Kubota Tractor M125GXDTSC-4 Spare Parts Catalog EN TR
Language: English, Turkish
Region: Turkey
Model: Kubota M125GXDTSC-4 Tractor
Number of Pages: 815 Pages
Engine 400100 Engine Block (Upper) Crankcase (Upper)
Engine 400200 Engine Block (Lower) Crankcase (Lower)
Engine 401000 Oil Pan
Engine 402000 Cylinder Head
Engine 403000 Inlet And Exhaust Valve Valve Inlet Valve And Exhaust Valve
Engine 404000 Rocker Arm Shaft
Engine 405000 Head Cover
Engine 410000 Front Cover
Engine 411000 Piston And Crankshaft
Engine 412000 Camshaft And Idle Gear
Engine 413000 Balancer
Engine 415002 Flywheel
Engine 420000 Fuel Filter
Engine 421000 Supply Pump
Engine 425000 Injector And Glow Plug
Engine 426000 Injection Pipe
Engine 428000 Common Rail
Engine 430000 Thermostat Water Flange And Thermostat
Engine 431000 Water Pump
Engine 435000 Oil Cooler
Engine 436000 Oil Separator
Engine 436300 Oil Separator Component Parts Oil
Engine 436500 Oil Separator Pipe
Engine 437000 Oil Pipe (Turbo Charger)
Engine 440002 Air Cleaner
Engine 440500 Air Cleaner Component Parts
Engine 441500 Inlet Pipe (Air Cleaner)
Engine 442000 Turbocharger Turbo Charger
Engine 443000 Intercooler Inter Cooler
Engine 444000 Inlet Manifold
Engine 445000 Air Filter Flange And Throttle Valve And
Engine 446000 EGR Valve
Engine 447000 EGR Cooler
Engine 448000 EGR Water System Piping EGR Water Piping
Engine 450000 Exhaust Manifold
Engine 452000 Sound Absorber Pipe Muffler Pipe
Engine 455000 Diesel Particulate Filter Absorber Diesel Particulate Filter
Engine 455500 Diesel Particulate Filter Absorber Component Parts Filter
Engine 455700 Sound Absorber Bracket (Dpf) Muffler Bracket (Dpf)
Engine 457500 Pressure Pipe
Engine 459000 Sound Absorber Pipe (Diesel Particle Filter) Muffler Pipe (Diesel
Engine 460000 Selective Catalytic Reduction Muffler
Engine 460500 Insulation (Scr Sound Absorber) Insulation Plate (Selective Catalytic
Engine 462000 Selector Catalyst Reduction Frame Selective Catalytic
Engine 463000 Selector Catalyst Reduction Cover Selective Catalytic Reduction
Selector Catalyst Reduction Injector Cover Old Selective Catalytic Reduction Injector Cover Old
Selector Catalyst Reduction Injector Cover New Selective Catalytic Reduction Injector Cover New
Engine 468000 Selector Catalyst Reduction Main Frame Selective Catalytic
Engine 470000 Diesel Exhaust Fluid Pump Diesel
Engine 471000 Diesel Exhaust Fluid Tank Diesel
Engine 471500 Diesel Exhaust Fluid Tank Component Parts Diesel
Engine 472000 Diesel Exhaust Fluid Hose
Engine 473000 EGR Valve (Selector Catalyst Reduced System) EGR Valve (Selective
Engine 474000 EGR Cooler (Selector Catalyst Reduced System) EGR Cooler (Selective
Engine 475000 EGR Pipe (Selector Catalyst Reduced System) EGR Pipe (Selective Catalytic
Engine 476000 EGR Water System Piping (Selector Catalyst Reduced System) EGR Water Piping (
Engine 495000 Engine Electrical Parts (Sensor ECu) Engine Electrical
Engine 496000 Engine Electrical Parts (Sound Absorber) Engine Electrical
Engine 497000 Injector Harness
Engine 498000 Engine Electrical Mounting PartsMounting
Engine A01000 Hand Accelerator Lever
Engine A03000 Accelerator Pedal
Fuel System A11500 Fuel Tank Bracket Old Fuel Tank Bracket Old Chassis No. 50273 S.
System Fuel System A11501 Fuel Tank Bracket New Fuel Tank Bracket New Chassis No. 50274 S.
