Kubota Tractor M128XDTC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M128XDTC Tractor
Number of Pages: 399 Pages
Bloco Motor(Superior) / Crankcase (Upper)
Bloco Motor(Inferior) / Crankcase (Lower)
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhaus T Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Compensador / Balancer
Volante Motor / Flywheel
Filtro Gasoleo / Fuel Filter
Injector E Vela Aquecimento / Injector And Glow Pl Ug
Common Rail / Common Rail
Bomba Agua E Termostacto / Water Flange And Thermo Stat
Acessorios / Water Pump
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Tubo Agua Valvula Egr / Egr Water Piping
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [Compo Nent Parts]
Tubo Aspiracao / Inlet Pipe (Air Cleaner)
Escpae / Muffler
Panela Escape / Muffler Pipe
Tubo Oleo (Turbo) / Oil Pipe (Turbo Charger)
Intercooler / Inter Cooler
Radiador Oleo / Oil Cooler
Componentes Electricos Motor / Engine Electrical P Arts
Cabo Acelerador / Accelerator Wire
Deposito Combustivel (Drt) / Fuel Tank Rh
Tubo Combustivel / Fuel Pipe 1 (Rear)
Tubo Combustivel / Fuel Pipe 2 (Front)
Tubo Combustivel / Fuel Pipe 3 (Fuel Cooler)
Separador / Separator [Old]
Separador / Separator [New]
Separador[Peças Componentes] / Separator [Component Parts] [Old]
Separador[Peças Componentes] / Separator [Component Parts] [New]
Bomba Gasoleo / Fuel Pump [O Ld]
Bomba Gasoleo / Fuel Pump [N Ew]
Bomba Gasoleo[Peças Componen Tes] / Fuel Pump [Component Parts]
Suporte Ve Ntilador / Fan Bracket
Ventilador / Fan
Radiador / Water Pipe
Deposito R Eserva / Reserve Tank
Alternador / Alternator
Motor Arranque / Starter
Motor Arranque [Componentes ] / Starter [Component Parts]
Interruptor/Sensor / Sensor (Engine Lh)
Interruptor/Sensor / Switch /Sensor (Engine Rh)
Interruptor/Sensor / Switch /Sensor (Front/Fuel Gauge)
Interruptor/Sensor / Switch /Sensor (Body)
Interruptor / Rele / Switch /Sensor (Function Part)
Interruptor / Switch (Cab/F Ender)
Interruptor Principal / Mai N Switch/Lever Control Switch
Interruptor / Rele / Relay
Painel / Panel Board
Painel[Peças Componentes] / Panel Board [Component Parts]
Conta Rotaçoes Tdf / Veloci Metro / Pto Tachometer/Speedometer
Painel Control / Control Pa Nel
Painel Control[Peças Compon Entes] / Control Panel [Component Parts]
Farol Dianteiro / Head Ligh T
Flasher Light / Flasher Lig Ht
Luzes Trabalho / Front Work Ing Light
Farois Trabalho (Traseiros) / Rear Work Light/Beacon Light [Ec]
Braco Traseiro / Rear Combi Nation Light
Ficha Reboque / Trailer Soc Ket
Radio Cd E Columnas / Cd-Ra Dio And Speaker
Depósito De Lavagem / Washe R Tank
Escova Limpa Vidros / Wiper
Cablagem Electrica (Crs) / Electrical Wiring (Crs)
Cablagem Electrica (Motor) / Electrical Wiring (Engine/Fuse)
Cablagem Eletrica (Luzes Fr Ente) / Electrical Wiring (Head Light)
Cablagem Eletrcia (Frente) / Electrical Wiring (Main/Fuse)
Cablagem Electrica / Electr Ical Wiring (Main/Position)
Cablagem Electrica (Painel Contrl) / Electrical Wiring (Control Panel)
Cablagem Electrica / Electr Ical Wiring (Body)
Cabalagem Eletrica(Cabine)[ Ec] [G] / Electrical Wiring (Cab) [Ec]
Valvula Powershift / Power Shift Valve
Valvula Powershift[P Eças Componentes] / Power Shift Valve (Body) [Compo Nent Parts]
Valvula Powershift[P Eças Componentes] / Power Shift Valve (Upper) [Comp Onent Parts]
Carter Embraiagem / Clutch Housing Cover
Caixa Intermedia / M Id Case
