Kubota Tractor M110GXDTC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M110GXDTC Tractor
Number of Pages: 465 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhau St Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Carreto / Gear Case
Arvore Cames E Veio / Camshaft And Idle Gear Shaf T
Compensador / Balancer
Volante Motor / Flywheel
Filtro Gasoleo / Fuel Filter
Common Rail / Common Rail
Bomba Agua E Termostacto / Water Flange And Therm Ostat
Acessorios / Water Pump
Flange Filtro Ar / Air Cleaner Flange And Throttl E Valve
Valvula Egr / Egr Valve
Filtro Ar / Air Cleaner [Old]
Filtro Ar / Air Cleaner [New]
Filtro Ar [Peças Componentes] / Air Cleaner [Comp Onent Parts]
Tubo Aspiracao / Inlet Pipe (Air Cleaner)
Panela Escape / Muffler Pipe
Tampa Tubo Colector / Muffler Pipe Cover
Silenciador Do Filtro De Partículas Diesel / Dies El Particulate Filter Muffler
Suporte / Muffler Bracket
Silenciador Do Filtro De Partículas Diesel [Peças Componentes] / Diesel Particulate Filter Muffler [ Component Parts]
Sensor Escape / Muffler Sensor
Tubo Pressao / Pressure Pipe
Intercooler / Inter Cooler [Old]
Intercooler / Inter Cooler [New]
Componentes Electricos Motor / Engine Electrical Parts
Diagmaster / Diagmaster
Suporte Deposito Combustive L / Fuel Tank Bracket
Tubo Combustivel / Fuel Pip E (Fuel Filler)
Tubo Combustivel / Fuel Pip E (Fuel Pump)
Tubo Combustivel / Fuel Pip E (Fuel Cooler)
Arrefecedor Gasoleo / Fuel Cooler
Separador / Separator
Separador[Peças Componentes ] / Separator [Component Parts]
Ventoinha / Fan [Old]
Ventoinha / Fan [New]
Tubo Agua / Water Pipe [Old]
Tubo Agua / Water Pipe [New]
Radiador / Radiator [Old]
Radiador / Radiator [New]
Deposito Reserva / Reserve Tank [Old]
Deposito Reserva / Reserve Tank [New]
Alternador / Alternator [O Ld]
Alternador / Alternator [N Ew]
Alternador [Peças Componen Tes] / Alternator [Component Parts]
Interruptor/Sensor (Bloco Motor) / Switch/Sensor (Engine)
Interruptor/Sensor (Panela Escape) / Switch/Sensor (Muffler)
Interruptor/Sensor / Switc H/Sensor (Front)
Interruptor/Sensor / Switc H/Sensor (Body)
Interruptor / Rele / Switc H/Sensor (Rear)
Interruptor / Switch (Oper Ation)
Interruptor Principal / Ma In Switch/Lever Control Switch
Interruptor / Rele / Relay
Unidade Control Electrico (Bloco Motor) / Electronic Control Unit (Engine)
Unidade Control Electrico (Corpo) / Electronic Control Unit (Body)
Painel / Panel Board
Conta Rotaçoes Tdf / Veloc Imetro / Pto Tachometer/Speedmeter
Painel Control / Control P Anel
Painel Control[Peças Compo Nentes] / Control Panel [Component Parts]
Luzes Frente / Head Light [Ec] [Old]
Luzes Frente / Head Light [Ec] [New]
Farol Frente[Peças Compone Ntes] / Head Light [Component Parts] [Ec]
Luzes Frontais / Front Com Bination Light
Luzes Trabalho / Work Ligh T (Front) [Ec]
Farois Trabalho (Traseiros ) / Work Light (Rear)
Braco Traseiro / Rear Comb Ination Light
Ficha Reboque / Trailer So Cket
Luz Interior / Room Light
Radio Cd E Columnas / Cd-R Adio And Speaker
Depósito De Lavagem / Wash Er Tank