Fuel System A11701 Fuel Tank Support EC Ge Fuel Tank Support
Fuel System A11702 Fuel Tank Support Uk Fuel Tank Support
Fuel System A12000 Fuel Tank (Right Side) Fuel Tank Rh
Fuel System A13001 Fuel Tank (Left Side) Old Fuel Tank Lh Old Chassis No. 50273 S.No.
Fuel System A13003 Fuel Tank (Left Side) New Fuel Tank Lh New Chassis No. 50274 S.No.
Fuel System A13800 Fuel Pipe (Diesel Exhaust Fluid Ventilation) Fuel Pipe (Diesel
Fuel System A14000 Fuel Pipe (Fuel Tank) Fuel Pipe (Fuel
Fuel System A14100 Fuel Pipe (Fuel Filter) Fuel Pipe (Fuel
Fuel System A14200 Fuel Pipe (Rear) Fuel Pipe (Fuel Pump)
Fuel System A14300 Fuel Pipe (Fuel Tank Ventilation) Fuel Pipe (
Fuel System A14400 Fuel Pipe (Fuel Cooler)
Fuel System A14500 Fuel Cooler
Fuel System A15100 Separator
Fuel System A16100 Separator Component Parts
Fuel System A16500 Fuel Pump Fuel Pump
Fuel System A16600 Fuel Pump Component Parts Fuel Pump
Fuel System A17000 Fuel Filter
Fuel System A18000 Fuel Filter Component Parts
Cooling Water System A40500 Fan Bracket Fan Bracket
Cooling Water System A41000 Fan
Cooling Water System A42000 Water Pipe
Cooling Water System A43000 Radiator
Cooling Water System A45000 Reserve Tank Reserve
Electrical System A54000 Alternator
Electrical System A55000 Alternator Component Parts
Electrical System A56000 Starter
Electrical System A57000 Starter Component Parts
Electrical System A58000 Battery
Electrical System B00200 Switch Sensor (Engine Left Side) Switch
Electrical System B00300 Switch Sensor (Engine Right Side) Switch
Electrical System B00800 Electrical Part Cover Electrical
Electrical System B01000 Selector Catalyst Reduction Sensor (Engine) Selective
Electrical System B01100 Selector Catalyst Reduction Sensor (Body) Selective
Electrical System B01500 Switch Sensor (Suspension)
Electrical System B02000 Switch Sensor (Front)
Electrical System B03000 Switch Sensor (Body)
Electrical System B03500 Sensor (Brake)
Electrical System B04001 Switch Sensor (Rear) EC Uk
Electrical System B04002 Switch Sensor (Rear) Ge
Electrical System B11000 Switch (Use) Switch (Operation)
Electrical System B12000 Main Switch Lever Control Switch
Electrical System B13000 Relay
Electrical System B13300 Electronic Control Unit (Engine) Electrical
Electrical System B13402 Electronic Control Unit (Body) Electrical
Electrical System B14000 Instrument Panel Panel Panel
Electrical System B18000 PTO Revolution Indicator Speed Indicators Pto
Electrical System B18502 Control Panel Panel
Electrical System B18600 Control Panel Component Panel
Electrical System B32000 Outdoor Lighting Head Light
Electrical System B32100 Outdoor Lighting Component Parts Head Light
Electrical System B33900 Front Combination Lamp Old Front Combination Lamp Old Chassis No. 50128
Electrical System B33901 Front Combination Lamp New Front Combination Lamp New Chassis No.