Carter Transmissao / Transmission Case Rear Cover
Carter Eixo Traseiro Drt (Tipo Arco) / Rear Axle Case Rh
Carter Eixo Traseiro Esq (Tipo Arco) / Rear Axle Case Lh
Disco Amortecedor / Damper Disk
Bloqueio Diferencial / Clutch Pedal
Embraiagem / Clutch Rod
Suporte Carreto / Ge Ar Support
Veio Primario / Inpu T Shaft
Veio Inversor / Shut Tle Shaft
Primeira/Segunda Mud Ança / First/Second Shift Gear
Primeiro Veio / Firs T Shaft
Carreto Terceira/Qua Rta / Third/Fourth Shift Gear
Veio Secundario / Co Untershaft
Carreto Principal / Main Gear Shift Shaft And Range Gear Shaft
Veio (Frente) / Driv E Shaft (Front)
Veio (Meio/Traseiro) / Drive Shaft (Middle/Rear)
Sistema Hi-Lo / Hi-L O Shift Case
Grupo Conico / Bevel Gear
Diferencial Traseiro / Differential Rear
Embraiagem Bloqueio Diferencial Traseiro / Rear Differential Lock Clutc H
Veio Tdf / Pto Prope Ller Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf[Peças Componentes] / Pto Clutch [Component Parts]
Valvula Embraiagem T Df / Pto Clutch Valve
Valvula Embraiagem T Df[Peças Componentes] / Pto Clutch Valve [Component Parts]
Tdf / Veio Tdf / Pto Drive Shaft
Veio Tdf / Pto Shaft
Embraiagem Hidraulic A (Bi Speed) / Hydraulic Clutch (Bi-Speed Turn)
Veio Bi-Speed / Bi-S Peed Turn Shaft
Forqueta Caixa / Creeper / Range Gear Sh Ift Fork
Alvanca Tdf / Pto Shift Fork
Alavanca Velocidades / Main Gear Shift L Ever
Range Gear Shift Rod / Range Gear Shift Rod
Pedal Bloqueio Diferencia L Traseiro / Rear Differential Lock Pedal
Eixo Traseiro / Rear Axle
Travão / Brake
Alavanca Travao Mao / Par King Brake Lever
Travão De Estacionamento / Parking Brake
Pedal Travao / Brake Peda L
Deposito Oleo Travoes / B Rake Oil Tank
Cilindro Travao Principal [Peças Componentes] / Brake Master Cylinder [Compon Ent Parts]
Tubo Travao / Brake Pipe
Suporte Eixo Dianteiro / Front Axle Bracket
Front Propeller Shaft [Old] / Front Propeller Shaft [Old]
Front Propeller Shaft [New] / Front Propeller Shaft [New]
Caixa Diferencial Dian Teiro / Front Differential Case
Engrenagem Cónica (Dia Nteira) / Bevel Gear (Front)
Diferencial Dianteiro / Differential Front
Bloqueio Diferencial F Rente / Front Differential Lock Clutch
Caixas Engrenagens Con Ica(Drt) / Bevel Gear Case Rh
Caixas Engrenagens Con Ica(Esq) / Bevel Gear Case Lh
Carter Eixo / Front Ax Le Case
Grupo Conico / Differe Ntial Gear Shaft
Direcção Assistida / Direção Punho / Steering Handle
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção[Peças Componentes] / St Eering Controller [Component Parts] [Old]
S. No.;>=50538
Direcção Assistida / Tie Rod/Steering Cylinde R
Cilindro Direccao [Peças Componentes(Antiga) / Steering Cylinder [Component Parts] [Old]
Cilindro Direccao [Peças Componentes(Nova) / Steering Cylinder [Component Parts] [New]
Bomba Hidraulico[Peças Compon Entes] / Hydraulic Pump (Ps) [Component Parts]
Bomba Hidraulico[Peças Compon Entes] / Hydraulic Pump (3p) [Component Parts]
Válvula Do Regulador / Regula Ter Valve
Valvula Reguladora[Peças Comp Onentes] / Regulater Valve [Component Parts]
Linha Aspiração / Hydraulic P Ipe (Suction)
Tubo Oleo / Hydraulic Pipe (D Elivery)
Tubo Hidraulico / Hydraulic O Il Line
Valvula Travao Reboque / Trai Ler Brake Valve [Old Type]
Valvula Travao Reboque / Trai Ler Brake Valve [New Type]
Valvula Segurança / Safety Va Lve
Circuito Oleo Hidraulico(Bi S Peed) / Hydraulic Oil Line (Bi-Speed Turn/Rear Diff .)
