702,019
Kubota Tractor M135GXDTC Australia Parts Catalog
Model: Kubota M135GXDTC Tractor
Region: Australia
Number of Pages: 784 Pages
Frequently Used Items Frequently Used Items
Engine Crankcase (Upper) [Old] ## S.No. =3fkz999 S.No.; =3fkz999
Engine Crankcase (Upper) [Old] ## S.No.3fl0001 To 3fzz999 S.No.;3fl0001 To 3fzz999
Engine Crankcase (Upper) [New] ## S.No. =3ga0001 S.No.; =3ga0001
Engine Crankcase (Lower) [Old] ## S.No. =3fkz999 [Note Order By Ref.No.010 And Fig.No
Engine Crankcase (Lower) [Old] ## S.No.3fl0001 To 3fzz999 S.No.;3fl0001 To 3fzz999
Engine Crankcase (Lower) [New] ## S.No. =3ga0001 S.No.; =3ga0001
Engine Oil Pan
Engine Cylinder Head
Engine Inlet Valve And Exhaust Valve
Engine Rocker Arm Shaft [Old] ## S.No. =3evz999 S.No.; =3evz999
Engine Rocker Arm Shaft [New] ## S.No. =3ew0001 S.No.; =3ew0001
Engine Head Cover
Engine Front Cover
Engine Piston And Crankshaft
Engine Camshaft And Idle Gear Shaft
Engine Balancer
Engine Flywheel [Except [Dtsc]]
Engine Supply Pump
Engine Fuel Filter
Engine Injector And Glow Plug
Engine Injection Pipe
Engine Common Rail
Engine Water Flange And Thermostat
Engine Water Pump
Engine Inlet Manifold
Engine Air Cleaner Flange And Throttle Valve
Engine Exhaust Manifold
Engine Egr Valve
Engine Egr Cooler
Engine Egr Water Piping
Engine Turbo Charger
Engine Air Cleaner [Except [Dtsc]]
Engine Air Cleaner [Component Parts]
Engine Inlet Pipe (Air Cleaner)
Engine Muffler Pipe
Engine Muffler Pipe Cover
Engine Diesel Particulate Filter Muffler
Engine Diesel Particulate Filter Muffler [Component Parts]
Engine Muffler Sensor
Engine Pressure Pipe
Engine Oil Pipe (Turbo Charger)
Engine Inter Cooler
Engine Oil Cooler
Engine Engine Electrical Parts
Engine Injector Harness
Engine Engine Electrical Mounting Parts
Engine Accelerator Lever
Engine Accelerator Pedal
Fuel System Fuel Tank [Old] ## S.No. =54335 S.No.; =54335
Fuel System Fuel Tank [New] ## S.No. =54336 S.No.; =54336
Fuel System Fuel Tank Bracket
Fuel System Fuel Pipe (Fuel Filter)
Fuel System Fuel Pipe (Fuel Pump) [Old] ## S.No. =54335 S.No.; =54335
Fuel System Fuel Pipe (Fuel Pump) [New] ## S.No. =54336 S.No.; =54336
Fuel System Fuel Pipe (Fuel Cooler) [Old] ## S.No. =54335 S.No.; =54335
Fuel System Fuel Pipe (Fuel Cooler) [New] ## S.No. =54336 S.No.; =54336
Fuel System Fuel Cooler
Fuel System Separator
Fuel System Separator [Component Parts]
Fuel System Fuel Pump
Fuel System Fuel Pump [Component Parts]
Fuel System Fuel Filter
Fuel System Fuel Filter [Component Parts]
Cooling Water System Fan Bracket
Cooling Water System Water Pipe
Cooling Water System Radiator [Old] ## S.No. =54277 S.No.; =54277
Cooling Water System Radiator [New] ## S.No. =54278 S.No.; =54278
Cooling Water System Reserve Tank
Electrical System Alternator
Electrical System Alternator [Component Parts]
Electrical System Starter
Electrical System Starter [Component Parts]
Electrical System Battery
Electrical System Switch Sensor (Engine Lh)
Electrical System Switch Sensor (Engine Rh Muffler)
Electrical System Electrical Parts Cover
Electrical System Switch Sensor (Front)
Electrical System Switch Sensor (Body)
Electrical System Switch Sensor (Rear)
Electrical System Switch (Operation)
Electrical System Main Switch Lever Control Switch
Electrical System Relay
Electrical System Electronic Control Unit (Engine)
Electrical System Electronic Control Unit (Body) [Except [Dtsc]]
Electrical System Panel Board
Electrical System PTO Tachometer Speedmeter
Electrical System Control Panel [Except [Dtsc]]
Electrical System Control Panel [Component Parts]
Electrical System Head Light
