Kubota Tractor M130XDTC Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M130XDTC Tractor
Number of Pages: 681 Pages
Bloque Motor(Superior) / Crankcase (Upper)
Bloque Motor(Bajar) / Crankcase (Lower)
Engrase La Cacerola / Oil Pan
Cilindro Culate / Cylinder Head
Eje Del Brazo Del Eje De Balancin [Antiguo] / Rocker Arm Shaft [Old]
Eje Del Brazo Del Eje De Balancin [Nuevo] / Rocker Arm Shaft [New]
Culata Cubierta / Head Cover
Piston Y Ciguenal / Piston And Crankshaft
Compensador / Balancer
Volante / Flywheel
Filtro Combustible / Fuel Filter
Carril Comun / Common Rail
Bomba Agua / Water Pump
Valvula De Egr / Egr Valve
Tuberia Del Agua De Egr / Egr Water Piping
Aire Limpiador / Air Cleaner
Pipa De Entrada(Aire Limpiador) / Inlet Pipe (Air Cleaner)
Silenciador / Muffler
Aceite Tubo(Turbo Cargador) / Oil Pipe (Turbo Charger)
Inter Refrigerador / Inter Cooler
Piezas Electricas Del Motor / Engine Electrical Parts
Mano Acelerador Palanca / Hand Accelerator Lever
Combustible Deposito Derecho / Fuel Tank Rh
Combustible Deposito Izquierdo / Fuel Tank Lh
Combustible Tubo 1 (Adelante) / Fuel Pipe 1 (Front)
Combustible Tubo 2 (Trasero) / Fuel Pipe 2 (Rear)
Combustible Tubo 3 (Refrigerador Del Combustible) / Fuel Pipe 3 (Fuel Cooler)
Separador / Separator
Combustible Bomba / Fuel Pump
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Sensor (Motor Izquierdo) / Sensor (Engine Lh)
Conmutador/Sensor (Motor Derecho) / Sensor (Engine Rh)
Conmutador/Sensor (Frente/Galga De Combustible) / Switch/Sensor (Front/Fuel Gauge)
Conmutador/Sensor (Cuerpo) / Switch/Sensor (Body)
Conmutador/Sensor (Pieza De La Funcion) / Switch/Sensor (Function Part)
Conmutador (Cabina/Guardabarros) / Switch (Cab/Fender)
Interruptor Principal/Interruptor Del Mando / Main Switch/Lever Control Switch
Rele / Relay
Panel Tablero / Panel Board
Tacometro De Tdf/Velocimetro / Pto Tachometer/Speedometer
Mando Panel / Control Panel
Mando Panel [Componente Piezas] / Control Panel [Component Parts]
Culata Luz [Ec] [Trk] [Saf] / Head Light [Ec] [Trk] [Saf]
Faro Delantero [Componente Piezas] [Ec] [Trk] [Saf] / Head Light [Component Parts] [Ec] [Trk] [Saf]
Intermitente Luz / Flasher Light
Adelante Trabajo Luz / Front Working Light
Trasero Trabajo Luz/Luz Del Faro [Ec] [Trk] [Saf] / Rear Work Light/Beacon Light [Ec] [Trk] [Saf]
Trasero Combinacion Luz / Rear Combination Light
Cd-Radio Y Altavoz / Cd-Radio And Speaker
Limpiaparabrisas / Wiper
Electrico Cableado (Crs) / Electrical Wiring (Crs)
Cableado Electrico (Motor/Fusible) / Electrical Wiring (Engine/Fuse)
Cableado Electrico (Faro Delantero) / Electrical Wiring (Head Light)
Cableado Electrico (Principal/Fusible) / Electrical Wiring (Main/Fuse)
Electrico Cableado (Principal/Posicion) / Electrical Wiring (Main/Position)
Cableado Electrico (Mando Panel) / Electrical Wiring (Control Panel)
Electrico Cableado (Apoyabrazo) / Electrical Wiring (Armrest)
Electrico Cableado (Cuerpo) / Electrical Wiring (Body)
Cableado Electrico (Cabina) [Ec] [Trk] [Saf] / Electrical Wiring (Cab) [Ec] [Trk] [Saf]
Potencia Cambio Valvula / Power Shift Valve
Potencia Cambio Valvula(Carroceria)[Componente Piezas] / Power Shift Valve (Body) [Component Parts]
Potencia Cambio Valvula (Superior) [Componente Piezas] / Power Shift Valve (Upper) [Component Parts]