Electrical System B35000 Work Light (Front) Work Light (
Electrical System B35100 Work Light (Rear) Work Light (
Electrical System B36000 Rear Combination Headlight
Electrical System B36500 License Lamp
Electrical System B37000 Trailer Socket
Electrical System B41000 Indoor Room Light
Electrical System B42500 Radio Speaker Radio Speaker
Electrical System B43000 Washer Tank Washer Tank
Electrical System B44000 Wiper Wiper
Electrical System B50102 Wire Harness (Crs) Electrical Wiring
Electrical System B50200 Wire Harness (Scr) Electrical Wiring
Electrical System B50300 Wire Harness (Motor) Electrical Wiring
Electrical System B50400 Wire Harness (Outdoor Lighting) Electrical Wiring
Electrical System B50500 Wire Harness (Panel) Electrical Wiring
Electrical System B50600 Wire Harness (Rear) Electrical Wiring
Electrical System B50700 Wire Harness (Key) Electrical Wiring
Electrical System B51302 Wire Harness (Control Panel) Electrical Wiring
Electrical System B51400 Wire Harness (Armrest) Electrical Wiring
Electrical System B51501 Wire Harness (Body) EC Uk Electrical Wiring
Electrical System B51502 Wire Harness (Body) Ge Electrical Wiring
Electrical System B51600 Wire Harness (Front Suspension Valve) Electrical Wiring
Electrical System B52000 Wire Harness (Cabin) Electrical Wiring
Clutch Gear Clutch Transmission C11000 Clutch Housing
Clutch Gear Clutch Transmission C11700 Valve Power Shift Power Shift
Clutch Gear Clutch Transmission C11800 Valve Power Shift (Body) Component Parts Power Shift
Clutch Gear Clutch Transmission C11900 Valve Power Shift (Upper) Component Parts Power Shift
Clutch Gear Clutch Transmission C12002 Clutch Housing Cover (Lower) Clutch Housing
Clutch Gear Clutch Transmission C13000 Mid Case
Clutch Gear Clutch Transmission C14000 Transmission Case
Clutch Gear Clutch Transmission C15000 Gear Housing Rear Cover Transmission
Clutch Gear Clutch Transmission C17100 Rear Axle Housing Right Side Rear
Clutch Gear Clutch Transmission C17200 Rear Axle Housing Left Side Rear
Clutch Gear Clutch Transmission C22000 Damper Disc Damper Disc
Clutch Gear Clutch Transmission C24000 Clutch Pedal
Clutch Gear Clutch Transmission C25000 Clutch Rod
Clutch Gear Clutch Transmission D11000 Front Cover
Clutch Gear Clutch Transmission D12000 Front Bearing Support
Clutch Gear Clutch Transmission D21500 Input Shaft
Clutch Gear Clutch Transmission D21700 Shuttle Shaft
Clutch Gear Clutch Transmission D22000 First Second Gear Transmission
Clutch Gear Clutch Transmission D22500 First Shaft
Clutch Gear Clutch Transmission D23000 Third Fourth Gear Transmission Third
Clutch Gear Clutch Transmission D24000 Counter Shaft
Clutch Gear Clutch Transmission D24500 Main Transmission Shaft Gear Range Shaft Main Gear
Clutch Gear Clutch Transmission D25000 Gear Range Shaft (Front) Range Gear
Clutch Transmission D25100 Gear Range Shaft (Rear) Old Range Gear Shaft (Rear) Old Chassis
Clutch Transmission D25101 Gear Range Gear Shaft (Rear) New Range Gear Shaft (Rear) New Chassis
Clutch Gear Clutch Transmission D25400 Shaft Drive (Front) Drive Shaft (
Clutch Gear Clutch Transmission D25500 Shaft Drive (Center Rear) Drive Shaft (
Clutch Gear Clutch Transmission D25700 Hi-Low Gear Body Hi-Lo
Clutch Gear Clutch Transmission D26000 Bevel Gear
Clutch Gear Clutch Transmission D26200 Rear Differential
Clutch Gear Clutch Transmission D26300 Rear Differential Lock Clutch Rear
Clutch Gear Clutch Transmission D26500 PTO Propeller Shaft
Clutch Gear Clutch Transmission D26600 PTO Clutch
Clutch Gear Clutch Transmission D26700 PTO Clutch Component Parts
Clutch Gear Clutch Transmission D26800 PTO Clutch Valve PTO Clutch
Clutch Gear Clutch Transmission D26900 PTO Clutch Valve Component Parts
