Kubota Tractor M128XDTC Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M128XDTC Tractor
Number of Pages: 671 Pages
Bloque Motor(Superior) / Crankcase (Upper)
Bloque Motor(Bajar) / Crankcase (Lower)
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Compensador / Balancer
Volante / Flywheel
Carril Comun / Common Rail
Agua Bomba / Water Pump
Valvula De Egr Y Refrigerador De Egr / Egr Valve
Tuberia Del Agua De Egr / Egr Water Piping
Aire Limpiador / Air Cleaner
Aire Limpiador(Componente Piezas) / Air Cleaner [Component Parts]
Pipa De Entrada(Aire Limpiador) / Inlet Pipe (Air Cleaner)
Silenciador / Muffler
Aceite Tubo(Turbo Cargador) / Oil Pipe (Turbo Charger)
Intercooler / Inter Cooler
Piezas Electricas Del Motor / Engine Electrical Parts
Palanca De Acelerador De Mano / Hand Accelerator Lever
Acelerador Cable / Accelerator Wire
Deposito De Combustible Dcha / Fuel Tank Rh
Deposito De Combustible Izqd / Fuel Tank Lh
Combustible Tubo 1 (Deposito) / Fuel Pipe 1 (Rear)
Combustible Tubo 2 (Motor) / Fuel Pipe 2 (Front)
Combustble Tubo 3 (Refrigerador Del Combustible) / Fuel Pipe 3 (Fuel Cooler)
Decantador [Antiguo] / Separator [Old]
Decantador [Nuevo] / Separator [New]
Separador [Componente Piezas] [Antiguo] / Separator [Component Parts] [Old]
Separador [Componente Piezas] [Nuevo] / Separator [Component Parts] [New]
Combustible Bomba [Antiguo] / Fuel Pump [Old]
Combustible Bomba [Nuevo] / Fuel Pump [New]
Combustible Bomba[Componente Piezas] / Fuel Pump [Component Parts]
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Sensor (Motor Izquierdo) / Sensor (Engine Lh)
Conmutador/Sensor (Combustrible/Cubierta) / Switch/Sensor (Front/Fuel Gauge)
Conmutador/Sensor (Cuerpo) / Switch/Sensor (Body)
Conmutador/Rele (Pieza De La Funcion) / Switch/Sensor (Function Part)
Interruptor Interno Del Cabina / Switch (Cab/Fender)
Interruptor Principal/Interruptor Del Mando / Main Switch/Lever Control Switch
Rele De Arranque / Relay
Tablero Panel / Panel Board
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Tacometro De Tdf/Velocimetro / Pto Tachometer/Speedometer
Mando Panel / Control Panel
Mando Panel [Componente Piezas] / Control Panel [Component Parts]
Culata Luz / Head Light
Luz Intermitente / Flasher Light
Trabajo Luz/Luz Del Faro / Front Working Light
Trasero Trabajo Luz [Ec] / Rear Work Light/Beacon Light [Ec]
Luces Combinadas Traseras / Rear Combination Light
Altavoz De Cd-Radio / Cd-Radio And Speaker
Limpiaparabrisas / Wiper
Electrico Cableado (Crs) / Electrical Wiring (Crs)
Cableado Electrico (Motor/Fusible) / Electrical Wiring (Engine/Fuse)
Cableado Electrico (Faro Delantero) / Electrical Wiring (Head Light)
Electrico Cableado (Motor/Capo(Capo)) / Electrical Wiring (Main/Fuse)
Electrico Cableado (Principal/Posicion) / Electrical Wiring (Main/Position)
Cableado Electrico (Mando Panel) / Electrical Wiring (Control Panel)
Electrical Wiring 1 [Excepto Tipo Doble Aguilon] / Electrical Wiring (Body)
Cableado Electrico (Cabina) [Ec] / Electrical Wiring (Cab) [Ec]
Carcasa De Embrague / Clutch Housing
Potencia Cambio Valvula / Power Shift Valve
Potencia Cambio Valvula (Carroceria) [Componente Piezas] / Power Shift Valve (Body) [Component Parts]
Potencia Cambio Valvula(Superior)[Componente Piezas] / Power Shift Valve (Upper) [Component Parts]
