702,019
Kubota Tractor M125XDT Australia Parts Catalog
Model: Kubota M125XDT Tractor
Region: Australia
Number of Pages: 543 Pages
Frequently Used Items Frequently Used Items
Engine Crankcase
Engine Oil Pan
Engine Cylinder Head
Engine Gear Case
Engine Head Cover
Engine Oil Pump
Engine Fuel Pump Base
Engine Breather
Engine Relief Valve
Engine Main Bearing Case
Engine Camshaft And Idle Gear Shaft
Engine Piston And Crankshaft
Engine Flywheel
Engine Injection Pump
Engine Injection Pump [Component Parts]
Engine Nozzle Holder And Glow Plug
Engine Fuel Control Motor
Engine Fuel Filter
Engine Fuel Filter [Component Parts]
Engine Water Flange And Thermostat
Engine Water Pump
Engine Valve And Rocker Arm
Engine Inlet Manifold
Engine Exhaust Manifold
Engine Air Cleaner
Engine Air Cleaner [Component Parts]
Engine Inlet Pipe
Engine Muffler
Engine Turbo Charger
Engine Turbo Charger [Component Parts]
Engine Oil Pipe (Turbo Charger)
Engine Hydraulic Pump Base
Engine Upper Gasket Kit
Engine Lower Gasket Kit
Engine Hand Accelerator Lever
Engine Accelerator Pedal
Engine Accelerator Wire
Engine Engine Stop Wire
Fuel System Fuel Tank Rh
Fuel System Fuel Tank Lh
Fuel System Fuel Pipe
Fuel System Sedimenter
Fuel System Separator [Component Parts]
Cooling Water System Fan
Cooling Water System Water Pipe
Cooling Water System Radiator
Cooling Water System Reserve Tank
Electrical System Alternator
Electrical System Alternator [Component Parts]
Electrical System Starter
Electrical System Starter [Component Parts]
Electrical System Battery
Electrical System Switch Sensor 1
Electrical System Switch Sensor 2
Electrical System Main Switch Lever Control Swich
Electrical System Relay
Electrical System Panel Board
Electrical System Panel Board [Component Parts]
Electrical System PTO Tachometer Speedometer
Electrical System Contorol Panel
Electrical System Control Panel [Component Parts]
Electrical System Lift Arm Sensor
Electrical System Head Light
Electrical System Flasher Light [Old Type] ## S.No. =51307
Electrical System Flasher Light [New Type] ## S.No. =51308
Electrical System Work Light [Old Type] ## S.No. =52182
Electrical System Working Light [New Type] ## S.No. =52183
Electrical System Rear Combination Light [Old Type] ## S.No. =51307
Electrical System Rear Combination Light [New Type] ## S.No. =51308
Electrical System Trailer Socket
Electrical System Cd-Radio And Speaker
Electrical System Washer Tank
Electrical System Wiper
Electrical System Electrical Wiring (Engine)
Electrical System Electrical Wiring (Main)
Electrical System Electrical Wiring (Rear)
Electrical System Electrical Wiring (Cab) [Old Type] ## S.No. =52182
Electrical System Electrical Wiring (Cab) [New Type] ## S.No. =52183
Clutch Transmission Clutch Housing
Clutch Transmission Power Shift Valve
Clutch Transmission Power Shift Valve (Body) [Component Parts]
Clutch Transmission Power Shift Valve (Upper) [Component Parts]
Clutch Transmission Clutch Housing Cover
Clutch Transmission Mid Case
Clutch Transmission Transmission Case
Clutch Transmission Transmission Case Rear Cover
Clutch Transmission Rear Axle Case
