Kubota Tractor M128GXDTSC-2 Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M128GXDTSC-2 Tractor
Number of Pages: 725 Pages
Aceite Cárter / Oil Pan
Cilindro Ppal / Cylinder Head
Culata Cubierta / Head Cover
Pistón Y Cigüeñal / Piston And Crankshaft
Compensador / Balancer
Volante / Flywheel
Filtro Combustible / Fuel Filter
Carril Comun / Common Rail
Agua Bomba / Water Pump
Aire Limpiador Brida Y Valvula Reguladore / Air Cleaner Flange And Throttle Valve
Valvula De Egr / Egr Valve
Tuberia Del Agua De Egr / Egr Water Piping
Aire Limpiador / Air Cleaner
Entrada Tubo (Aire Limpiador) / Inlet Pipe (Air Cleaner)
Cubierta De La Pipa Del Silenciador / Muffler Pipe Cover
Sensor Del Muflfer / Muffler Sensor
Intercooler / Inter Cooler
Piezas Electricas Del Motor / Engine Electrical Parts
Motor Eléctrico Piezas De Montaja / Engine Electrical Mounting Parts
Deposito De Combustible [Antiguo] / Fuel Tank [Old]
Deposito Combustible [Nuevo] / Fuel Tank [New]
Combustible Deposito Soporte / Fuel Tank Bracket
Combustible Tubo (Limpiador) / Fuel Pipe (Fuel Filler)
Combustible Tubo (Bomba) [Antiguo] / Fuel Pipe (Fuel Pump) [Old]
Combustible Tubo (Bomba) [Nuevo] / Fuel Pipe (Fuel Pump) [New]
Combustble Tubo (Refrigerador Del Combustible) [Antiguo] / Fuel Pipe (Fuel Cooler) [Old]
Combustble Tubo (Refrigerador Del Combustible) [Nuevo] / Fuel Pipe (Fuel Cooler) [New]
Separador / Separator
Combustible Bomba / Fuel Pump
Ventilador / Fan
Agua Tubo / Water Pipe
Reserva Deposito / Reserve Tank
Alternador / Alternator
Motor De Arranque / Starter
Conmutador/Sensor (Motor Derecho/Silenciador) / Switch/Sensor (Engine Rh/Muffler)
Electrico Piezas Cubierta / Electrical Parts Cover
Conmutador/Sensor (Suspension) / Switch/Sensor (Suspension)
Conmutador/Sensor (Adelante) / Switch/Sensor (Front)
Conmutador/Sensor (Carroceria) / Switch/Sensor (Body)
Conmutador/Rele (Posterior) / Switch/Sensor (Rear)
Conmutador (Operacion) / Switch (Operation)
Interruptor Principal/Interruptor Del Mando / Main Switch/Lever Control Switch
Rele / Relay
Ecu (Motor) / Ecu (Engine)
Ecu (Cuerpo) / Ecu (Body)
Tacometro De Tdf/Velocimetro / Pto Tachometer/Speedmeter
Mando Panel / Control Panel
Mando Panel [Componente Piezas] / Control Panel [Component Parts]
Culata Luz [Ec] / Head Light [Ec]
Culata Luz [Uk] / Head Light [Uk]
Faro Delantero [Componente Piezas] [Ec] / Head Light [Component Parts] [Ec]
Lampeggiante Lampada / Front Combination Light
Trabajo Luz (Adelante) [Ec] / Work Light (Front) [Ec]
Trabajo Luz (Adelante) [Uk] / Work Light (Front) [Uk]
Trabajo Luz (Posterior) / Work Light (Rear)
Trasero Combinacion Luz / Rear Combination Light
Sitio Luz / Room Light
Altavoz De Cd-Radio / Cd-Radio And Speaker
Deposito De Lavaparabrisas / Washer Tank
Limpiaparabrisas [Viejo] / Wiper [Old]
Limpiaparabrisas [Nuevo] / Wiper [New]
Instalacion Electrica (Crs) [Viejo] / Electrical Wiring (Crs) [Old]
Instalacion Electrica (Crs) [Nuevo] / Electrical Wiring (Crs) [New]
Instalacion Electrica (Motor) / Electrical Wiring (Engine)
Electrico Cableado (Luz Principal) / Electrical Wiring (Head Light)
Instalacion Electrica (Panel) [Viejo] / Electrical Wiring (Panel) [Old]
Instalacion Electrica (Panel) [Nuevo] / Electrical Wiring (Panel) [New]
Instalacion Electrica (Trasero) [Viejo] / Electrical Wiring (Rear) [Old]
Instalacion Electrica (Trasero) [Nuevo] / Electrical Wiring (Rear) [New]