Embrague Carcasa Cubierta / Clutch Housing Cover
Caja Intermedia / Mid Case
Varilla De Embrague / Clutch Rod
Engranaje Soporte / Gear Support
Eje De Entrada / Input Shaft
Inversor Eje / Shuttle Shaft
Primero/Segundo Cambio Engranaje / First/Second Shift Gear
Primer Eje / First Shaft
Tercero/Cuarto Cambio Engranaje / Third/Fourth Shift Gear
Arbol Contrarrotante / Countershaft
Principal Engranaje Cambio Eje Y Gama Engranaje Eje / Main Gear Shift Shaft And Range Gear Shaft
Accionar Eje(Adelante) / Drive Shaft (Front)
Accionar Eje(Medio/Trasero) / Drive Shaft (Middle/Rear)
Caso De La Cambio De Hi-Lo / Hi-Lo Shift Case
Eje De Engranaje Diferencial / Bevel Gear
Trasero Diferencial / Differential Rear
Trasero Diferencial Cerradura Embrague / Rear Differential Lock Clutch
Eje Propulsor De Tdf / Pto Propeller Shaft
Tdf Embrague / Pto Clutch
Embrague De Tdf [Componente Piezas] / Pto Clutch [Component Parts]
Pto Embrague Valvula [Componente Piezas] / Pto Clutch Valve [Component Parts]
Eje Motor De Tdf / Pto Drive Shaft
Eje De Tdf / Pto Shaft
Embrague Hidraulico (Impulsion Delantera De La Rueda) / Hydraulic Clutch (Bi-Speed Turn)
Bi-Velocidad Girar Eje / Bi-Speed Turn Shaft
Horquilla De Cambio De Gama / Range Gear Shift Fork
Pto Cambio Bifurcacion / Pto Shift Fork
Palanca De Cambio Principal / Main Gear Shift Lever
Inversor Cambio Palanca / Shuttle Shift Lever
Varilla Cambio De Gama/Varilla Cambio Creeper / Range Gear Shift Rod
Eje Trasero / Rear Axle
Freno / Brake
Estacionamiento Freno / Parking Brake
Freno Pedal / Brake Pedal
Deposito De Aceite De Freno / Brake Oil Tank
Freno Maestro Cilindro [Componente Piezas] [Tipo Cabina] / Brake Master Cylinder [Component Parts]
Tubo De Freno / Brake Pipe
Soporte De Eje Delantero / Front Axle Bracket
Adelante Helice Eje [Antiguo] / Front Propeller Shaft [Old]
Adelante Helice Eje [Nuevo] / Front Propeller Shaft [New]
Engranaje Conico(Anterior) / Bevel Gear (Front)
Embrague De Bloqueo De Diferencial Delantero / Front Differential Lock Clutch
Caja De Engranaje Conico Dcha / Bevel Gear Case Rh
Caja De Engranaje Conico Izqd / Bevel Gear Case Lh
Adelante Eje / Front Axle
Diferencial Eje Del Engranaje / Differential Gear Shaft
Direccion Controlador[Componente Piezas] [Antiguo] / Steering Controller [Component Parts] [Old]
Direccion Controlador [Componente Piezas] [Nuevo] / Steering Controller [Component Parts] [New]
Cilindro De Direccion [Componente Piezas] [Antiguo] / Steering Cylinder [Component Parts] [Old]
Cilindro De Direccion[Componente Piezas] [Nuevo] / Steering Cylinder [Component Parts] [New]
Bomba Hidraulica [Componentes] / Hydraulic Pump (Ps) [Component Parts]
Bomba Hidraulica [Componentes] / Hydraulic Pump (3p) [Component Parts]
Valvula Reguladora / Regulater Valve
Regulador Valvula[Componente Piezas] / Regulater Valve [Component Parts]
Tubo Hidraulico(Aspiracion)[Tipo Arco] / Hydraulic Pipe (Suction)
Tubo Hidraulico(Impulsion)[Tipo Arco] / Hydraulic Pipe (Delivery)
Pipa Hidraulica / Hydraulic Oil Line
Remolque Freno Valvula / Trailer Brake Valve [Old Type]
Remolque Freno Valvula / Trailer Brake Valve [New Type]
Seguridad Valvula / Safety Valve
Hidraulico Aceite Linea(Bi-Velocidad Girar/Trasero Dfrncl) / Hydraulic Oil Line (Bi-Speed Turn/Rear Diff.)