Clutch Transmission Damper Disk
Clutch Transmission Clutch Pedal
Clutch Transmission Clutch Rod
Clutch Transmission Front Cover
Clutch Transmission Gear Support
Clutch Transmission Input Shaft
Clutch Transmission Shuttle Shaft
Clutch Transmission First Second Shift Gear
Clutch Transmission First Shaft
Clutch Transmission Third Fourth Shift Gear
Clutch Transmission Countershaft
Clutch Transmission Main Gear Shift Shaft And Range Gear Shaft
Clutch Transmission Range Gear Shaft
Clutch Transmission Drive Shaft (Front)
Clutch Transmission Drive Shaft (Middle Rear)
Clutch Transmission Transmission Case Side Cover
Clutch Transmission Bevel Gear
Clutch Transmission Differential Rear
Clutch Transmission Rear Differential Lock Clutch
Clutch Transmission PTO Propeller Shaft
Clutch Transmission PTO Clutch ## Note Order By Ref.No.010 And Fig.No.D27000 Ref.No
Clutch Transmission PTO Clutch [Component Parts] [Old] ## S.No. =54622 [Note Order By Fig.No.D26600 Ref.No
Clutch Transmission PTO Clutch [Component Parts] [New] ## S.No. =54623 S.No.; =54623
Clutch Transmission PTO Clutch Valve
Clutch Transmission PTO Clutch Valve [Component Parts]
Clutch Transmission PTO Drive Shaft
Clutch Transmission PTO Shaft
Clutch Transmission Hydraulic Clutch (Bi-Speed Turn)
Clutch Transmission Bi-Speed Turn Shaft
Speed Change Shift Fork Shift Lever Range Gear Shift Fork
Speed Change Shift Fork Shift Lever PTO Shift Fork
Speed Change Shift Fork Shift Lever Main Gear Shift Lever
Speed Change Shift Fork Shift Lever Shuttle Shift Lever
Speed Change Shift Fork Shift Lever Range Gear Shift Rod
Speed Change Shift Fork Shift Lever PTO Gear Shift Lever ## Note Order By Ref.No
Rear Axle Brake Rear Axle
Rear Axle Brake Brake
Rear Axle Brake Parking Brake Lever
Rear Axle Brake Brake Pedal
Rear Axle Brake Rear Differential Lock Pedal
Rear Axle Brake Brake Oil Tank
Rear Axle Brake Brake Master Cylinder [Component Parts]
Rear Axle Brake Brake Pipe
Front Axle Chassis Front Axle Bracket
Front Axle Chassis Front Axle Support
Front Axle Chassis Front Propeller Shaft
Front Axle Chassis Front Differential Case
Front Axle Chassis Bevel Gear (Front)
Front Axle Chassis Differential Front
Front Axle Chassis Front Differential Lock Clutch
Front Axle Chassis Bevel Gear Case Rh
Front Axle Chassis Bevel Gear Case Lh
Front Axle Chassis Front Axle Case
Front Axle Chassis Differential Gear Shaft
Steering Steering Handle
Steering Tilt Pedal
Steering Steering Joint
Steering Steering Controller
Steering Steering Controller [Component Parts] [Old] ## S.No. =54768 S.No.; =54768
Steering Steering Controller [Component Parts] [New] ## S.No. =54769 S.No.; =54769
Steering Tie Rod
Steering Steering Cylinder [Component Parts]
Hydraulic System Hydraulic Pump
Hydraulic System Hydraulic Pump [Component Parts]
Hydraulic System Regulater Valve
Hydraulic System Regulater Valve [Component Parts]
Hydraulic System Hydraulic Pipe (Suction)
Hydraulic System Hydraulic Pipe (Delivery)
Hydraulic System Hydraulic Oil Line
Hydraulic System Safety Valve
Hydraulic System Hydraulic Oil Line (Bi-Speed Turn Rear Diff.)
