Kubota Tractor M125XDT Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M125XDT Tractor
Number of Pages: 314 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Bomba Oleo / Oil Pump
Fuel Pump Base / Fuel Pump Base
Breather / Breather
Valvula Descarga / Relief Valve
Radiador / Main Bearing Case
Volante Motor / Flywheel
Injection Pump [Component Parts] / Injection Pump [Component Parts]
Valvula Solenoide / Nozzle Holder And Glow Pl Ug
Fuel Control Motor / Fuel Control Motor
Filtro Gasoleo / Fuel Filter
Filtro Gasoleo[Peças Componentes] / Fuel Filt Er [Component Parts]
Bomba Agua E Termostacto / Water Flange And T Hermostat
Acessorios / Water Pump
Válvula E Veio Do Balanceiro / Valve And Rock Er Arm
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [ Component Parts]
Tubo Aspiracao / Inlet Pipe
Escpae / Muffler
Turbo Compressor (Componentes) / Turbo Charge R [Component Parts]
Tubo Oleo (Turbo) / Oil Pipe (Turbo Charger)
Hydraulic Pump Base / Hydraulic Pump Base
Deposito Combustivel / Lower Gasket Kit
Cabo Acelerador / Accelerator Wire
Engine Stop Wire / Engine Stop Wire
Deposito Combustivel (Drt) / Fuel Tank Rh
Deposito Combustivel (Esq) / Fuel Tank Lh
Tubo Combustivel / Fuel Pipe
Sedimenter / Sedimenter
Separador[Peças Componentes] / Separator [Component Parts]
Ventilador / Fan
Radiador / Water Pipe
Deposito Re Serva / Reserve Tank
Alternador / Alternator
Alternador [Peças Componente S] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Componentes] / Starter [Component Parts]
Interruptor/Sensor / Switch/ Sensor 1
Interruptor/Sensor / Switch/ Sensor 2
Comutador / Switch
Interruptor Principal / Main Switch/Lever Control Switch
Interruptor / Rele / Relay
Painel / Panel Board
Painel[Peças Componentes] / Panel Board [Component Parts]
Conta Rotaçoes Tdf / Velocim Etro / Pto Tachometer/Speedometer
Painel Control / Control Pan El
Painel Control[Peças Compone Ntes] / Control Panel [Component Parts]
Lift Arm Sensor / Lift Arm S Ensor
Farol Dianteiro / Head Light
Flasher Light / Flasher Ligh T
Luzes Trabalho / Working Lig Ht [Old Type]
Luzes Trabalho / Working Lig Ht [New Type]
Braco Traseiro / Rear Combin Ation Light
Ficha Reboque / Trailer Sock Et
Radio Cd E Columnas / Cd-Rad Io And Speaker
Escova Limpa Vidros / Wiper
Cablagem Electrica (Motor) / Electrical Wiring (Engine)
Cablagem Electrica / Electri Cal Wiring (Main)
Cablagem Electrica / Electri Cal Wiring (Rear)
Cabalagem Eletrica(Cabine)[E C] [G] / Electrical Wiring (Cab)
Carter Embraiagem / C Lutch Housing
Valvula Powershift / Power Shift Valve
Valvula Powershift[Pe Ças Componentes] / Power Shift Valve (Body) [Compon Ent Parts]
Valvula Powershift[Pe Ças Componentes] / Power Shift Valve (Upper) [Compo Nent Parts]
Carter Embraiagem / C Lutch Housing Cover
Caixa Intermedia / Mi D Case
Caixa Velocidades / T Ransmission Case
Carter Transmissao / Transmission Case Rear Cover
Carter Eixo / Rear Ax Le Case
Disco Amortecedor / D Amper Disk
Bloqueio Diferencial / Clutch Pedal
Embraiagem / Clutch R Od
Cobertura Frontal / F Ront Cover
Suporte Carreto / Gea R Support
Veio Primario / Input Shaft
Veio Inversor / Shutt Le Shaft
Primeira/Segunda Muda Nça / First/Second Shift Gear
Primeiro Veio / First Shaft
Carreto Terceira/Quar Ta / Third/Fourth Shift Gear
Veio Secundario / Cou Ntershaft
Carreto Principal / M Ain Gear Shift Shaft And Range Gear Shaft
Veio Gamas Velocidade S / Range Gear Shaft
Veio (Frente) / Drive Shaft (Front)
Veio (Meio/Traseiro) / Drive Shaft (Middle/Rear)
Painel Lateral / Tran Smission Case Side Cover
Grupo Conico / Bevel Gear
Embraiagem Bloqueio D Iferencial Traseiro / Rear Differential Lock Clutch
Veio Tdf / Pto Propel Ler Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf[Peças Componentes] / Pto Clutch [Component Parts] [Old] # # N.º De Série<=54622 S.No.;<=54622 [Note:Order By Fig.No.D26600 Ref.No.010 And Fig.No.D27000 Ref.No.0 90 New Parts.] / S.No.<=54622 [Note:Order By Fig.No .D26600 Ref.No.010 And Fig.No.D27000 Ref.No.090 New Parts.]
