Kubota Tractor M128GXDTC-2 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M128GXDTC-2 Tractor
Number of Pages: 401 Pages
Itens Uso Frequent E / Frequently Used Items
Bloco Motor (Superior) / Crankcase (Upper)
Bloco Motor (Inferior) / Crankcase (Lower)
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exh Aust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Arvore Cames E Veio / Camshaft And Idle Gear Sh Aft
Compensador / Balancer
Volante Motor / Flywheel
Filtro Gasoleo / Fuel Filter
Injector E Vela Aquecimento / Injector And Glow Plug
Common Rail / Common Rail
Bomba Agua E Termostacto / Water Flange And The Rmostat
Bomba Agua / Water Pump
Flange Filtro Ar E Valvula Acelarador / Air Cle Aner Flange And Throttle Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Tubo Agua Valvula Egr / Egr Water Piping
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [Co Mponent Parts]
Tubo Aspiracao (Filtro Ar) / Inlet Pipe (Air Cl Eaner)
Panela Escape / Muffler Pipe
Tampa Tubo Colector / Muffler Pipe Cover
Silenciador Do Filtro De Partículas Diesel / Di Esel Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [Peç As Componentes] / Diesel Particulate Filter Muffler [Component Parts]
Sensor Escape / Muffler Sensor
Tubo Pressao / Pressure Pipe
Tubo Oleo (Turbo Caricatore) / Oil Pipe (Turbo Charger)
Intercooler / Inter Cooler
Componentes Electricos Motor / Engine Electrica L Parts
Motor Elétrica Peças De Montagem / Engine Elect Rical Mounting Parts
Deposito Combustivel [Vel Ho] / Fuel Tank [Old]
Deposito Combustivel [Nov O] / Fuel Tank [New]
Suporte Deposito Combusti Vel / Fuel Tank Bracket
Tubo Combustivel (Filtro) / Fuel Pipe (Fuel Filler)
Tubo Combustivel (Bomba) [Velho] / Fuel Pipe (Fuel Pump) [Old]
Tubo Combustivel (Bomba) [Novo] / Fuel Pipe (Fuel Pump) [New]
Tubo Combustivel (Arrefec Edor Gasoleo) [Velho] / Fuel Pipe (Fuel Cooler) [Ol D]
Tubo Combustivel (Arrefec Edor Gasoleo) [Novo] / Fuel Pipe (Fuel Cooler) [New ]
Arrefecedor Gasoleo / Fue L Cooler
Separador / Separator
Separador [Peças Componen Tes] / Separator [Component Parts]
Bomba Gasoleo [Peças Comp Onentes] / Fuel Pump [Component Parts]
Filtro Gasoleo / Fuel Fil Ter
Filtro Gasoleo [Peças Com Ponentes] / Fuel Filter [Component Parts]
Suporte Ventilador / Fan Bracket
Ventoin Ha / Fan
Tubo Ag Ua / Water Pipe
Radiado R / Radiator
Deposit O Reserva / Reserve Tank
Alternador / Alternator
Motor Arranque / Starter
Motor Arranque [Peças Co Mponentes] / Starter [Component Parts]
Interruptor/Sensor (Bloc O Motor Esquerda) / Switch/Sensor (Engine Lh)
Interruptor/Sensor (Maqu Ina (Drt)/Panela Escape) / Switch/Sensor (Engine Rh /Muffler)
Componenetes Electricos Resguardo / Electrical Parts Cover
Interruptor/Sensor (Fren Te) / Switch/Sensor (Front)
Interruptor/Sensor (Corp O) / Switch/Sensor (Body)
Interruptor / Rele (Tras Eira) / Switch/Sensor (Rear)
Interruptor (Operação) / Switch (Operation)
Interruptor Principal/Ch Ave De Controle Alavanca / Main Switch/Lever Contro L Switch
Relé / Relay
Ecu (Corpo) / Ecu (Body)
Painel / Panel Board
Conta Rotaçoes Tdf/Veloc Imetro / Pto Tachometer/Speedmeter
Painel Control / Control Panel
Painel Control [Peças Co Mponentes] / Control Panel [Component Parts]
Lampada Cabeça [Ec] / He Ad Light [Ec]
Lampada Cabeça [Uk] / He Ad Light [Uk]
Lampada Cabeça [Peças Co Mponentes] [Ec] / Head Light [Component Parts] [Ec]
Lampada Cabeça [Peças Co Mponentes] [Uk] / Head Light [Component Parts] [Uk]