Hydraulic System Hydraulic Oil Line (Front Differential)
Hydraulic System Oil Cooler
Hydraulic System Hydraulic Oil Line (Steering PTO)
Hydraulic System Steering Hose (Delivery)
Hydraulic System Hydraulic Cylinder
Hydraulic System Hydraulic Lift Arm
Hydraulic System Hydraulic Cylinder Cover
Hydraulic System Lowerring Lock Lever
Hydraulic System Draft Control Valve
Hydraulic System Draft Control Valve [Component Parts]
Hydraulic System Detector Bar 1 (Bar Bar Support)
Hydraulic System Detector Bar 2 (Draft Link)
Hydraulic System Position Control Lever
Hydraulic System Auxiliary Control Valve
Hydraulic System Auxiliary Control Valve (Fd) [Component Parts]
Hydraulic System Auxiliary Control Valve (Scd) [Component Parts]
Hydraulic System Auxiliary Control Valve Pipe
Hydraulic System Auxiliary Control Valve Lever
Hydraulic System Assist Cylinder Lh
Hydraulic System Assist Cylinder Rh
Hydraulic System Assist Cylinder [Component Parts]
3-Point Linkage Drawbar Hitch Top Link Bracket
3-Point Linkage Drawbar Hitch Lower Link [Old Type] ## S.No. =51857
3-Point Linkage Drawbar Hitch Lower Link [New Type] ## S.No. =51858
3-Point Linkage Drawbar Hitch Stabilizer
3-Point Linkage Drawbar Hitch Lift Rod Rh
3-Point Linkage Drawbar Hitch Lift Rod Lh
3-Point Linkage Drawbar Hitch Swinging Drawbar
3-Point Linkage Drawbar Hitch PTO Shaft Protector
Hood Bonnet Front Grille
Hood Bonnet Hood(Bonnet) Upper
Hood Bonnet Bonnet Frame
Hood Bonnet Bonnet Support
Hood Bonnet Hood(Bonnet) Side Lower
Hood Bonnet Hood(Bonnet) Rear
Cab Cab Frame
Cab Front Glass
Cab Door Rh
Cab Door Lh
Cab Door Lock Rh
Cab Door Lock Lh
Cab Side Window
Cab Rear Window
Cab Rearview Mirror
Cab Inner Roof
Cab Outer Roof
Cab Seat
Cab Armrest
Cab Floor Mat
Cab Inspection Plate
Cab Shift Lever Guide
Cab Fender Cover
Cab Pillar Cover
Cab Fender Rh
Cab Fender Lh
Cab Cab Bracket Front
Cab Cab Bracket Rear
Cab Tool Box
Air Conditioner Air Conditioner Controller
Air Conditioner Air Conditioner Duct
Air Conditioner Blower Motor
Air Conditioner Heater Hose
Air Conditioner Condenser
Air Conditioner Air Conditioner Hose Condenser Hose
Air Conditioner Compressor
Air Conditioner Compressor Bracket
Air Conditioner Drain Hose
Front Rear Tire Front Wheel Disk
Front Rear Tire Rear Wheel Disk
Labels Label 1 (Front)
Labels Label 2 (Rear)
Accessories Accessories And Service Parts
Option Rear Defogger Kit [Option]
Option Fuel Tank Cover Kit [Option]
Option Creep Speed Kit 1 (Gear Case) [Option]
Option Creep Speed Kit 2 (Shift Fork Lever) [Option]
Option Front Bumper Kit [Option]
Option Auxiliary Control Valve Kit (Scd) (3rd) [Option]
Option Auxiliary Control Valve Kit (Fd) (3rd) [Option]
Option Auxiliary Control Valve Kit (Scd) (4th) [Option]
Option Auxiliary Control Valve Kit (Scd Fc) (4th) [Option]
Option Auxiliary Control Valve Kit (Fd) (4th) [Option]
Option Auxiliary Control Valve Kit (Fc) [Option]
Option Auxiliary Control Valve (Scd Fc) [Component Parts] [Option]
Option Auxiliary Control Valve (Fc) [Component Parts] [Option]
Option Auxiliary Control Valve Lever Kit (3rd) [Option]
Option Auxiliary Control Valve Lever Kit (4th) [Option]