Embraiagem Tdf[Peças Componentes] / Pto Clutch [Component Parts] [New] # # N.º De Série>=54623 S.No.;>=54623 / S.No.>=54623 S.No.;>=54623
Valvula Embraiagem Td F / Pto Clutch Valve
Valvula Embraiagem Td F[Peças Componentes] / Pto Clutch Valve [Component Parts]
Tdf / Veio Tdf / Pto Drive Shaft
Veio Tdf / Pto Shaft
Embraiagem Hidraulica (Bi Speed) / Hydraulic Clutch (Bi-Speed Turn)
Veio Bi-Speed / Bi-Sp Eed Turn Shaft
Forqueta Caixa / Creeper / Range Gear Shift Fork
Alvanca T Df / Pto Shift Fork
Alvanca I Nversor / Shuttle Shift Lever
Range Gea R Shift Rod / Range Gear Shift Rod
Eixo Traseiro / Rear Axle
Travão / Brake
Alavanca Travao Mao / Park Ing Brake Lever
Pedal Travao / Brake Pedal
Pedal Bloqueio Diferencial Traseiro / Rear Differential Lock Pedal
Deposito Oleo Travoes / Br Ake Oil Tank
Cilindro Travao Principal[ Peças Componentes] / Brake Master Cylinder [Compone Nt Parts]
Tubo Travao / Brake Pipe
Suporte Eixo Dianteiro / Front Axle Bracket
Front Axle Support / Fr Ont Axle Support
Caixa Diferencial Diant Eiro / Front Differential Case
Engrenagem Cónica (Dian Teira) / Bevel Gear (Front)
Bloqueio Diferencial Fr Ente / Front Differential Lock Clutch
Caixas Engrenagens Coni Ca(Drt) / Bevel Gear Case Rh
Caixas Engrenagens Coni Ca(Esq) / Bevel Gear Case Lh
Carter Eixo / Front Axl E Case
Grupo Conico / Differen Tial Gear Shaft
Direcção Assistida / Direção Punho / Steering Handle
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção[Peças Componentes] / Ste Ering Controller [Component Parts] [Old]
S.N O.;>=54769
Direcção Assistida / Tie Rod
Cilindro Direcção[Peças Componentes] / Steerin G Cylinder [Component Parts]
Bomba Hidraulico[Peças Compo Nentes] / Hydraulic Pump [Component Parts]
Válvula Do Regulador / Regul Ater Valve
Valvula Reguladora[Peças Com Ponentes] / Regulater Valve [Component Parts]
Linha Aspiração / Hydraulic Pipe (Suction)
Tubo Oleo / Hydraulic Pipe ( Delivery)
Tubo Hidraulico / Hydraulic Oil Line
Valvula Travao Reboque / Tra Iler Brake Valve
Circuito Oleo Hidraulico(Bi Speed) / Hydraulic Oil Line (Bi-Speed Turn/Rear Dif F.)
