Capo (Capo Bastidor) [Opcion] / Bonnet Kit (Bonnet Frame) [Option]
Protector De Pantalla Del Sol [Opcion] / Sunshade Shield Kit [Option]