Escova / Wiper [Old]
Escova / Wiper [New]
Cablagem Electrica (Crs) / Electrical Wiring (Crs)
Cablagem Electrica (Motor) / Electrical Wiring (Engine)
Cablagem Eletrica (Luzes F Rente) / Electrical Wiring (Head Light) [Old]
Cablagem Electrica (Luzes Frente) / Electrical Wiring (Head Light) [New]
Cablagem Eletrcia (Princip Al/Motor) / Electrical Wiring (Panel) [Old]
Cablagem Eletrcia (Princip Al/Motor) / Electrical Wiring (Panel) [New]
Cablagem Electrica / Elect Rical Wiring (Rear) [Old]
Cablagem Electrica / Elect Rical Wiring (Rear) [New]
Cablagem Eletrcia (Frente) / Electrical Wiring (3p Switch)
Cablagem Electrica (Painel Contrl) / Electrical Wiring (Control Panel)
Cablagem Electrica (Braco) / Electrical Wiring (Armrest)
Cablagem Electrica / Elect Rical Wiring (Body)
Cabalagem Eletrica(Cabine) [Ec] [G] / Electrical Wiring (Cab) [Ec]
Valvula Powershift / Power Shift Valve
Valvula Powershift[ Peças Componentes] / Power Shift Valve (Body) [Comp Onent Parts]
Valvula Powershift[ Peças Componentes] / Power Shift Valve (Upper) [Com Ponent Parts]
Carter Embraiagem / Clutch Housing Cover Lower
Caixa Intermedia / Mid Case [Old]
Caixa Intermedia / Mid Case [New]
Caixa Velocidades / Transmission Case [Old]
Caixa Velocidades / Transmission Case [New]
Carter Transmissao / Transmission Case Rear Cover
Carter Eixo Traseir O Drt (Tipo Arco) / Rear Axle Case Rh
Carter Eixo Traseir O Esq (Tipo Arco) / Rear Axle Case Lh
Disco Amortecedor / Damper Disk
Bloqueio Diferencia L / Clutch Pedal
Embraiagem / Clutch Rod
Suporte Carreto / G Ear Support
Veio Primario / Inp Ut Shaft
Veio Inversor / Shu Ttle Shaft
Primeira/Segunda Mu Dança / First/Second Shift Gear
Primeiro Veio / Fir St Shaft
Carreto Terceira/Qu Arta / Third/Fourth Shift Gear
Veio Secundario / C Ountershaft
Carreto Principal / Main Gear Shift Shaft And Range Gear Shaft [Old] # # N.º De Série<=76480 S.No.;<=76480 / S.No.<=76480 S.No.;<=76480
Carreto Principal / Main Gear Shift Shaft And Range Gear Shaft [New] # # N.º De Série>=76481 S.No.;>=76481 / S.No.>=76481 S.No.;>=76481
Veio Gamas Velocida Des Inversor / Range Gear Shaft (Front)
Veio Gamas Velocida Des / Range Gear Shaft (Rear)
Veio (Frente) / Dri Ve Shaft (Front)
Veio (Meio/Traseiro ) / Drive Shaft (Middle/Rear)
Sistema Hi-Lo / Hi- Lo Shift Case
Grupo Conico / Beve L Gear
Diferencial Carter / Rear Differential
Embraiagem Bloqueio Diferencial Traseiro / Rear Differential Lock Clut Ch
Veio Tdf / Pto Prop Eller Shaft
Embraiagem Tdf / Pt O Clutch
Embraiagem Tdf[Peça S Componentes] / Pto Clutch [Component Parts] [Old]
Embraiagem Tdf[Peça S Componentes] / Pto Clutch [Component Parts] [New]
Valvula Embraiagem Tdf / Pto Clutch Valve
Valvula Embraiagem Tdf[Peças Componentes] / Pto Clutch Valve [Componen T Parts]
Tdf / Veio Tdf / Pt O Drive Shaft
Veio Tdf / Pto Shaf T
Embraiagem Hidrauli Ca (Bi Speed) / Hydraulic Clutch (Bi-Speed Turn)
Veio Bi-Speed / Bi- Speed Turn Shaft
Forquet A Caixa / Creeper / Range Gear Shift Fork
Alvanca Tdf / Pto Shift Fork
Alavanc A Velocidades / Main Gear Shift Lever