Clutch Gear Clutch Transmission D27000 PTO Drive Shaft PTO Drive Shaft
Clutch Gear Clutch Transmission D27500 PTO Shaft
Clutch Gear Clutch Transmission D35000 Front Drive Clutch Front Drive
Clutch Gear Clutch Transmission D35200 Front Drive Clutch Component Parts Front Drive
Speed Change Shift Fork D43000 Range Transmission
Speed Change Shift Fork D46000 PTO Transmission
Gear Speed Change Shift Fork F11000 Main Gear
Speed Change Shift Fork F12500 Transmission Shuttle
Speed Change Shift Fork F14100 Gear Range
Speed Change Shift Fork F15000 PTO Transmission
Rear Axle Brake F18000 Rear Differential Lock Pedal Rear Differential
Rear Axle Brake F20000 Rear Axle
Rear Axle Brake F20501 Brake EC Uk Brake EC Uk
Rear Axle Brake F20502 Brake Ge
Rear Axle Brake F22000 Parking Brake Lever
Rear Axle Brake F23000 Parking Brake
Rear Axle Brake F23500 Brake Pedal
Rear Axle Brake F31500 Brake Master Cylinder Brake Master
Rear Axle Brake F32000 Brake Master Cylinder Component Parts Brake Master
Rear Axle Brake F33001 Brake Pipe EC Uk Brake Pipe EC
Rear Axle Brake F33002 Brake Pipe Ge Brake Pipe Ge
Rear Axle Brake F33500 Brake Main Cylinder Pipe Brake Master
Front Axle Chassis G10502 Front Axle Frame Front Axle
Front Axle Chassis G11002 Front Axle Housing Bracket Front Axle
Front Axle Chassis G14002 Propeller Shaft (Front Center) Propeller Shaft
Front Axle Chassis G14200 Mid Propeller Shaft Component Parts
Front Axle Chassis G14300 Propeller Shaft (Rear) Propeller Shaft
Front Axle Chassis G15002 Front Differential Housing Front
Front Axle Chassis G16002 Inclination Transmission (Front) Bevel Gear (
Front Axle Chassis G17002 Front Differential Differential
Front Axle Chassis G21502 Front Differential Lock Clutch Front Differential
Front Axle Chassis G22100 Sloped Transmission Housing (Right Side) Bevel
Front Axle Chassis G22200 Sloped Transmission Housing (Left Side) Bevel
Front Axle Chassis G22500 Front Axle Housing Front Axle
Front Axle Chassis G22700 Front Axle
Front Axle Chassis G23002 Differential Transmission Shaft Differential
Steering H11000 Steering Handle
Steering H11300 Steering Part Cover Steering Post Cover
Steering H12300 Tilt Lever
Steering H12500 Telescope Lever
Steering H14000 Steering Control Steering Controller
Steering H15000 Steering Control Component Parts Steering Controller
Steering H16002 Rubber Tie Rod Steering Cylinder
Steering H16500 Steering Cylinder Component Parts
Hydraulic System J13000 Hydraulic Pump
Hydraulic System J13500 Hydraulic Pump
Hydraulic System J16000 Regulator Valve Regulator Valve
Hydraulic System J16500 Regulator Valve Component Parts Regulator Valve
Hydraulic System J21000 Hydraulic Oil Line (Suction)
Hydraulic System J22001 Hydraulic Oil Line (Feed) EC Uk Hydraulic Oil
Hydraulic System J22002 Hydraulic Oil Line (Feed) Ge Hydraulic Oil
System J22300 Hydraulic Pipe (Trailer Brake) EC Uk Old Hydraulic Pipe (Trailer Brake) EC Uk
System J22301 Hydraulic Pipe (Trailer Brake) EC Uk New Hydraulic Pipe (Trailer Brake) EC Uk
Hydraulic System J23300 Front Loader Pipe Front Loader
Hydraulic System J23500 Hydraulic Oil Line Hydraulic Oil
Hydraulic System J23700 Trailer Brake Valve EC Uk Old Trailer Brake Valve EC Uk Old Chassis
Hydraulic System J23701 Trailer Brake Valve EC Uk New Trailer Brake Valve EC Uk New Chassis
Hydraulic System J24000 Safety Valve Safety Valve
Hydraulic System J24500 Hydraulic Oil Line (Rear Differential) Hydraulic Oil
Hydraulic System J26002 Hydraulic Oil Line (Front Differential) Hydraulic Oil
Hydraulic System J26500 Oil Cooler
Hydraulic System J27000 Hydraulic Oil Line (Oil Cooler) Hydraulic Oil