Luzes Frontais / Front C Ombination Light
Luzes Trabalho (Frente) [Ec] / Work Light (Front) [Ec]
Luzes Trabalho (Frente) [Uk] / Work Light (Front) [Uk]
Farois Trabalho (Traseir Os) / Work Light (Rear)
Braco Traseiro / Rear Co Mbination Light
Luz Interior / Room Ligh T
Radio Cd E Columnas / Cd -Radio And Speaker
Deposito Limpa Parabris As / Washer Tank
Escova [Novo] / Wiper [N Ew]
Cablagem Electrica (Crs) [Velho] / Electrical Wiring (Crs) [Old]
Cablagem Electrica (Crs) [Novo] / Electrical Wiring (Crs) [New]
Cablagem Electrica (Moto R) / Electrical Wiring (Engine)
Cablagem Electrica (Luze S Frente) / Electrical Wiring (Head Light)
Cablagem Eletrcia (Paine L) [Velho] / Electrical Wiring (Panel) [Old]
Cablagem Eletrcia (Paine L) [Novo] / Electrical Wiring (Panel) [New]
Cablagem Eletrcia (Trase Ira) [Velho] / Electrical Wiring (Rear) [Old]
Cablagem Eletrcia (Trase Ira) [Novo] / Electrical Wiring (Rear) [New]
Cablagem Eletrcia (Botão ) / Electrical Wiring (3p Switch)
Cablagem Electrica (Pain El Contrl) / Electrical Wiring (Control Panel)
Cablagem Electrica (Brac O) / Electrical Wiring (Armrest)
Cablagem Elétrica (Corpo ) / Electrical Wiring (Body)
Cablagem Electrica (Cabi Ne) [Ec] / Electrical Wiring (Cab) [Ec]
Cablagem Electrica (Cabi Ne) [Uk] / Electrical Wiring (Cab) [Uk]
Valvula Powershif T / Power Shift Valve
Valvula Powershif T (Corpo) [Peças Componentes] / Power Shift Valve ( Body) [Component Parts]
Valvula Powershif T (Superior) [Peças Componentes] / Power Shift Valv E (Upper) [Component Parts]
Carter Embraiagem Cambota (Inferior) / Clutch Housing Cover (Lower)
Caixa Intermedia / Mid Case
Carter Transmissa O / Transmission Case Rear Cover
Caixa Do Eixo Tra Seiro Esquerdo / Rear Axle Case Lh
Disco Amortecedor / Damper Disk
Tirante Embraiage M / Clutch Rod
Suporte Carreto / Gear Support
Veio Primario / I Nput Shaft
Veio Inversor / S Huttle Shaft
Primeira/Segunda Mudança / First/Second Shift Gear
Primeiro Veio / F Irst Shaft
Carreto Terceira/ Quarta / Third/Fourth Shift Gear
Veio Secundario / Counter Shaft
Carreto Principal [Antigo] / Main Gear Shift Shaft And Range Gear Sh Aft [Old]
Carreto Principal [Novo] / Main Gear Shift Shaft/Range Gear Shaft [N Ew]
Veio Gamas Veloci Dades Inversor (Frente) / Range Gear Shaft (Front)
Veio Gamas Veloci Dades (Traseira) / Range Gear Shaft (Rear)
Veio (Frente) / D Rive Shaft (Front)
Veio (Meio/Trasei Ro) / Drive Shaft (Middle/Rear)
Sistema Hi-Lo / H I-Lo Shift Case
Grupo Conico / Be Vel Gear
Diferencial Trase Iro / Rear Differential
Embraiagem Bloque Io Diferencial Traseiro / Rear Differential Lock Cl Utch
Veio Tdf / Pto Pr Opeller Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf [P Eças Componentes] / Pto Clutch [Component Parts]
Valvula Embraiage M Tdf / Pto Clutch Valve
Valvula Embraiage M Tdf [Peças Componentes] / Pto Clutch Valve [Compo Nent Parts]
Veio Principal Td F / Pto Drive Shaft
Veio Tdf / Pto Sh Aft
Embraiagem Hidrau Lica (Bi Speed) / Hydraulic Clutch (Bi-Speed Turn)
Veio Bi-Speed / B I-Speed Turn Shaft
Forque Ta Velocidades / Range Gear Shift Fork
Forque Ta Tdf / Pto Shift Fork
Alavan Ca Velocidades / Main Gear Shift Lever
Alvanc A Inversor / Shuttle Shift Lever
Cabo E Mbraiagem / Range Gear Shift Cable
Alavan Ca Tdf / Pto Gear Shift Lever
Pedal Bloqueio Diferen Cial Traseiro / Rear Differential Lock Pedal
Eixo Traseiro / Rear A Xle Shaft
Travão / Brake
Travão Parque / Parkin G Brake