Hidraulico Aceite Linea(Adelante Diferencial) / Hydraulic Oil Line (Front Differential)
Radiador De Aceite / Oil Cooler
Linea De Aceite Hidraulico(Radiador De Aceite)[Tipo Cabina] / Hydraulic Oil Line (Oil Cooler)
Linea De Aceite Hidraulico(Direccion/Tdf)[Tipo Cabina] / Hydraulic Oil Line (Steering/Pto)
Latiguillo De Direccion(Impulsion) / Steering Hose (Delivery)
Piston Hidraulico/Brazo De Elevacion / Hydraulic Lift Arm
Cubierta De Cilindro Hidraulico / Hydraulic Cylinder Cover
Esfuerzo Control Valvula / Draft Control Valve
Valvula De Esfuerzo [Comp Piezas] [Se] [ [Ce][Uk]Opcion] [Viejo Tipo] / Draft Control Valve [Component Parts]
Detector Barra 1(Barra/Barra Soporte) / Detector Bar 1 (Bar/Bar Support)
Detector Barra 2(Esfuerzo Vinculo) / Detector Bar 2 (Draft Link)
Coloque La Palanca De Mando / Position Control Lever
Distribuidor De Servicios Externos / Auxiliary Control Valve
Distribuidor De Servicios Externos (Fd) [Componente Piezas] [Antiguo] / Auxiliary Control Valve (Fd) [Component Parts] [Old]
Distribuidor De Servicios Externos (Fd) [Componente Piezas] [Nuevo] / Auxiliary Control Valve (Fd) [Component Parts] [New]
Distribuidor De Servicios Externos (Scd) [Componente Piezas] [Antiguo] / Auxiliary Control Valve (Scd) [Component Parts] [Old]
Distribuidor De Servicios Externos (Scd) [Componente Piezas] [Nuevo] / Auxiliary Control Valve (Scd) [Component Parts] [New]
Tubo De Distribuidor De Servicios Externos / Auxiliary Control Valve Pipe
Palanca De Distribuidor De Servicios Externos / Auxiliary Control Valve Lever
Ayudar Cilindro Izquierdo / Assist Cylinder Lh
Ayudar Cilindro Derecho / Assist Cylinder Rh
Ayudar Cilindro [Componente Piezas] [Uk] / Assist Cylinder [Component Parts]
Soporte De Tercer Punto / Top Link Bracket
3-Punto Varillaje / Lower Link
Estabilizador / Stabilizer
Varilla De Elevacion Izqd / Lift Rod Lh
Ayudar Cilindro Soporte / Drawbar Bracket
Protector De Eje De Tdf / Pto Shaft Protector
Capo Superior / Hood(Bonnet) Upper
Amortiguador De La Capo / Hood(Bonnet) Damper
Soporte De Capo / Bonnet Support
Capo Lateral Inferior / Hood(Bonnet) Side Lower
Capo Posterior / Hood(Bonnet) Rear
Bastidor De Cabina / Cab Frame
Adelante Vidrio / Front Glass
Puerta Derecho / Door Rh
Puerta Izqd / Door Lh
Cerradura De Puerta Izqd / Door Lock Lh
Lado Vidrio / Side Window
Trasero Ventana (Superior) [Tipo Cabina] / Rear Window (Upper)
Trasero Ventana / Rear Window
Techo Interior / Inner Roof
Externo Techo / Outer Roof
Hoja / Seat
Apoyabrazo [Antiguo] / Armrest [Old]
Apoyabrazo [Nuevo] / Armrest [New]
Alfombrilla De Piso / Floor Mat
Placa De Inspeccion[Tipo Cabina] / Inspection Plate (Front)
Inspeccion Placa (Trasero) / Inspection Plate (Rear)
Cambie De Puesto La Cubierta / Shift Lever Guide
Guardabarros Cubierta / Fender Cover
Cubierta De Montante / Pillar Cover