Cabo Em Braiagem / Range Gear Shift Cable
Alavanc A Tdf / Pto Gear Shift Lever
Pedal Bloqueio Diferenci Al Traseiro / Rear Differential Lock Pedal
Eixo Traseiro / Rear Axl E Shaft
Travão / Brake
Alavanca Travao Mao / Pa Rking Brake Lever
Travão De Estacionamento / Parking Brake
Pedal Travao / Brake Ped Al
Cilindro Travao Principa L / Brake Master Cylinder
Cilindro Travao Principa L[Peças Componentes] / Brake Master Cylinder [Compo Nent Parts]
Tubo Travao / Brake Pipe
Tubo Travao / Brake Mast Er Cylinder Pipe
Suporte Eixo Dianteir O / Front Axle Bracket
Veio Primario / Prope Ller Shaft
Caixa Diferencial Dia Nteiro / Front Differential Case
Engrenagem Cónica (Di Anteira) / Bevel Gear (Front)
Diferencial Dianteiro / Differential Front
Bloqueio Diferencial Frente / Front Differential Lock Clutch
Caixas Engrenagens Co Nica(Drt) / Bevel Gear Case Rh
Caixas Engrenagens Co Nica(Esq) / Bevel Gear Case Lh
Carter Eixo / Front A Xle Case
Eixo Dianteiro / Fron T Axle
Grupo Conico / Differ Ential Gear Shaft
Tampa Coluna Direccao / Steering Post Cover
Alavanca / Tilt Lever
Placa Telescopio / Telescope Lever
Distribuidor Direcção[Peças Componentes] / S Teering Controller [Component Parts]
Direcção Assistida / Tie Rod/Steering Cylind Er
Cilindro Direcção[Peças Componentes] / Steer Ing Cylinder [Component Parts]
Bomba Hidraulico / Hydraul Ic Pump
Bomba Hidraulico[Peças Com Ponentes] / Hydraulic Pump [Component Parts]
Válvula Do Regulador / Reg Ulater Valve
Valvula Reguladora[Peças C Omponentes] / Regulater Valve [Component Parts]
Linha Aspiração / Hydrauli C Pipe (Suction)
Linha De Óleo Hidráulico ( Fornecimento) / Hydraulic Oil Line (Delivery)
Tubo Hidraulico / Hydrauli C Oil Line
Valvula Travao Reboque / T Railer Brake Valve
Valvula Segurança / Safety Valve
Circuito Oleo Hidraulico(B I Speed) / Hydraulic Oil Line (Rear Diff.)
Circuito Oleo Hidraulico(D Iferencial Frente) / Hydraulic Oil Line (Front Diff Erential)
Radiador Oleo / Oil Cooler
Circuito Oleo Radiador / H Ydraulic Oil Line (Oil Cooler)
Circuito Oleo Direcção / H Ydraulic Oil Line (Steering/Pto)
Tubo Direccao / Steering H Ose (Delivery)
Caixa Valvula Hidraulico / Hydraulic Valve Case
Valvula Base / Valve
Base Valvula / Valve Base
Braço De Elevação Hidráuli Co / Hydraulic Lift Arm
Valvula Descarga / Relief Valve/Check Valve
Trinco / Lowering Lock Lev Er
Barra Deflectora (Suporte ) / Detector Bar (Bar/Bar Support)
Barra Deflectora / Detecto R Bar (Draft Link)
Alavanca Control Posicao / Position Control Lever
Valvula Contol Automatico / Auto Control Valve
Valvula Control Automatico [Peças Componentes] / Auto Control Valve [Component Parts]
Distribuidor Auxiliar / Au Xiliary Control Valve
Valvula Auxiliar [Peças Co Mponentes] / Auxiliary Control Valve (Scd) [Compone Nt Parts]
Distribuidor Auxiliar[Peça S Componentes] / Auxiliary Control Valve (Fd) [Comp Onent Parts]
Alavanca Valvula Auxiliar 1 Pos / Auxiliary Control Valve Lever
Cilindro Auxiliar De Eleva Cao(Esq) / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De Eleva Cao(Drt) / 3p-Lift Assist Cylinder Rh