Embrague Carcasa Cubierta / Clutch Housing Cover
Intermedia Caja / Mid Case
Transmision Caja Trasero Cubierta / Transmission Case Rear Cover
Embrague Varilla / Clutch Rod
Engranaje Soporte / Gear Support
Entrada Eje / Input Shaft
Inversor Eje / Shuttle Shaft
Primero/Segundo Cambio Engranaje / First/Second Shift Gear
Primer Eje / First Shaft
Tercero/Cuarto Cambio Engranaje / Third/Fourth Shift Gear
Arbol Contrarrotante / Countershaft
Principal Engranaje Cambio Eje Y Gama Engranaje Eje / Main Gear Shift Shaft And Range Gear Shaft
Accionar Eje(Adelante) / Drive Shaft (Front)
Accionar Eje(Medio/Trasero) / Drive Shaft (Middle/Rear)
Caso De La Cambio De Hi-Lo / Hi-Lo Shift Case
Bisel Engranaje / Bevel Gear
Diferencial Trasero / Differential Rear
Trasero Diferencial Cerradura Embrague / Rear Differential Lock Clutch
Pto Helice Eje / Pto Propeller Shaft
Pto Embrague / Pto Clutch
Pto Embrague [Componente Piezas] [Antiguo] / Pto Clutch [Component Parts] [Old]
Pto Embrague [Componente Piezas] [Nuevo] / Pto Clutch [Component Parts] [New]
Pto Embrague Valvula / Pto Clutch Valve
Pto Embrague Valvula [Componente Piezas] / Pto Clutch Valve [Component Parts]
Pto Accionar Eje / Pto Drive Shaft
Pto Eje / Pto Shaft
Hidraulico Embrague (Bi-Velocidad Girar) / Hydraulic Clutch (Bi-Speed Turn)
Bi-Velocidad Girar Eje / Bi-Speed Turn Shaft
Pto Cambio Bifurcacion / Pto Shift Fork
Inversor Cambio Palanca / Shuttle Shift Lever
Gama Engranaje Cambio Varilla / Range Gear Shift Rod
Trasero Diferencial Cerradura Pedal / Rear Differential Lock Pedal
Trasero Eje / Rear Axle
Freno / Brake
Estacionamiento Freno / Parking Brake
Freno Pedal / Brake Pedal
Freno Aceite Deposito / Brake Oil Tank
Freno Tubo / Brake Pipe
Adelante Helice Eje / Front Propeller Shaft
Adelante Diferencial Cerradura Embrague / Front Differential Lock Clutch
Bisel Engranaje Caja Derecho / Bevel Gear Case Rh
Bisel Engranaje Caja Izquierdo / Bevel Gear Case Lh
Adelante Eje / Front Axle
Diferencial Eje Del Engranaje / Differential Gear Shaft
Junta De Direccion [Antiguo] / Steering Joint [Old]
Junta De Direccion [Nuevo] / Steering Joint [New]
Direccion Controlador [Componente Piezas] [Antiguo] / Steering Controller [Component Parts] [Old]
Direccion Controlador [Componente Piezas] [Nuevo] / Steering Controller [Component Parts] [New]
Atar Varilla/Direccion Cilindro [Antiguo] / Tie Rod/Steering Cylinder [Old]
Atar Varilla/Direccion Cilindro [Nuevo] / Tie Rod/Steering Cylinder [New]
Direccion Cilindro [Componente Piezas] [Antiguo] / Steering Cylinder [Component Parts] [Old]
Direccion Cilindro [Componente Piezas] [Nuevo] / Steering Cylinder [Component Parts] [New]
Hidraulico Bomba / Hydraulic Pump
Hidraulico Bomba (Potencia Direccion) [Componente Piezas] / Hydraulic Pump (Ps) [Component Parts]
Hidraulico Bomba (3p) [Componente Piezas] / Hydraulic Pump (3p) [Component Parts]
Regulador Valvula / Regulater Valve
Regulador Valvula[Componente Piezas] / Regulater Valve [Component Parts]
Hidraulico Tubo (Aspiracion) / Hydraulic Pipe (Suction)
Hidraulico Tubo (Entrega) / Hydraulic Pipe (Delivery)
Hidraulico Aceite Linea / Hydraulic Oil Line
Remolque Freno Valvula / Trailer Brake Valve
Seguridad Valvula / Safety Valve
Hidraulico Aceite Linea(Bi-Velocidad Girar/Trasero Dfrncl) / Hydraulic Oil Line (Bi-Speed Turn/Rear Diff.)