Electrical System Head Light [Component Parts]
Electrical System Front Combination Light
Electrical System Work Light (Front)
Electrical System Work Light (Rear)
Electrical System Rear Combination Light
Electrical System Trailer Socket
Electrical System Room Light
Electrical System Cd-Radio And Speaker
Electrical System Washer Tank
Electrical System Wiper [Old] ## S.No. =54100 S.No.; =54100
Electrical System Wiper [New] ## S.No. =54101 S.No.; =54101
Electrical System Electrical Wiring (Crs) [Old] ## S.No. =54033 [Note Order By Fig.No.B50103 Ref
Electrical System Electrical Wiring (Crs) [Old] ## S.No.54034 To 54068 S.No
Electrical System Electrical Wiring (Crs) [New] ## S.No. =54069 S.No.; =54069
Electrical System Electrical Wiring (Engine)
Electrical System Electrical Wiring (Head Light) [Old] ## S.No. =54033 S.No.; =54033
Electrical System Electrical Wiring (Head Light) [New] ## S.No. =54034 S.No.; =54034
Electrical System Electrical Wiring (Panel) [Old] ## S.No. =52312 [Note Order By Fig.No
Electrical System Electrical Wiring (Panel) [Old] ## S.No.52313 To 54100 [Note Order By Ref.No
Electrical System Electrical Wiring (Panel) [New] ## S.No. =54101 S.No.; =54101
Electrical System Electrical Wiring (Rear) [Old] ## S.No. =52312 [Note Order By Fig.No
Electrical System Electrical Wiring (Rear) [Old] ## S.No.52313 To 54100 [Note Order By Ref.No
Electrical System Electrical Wiring (Rear) [New] ## S.No. =54101 S.No.; =54101
Electrical System Electrical Wiring (3p Switch) ## Note Order By Ref.No
Electrical System Electrical Wiring (Control Panel) [Except [Dtsc]]
Electrical System Electrical Wiring (Armrest)
Electrical System Electrical Wiring (Body)
Electrical System Electrical Wiring (Cab)
Clutch Transmission Clutch Housing
Clutch Transmission Power Shift Valve
Clutch Transmission Power Shift Valve (Body) [Component Parts]
Clutch Transmission Power Shift Valve (Upper) [Component Parts]
Clutch Transmission Clutch Housing Cover Lower [Except [Dtsc]]
Clutch Transmission Mid Case [Old] ## S.No. =52419 S.No.; =52419
Clutch Transmission Mid Case [New] ## S.No. =52420 S.No.; =52420
Clutch Transmission Transmission Case [Old] ## S.No. =52419 [Note Order By Ref.No
Clutch Transmission Transmission Case [New] ## S.No. =52420 S.No.; =52420
Clutch Transmission Transmission Case Rear Cover
Clutch Transmission Rear Axle Case Rh
Clutch Transmission Rear Axle Case Lh
Clutch Transmission Damper Disk
Clutch Transmission Clutch Pedal
Clutch Transmission Clutch Rod
Clutch Transmission Front Cover
Clutch Transmission Gear Support
Clutch Transmission Input Shaft
Clutch Transmission Shuttle Shaft
Clutch Transmission First Second Shift Gear
Clutch Transmission First Shaft
Clutch Transmission Third Fourth Shift Gear
Clutch Transmission Countershaft
Clutch Transmission Main Gear Shift Shaft And Range Gear Shaft [Old] ## S.No. =54114 S
Clutch Transmission Main Gear Shift Shaft And Range Gear Shaft [New] ## S.No. =54115 S
Clutch Transmission Range Gear Shaft (Front)
Clutch Transmission Range Gear Shaft (Rear) [Old] ## S.No. =54280 Note Order By Ref.No
Clutch Transmission Range Gear Shaft (Rear) [New] ## S.No. =54281 S.No.; =54281
Clutch Transmission Drive Shaft (Front)
Clutch Transmission Drive Shaft (Middle Rear)
Clutch Transmission Hi-Lo Shift Case
Clutch Transmission Bevel Gear ## Note Order By Ref.No.010 And Fig.No.D25100 Ref.No
Clutch Transmission Rear Differential
Clutch Transmission Rear Differential Lock Clutch
Clutch Transmission PTO Propeller Shaft
Clutch Transmission PTO Clutch
Clutch Transmission PTO Clutch [Component Parts] [Old] ## S.No