Cilindro Auxiliar De Eleva Cao[Peças Componentes] / 3p-Lift Assist Cylinder [C Omponent Parts] [Old]
Cilindro Auxiliar De Eleva Cao[Peças Componentes] / 3p-Lift Assist Cylinder [C Omponent Parts] [New]
Parte Superior / Top Link Bracket
Ligac Ao Superior / Top Link
Ligac Ao Inferior / Lower Link
Estab Ilizador / Stabilizer
Estab Ilizador(Drt) / Lift Rod Rh
Estab Ilizador(Esq) / Lift Rod Lh
Prote Ccao Tdf / Pto Protector
Grelha Frontal / Front Grille [Old]
Grelha Frontal / Front Grille [New]
Capot Superior / Hood (Bonnet) [Old]
Capot Superior / Hood (Bonnet) [New]
Capot Superior (Som Absorvedor/Isolador) / H Ood (Bonnet) (Sound Absorber/Insulator) [Old]
Capot Superior (Som Absorvedor/Isolador) / H Ood (Bonnet) (Sound Absorber/Insulator) [New]
Amortecedor Capot / Hood(Bonnet) Damper
Trico Capot / Bonnet Lock [New]
Estrutura Capot / Bonnet Frame [Old]
Estrutura Capot / Bonnet Frame [New]
Capot Inferior (Direito) / Hood (Bonnet) Sid E Lower Rh [Old]
Capot Inferior (Direito) / Hood (Bonnet) Sid E Lower Rh [New]
Capot Inferior (Esquerdo) / Hood (Bonnet) Si De Lower Lh [Old]
Capot Inferior (Esquerdo) / Hood (Bonnet) Si De Lower Lh [New]
Estrutura Cabine / Cab Frame
Vidro Frente E Traseiro / Front Glass
Porta(Drt) / Door Rh
Porta(Esq) / Door Lh
Trinco Porta(Drt) / Door Lock Rh
Trinco Porta(Esq) / Door Lock Lh
Vidro Traseiro / Rear Window (Upper)
Tejadilho / Sun Roof
Espelho Retrovisor(Antiga) / Rearview Mirror [Ec] [ Old]
Espelho Retrovisor(Novo) / Rearview Mirror [Ec] [Ne W]
Tecto Interior / Inner Roof [Old]
Tecto Interior / Inner Roof [New]
Tecto Abrir / Outer Roof
Acessorios / Seat
Banco [Peças Componentes] / Seat[Component Parts] [ Old]
Banco [Peças Componentes] / Seat[Component Parts] [ New]
Apoio Braço / Armrest
Piso / Floor Mat
Isolante / Soundproof Material
Chapa Inspecção(Frente) / Inspection Plate (Front)
Chapa Inspecção(Traseira) / Inspection Plate (Rear)
Tampa / Shift Cover
Cobertura Gurada Lamas(Esq) / Fender Cover Lh
Guarda Lamas(Drt) / Fender Rh
Dianteira Do Suporte Da Cabine / Cab Bracket Front
Suporte Cabine Traseiro / Cab Bracket Rear
Caixa Ferramenta / Tool Box
Air Condicionado / Air Condit Ioner
Cuberto Tubo Air Condicionado / Air Conditioner Duct Cover
Tubo Ar Condicionado / Air Co Nditioner Duct (Front)
Tubo Ar Condicionado / Air Co Nditioner Duct (Rear)
Modo Caixa / Mode Case
Entradas Ar Painel Instrument Os / Dashboard Air Outlets
Circulaçao Ar Interior / Inne R Air Recirculation
Tubo Aquecimento / Heater Hos E
Condesador / Condenser [Old]
Condesador / Condenser [New]
Tubo Ar Condicionado/Tubo Con Densador / Air Conditioner Hose/Condenser Hose
Compressor / Compressor [Old]
Compressor / Compressor [New]
Suporte Compressor / Compress Or Bracket [Old]
Suporte Compressor / Compress Or Bracket [New]
Etiqueta (Dianteira) / Label (Front)
Etiqueta 2 / Label (Rear/Cab)
Acessorios / Accessories
Kit Farios Trabalho (Opçao) / Working Light Kit [ Option]
Kit Farios Trabalho (Trseiros) (Opcao) / Working Light (Rear) Kit [Option]