Electrico Cableado (Interruptor) / Electrical Wiring (3p Switch)
Electrico Cableado (Mando Panel) / Electrical Wiring (Control Panel)
Electrico Cableado (Apoyabrazo) / Electrical Wiring (Armrest)
Electrico Cableadoo (Cuerpo) / Electrical Wiring (Body)
Electrico Cableado (Valvula Delantera De La Suspension) / Electrical Wiring (Front Suspension Valve)
Instalacion Electrica (Cabina) [Ec] / Electrical Wiring (Cab) [Ec]
Instalacion Electrica (Cabina) [Uk] / Electrical Wiring (Cab) [Uk]
Potencia Cambio Valvula / Power Shift Valve
Potencia Cambio Valvula (Carroceria) [Componente Piezas] / Power Shift Valve (Body) [Component Parts]
Potencia Cambio Valvula (Superior) [Componente Piezas] / Power Shift Valve (Upper) [Component Parts]
Embrague Carcasa Cubierta (Inferior) / Clutch Housing Cover (Lower)
Intermedia Caja / Mid Case
Embrague Pedal / Clutch Pedal
Varilla De Embrague / Clutch Rod
Engranaje Soporte / Gear Support
Entrada Eje / Input Shaft
Inversor Eje / Shuttle Shaft
Primero/Segundo Cambio Engranaje / First/Second Shift Gear
Primer Eje / First Shaft
Tercero/Cuarto Cambio Engranaje / Third/Fourth Shift Gear
Arbol Contrarrotante / Counter Shaft
Principal Engranaje Cambio Eje Y Gama Engranaje Eje [Antiguo] / Main Gear Shift Shaft And Range Gear Shaft [Old]
Principal Engranaje Cambio Eje Y Gama Engranaje Eje [Nuevo] / Main Gear Shift Shaft/Range Gear Shaft [New]
Gama Engranaje Eje (Adelante) / Range Gear Shaft (Front)
Gama Engranaje Eje (Trasero) / Range Gear Shaft (Rear)
Accionar Eje (Adelante) / Drive Shaft (Front)
Accionar Eje (Medio/Trasero) / Drive Shaft (Middle/Rear)
Caso De La Cambio De Hi-Lo / Hi-Lo Shift Case
Trasero Diferencial Cerradura Embrague / Rear Differential Lock Clutch
Tdf Embrague / Pto Clutch
Tdf Embrague [Componente Piezas] / Pto Clutch [Component Parts]
Tdf Embrague Valvula [Componente Piezas] / Pto Clutch Valve [Component Parts]
Tdf Eje / Pto Shaft
Embrague Hidraulico (Bi-Velocidad Girar) / Hydraulic Clutch (Bi-Speed Turn)
Bi-Velocidad Girar Eje / Bi-Speed Turn Shaft
Tdf Engranaje Cambio Bifurcacion / Pto Shift Fork
Cambio De Engran.De La Gama Cable / Range Gear Shift Cable
Trasero Eje / Rear Axle Shaft
Freno / Brake
Estacionamiento Freno / Parking Brake
Freno Pedal / Brake Pedal
Freno Tubo / Brake Pipe
Pipa Del Distribuidor Del Freno / Brake Master Cylinder Pipe
Soporte De Eje Delantero / Front Axle Bracket
Helice Eje / Propeller Shaft
Adelante Helice Eje [Componente Piezas] / Mid Propeller Shaft [Component Parts]
Embrague De Bloqueo De Diferencial Delantero / Front Differential Lock Clutch
Caja De Engranaje Conico Derecho / Bevel Gear Case Rh
Caja De Engranaje Conico Izquierdo / Bevel Gear Case Lh
Adelante Eje Caja / Front Axle Case
Diferencial Engranaje Eje / Differential Gear Shaft
Cubierta Del Poste De Manejo / Steering Post Cover
Palanca Del Telescopio / Telescope Lever
Direccion Controlador / Steering Controller
Direccion Controlador [Componente Piezas] / Steering Controller [Component Parts]
Regulador Valvula / Regulater Valve
Regulador Valvula [Componente Piezas] / Regulater Valve [Component Parts]
Hidraulico Aceite Linea (Aspiracion) / Hydraulic Pipe (Suction)
Hidraulico Aceite Linea (Entrega) / Hydraulic Oil Line (Delivery)
Pipa Hidraulica / Hydraulic Oil Line
Remolque Freno Valvula / Trailer Brake Valve
Seguridad Valvula / Safety Valve
Hidraulico Aceite Linea (Trasero Dfrncl) / Hydraulic Oil Line (Rear Diff.)