Circuito Oleo Hidraulico(Dife Rencial Frente) / Hydraulic Oil Line (Front Differe Ntial)
Circuito Oleo Radiador / Hydr Aulic Oil Line (Oil Cooler)
Tubo Direccao / Steering Hose (Delivery)
Cilindro Hidraulico / Hydraul Ic Cylinder
Braço De Elevação Hidráulico / Hydraulic Lift Arm
Hydraulic Cylinder Cover / Hy Draulic Cylinder Cover
Trinco / Lowering Lock Lever
Draft Control Valve / Draft C Ontrol Valve
Draft Control Valve [Componen T Parts] / Draft Control Valve [Component Parts]
Barra Deflectora (Suporte) / Detector Bar 1 (Bar/Bar Support)
Barra Deflectora / Detector B Ar 2 (Draft Link)
Alavanca Control Posicao / Po Sition Control Lever
Distribuidor Auxiliar / Auxil Iary Control Valve
Valvula Auxiliar [Peças Compo Nentes] / Auxiliary Control Valve (Fd) [Component Parts] [Old]
Valvula Auxiliar [Peças Compo Nentes] / Auxiliary Control Valve (Fd) [Component Parts] [New]
Valvula Auxiliar [Peças Compo Nentes] / Auxiliary Control Valve (Scd) [Component Parts] [Old]
Valvula Auxiliar [Peças Compo Nentes] / Auxiliary Control Valve (Scd) [Component Parts] [New]
Auxiliary Control Valve Pipe / Auxiliary Control Valve Pipe
Assist Cylinder Lh / Assist C Ylinder Lh
Assist Cylinder Rh / Assist C Ylinder Rh
Cilindro Auxiliar (Componente S) / Assist Cylinder [Component Parts]
Parte Superior / Top Link Bracket
Ligaca O Superior / Top Link
Ligaca O Inferior / Lower Link
Estabi Lizador / Stabilizer
Estabi Lizador(Drt) / Lift Rod Rh
Estabi Lizador(Esq) / Lift Rod Lh
Barra / Drawbar Bracket
Protec Cao Tdf / Pto Shaft Protector
Capot Superior / Hood(Bonnet) Upper
Amortecedor Capot / Hood(Bonnet) Damper
Trico Capot / Bonnet Lock
Hood(Bonnet) Side Lower / Hood(Bonnet) Side L Ower
Capot Traseiro / Hood(Bonnet) Rear
Estr Utura Cabine / Cab Frame
Vidr O Frente E Traseiro / Front Glass
Port A(Drt) / Door Rh
Port A(Esq) / Door Lh
Trin Co Porta(Drt) / Door Lock Rh
Trin Co Porta(Esq) / Door Lock Lh
Lado Vidro / Side Window
Vidr O Traseiro / Rear Window (Upper)
Espe Lho Rectrovisor / Rearview Mirror
Tect O Interior / Inner Roof
Tect O Abrir / Outer Roof
Aces Sorios / Seat
Apoi O Braço / Armrest [Old]
Apoi O Braço / Armrest [New]
Chap A Inspecção(Frente) / Inspection Plate (Front)
Chap A Inspecção(Traseira) / Inspection Plate (Rear)
Tamp A / Shift Lever Guide
Cobe Rtura Do Guarda-Lamas / Fender Cover
Pill Ar Cover / Pillar Cover
Guar Da Lamas(Drt) / Fender Rh
Guar Da Lamas(Esquerda) / Fender Lh
Dian Teira Do Suporte Da Cabine / Cab Bracket Front
Supo Rte Cabine Traseiro / Cab Bracket Rear
Caix A Ferramenta / Tool Box
Comando Ar Condicionado / Air Conditioner Controller
Air Condicionado / Air Conditi Oner
Tubo Ar Condicionado / Air Con Ditioner Duct
Blower Motor / Blower Motor
Condesador / Condenser
Tubo Ar Condicionado/Tubo Cond Ensador / Air Conditioner Hose / Condenser Hose
Compressor / Compressor
Mangueira De Drenagem / Drain Hose
Etiqueta 1 / Label 1 (Front)
Acessorios / Accessori Es And Service Parts
Separator Kit [Option] / Separator Kit [Option]
Desempanador (Opcao) / Rear Defogger Kit [Option]
Kit Cobertuta Deposito Gasoleo / Fuel Tank Cover K It [Option]
Propeller Shaft Kit [Option] / Propeller Shaft Kit [Option]
Kit Caixa Crepper(Opção) / Creep Speed Kit 1 (Gear Case) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Co Ntrol Valve Kit (Scd) (3rd) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Co Ntrol Valve Kit (Fd) (3rd) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Co Ntrol Valve Kit (S/D) (3rd) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Co Ntrol Valve Kit (Scd) (4th) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Co Ntrol Valve Kit (Scd/Fc) (4th) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Co Ntrol Valve Kit (Fd) (4th) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Co Ntrol Valve Kit (Fc) [Option]
Kit Distribuidor Serviços Externos[Peças Component Es][Opcao] / Auxiliary Control Valve (Scd/Fc) [Comp Onent Parts] [Old] [Option]
Kit Distribuidor Serviços Externos[Peças Component Es][Opcao] / Auxiliary Control Valve (Scd/Fc) [Comp Onent Parts] [New] [Option]
Kit Distribuidor Serviços Externos[Peças Component Es][Opcao] / Auxiliary Control Valve (S/D) [Compone Nt Parts] [Old] [Option]
Kit Distribuidor Serviços Externos[Peças Component Es][Opcao] / Auxiliary Control Valve (S/D) [Compone Nt Parts] [New] [Option]
Kit Distribuidor Serviços Externos[Peças Component Es][Opcao] / Auxiliary Control Valve (Fc) [Componen T Parts] [Option]
Kit Alavanca Serviços Externos[Opcao] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Kit Alavanca Serviços Externos[Opcao] / Auxiliary Control Valve Lever Kit (4th) [Option]
Banco Passageiro[Opcao] / Instructional Seat Kit [ Option]