Hydraulic System J27503 Hydraulic Oil Line (Steering,PTO) EC Uk Hydraulic Oil
Hydraulic System J27504 Hydraulic Oil Line (Steering,PTO) Ge Hydraulic Oil
Hydraulic System J28002 Steering Hose (Delivered) Steering Hose
Hydraulic System J29300 Front Suspension Valve Front Suspension
Hydraulic System J29401 Front Suspension Valve (Relief Control) Component Parts Front
Hydraulic System J29402 Front Suspension Valve (Safety) Component Parts Front Suspension
Hydraulic System J29403 Front Suspension Valve (Additional) Component Parts Front Suspension
Hydraulic System J29500 Front Suspension Valve Hose Front Suspension
Hydraulic System J29600 Front Suspension Cylinder Front Suspension
Hydraulic System J29700 Front Suspension Cylinder Component Parts Front Suspension
Hydraulic System J29800 Auxiliary Flow Valve Branch Flow
Hydraulic System J29900 Auxiliary Flow Valve Component Parts Branch Flow
Hydraulic System J30800 Hydraulic Cylinder Housing Hydraulic
Hydraulic System J31300 Valve Valve
Hydraulic System J31400 Valve Base Valve Base
Hydraulic System J31500 Lift Arm Hydraulic Lift Arm
Hydraulic System J31900 Relief Valve Control Valve Relief Valve
Hydraulic System J32300 Lowering Adjustment Valve Lowering Lock
Hydraulic System J33400 Detector Lever 1 (Support) Detector Bar (
Hydraulic System J33600 Detector Lever (Drawbar) Detector
Hydraulic System J37800 Position Control Lever Position Control
Hydraulic System J41300 Automatic Control Valve Auto Control
Hydraulic System J41500 Automatic Control Valve Component Parts Auto Control
Hydraulic System J43200 Remote Control Valve (With Flow Control) Mounting Assembly Auxiliary
Hydraulic System J43400 Remote Control Valve (With FC) Auxiliary Control
System J43501 Remote Control Valve (With Flow Control) Mounting Assembly Component Parts Auxiliary
Hydraulic System J43502 Remote Control Valve (SCD Fd) Component Parts Auxiliary Control
Hydraulic System J43503 Remote Control Valve (FC Fd) Component Parts Auxiliary Control
Hydraulic System J43600 Remote Control Valve (With FC) Spare Tank Auxiliary Control
Hydraulic System J43700 Remote Control Valve Lever (With FC) Auxiliary Control
Hydraulic System J45600 External Oil Flow Adjustment Control Rope Auxiliary
Hydraulic System J47100 3p-Left Lift Support Cylinder 3p-Lift Assist
Hydraulic System J47200 3p-Right Lift Support Cylinder 3p-Lift Assist
System J47300 3p-Lift Support Cylinder Component Parts Old 3p-Lift Assist Cylinder Component
System J47301 3p-Lift Support Cylinder Component Parts New 3p-Lift Assist Cylinder Component
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K10500 Upper Link Bracket
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K11000 Top Link
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K12500 Bottom Link
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K13300 Stabilizer
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K14000 Right Draw Shaft
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K14300 Left Draw Shaft
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L17000 PTO Protector
Hood Bone M11000 Front Grille
Kaput Bone Hood Bonnet M12000 Hood (Bonnet) Upper
Hood Bone M12100 Hood (Bonnet) (Silencer Isolator) Hood (Bonnet) (Sound)
Hood Bone M12300 Hood (Bonnet) Damper
Hood Bone M12400 Bone Lock Hood (Bonnet) Lock
Kaput Bone Hood Bonnet M13700 Bone Frame Bonnet Frame
Kaput Bone Hood Bonnet M14000 Bone Support Bonnet Support
Hood Bone M15100 Bone Side Cover Right Side Hood (Bonnet) Side
Hood Bonnet Hood Bonnet M15200 Bone Side Cover Left Side Hood (Bonnet) Side
Cab N11000 Cab Frame Old Cab Frame Old Chassis No. 50205 S.No. 50205 S.No.
Cab N11001 Cab Frame New Cab Frame New Chassis No. 50206 S.No. 50206 S.No.