Hidraulico Aceite Linea (Adelante Diferencial) / Hydraulic Oil Line (Front Differential)
Linea De Aceite Hidraulico Radiador De Aceite / Oil Cooler
Linea De Aceite Hidraulico (Radiador De Aceite) / Hydraulic Oil Line (Oil Cooler)
Hidraulico Aceite Linea (Direccion/Tdf) / Hydraulic Oil Line (Steering/Pto)
Latiguillo De Direccion (Impulsion) / Steering Hose (Delivery)
Suspensión Delantera Valvula / Front Suspension Valve
Valvula Delantera De La Suspension (Descarga/Cheque) [Componente Piezas] / Front Suspension Valve (Relief/Check) [Component Parts]
Valvula Delantera De La Suspension (Seguridad) [Componente Piezas] / Front Suspension Valve (Safety) [Component Parts]
Valvula Delantera De La Suspension (Conjunto) [Componente Piezas] / Front Suspension Valve (Joint) [Component Parts]
Suspensión Delantera Valvula Tubo / Front Suspension Valve Hose
Suspensión Delantera Cilindro / Front Suspension Cylinder
Suspensión Delantera Cilindro [Componente Piezas] / Front Suspension Cylinder [Component Parts]
Valvula De Flujo De La Rama / Branch Flow Valve
Valvula De Flujo De La Rama [Componente Piezas] / Branch Flow Valve [Component Parts]
Valvula / Valve
Base De La Valvula / Valve Base
Ascenzo Brazo / Hydraulic Lift Arm
Descarga Valvula/Cheque Valvula / Relief Valve/Check Valve
Detector Barra (Barra/Barra Soporte) / Detector Bar (Bar/Bar Support)
Detector Barra (Esfuerzo Vinculo) / Detector Bar (Draft Link)
Posicion Control Palanca / Position Control Lever
Auto Control Valvula / Auto Control Valve
Auto Control Valvula [Componente Piezas] / Auto Control Valve [Component Parts]
Montaje De Distribuidor De Servicios Externos (Con Fc) / Auxiliary Control Valve (With Fc) Mounting Base
Distribuidor De Servicios Externos (Con Fc) [Componente Piezas] / Auxiliary Control Valve (With Fc) (Mounting) [Component Parts]
Distribuidor De Servicios Externos (Scd Con Fc) [Componente Piezas] / Auxiliary Control Valve (Scd With Fc) [Component Parts]
Distribuidor De Servicios Externos (Fd Con Fc) [Componente Piezas] / Auxiliary Control Valve (Fd With Fc) [Component Parts]
Distribuidor De Servicios Externos (Con Fc) Tapa/Rsrv Dpst / Auxiliary Control Valve (With Fc) Cap/Reserve Tank
Palanca De Distribuidor De Servicios Externos (Con Fc) / Auxiliary Control Valve (With Fc) Lever
Bajar Vinculo / Lower Link
Estabilizador / Stabilizer
Tdf Protector / Pto Protector
Capo Superior / Hood (Bonnet)
Capo Superior (Amortiguador Sano/Aislador) / Hood (Bonnet) (Sound Absorber/Insulator)
Amortiguador De La Capo / Hood(Bonnet) Damper
Capo Bastidor / Bonnet Frame
Capo Soporte / Hood (Bonnet) Support
Capo Lado Bajar Izquierdo / Hood (Bonnet) Side Lower Lh
Cabina Bastidor / Cab Frame
Adelante Vidrio / Front Glass
Puerta Derecho / Door Rh
Puerta Izquierdo / Door Lh
Puerta Cerradura Derecho / Door Lock Rh
Puerta Cerradura Izquierdo / Door Lock Lh
Trasero Ventana (Superior) / Rear Window (Upper)
Azotea Del Sol / Sun Roof
Espejo Retrovisor [Ec] / Rearview Mirror [Ec]
