Kubota Tractor M125XDT Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M125XDT Tractor
Number of Pages: 549 Pages
Frequently Used Items
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Bomba / Oil Pump
Combustible Bomba Base / Fuel Pump Base
Respiradero / Breather
Descarga Valvula / Relief Valve
Volante / Flywheel
Bomba De Inyeccion[Componente Piezas][Tipo Antiguo] / Injection Pump [Component Parts]
Combustible Control Motor / Fuel Control Motor
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Aire Limpiador[Componente Piezas] / Air Cleaner [Component Parts]
Entrada Tubo / Inlet Pipe
Silenciador / Muffler
Turbo Cargador[Componente Piezas] / Turbo Charger [Component Parts]
Aceite Tubo(Turbo Cargador) / Oil Pipe (Turbo Charger)
Hidraulico Bomba Base / Hydraulic Pump Base
Mano Acelerador Palanca / Hand Accelerator Lever
Acelerador Cable / Accelerator Wire
Motor Parar Cable / Engine Stop Wire
Fuel Tank Rh [Se]
Combustible Deposito Izquierdo / Fuel Tank Lh
Combustible Tubo / Fuel Pipe
Sedimentario / Sedimenter
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Battery [Se]
Conmutador/Sensor 1 / Switch/Sensor 1
Conmutador/Sensor 2 / Switch/Sensor 2
Conmutador / Switch
Interruptor Principal/Interruptor Del Mando / Main Switch/Lever Control Switch
Rele / Relay
Tablero Panel / Panel Board
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Tacometro De Tdf/Velocimetro / Pto Tachometer/Speedometer
Control Panel
Mando Panel [Componente Piezas] / Control Panel [Component Parts]
Ascenso Brazo Sensor / Lift Arm Sensor
Culata Luz / Head Light
Intermitente Luz / Flasher Light
Working Light [Old Type]
Trabajo Luz[Tipo Nuevo] / Working Light [New Type]
Trasero Combinacion Luz / Rear Combination Light
Cd-Radio Y Altavoz / Cd-Radio And Speaker
Limpiaparabrisas / Wiper
Electrico Cableado(Motor) / Electrical Wiring (Engine)
Electrico Cableado (Principal) / Electrical Wiring (Main)
Electrico Cableado(Trasero) / Electrical Wiring (Rear)
Electrico Cableado(Cabina) / Electrical Wiring (Cab)
Potencia Cambio Valvula / Power Shift Valve
Potencia Cambio Valvula(Carroceria)[Componente Piezas] / Power Shift Valve (Body) [Component Parts]
Potencia Cambio Valvula(Superior)[Componente Piezas] / Power Shift Valve (Upper) [Component Parts]
Embrague Carcasa Cubierta / Clutch Housing Cover
Intermedia Caja / Mid Case
Transmision Caja Trasero Cubierta / Transmission Case Rear Cover
Trasero Eje Caja / Rear Axle Case
Embrague Varilla / Clutch Rod
Engranaje Soporte / Gear Support
Entrada Eje / Input Shaft
Inversor Eje / Shuttle Shaft
Primero/Segundo Cambio Engranaje / First/Second Shift Gear
Primero Eje / First Shaft
Tercero/Cuarto Cambio Engranaje / Third/Fourth Shift Gear
Arbol Contrarrotante / Countershaft
Principal Engranaje Cambio Eje Y Gama Engranaje Eje / Main Gear Shift Shaft And Range Gear Shaft
Accionar Eje(Adelante) / Drive Shaft (Front)
Accionar Eje(Medio/Trasero) / Drive Shaft (Middle/Rear)
Transmision Caja Lado Cubierta / Transmission Case Side Cover
Bisel Engranaje / Bevel Gear
Diferencial Trasero / Differential Rear
Trasero Diferencial Cerradura Embrague / Rear Differential Lock Clutch
Pto Helice Eje / Pto Propeller Shaft
Tdf Embrague / Pto Clutch