Guardabarros / Fender Rh
Guardabarros Izqd / Fender Lh
Soporte Posterior De Cabina / Cab Bracket Rear
Caja De Herramientas / Tool Box
Controlador De Aire Acondicionado / Air Conditioner Controller
Aire Acondicionador Conducto / Air Conditioner Duct
Motor Del Ventilador / Blower Motor
Condensador / Condenser
Aire Acondicionador Manguito/Condensador Manguito / Air Conditioner Hose / Condenser Hose
Compresor / Compressor
Vaciar Manguito / Drain Hose
Etiqueta 1 (Delantero) [Fr] / Label 1 (Front)
Etiquetta 2 (Panel) / Label 2 (Rear)
Separador [Opcion] / Separator Kit [Option]
Trasero Desempanador Kit [Opcion] / Rear Defogger Kit [Option]
Combustible Deposito Cubierta Kit [Opcion] / Fuel Tank Cover Kit [Option]
Helice Eje Kit [Opcion] / Propeller Shaft Kit [Option]
Marcha Muy Lenta Velocidad Kit 1(Engranaje Caja)[Opcion] / Creep Speed Kit 1 (Gear Case) [Option]
Marcha Muy Lenta Velocidad Kit 2 (Cambio Bfrccn/Plnc) [Opcion] / Creep Speed Kit 2 (Shift Fork/Lever) [Option]
Kit De Distribuidor De Servicios Externos (Scd) (Tercero) [Opcion] / Auxiliary Control Valve Kit (Scd) (3rd) [Option]
Kit De Distribuidor De Servicios Externos (Fd) (Tercero) [Opcion] / Auxiliary Control Valve Kit (Fd) (3rd) [Option]
Kit De Distribuidor De Servicios Externos (S/D) (Tercero) [Opcion] / Auxiliary Control Valve Kit (S/D) (3rd) [Option]
Kit De Distribuidor De Servicios Externos (Scd) (Cuarto) [Opcion] / Auxiliary Control Valve Kit (Scd) (4th) [Option]
Kit De Distribuidor De Servicios Externos (Scd/Fc) (Cuarto) [Opcion] / Auxiliary Control Valve Kit (Scd/Fc) (4th) [Option]
Kit De Distribuidor De Servicios Externos (Fd) (Cuarto) [Opcion] / Auxiliary Control Valve Kit (Fd) (4th) [Option]
Kit De Distribuidor De Servicios Externos (Fc) [Opcion] / Auxiliary Control Valve Kit (Fc) [Option]
Distribuidor De Servicios Externos (Scd/Fc) [Componente Piezas] [Antiguo] [Opcion] / Auxiliary Control Valve (Scd/Fc) [Component Parts] [Old] [Option]
Distribuidor De Servicios Externos (Scd/Fc) [Componente Piezas] [Nuevo] [Opcion] / Auxiliary Control Valve (Scd/Fc) [Component Parts] [New] [Option]
Distribuidor De Servicios Externos (S/D) [Componente Piezas] [Antiguo] [Opcion] / Auxiliary Control Valve (S/D) [Component Parts] [Old] [Option]
Distribuidor De Servicios Externos (S/D) [Componente Piezas] [Nuevo] [Opcion] / Auxiliary Control Valve (S/D) [Component Parts] [New] [Option]
Distribuidor De Servicios Externos (Fc) [Componente Piezas] [Opcion] / Auxiliary Control Valve (Fc) [Component Parts] [Option]
Kit De Palanca De Distribuidor De Servicios Externos (Tercero) [Opcion] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Kit De Palanca De Distribuidor De Servicios Externos (Scd) (Cuarto) [Opcion] / Auxiliary Control Valve Lever Kit (4th) [Option]
Asiento Del Instructor [Opcion] / Instructional Seat Kit [Option]