Radiador Oleo / Oil Cooler
Circuito Oleo Direcção / Hyd Raulic Oil Line (Steering/Pto)
Tubo Direccao / Steering Hos E (Delivery)
Cilindro Hidraulico / Hydrau Lic Cylinder
Braço De Elevação Hidráulico / Hydraulic Lift Arm
Hydraulic Cylinder Cover / H Ydraulic Cylinder Cover
Trinco / Lowerring Lock Leve R
Draft Control Valve / Draft Control Valve
Draft Control Valve [Compone Nt Parts] / Draft Control Valve [Component Parts]
Barra Deflectora (Suporte) / Detector Bar 1 (Bar/Bar Support)
Barra Deflectora / Detector Bar 2 (Draft Link)
Distribuidor Auxiliar / Auxi Liary Control Valve
Valvula Auxiliar [Peças Comp Onentes] / Auxiliary Control Valve(Fd) [Component Parts] [Old]
Valvula Auxiliar [Peças Comp Onentes] / Auxiliary Control Valve(Fd) [Component Parts] [New]
Valvula Auxiliar [Peças Comp Onentes] / Auxiliary Control Valve(Scd) [Component Parts] [Old]
Valvula Auxiliar [Peças Comp Onentes] / Auxiliary Control Valve(Scd) [Component Parts] [New]
Tubo Da Válvula De Controlo Auxiliar (4v Me: 2b+1f+1fh) / Auxiliary Control Val Ve Pipe
Alavanca Valvula Auxiliar 1 Pos / Auxiliary Control Valve Lever
Assist Cylinder Lh / Assist Cylinder Lh
Assist Cylinder Rh / Assist Cylinder Rh
Cilindro Auxiliar (Component Es) / Assist Cylinder [Component Parts]
Parte S Uperior / Top Link Bracket
Ligacao Superior / Top Link
Ligacao Inferior / Lower Link [Old Type]
Ligacao Inferior / Lower Link [New Type]
Estabil Izador / Stabilizer
Estabil Izador(Drt) / Lift Rod Rh
Estabil Izador(Esq) / Lift Rod Lh
Barra / Assist Cylinder Bracket
Protecc Ao Tdf / Pto Shaft Protector
Grelha Frontal / Front Grille
Capot Superior / Hood(Bonnet) Upper
Estrutura Capot / Bonnet Frame
Capot Traseiro / Hood(Bonnet) Rear
Es Trutura Cabine / Cab Frame
Vi Dro Frente E Traseiro / Front Glass
Po Rta(Esq) / Door Lh
Tr Inco Porta(Drt) / Door Lock Rh
Tr Inco Porta(Esq) / Door Lock Lh
La Do Vidro / Side Window
Vi Dro Traseiro / Rear Window
Es Pelho Rectrovisor / Rearview Mirror
Te Cto Interior / Inner Roof
Ac Essorios / Seat
Ap Oio Braço / Armrest
Pi So / Floor Mat
Ch Apa Inspecção(Frente) / Inspection Plate
Ta Mpa / Shift Lever Guide
Co Bertura Do Guarda-Lamas / Fender Cover
Pi Llar Cover / Pillar Cover
Gu Arda Lamas(Drt) / Fender Rh
Gu Arda Lamas(Esquerda) / Fender Lh
Di Anteira Do Suporte Da Cabine / Cab Bracket Front
Su Porte Cabine Traseiro / Cab Bracket Rear
Ca Ixa Ferramenta / Tool Box
Comando Ar Condicionado / Air C Onditioner Controller
Air Condicionado / Air Conditio Ner
Tubo Ar Condicionado / Air Cond Itioner Duct
Blower Motor / Blower Motor
Condesador / Condenser
Tubo Ar Condicionado/Tubo Conde Nsador / Air Conditioner Hose / Condenser Hose
Suporte Compressor / Compressor Bracket
Mangueira De Drenagem / Drain H Ose
Etiqueta 1 / Label 1 (Front)
Etiqueta 2 / Label 2 (Rear)
Acessorios / Accessories And Service Part S
Kit Farios Trabalho (Opçao) / Working Light Kit [Op Tion]
Desempanador (Opcao) / Rear Defogger Kit [Option]
Kit Caixa Crepper(Opção) / Creep Speed Kit 1 (Gear Case) [Option]
Forqueta Caixa / Creeper / Creep Speed Kit 2 (Shift Fork/Lever) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Con Trol Valve Kit(Scd)(3rd) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Con Trol Valve Kit(Fd)(3rd) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Con Trol Valve Kit(Scd)(4th) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Con Trol Valve Kit(Scd/Fc)(4th) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Con Trol Valve Kit(Fd)(4th) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Con Trol Valve Kit(Fc) [Option]
Kit Distribuidor Serviços Externos[Peças Componente S][Opcao] / Auxiliary Control Valve(Scd/Fc) [Compon Ent Parts] [Old] [Option]
Kit Distribuidor Serviços Externos[Peças Componente S][Opcao] / Auxiliary Control Valve(Scd/Fc) [Compon Ent Parts] [New] [Option]
Kit Distribuidor Serviços Externos[Peças Componente S][Opcao] / Auxiliary Control Valve(Fc) [Component Parts] [Option]
Kit Alavanca Serviços Externos[Opcao] / Auxiliary C Ontrol Valve Lever Kit (3rd) [Option]
Kit Alavanca Serviços Externos[Opcao] / Auxiliary C Ontrol Valve Lever Kit (4th) [Option]
Carreto / Gear Case
Breather / Breather
Escpae / Muffler
Ventilador / Fan
Comutador / Switch
Travão / Brake
S.N O.;>=54769
Ac Essorios / Seat
Pi So / Floor Mat