Espejo Retrovisor [Uk] / Rearview Mirror [Uk]
Interno Techo / Inner Roof
Cubierta Exterior / Outer Roof
Asiento / Seat
Asiento [Componente Piezas] / Seat [Component Parts]
Reposabrazos / Armrest
Asiento Del Instructor / Instructional Seat
Piso Estera / Floor Mat
Material Insonoro / Soundproof Material
Inspeccion Placa (Adelante) / Inspection Plate (Front)
Inspeccion Placa (Trasero) / Inspection Plate (Rear)
Cubierta De Guardabarros Izquierdo / Fender Cover Lh
Guardabarros Iz / Fender Lh
Herramienta Caja / Tool Box
Cubierta Del Aire Acondicionador Conducto / Air Conditioner Duct Cover
Aire Acondicionador Conducto (Adelante) / Air Conditioner Duct (Front)
Aire Acondicionador Conducto (Posterior) / Air Conditioner Duct (Rear)
Modo Caso / Mode Case
Condensador / Condenser
Compresor Del Aire Acondicionado / Air Conditioner Compressor
Etiqueta (Adelante) [Ec] [Uk] / Label (Front) [Ec] [Uk]
Etiqueta (Posterior) / Label (Rear)
Etiqueta (Posterior/Cabina) / Label (Rear/Cab)
Funcionamiento Luz Kit (Posterior) [Opcion] / Working Light Kit (Rear) [Option]
Trasero Desempanador Kit [Opcion] / Rear Defogger Kit [Option]
Limpiador Delantero [Opción] / Front Wiper Kit [Option]
Kit Fusible [Opcion] / Fuse Kit [Option]
Combustible Deposito Cubierta Kit [Opcion] / Fuel Tank Cover Kit [Option]
Marcha Muy Lenta Velocidad Kit (Engranaje Caja) [Opcion] / Creep Speed Kit (Gear Case) [Option]
Marcha Muy Lenta Velocidad Kit (Cambio Bfrccn) [Opcion] / Creep Speed Kit (Shift Fork) [Option]
Marcha Muy Lenta Velocidad Kit (Palanca) [Opcion] / Creep Speed Kit (Lever) [Option]
Kit De Sustitucion De Principal Engranaje Embrague (Embrague) [Opcion] / Main Gear Shift Clutch Replacement Kit (Clutch) [Option]
Kit De Sustitucion De Principal Engranaje Embrague (Soporte) [Opcion] / Main Gear Shift Clutch Replacement Kit (Support) [Option]
Tdf(540/540e) Conversion Kit (Engranaje) [Opcion] / Pto (540/540e) Conversion Kit (Gear) [Option]
Tdf (540/1000) Conversion Kit (Engranaje Caja) [Opcion] / Pto (540/1000) Conversion Kit (Gear Case) [Option]
Tdf(540/1000) Conversion Kit (Engranaje) [Opcion] / Pto(540/1000) Conversion Kit (Gear) [Option]
80 Pulgada Ancho De Via Kit [Opcion] / 80 Inch Tread Kit [Option]
Kit De Tubería De Lubricante De Aceite [Opcion] / Oil Lubrication Pipe Kit [Option]
Kit De Distribuidor De Servicios Externos (Scd Con Fc) [Opcion] / Auxiliary Control Valve Kit (Scd With Fc) [Option]
Kit De Distribuidor De Servicios Externos (Fd Con Fc) [Opcion] / Auxiliary Control Valve Kit (Fd With Fc) [Option]
Kit De Palanca De Distribuidor De Servicios Externos (Con Fc) (Tercero) [Opcion] / Auxiliary Control Valve Lever Kit (With Fc) (3rd) [Option]
Kit De Palanca De Distribuidor De Servicios Externos (Con Fc) (Cuatro) [Opcion] / Auxiliary Control Valve Lever Kit (With Fc) (4th) [Option]
Protector De Pantalla Del Sol [Opcion] / Sunshade Shield Kit [Option]
Volante / Flywheel
Ventilador / Fan
Rele / Relay
Tdf Eje / Pto Shaft
Freno / Brake
Valvula / Valve
Asiento / Seat