Pedal Travao / Brake P Edal
Cilindro Travao Princi Pal / Brake Master Cylinder
Cilindro Travao Princi Pal [Peças Componentes] / Brake Master Cylinder [Co Mponent Parts]
Tubo Travao / Brake Pi Pe
Tubo Travao / Brake Ma Ster Cylinder Pipe
Suporte Eixo Diante Iro / Front Axle Bracket
Veio Primario / Pro Peller Shaft
Caixa Diferencial D Ianteiro / Front Differential Case
Grupo Conico (Frent E) / Bevel Gear (Front)
Diferencial Diantei Ro / Differential Front
Bloqueio Diferencia L Frente / Front Differential Lock Clutch
Caixas Engrenagens Conica Drt / Bevel Gear Case Rh
Caixas Engrenagens Conica Esq / Bevel Gear Case Lh
Eixo Dianteiro / Fr Ont Axle
Veio Carreto Difere Ncial / Differential Gear Shaft
Tampa Coluna Direccao / Steering Post Cove R
Alavanca / Tilt Lever
Placa Telescopio / Telescope Lever
Distribuidor Direcção / Steering Controlle R
Distribuidor Direcção [Peças Componentes] / Steering Controller [Component Parts]
Cilindro Direcção [Peças Componentes] / St Eering Cylinder [Component Parts]
Bomba Hidraulico / Hydra Ulic Pump
Valvula Reguladora / Reg Ulater Valve
Valvula Reguladora [Peça S Componentes] / Regulater Valve [Component Parts]
Linha Aspiração (Sucção) / Hydraulic Pipe (Suction)
Tubo Oleo (Fornecimento) / Hydraulic Oil Line (Delivery)
Tubo Hidraulico / Hydrau Lic Oil Line
Valvula Travao Reboque / Trailer Brake Valve
Valvula Segurança / Safe Ty Valve
Circuito Oleo Hidraulico (Diferencial Traseiro) / Hydraulic Oil Line (Rear Diff.)
Circuito Oleo Hidraulico (Diferencial Frente) / Hydraulic Oil Line (Front D Ifferential)
Radiador Oleo / Oil Cool Er
Circuito Oleo Radiador ( Radiador Oleo) / Hydraulic Oil Line (Oil Cooler)
Circuito Oleo Direcção ( Direcção/Tdf) / Hydraulic Oil Line (Steering/Pto)
Tubo Direccao (Entrega) / Steering Hose (Delivery)
Caixa Cilindro Hidraulic O / Hydraulic Cylinder Case
Valvula Base / Valve
Base Valvula / Valve Bas E
Hidraulico Braços / Hydr Aulic Lift Arm
Trinco / Lowering Lock L Ever
Barra Deflectora (Barra /Barra Suporte) / Detector Bar (Bar/Bar Support)
Barra Deflectora (Ligaçã O) / Detector Bar (Draft Link)
Alavanca Control Posicao / Position Control Lever
Valvula Contol Automatic O / Auto Control Valve
Valvula Control Automati Co [Peças Componentes] / Auto Control Valve [Compon Ent Parts]
Válvula De Controlo Auxi Liar (Com Fc) / Auxiliary Control Valve (With Fc) M Ounting Base
Serviços Externos (Com F C) [Peças Componentes] / Auxiliary Control Valve (W Ith Fc) (Mounting) [Component Parts]
Serviços Externos (Scd C Om Fc) [Peças Componentes] / Auxiliary Control Valv E (Scd With Fc) [Component Parts]
Serviços Externos (Fd Co M Fc) [Peças Componentes] / Auxiliary Control Valve (Fd With Fc) [Component Parts]
Tampa Da Válvula De Cont Rolo Auxiliar (Com Fc) Tampa/Depósito De Reserva / Auxiliary Control Valve (With Fc) Cap/Reserve Tank
Alavanca Da Válvula De C Ontrolo Auxiliar (Com Fc) / Auxiliary Control Valve (With Fc) Lever
Cilindro Auxiliar De Ele Vacao Esq / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De Ele Vacao Drt / 3p-Lift Assist Cylinder Rh
Par Te Superior / Top Link Bracket
Lig Acao Superior / Top Link
Lig Acao Inferior / Lower Link
Est Abilizador / Stabilizer
Est Abilizador Drt / Lift Rod Rh
Est Abilizador Esq / Lift Rod Lh
Pro Teccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Amortecedor Capot / Hood(Bonnet) Damper
Trico Capot / Bonnet Lock
Estrutura Capot / Bonnet Frame
Suporte Capot / Hood (Bonnet) Support