Hidraulico Aceite Linea(Adelante Diferencial) / Hydraulic Oil Line (Front Differential)
Hidraulico Aceite Linea (Aceite Refrigerador) / Hydraulic Oil Line (Oil Cooler)
Hidraulico Aceite Linea (Direccion/Pto) / Hydraulic Oil Line (Steering/Pto)
Hidraulico Ascenso Brazo / Hydraulic Lift Arm
Hidraulico Cilindro Cubierta / Hydraulic Cylinder Cover
Esfuerzo Control Valvula / Draft Control Valve
Esfuerzo Control Valvula [Componente Piezas] / Draft Control Valve [Component Parts]
Detector Barra 1(Barra/Barra Soporte) / Detector Bar 1 (Bar/Bar Support)
Detector Barra 2(Esfuerzo Vinculo) / Detector Bar 2 (Draft Link)
Coloque La Palanca De Mando / Position Control Lever
Distribuidor De Servicios Externos / Auxiliary Control Valve
Distribuidor De Servicios Externos (Fd) [Componente Piezas] / Auxiliary Control Valve (Fd) [Component Parts]
Distribuidor De Servicios Externos (Scd) [Componente Piezas] / Auxiliary Control Valve (Scd) [Component Parts]
Tubo De Distribuidor De Servicios Externos / Auxiliary Control Valve Pipe
Palanca De Distribuidor De Servicios Externos / Auxiliary Control Valve Lever
Ayudar Cilindro Izquierdo / Assist Cylinder Lh
Ayudar Cilindro Derecho / Assist Cylinder Rh
Ayudar Cilindro [Componente Piezas] / Assist Cylinder [Component Parts]
Bajar Vinculo / Lower Link
Estabilizador / Stabilizer
Ascenso Varilla Derecho / Lift Rod Rh
Pto Eje Protector / Pto Shaft Protector
Capo(Capo) Superior / Hood(Bonnet) Upper
Capo Bastidor / Bonnet Frame
Capo Soporte / Bonnet Support
Capo(Capo)Lado Bajar Derecho / Hood(Bonnet) Side Lower Rh
Capo(Capo)Lado Bajar Izquierdo / Hood(Bonnet) Side Lower Lh
Capo(Capo)Trasero / Hood(Bonnet) Rear
Cabina Bastidor / Cab Frame
Adelante Vidrio / Front Glass
Puerta Derecho / Door Rh
Puerta Izqd / Door Lh
Cerradura De Puerta Izqd / Door Lock Lh
Lado Ventana / Side Window
Trasero Ventana (Superior) / Rear Window (Upper)
Trasero Ventana (Baje) / Rear Window (Lower)
Interno Techo / Inner Roof
Externo Techo / Outer Roof
Asiento [Antiguo] / Seat [Old]
Asiento [Nuevo] / Seat [New]
Apoyabrazo / Armrest
Piso Estera / Floor Mat
Inspeccion Placa (Delantero) / Inspection Plate (Front)
Inspeccion Placa (Trasero) / Inspection Plate (Rear)
Cambio Palanca Guia / Shift Lever Guide
Guardabarros Cubierta / Fender Cover
Montante Cubierta / Pillar Cover
Guardabarros Izquierdo / Fender Lh
Herramienta Caja / Tool Box
Aire Acondicionador Controlador / Air Conditioner Controller
Aire Acondicionador Conducto / Air Conditioner Duct
Ventilador Motor / Blower Motor
Condensador / Condenser