Desempanador (Opcao) / Rear Defogger Kit [Option]
Escova Limpa Vidro Frontal [Opção] / Front Wiper Kit [Option]
Kit Fusivel [Opção] / Fuse Kit [Option]
Kit Cobertuta Deposito Gasoleo / Fuel Tank Cover Kit [Option]
Kit Caixa Crepper(Opção) / Creep Speed Kit (Gear Case) [Option]
Forqueta Caixa / Creeper / Creep Speed Kit (Shift Fork) [Option]
Alavanca Caixa Creper / Creep Speed Kit (Lever) [ Option]
Kit Conversao Tdf 540/540e (Engrenagem) (Opção) / Pto (540/540e) Conversion Kit (Gear) [Option]
Kit Conversao Tdf 540/1000 (Engrenagem Box)(Opção ) / Pto(540/1000) Conversion Kit (Gear Case) [Optio N]
Kit Conversao Tdf 540/1000 (Engrenagem) (Opção) / Pto(540/1000) Conversion Kit (Gear) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary C Ontrol Valve Kit (Scd) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary C Ontrol Valve Kit (Fd) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary C Ontrol Valve Kit (Fc) [Option]
Kit Distribuidor Serviços Externos[Peças Componen Tes][Opcao] / Auxiliary Control Valve (Scd/Fc) [Com Ponent Parts] [Option]
Kit Alavanca Serviços Externos[Opcao] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Kit Alavanca Serviços Externos[Opcao] / Auxiliary Control Valve Lever Kit (4th) [Option]
Kit Alavanca Serviços Externos[Opcao] / Auxiliary Control Valve (With Fc) Mounting Kit (1st) [Option ]
Kit Alavanca Serviços Externos[Opcao] / Auxiliary Control Valve (With Fc) Mounting Kit (2nd) [Option ]
Kit Serviços Externos (Fd/Fc) / Auxiliary Control Valve Kit (Scd With Fc) [Option]
Kit Serviços Externos (Fd/Fc) / Auxiliary Control Valve Kit (Fd With Fc) [Option]
Kit Serviços Externos (Fd/Fc)[Peças Componentes][ Opcao] / Auxiliary Control Valve (With Fc) (Mountin G) [Component Parts] [Option]
Kit Serviços Externos (Fd/Fc)[Peças Componentes][ Opcao] / Auxiliary Control Valve (Scd With Fc) [Com Ponent Parts] [Option]
Kit Serviços Externos (Fd/Fc)[Peças Componentes][ Opcao] / Auxiliary Control Valve (Fd With Fc) [Comp Onent Parts] [Option]
Kit Alavanca Serviços Externos[Opcao] / Auxiliary Control Valve Lever Kit (With Fc) (4th) [Option]
Kit De Tampas Do Acoplador Da Válvula De Controlo Auxiliar [Opção] / Auxiliary Control Valve Coupler Cap Kit [Option]
Banco Passageiro[Opcao] / Instructional Seat Kit [Option]
Capot (Capa Superior) [Opção] / Bonnet Kit (Hood( Bonnet)) [Option]
Capot (Prato) [Opção] / Bonnet Kit (Shutter Plate ) [Option]
Capot (Cablagem Electrica) [Opção] / Bonnet Kit ( Electrical Wiring) [Option] [Old]
Capot (Cablagem Electrica) [Opção] / Bonnet Kit ( Electrical Wiring) [Option] [New]
Capot (Grelha Frontal) [Opção] / Bonnet Kit (Fron T Grille) [Option]
Capot (Absorvente Sao/Isolador) [Opção] / Bonnet Kit (Sound Absorber/Insulator) [Option] [Old]
Capot (Absorvente Sao/Isolador) [Opção] / Bonnet Kit (Sound Absorber/Insulator) [Option] [New]
Capot (Trico Capot) [Opção] / Bonnet Kit (Bonnet Lock) [Option]
Capot (Estrutura Capot) [Opção] / Bonnet Kit (Bon Net Frame) [Option]
Protetor De Para-Sol [Opção] / Sunshade Shield Ki T [Option]