Capot Inferior Direito / Hood (Bonnet) Sid E Lower Rh
Capot Inferior Esquerdo / Hood (Bonnet) Si De Lower Lh
Estrutura Cabine / Cab Frame
Vidro Frente / Front Glass
Porta Drt / Door Rh
Porta Esq / Door Lh
Vidro Traseiro (Superior) / Rear Window (Upper)
Tejadilho / Sun Roof
Espelho Rectrovisor [Ec] / Rearview Mirror [Ec]
Espelho Rectrovisor [Uk] / Rearview Mirror [Uk]
Tecto Interior / Inner Roof
Cobertura Exterior Do Tejadilho / Outer Roof
Banco / Seat
Banco [Peças Componentes] / Seat [Component Parts ]
Apoio Braço / Armrest
Banco Passageiro / Instructional Seat
Piso / Floor Mat
Isolante / Soundproof Material
Chapa Inspecção (Frente) / Inspection Plate (Fron T)
Chapa Inspecção (Traseira) / Inspection Plate (Re Ar)
Tampa / Shift Cover
Cobertura Gurada Lamas Esq / Fender Cover Lh
Guarda Lamasdrt Drt / Fender Rh
Guarda Lamas Esq / Fender Lh
Suporte Cabine Dianteiro / Cab Bracket Front
Suporte Cabine Traseiro / Cab Bracket Rear
Caixa Ferramenta / Tool Box
Air Condicionado / Air Cond Itioner
Cuberto Tubo Air Condiciona Do / Air Conditioner Duct Cover
Tubo Ar Condicionado (Frent E) / Air Conditioner Duct (Front)
Tubo Ar Condicionado (Trase Ira) / Air Conditioner Duct (Rear)
Modo Caixa / Mode Case
Entradas Ar Painel Instrume Ntos / Dashboard Air Outlets
Circulaçao Ar Interior / In Ner Air Recirculation
Tubo Aquecimento / Heater H Ose
Condesador / Condenser
Tubo Ar Condicionado/Tubo C Ondensador / Air Conditioner Hose/Condenser Hose
Compressor Do Ar Condiciona Do / Air Conditioner Compressor
Decalcomania (Frente) [Ec] [Uk] / Label (Fro Nt) [Ec] [Uk]
Etiqueta (Traseira/Cabine) / Label (Rear/Cab )
Kit Farios Trabalho [Opçao] / Working Light Kit [Option]
Kit Farios Trabalho (Trseira) [Opçao] / Working Light Kit (Rear) [Option]
Kit Desempanador [Opçao] / Rear Defogger Kit [O Ption]
Escova Limpa Vidro Frontal [Opção] / Front Wipe R Kit [Option]
Kit Fusivel [Opção] / Fuse Kit [Option]
Kit Cobertuta Deposito Gasoleo [Opçao] / Fuel T Ank Cover Kit [Option]
Crepper Kit (Caica De Carretos) [Opção] / Creep Speed Kit (Gear Case) [Option]
Kit Caixa Crepper (Forqueta) [Opçao] / Creep Sp Eed Kit (Shift Fork) [Option]
Kit Caixa Crepper (Alvanca) [Opçao] / Creep Spe Ed Kit (Lever) [Option]
Kit Substituição De Principal De Transmissão Em Braiagem (Embraiagem) [Opção] / Main Gear Shift Clu Tch Replacement Kit (Clutch) [Option]
Kit Substituição De Principal De Transmissão Em Braiagem (Suporte) [Opção] / Main Gear Shift Clutch Replacement Kit (Support) [Option]
Kit Conversao Tdf 540/540e (Engrenagem) [Opçao] / Pto (540/540e) Conversion Kit (Gear) [Option]
Kit Conversao Tdf 540/1000 (Engrenagem Box) [Op Ção] / Pto (540/1000) Conversion Kit (Gear Case) [O Ption]
Kit Conversao Tdf 540/1000 (Engrenagem) [Opção] / Pto(540/1000) Conversion Kit (Gear) [Option]
80" Kit De Piso [Opção] / 80 Inch Tread Kit [Op Tion]
Kit De Tubulação De Lubrificação De Óleo [Opção ] / Oil Lubrication Pipe Kit [Option]
Kit Serviços Externos (Scd Com Fc) [Opção] / Au Xiliary Control Valve Kit (Scd With Fc) [Option]
Kit Serviços Externos (Fd Com Fc) [Opção] / Aux Iliary Control Valve Kit (Fd With Fc) [Option]
Kit Alavanca Serviços Externos (Com Fc) (3rd) [ Opção] / Auxiliary Control Valve Lever Kit (With Fc ) (3rd) [Option]
Kit Alavanca Serviços Externos (Com Fc) (4th) [ Opção] / Auxiliary Control Valve Lever Kit (With Fc ) (4th) [Option]
Protetor De Para-Sol [Opção] / Sunshade Shield Kit [Option]
