118
7,392
Kubota Tractor M108SDTC Spare Parts Catalog EN TR
Language: English, Turkish
Region: Turkey
Model: Kubota M108SDTC Tractor
Number of Pages: 810 Pages
Engine 300000 Crankcase
Engine 301000 Oil Pan
Engine 302000 Cylinder Head
Engine 303000 Inlet Valve And Exhaust Valve
Engine 304000 Rocker Arm Shaft
Engine 305000 Head Cover
Engine 308000 Transmission Box Gear Case
Engine 311000 Piston And Crankshaft
Engine 312000 Camshaft And Idle Gear
Engine 313000 Balancer
Engine 315000 Flywheel
Engine 320500 Feeding Pump Supply Pump
Engine 331000 Fuel Filter
Engine 345000 Injection Pipe
Engine 348000 Common Rail
Engine 360000 Thermostat Water Flange And Thermostat
Engine 361000 Water Pump
Engine 371000 Inlet Manifold
Engine 371500 EGR Flange Valve EGR Valve Flange
Engine 372001 Exhaust Manifold Old Chassis No. Bmz999 S.No. Bmz999
Engine 372002 Exhaust Manifold New Exhaust Manifold New Chassis No. Bn0001 S.No. Bn0001
Engine 372200 EGR Valve EGR Cooler EGR Valve And EGR Cooler
Engine 372600 Turbocharge Turbo Charger
Engine 373000 Air Cleaner
Engine 373500 Air Cleaner Component Parts
Engine 375000 Muffler
Engine 380000 Oil Pipe (Turbo Charger)
Engine 381000 Inter Cooler Inter Cooler
Engine 382000 Oil Cooler
Engine 391000 Gasket Kit (Upper)
Engine 392000 Contagasket Kit (Bottom) Lower Gasket Kit
Engine 395000 Engine Electrical Parts Engine Electrical Parts
Engine 395200 Injector Harness
Engine 399000 Diagmaster
Engine A01000 Hand Accelerator Lever
Engine A03000 Accelerator Pedal
Fuel System A12000 Fuel Tank (Right Side) Fuel Tank Rh
Fuel System A13000 Fuel Tank (Left Side) Fuel Tank Lh
Systems Fuel System A14101 Fuel Pipe 1 (Front) Old Fuel Pipe 1 (Front) Old Chassis No. 70720 S.No.
System Fuel System A14102 Fuel Pipe 1 (Front) New Fuel Pipe 1 (Front) New Chassis No. 70721 S.No.
System Fuel System A14201 Fuel Pipe 2 (Rear) Old Fuel Pipe 2 (Rear) Old Chassis No. 70720 S.No.
System Fuel System A14202 Fuel Pipe 2 (Rear) New Fuel Pipe 2 (Rear) New Chassis No. 70721 S.No.
Fuel System A14400 Fuel Pipe 3 (Fuel Cooler) Fuel Pipe 3 (Fuel
Fuel System A14500 Fuel Cooler
Fuel System A15101 Separator Old Separator Old Chassis No. 70720 S.No. 70720 S.
Fuel System A15102 Separator New Separator New Chassis No. 70721 S.No. 70721
Fuel System A16101 Separator Component Parts Old Separator Component Parts Old Chassis No.
A16102 Separator Component Parts Old Separator Component Parts Old Chassis No.51504 To 70720
Fuel System A16103 Separator Component Parts New Chassis No.
Cooling Water System A41000 Fan
Water Pipe Old Chassis No. 76188 S.
Water Pipe Cooling Water System A42002 Water Pipe New Chassis No. 76189 S.
Cooling Water System A43000 Radiator
Cooling Water System A45000 Reserve Tank
Electrical System A54000 Alternator
Electrical System A55000 Alternator Component Parts
Electrical System A56000 Starter
Electrical System A57000 Starter Component Parts
Electrical System A58000 Battery
Electrical System B00100 Switch Sensor (Motor)
Electrical System B01500 Switch Sensor Switch Sensor
Electrical System B02002 Switch Sensor (Fuel Center) Fr G Sp Pog Tur Switch Sensor
Electrical System B11000 Switch Cab Inner Switch
Electrical System B12000 Main Switch
Electrical System B13000 Relay
Electrical System B14000 Dashboard Panel Board
Electrical System B32002 Outdoor Lighting Fr G Sp Pog Tur Head Light Fr
Electrical System B32102 Exterior Lighting Component Parts Fr G Sp Pog Tur Head Light
System B33900 Front Combined Headlight Front Combination Light Not 010,020 And 080,090 New
Electrical System B35002 Working Lighting Pillow Fr G Sp Pog Tur Working Light
System B36000 Rear Combination Headlight Light Not 010,020 And 080,090 New
Electrical System B37000 Trailer Socket
Electrical System B41000 Interior Lighting Room Light
Electrical System B42500 Radio Speaker Fr G Sp Pog Tur Radio Speaker
Electrical System B43000 Washer Tank Washer Tank
Electrical System B44000 Wiper Wiper
B50101 Electrical Cables (Crs) Old Electrical Wiring (Crs) Old Chassis No. 70700 Note Order Fig. No.
New Electrical Wiring (Crs) New Chassis No. 70701 Note 010 New Part And Fig. No. A58000 Ref.