Aire Acondicionador Manguito/Condensador Manguito / Air Conditioner Hose / Condenser Hose
Compresor / Compressor
Vaciar Manguito / Drain Hose
Etiqueta 1 (Capo) / Label 1 (Bonnet/Panel)
Etiqueta 2 (Adelante) / Label 2 (Front)
Etiqueta 3 (Trasero) / Label 3 (Rear)
Etiqueta 4 (Cabina) / Label 4 (Rear/Cab)
Trasero Desempanador Kit[Opcion] / Rear Defogger Kit [Option]
Combustible Deposito Cubierta Kit[Opcion] / Fuel Tank Cover Kit [Option]
Teniento Kit De Sustitucion De Soporte [Opcion] / Bearing Support Replacement Kit [Option]
Marcha Muy Lenta Velocidad Kit 1(Engranaje Caja)[Opcion] / Creep Speed Kit 1 (Gear Case) [Option]
Marcha Muy Lenta Velocidad Kit 2(Cambio Bfrccn/Plnc)[Opcion] / Creep Speed Kit 2 (Shift Fork/Lever) [Option]
80 Pulgada Ancho De Via Kit[Opcion] / 80 Inch Tread Kit [Option]
Kit De Distribuidor De Servicios Externos (Scd) (Tercero) [Opcion] / Auxiliary Control Valve Kit (Scd) (3rd) [Option]
Kit De Distribuidor De Servicios Externos (Fd) (Tercero) [Opcion] / Auxiliary Control Valve Kit (Fd) (3rd) [Option]
Kit De Distribuidor De Servicios Externos (S/D) (Tercero) [Opcion] / Auxiliary Control Valve Kit (S/D) (3rd) [Option]
Kit De Distribuidor De Servicios Externos (Scd) (Cuarto) [Opcion] / Auxiliary Control Valve Kit (Scd) (4th) [Option]
Kit De Distribuidor De Servicios Externos (Scd/Fc) (Cuarto) [Opcion] / Auxiliary Control Valve Kit (Scd/Fc) (4th) [Option]
Kit De Distribuidor De Servicios Externos (Fd) (Cuarto) [Opcion] / Auxiliary Control Valve Kit (Fd) (4th) [Option]
Kit De Distribuidor De Servicios Externos (Fc) [Opcion] / Auxiliary Control Valve Kit (Fc) [Option]
Distribuidor De Servicios Externos (Scd/Fc) [Componente Piezas] [Antiguo] [Opcion] / Auxiliary Control Valve (Scd/Fc) [Component Parts] [Old] [Option]
Distribuidor De Servicios Externos (Scd/Fc) [Componente Piezas] [Nuevo] [Opcion] / Auxiliary Control Valve (Scd/Fc) [Component Parts] [New] [Option]
Distribuidor De Servicios Externos (Fc) [Componente Piezas] [Opcion] / Auxiliary Control Valve (Fc) [Component Parts] [Option]
Distribuidor De Servicios Externos (S/D) [Componente Piezas] [Opcion] / Auxiliary Control Valve (S/D) [Component Parts] [Option]
Kit De Palanca De Distribuidor De Servicios Externos (Tercero) [Opcion] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Kit De Palanca De Distribuidor De Servicios Externos (Cuarto) [Opcion] / Auxiliary Control Valve Lever Kit (4th) [Option]
Asiento Del Instructor [Opcion] / Instructional Seat Kit [Option]
Volante / Flywheel
Ventilador / Fan
Rele / Relay
Pto Eje / Pto Shaft
Freno / Brake