Clutch Transmission PTO Clutch [Component Parts] [New] ## S.No. =53273 S.No.; =53273
Clutch Transmission PTO Clutch Valve
Clutch Transmission PTO Clutch Valve [Component Parts]
Clutch Transmission PTO Drive Shaft
Clutch Transmission PTO Shaft
Clutch Transmission Hydraulic Clutch (Bi-Speed Turn) [Except [Dtsc]]
Clutch Transmission Bi-Speed Turn Shaft [Except [Dtsc]]
Speed Change Shift Fork Shift Lever Range Gear Shift Fork
Speed Change Shift Fork Shift Lever PTO Shift Fork
Speed Change Shift Fork Shift Lever Main Gear Shift Lever
Speed Change Shift Fork Shift Lever Shuttle Shift Lever
Speed Change Shift Fork Shift Lever Range Gear Shift Cable
Speed Change Shift Fork Shift Lever PTO Gear Shift Lever
Rear Axle Brake Rear Differential Lock Pedal
Rear Axle Brake Rear Axle Shaft
Rear Axle Brake Brake
Rear Axle Brake Parking Brake Lever
Rear Axle Brake Brake Pedal
Rear Axle Brake Brake Master Cylinder
Rear Axle Brake Brake Master Cylinder [Component Parts]
Rear Axle Brake Brake Pipe
Rear Axle Brake Brake Master Cylinder Pipe
Front Axle Chassis Front Axle Frame [Except [Dtsc]]
Front Axle Chassis Front Axle Bracket [Except [Dtsc]]
Front Axle Chassis Propeller Shaft [Except [Dtsc]]
Front Axle Chassis Front Differential Case [Except [Dtsc]]
Front Axle Chassis Bevel Gear (Front) [Except [Dtsc]]
Front Axle Chassis Differential Front [Except [Dtsc]]
Front Axle Chassis Front Differential Lock Clutch [Except [Dtsc]]
Front Axle Chassis Bevel Gear Case Rh
Front Axle Chassis Bevel Gear Case Lh
Front Axle Chassis Front Axle Case [Old] ## S.No. =54227 S.No.; =54227
Front Axle Chassis Front Axle Case [New] ## S.No. =54228 S.No.; =54228
Front Axle Chassis Differential Gear Shaft [Except [Dtsc]]
Steering Steering Wheel ## Note Order By Ref.No.070 And Fig.No.H14000 Ref.No
Steering Steering Post Cover
Steering Tilt Lever
Steering Telescope Lever
Steering Steering Controller
Steering Steering Controller [Component Parts]
Steering Tie Rod Steering Cylinder [Except [Dtsc]]
Steering Steering Cylinder [Component Parts]
Hydraulic System Hydraulic Pump
Hydraulic System Hydraulic Pump [Component Parts]
Hydraulic System Regulater Valve
Hydraulic System Regulater Valve [Component Parts]
Hydraulic System Hydraulic Pipe (Suction)
Hydraulic System Hydraulic Oil Line (Delivery)
Hydraulic System Safety Valve
Hydraulic System Hydraulic Oil Line (Bi-Speed Turn Rear Diff.)
Hydraulic System Hydraulic Oil Line (Front Differential) [Except [Dtsc]]
Hydraulic System Oil Cooler
Hydraulic System Hydraulic Oil Line (Oil Cooler) [Old] ## S.No. =54159 S.No.; =54159
Hydraulic System Hydraulic Oil Line (Oil Cooler) [Except [Dtsc]] [New] ## S.No
Hydraulic System Hydraulic Oil Line (Steering PTO) [Except [Dtsc]]
Hydraulic System Steering Hose (Delivery) [Except [Dtsc]]
Hydraulic System Hydraulic Valve Case
Hydraulic System Valve
Hydraulic System Valve Base
Hydraulic System Hydraulic Lift Arm
Hydraulic System Relief Valve Check Valve
Hydraulic System Lowering Lock Lever
Hydraulic System Detector Bar (Bar Bar Support)
Hydraulic System Detector Bar (Draft Link)
Hydraulic System Position Control Lever
Hydraulic System Auto Control Valve
Hydraulic System Auto Control Valve [Component Parts]
Hydraulic System Auxiliary Control Valve (With Fc) Mounting Base
Hydraulic System Auxiliary Control Valve (With Fc) (Mounting) [Component Parts]
Hydraulic System Auxiliary Control Valve (Scd With Fc) [Component Parts]
Hydraulic System Auxiliary Control Valve (Fd With Fc) [Component Parts]
Hydraulic System Auxiliary Control Valve (With Fc) Cap Reserve Tank