Pto Embrague[Componente Piezas] / Pto Clutch [Component Parts] [Old]
Pto Clutch [Component Parts] [New]
Pto Embrague Valvula / Pto Clutch Valve
Pto Embrague Valvula [Componente Piezas] / Pto Clutch Valve [Component Parts]
Pto Accionar Eje / Pto Drive Shaft
Pto Eje / Pto Shaft
Hidraulico Embrague(Bi-Velocidad Girar) / Hydraulic Clutch (Bi-Speed Turn)
Bi-Velocidad Girar Eje / Bi-Speed Turn Shaft
Pto Cambio Bifurcacion / Pto Shift Fork
Inversor Cambio Palanca / Shuttle Shift Lever
Gama Engranaje Cambio Varilla / Range Gear Shift Rod
Palanca De Cambio De Tdf[Se] / Pto Gear Shift Lever [Se]
Eje Trasero / Rear Axle
Freno / Brake
Estacionamiento Freno / Parking Brake
Freno Pedal / Brake Pedal
Trasero Diferencial Cerradura Pedal / Rear Differential Lock Pedal
Freno Aceite Deposito / Brake Oil Tank
Freno Maestro Cilindro[Componente Piezas] / Brake Master Cylinder [Component Parts]
Freno Tubo / Brake Pipe
Adelante Eje Soporte / Front Axle Support
Adelante Helice Eje / Front Propeller Shaft
Bisel Engranaje(Adelante) / Bevel Gear (Front)
Adelante Diferencial Cerradura Embrague / Front Differential Lock Clutch
Bisel Engranaje Caja Derecho / Bevel Gear Case Rh
Bisel Engranaje Caja Izquierdo / Bevel Gear Case Lh
Adelante Eje / Front Axle
Diferencial Eje Del Engranaje / Differential Gear Shaft
Direccion Junta / Steering Joint
Direccion Controlador[Componente Piezas] / Steering Controller [Component Parts] [Old]
Steering Controller [Component Parts] [New]
Regulador Valvula / Regulater Valve
Regulador Valvula[Componente Piezas] / Regulater Valve [Component Parts]
Hidraulico Tubo(Aspiracion) / Hydraulic Pipe (Suction)
Hidraulico Tubo(Entrega) / Hydraulic Pipe (Delivery)
Hidraulico Aceite Linea / Hydraulic Oil Line
Remolque Freno Valvula / Trailer Brake Valve
Seguridad Valvula / Safety Valve
Hidraulico Aceite Linea(Bi-Velocidad Girar/Trasero Dfrncl) / Hydraulic Oil Line (Bi-Speed Turn/Rear Diff.)
Hidraulico Aceite Linea(Adelante Diferencial) / Hydraulic Oil Line (Front Differential)
Hidraulico Aceite Linea(Direccion/Pto) / Hydraulic Oil Line (Steering/Pto)
Direccion Manguito(Entrega) / Steering Hose (Delivery)
Hydraulic Lift Arm [Se]
Hydraulic Cylinder Cover [Se]
Lowerring Lock Lever [Se]
Esfuerzo Control Valvula / Draft Control Valve
Esfuerzo Control Valvula[Componente Piezas] / Draft Control Valve [Component Parts]
Detector Barra 1(Barra/Barra Soporte) / Detector Bar 1 (Bar/Bar Support)
Detector Barra 2(Esfuerzo Vinculo) / Detector Bar 2 (Draft Link)
Coloque La Palanca De Mando / Position Control Lever
Auxiliar Control Valvula / Auxiliary Control Valve
Distribuidor De Servicios Externos(Fd)[Componente Piezas] / Auxiliary Control Valve (Fd) [Component Parts] [Old]
Distribuidor De Servicios Externos(Scd)[Componente Piezas] / Auxiliary Control Valve (Fd) [Component Parts] [New]
Auxiliary Control Valve (Scd) [Component Parts] [Old]
Auxiliary Control Valve (Scd) [Component Parts] [New]
Auxiliar Control Valvula Tubo / Auxiliary Control Valve Pipe
Auxiliar Control Valvula Palanca / Auxiliary Control Valve Lever
Ayudar Cilindro Izquierdo / Assist Cylinder Lh
Ayudar Cilindro Derecho / Assist Cylinder Rh
Ayudar Cilindro[Componente Piezas] / Assist Cylinder [Component Parts]
Lower Link [Se] [Old Type]