Cab N11700 Hood (Bone) Rear Hood (Bonnet) Rear
Cab N12000 Front Glass Front Glass
Cab N12500 Door (Right Side) Door Rh
Cab N13000 Door (Left Side) Door Lh
Cab N13500 Door Lock (Right Side) Door Lock Rh
Cab N14000 Door Lock (Left Side) Door Lock Lh
Cab N15000 Rear Window Hatch Back Glass
Cab N15600 Sun Roof
Cab N15800 Rearview Mirror
Cab N16000 Inner Ceiling Inner Roof
Cab N16500 Outer Ceiling Outer Roof
Cab N17000 Seat
Cab N17100 Seat Component Parts
Cab N17200 Armrest
Cab N17400 Educational Seat Instructional Seat
Cab N17500 Floor Mat
Cab N17600 Soundproof Material
Cab N17800 Seat Mat
Cab N18000 Inspection Plate (Cover) Inspection Plate (Front)
Cab N18100 Inspection Plate (Rear)
Cab N18500 Shift Cover
Cab N21500 Fender Cover (Left Side) Fender Cover Lh
Cab N22500 Fender (Right Side) Fender Rh
Cab N23000 Fender (Left Side) Fender Lh
Cab N24000 Cab Bracket, Front Cab Bracket Front
Cab N24500 Cab Bracket, Rear Cab Bracket Rear
Cab N25000 Tool Box
Air Conditioner P11500 Air Conditioner
Air Conditioner P13800 Air Conditioner Tube Cover Air Conditioner Duct
Air Conditioner P13900 Air Conditioner Tube (Cover) Air Conditioner Duct (
Air Conditioner P14000 Air Conditioner Tube (Rear) Air Conditioner Duct (
Air Conditioner P14100 Mode Case
Air Conditioner P14300 Air Outlets Indicator Dashboard Air
Air Conditioner P14700 Inner Air Recirculation
Air Conditioner P15000 Heater Hose
Air Conditioner P15500 Condenser
Air Conditioner P15700 Air Conditioner Hose Condenser Hose
Air Conditioner P16000 Compressor (Air Conditioner) Compressor (Air Conditioner)
Labels S12000 Label (Front)
Labels S13000 Label (Rear Cab)
Labels S14000 Label (Rear Cab)
Accessories And Service Parts T11000 Accessories
Option U08000 Insulation Kit Option Insulation Kit Option
Option U13000 Working Light Kit Option
Option U13200 Lamp Kit Option Lamp Kit Option Chassis No. 50128 S.No. 50128 S.
Option U13300 Working Light (Rear) Kit Option Working Light (Rear) Kit
Option U14600 Working Light Kit (Led) Option
Option U14700 Working Light (Rear) Kit (Led) Option Working Light Kit (Rear)
Option U18000 Rear Defogger Kit Option Rear Defogger Kit
Option U25000 Cover Tank Fuel Kit Option Fuel Tank Cover Kit
Option U32100 Low Speed Kit (Gearbox) Option Creep Speed Kit (Gear
Option U32200 Low Speed Kit (Shift Fork) Option Creep Speed Kit (Shift
Option U32300 Low Speed Kit (Lever) Option Creep Speed Kit (Lever)
Option U34000 PTO (540 540e) Conversion Kit (Gear) Option PTO (540 540e) Conversion
Option U35000 PTO (540 1000) Conversion Kit (Gearbox) Option PTO (540 1000) Conversion
Option U35100 PTO (540 1000) Conversion Kit (Gear) Option Pto(540 1000) Conversion
Option U71401 Auxiliary Control Valve Kit (SCD FC) Option Auxiliary Control Valve Kit
Option U71402 Auxiliary Control Valve Kit (Fd FC) Option Auxiliary Control Valve Kit
Option U71801 Auxiliary Control Valve Coupler (With FC) (3.) Option Auxiliary Control Valve
Option U71802 Auxiliary Control Valve Coupler (With FC) (4.) Option Auxiliary Control Valve
Option U96600 Outer Roof Seal Kit (Seal) Option Outer Roof Seal Kit (
Region: Turkey
Cab N15600 Sun Roof
Cab N17000 Seat
Cab N17200 Armrest
Cab N17800 Seat Mat
Cab N25000 Tool Box
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