Hydraulic System Auxiliary Control Valve (With Fc) Lever
Hydraulic System 3p-Lift Assist Cylinder Lh
Hydraulic System 3p-Lift Assist Cylinder Rh
Hydraulic System 3p-Lift Assist Cylinder [Component Parts] [Old] ## S.No. =52200 S.No
Hydraulic System 3p-Lift Assist Cylinder [Component Parts] [New] ## S.No. =52201 S.No
3-Point Linkage Drawbar Hitch Top Link Bracket
3-Point Linkage Drawbar Hitch Lower Link
3-Point Linkage Drawbar Hitch Stabilizer
3-Point Linkage Drawbar Hitch Lift Rod Rh
3-Point Linkage Drawbar Hitch Lift Rod Lh
3-Point Linkage Drawbar Hitch Swinging Drawbar
3-Point Linkage Drawbar Hitch PTO Protector
Hood Bonnet Front Grille [Old] ## S.No. =51286 S.No.; =51286
Hood Bonnet Front Grille [New] ## S.No. =51287 S.No.; =51287
Hood Bonnet Hood (Bonnet)
Hood Bonnet Hood (Bonnet) (Sound Absorber Insulator) [Old] ## S.No. =53581 [Note1 Order By Fig.No
Hood Bonnet Hood (Bonnet) (Sound Absorber Insulator) [New] ## S.No. =53582 S.No
Hood Bonnet Hood (Bonnet) Damper
Hood Bonnet Bonnet Lock
Hood Bonnet Bonnet Frame [Old] ## S.No. =51286 [Note Order By Fig.No
Hood Bonnet Bonnet Frame [New] ## S.No. =51287 S.No.; =51287
Hood Bonnet Bonnet Support
Hood Bonnet Hood (Bonnet) Side Lower Rh
Hood Bonnet Hood (Bonnet) Side Lower Lh
Cab Cab Frame
Cab Hood (Bonnet) Rear
Cab Front Glass
Cab Door Rh
Cab Door Lh
Cab Door Lock Rh
Cab Door Lock Lh
Cab Rear Window (Upper)
Cab Sun Roof
Cab Rearview Mirror
Cab Inner Roof [Old] ## S.No. =52200 S.No.; =52200
Cab Inner Roof [New] ## S.No. =52201 S.No.; =52201
Cab Outer Roof
Cab Seat
Cab Seat [Component Parts] [Old] ## S.No. =54062 S.No.; =54062
Cab Seat [Component Parts] [New] ## S.No. =54063 S.No.; =54063
Cab Armrest
Cab Floor Mat
Cab Soundproof Material
Cab Inspection Plate (Front)
Cab Inspection Plate (Rear)
Cab Shift Cover
Cab Fender Cover Lh
Cab Fender Rh
Cab Fender Lh
Cab Cab Bracket Front
Cab Cab Bracket Rear
Cab Tool Box
Air Conditioner Air Conditioner
Air Conditioner Air Conditioner Duct Cover
Air Conditioner Air Conditioner Duct (Front)
Air Conditioner Air Conditioner Duct (Rear)
Air Conditioner Mode Case
Air Conditioner Dashboard Air Outlets
Air Conditioner Inner Air Recirculation
Air Conditioner Heater Hose
Air Conditioner Condenser
Air Conditioner Air Conditioner Hose Condenser Hose
Air Conditioner Compressor
Labels Label (Front) [Except [Dtsc]]
Labels Label (Rear Cab) [Except [Dtsc]]
Accessories Accessories
Option Ecu Kit [Option] ## S.No
Option Rear Wiper Kit [Option] ## S.No. =54187 S.No.; =54187
Option Working Light Kit [Option]
Option Front Wiper Kit [Option] ## S.No. =54100 S.No.; =54100
Option Fuel Tank Cover Kit [Option]
Option Bearing Support Replacement Kit [Except [Dtsc]] [Option] ## S.No. =52200 S.No
Option Creep Speed Kit (Gear Case) [Option]
Option Creep Speed Kit (Shift Fork) [Option]
Option Creep Speed Kit (Lever) [Option]
Option Main Gear Shift Clutch Replacement Kit 1 (Clutch) [Option] ## S.No. =54114 S.No
Option Main Gear Shift Clutch Replacement Kit 2 (Support) [Option] ## S.No. =54114 S
Option PTO (54040e) Conversion Kit (Gear) [Option]
Option 80 Inch Tread Kit [Option]
Option Oil Lubrication Pipe Kit [Except [Dtsc] [Option] ## S.No. =54159 S.No.; =54159
Option Joint Kit [Option]
Option Auxiliary Control Valve Kit (Scd With Fc) [Option]
Option Auxiliary Control Valve Kit (Fd With Fc) [Option]
Option Auxiliary Control Valve Lever Kit (With Fc) (3rd) [Option]
Option Auxiliary Control Valve Lever Kit (With Fc) (4th) [Option]
Option Hydraulic Hose Kit (Delivery) [Option]
Option Instructional Seat Kit [Option]
Option Outer Roof Seal Kit(Seal)[Option]