Lower Link [Se] [New Type]
Estabilizador / Stabilizer
Ascenso Varilla Derecho / Lift Rod Rh
Ayudar Cilindro Soporte / Assist Cylinder Bracket
Pto Eje Protector / Pto Shaft Protector
Capo(Capo)Superior / Hood(Bonnet) Upper
Capo Bastidor / Bonnet Frame
Capo Soporte / Bonnet Support
Capo(Capo)Lado Bajar / Hood(Bonnet) Side Lower
Capo(Capo)Trasero / Hood(Bonnet) Rear
Cabina Bastidor / Cab Frame
Adelante Vidrio / Front Glass
Puerta Derecho / Door Rh
Puerta Izqd / Door Lh
Cerradura De Puerta Izqd / Door Lock Lh
Side Window [Se]
Trasero Ventana (Superior) / Rear Window (Upper)
Trasero Ventana (Bajar) / Rear Window (Lower)
Interno Techo / Inner Roof
Externo Techo / Outer Roof
Hoja / Seat
Apoyabrazo / Armrest
Piso Estera / Floor Mat
Inspeccion Placa / Inspection Plate
Cambio Palanca Guia / Shift Lever Guide
Guardabarros Cubierta / Fender Cover
Montante Cubierta / Pillar Cover
Guardabarros Izquierdo / Fender Lh
Herramienta Caja / Tool Box
Aire Acondicionador Controlador / Air Conditioner Controller
Aire Acondicionador Conducto / Air Conditioner Duct
Ventilador Motor / Blower Motor
Condensador / Condenser
Aire Acondicionador Manguito/Condensador Manguito / Air Conditioner Hose / Condenser Hose
Compresor / Compressor
Compresor Soporte / Compressor Bracket
Vaciar Manguito / Drain Hose
Etiqueta(Anterior)[Se] / Label (Front) [Se]
Etiqueta(Posterior)[Se] / Label (Rear) [Se]
Funcionamiento Luz Kit[Opcion] / Working Light Kit [Option]
Trasero Desempanador Kit[Opcion] / Rear Defogger Kit [Option]
Combustible Deposito Cubierta Kit[Opcion] / Fuel Tank Cover Kit [Option]
Marcha Muy Lenta Velocidad Kit (Engranaje Caja) [Opcion] / Creep Speed Kit (Gear Case) [Option]
Marcha Muy Lenta Velocidad Kit (Cambio Bfrccn/Plnc) [Opcion] / Creep Speed Kit (Shift Fork/Lever) [Option]
Kit De Distribuidor De Servicious Externos (Scd) (Tercero) [Opcion] / Auxiliary Control Valve Kit (Scd) (3rd) [Option]
Kit De Distribuidor De Servicios Externos(Fd)(Tercero)[Opcion] / Auxiliary Control Valve Kit (Fd) (3rd) [Option]
Kit De Distribuidor De Servicios Externos(Scd)(Cuarto)[Opcion] / Auxiliary Control Valve Kit (Scd) (4th) [Option]
Kit De Distribuidor De Servicios Externos(Scd/Fc)(Cuarto)[Opcion] / Auxiliary Control Valve Kit (Scd/Fc) (4th) [Option]
Kit De Distribuidor De Servicios Externos(Fd)(Cuarto)[Opcion] / Auxiliary Control Valve Kit (Fd) (4th) [Option]
Kit De Distribuidor De Servicios Externos(Fc)[Opcion] / Auxiliary Control Valve Kit (Fc) [Option]
Distribuidor De Servicios Externos(Scd/Fc)[Componente Piezas][Opcion] / Auxiliary Control Valve (Scd/Fc) [Component Parts] [Old] [Option]
Distribuidor De Servicios Externos(Fc)[Componente Piezas][Opcion] / Auxiliary Control Valve (Scd/Fc) [Component Parts] [New] [Option]
Auxiliary Control Valve (Fc) [Component Parts] [Option]
Kit De Palanca De Distribuidor De Servicios Externos(Tercero)[Opcion] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Kit De Distribuidor De Servicious Externos (Scd) (Cuarto) [Opcion] / Auxiliary Control Valve Lever Kit (4th) [Option]
Volante / Flywheel
Fuel Tank Rh [Se]
Ventilador / Fan
Battery [Se]
Conmutador / Switch
Rele / Relay
Control Panel
Pto Eje / Pto Shaft
Freno / Brake
Side Window [Se]
Hoja / Seat