Electrical System B50500 Electrical Cables (Motor) Electrical Wiring
Electrical System B51000 Electrical Cables (Main) Electrical Wiring
Electrical System B51502 Electrical Cables (Body) Fr G Sp Pog Tur Electrical
Electrical System B52002 Electrical Cables (Cabin) Fr G Sp Pog Tur Electrical
Clutch Gear Clutch Transmission C11000 Clutch Housing
Clutch Gear Clutch Transmission C11100 Shuttle Valve Shuttle Valve
Clutch Gear Clutch Transmission C11200 Shuttle Valve Component Parts Shuttle Valve
Clutch Gear Clutch Transmission C11600 Clutch Housing Cover (Upper) Clutch Housing
Clutch Gear Clutch Transmission C12000 Clutch Housing Cover (Lower) Clutch Housing
Clutch Gear Clutch Transmission C13000 Mid Case Mid Case
Clutch Gear Clutch Transmission C14000 Transmission Case
Gear Clutch Transmission C15002 Gear Housing Rear Cover Fr G Sp Pog Tur Transmission Case
Clutch Gear Clutch Transmission C17000 Rear Axle Case
Clutch Gear Clutch Transmission C22000 Damper Disk
Clutch Gear Clutch Transmission C24000 Clutch Pedal
Clutch Gear Clutch Transmission C26000 Clutch Cable Clutch Cable
Clutch Transmission C26501 Valve Lever (Clutch Shuttle) Old Chassis
Clutch Transmission C26502 New Valve Lever (Clutch Shuttle) New Chassis
Clutch Gear Clutch Transmission D11000 Front Cover
Clutch Gear Clutch Transmission D12000 Support Gear
Clutch Gear Clutch Transmission D21500 Input Shaft
Clutch Gear Clutch Transmission D21700 Shuttle Transmission Shuttle Shaft
Clutch Gear Clutch Transmission D22000 First Second Gear Transmission
Clutch Gear Clutch Transmission D22500 First Shaft
Clutch Gear Clutch Transmission D23000 Third Fourth Gear Transmission Third Fourth
Clutch Gear Clutch Transmission D24000 Counter Shaft Countershaft
Gear Clutch Transmission D24500 Main Transmission Shift And Range Shaft Transmission Main Gear
Clutch Gear Clutch Transmission D24800 Range Shaft Transmission Range Gear
Clutch Gear Clutch Transmission D24900 Two Speed Clutch Dual Speed Clutch
Clutch Gear Clutch Transmission D25400 Shaft Drive (Front) Drive Shaft (Front)
Clutch Gear Clutch Transmission D25500 Shaft Drive (Center Rear) Drive Shaft (
Clutch Gear Clutch Transmission D25700 High-Low Gear Housing Hi-Lo Shift
Clutch Gear Clutch Transmission D26000 Bevel Gear
Clutch Gear Clutch Transmission D26200 Rear Differential Differential
Clutch Gear Clutch Transmission D26500 PTO Propeller Shaft
D26600 PTO Clutch Note 010 And Fig.No.D27001, D27002 Ref.No.080
Old PTO Clutch Component Parts Old Chassis No. 70681 Note Order Fig.No.D26600-010 And Fig.No.D27001,
Old PTO Clutch Component Parts Old Chassis No.70682 To 77519 Note Order Fig.No.D26703 1 Ref.No.010, 2
Transmission D26703 PTO Clutch Component Parts New PTO Clutch Component Parts New
Clutch Gear Clutch Transmission D26800 PTO Clutch Valve PTO Clutch Valve
Clutch Gear Clutch Transmission D26900 PTO Clutch Valve Component Parts
Clutch Gear Clutch Transmission D27002 PTO Drive Shaft Fr G Sp Pog Tur PTO Drive Shaft
Clutch Gear Clutch Transmission D27502 PTO Shaft Fr G Sp Pog Tur PTO Shaft Fr G
Clutch Gear Clutch Transmission D36000 Clutch Hydraulic (Front Drive) Hydraulic Clutch (
Speed Change Shift Fork D41000 Main Transmission
Speed Change Shift Fork D43000 Gear Range
Speed Change Shift Fork D47000 Differential Lock Transmission
Speed Change Shift Fork F11000 Main Gear
Speed Change Shift Fork F11500 Main Transmission
Speed Change Shift Fork F12000 Main Transmission
Speed Change Shift Fork F12500 Transmission Shuttle
Gear Speed Change Shift Fork F13300 Shuttle
Speed Change Shift Fork F13500 Gear Range
Gear Speed Change Shift Fork F14500 PTO Clutch
Fork Shift Lever Speed Change Shift Fork F15000 PTO Transmission Lever Fr G Sp
Rear Axle Brake F17000 Front Differential Lock Pedal Front Differential
Rear Axle Brake F18000 Rear Differential Lock Pedal Rear Differential
Rear Axle Brake F20000 Rear Axle
Rear Axle Brake F20500 Brake
Rear Axle Brake F22000 Parking Brake Lever
Rear Axle Brake F23000 Parking Brake
Rear Axle Brake F23500 Brake Pedal
Rear Axle Brake F31000 Brake Oil Tank Brake Oil Tank
Rear Axle Brake F32000 Brake Master Cylinder Component Parts Brake Master Cylinder
Rear Axle Brake F33000 Brake Pipe Brake Pipe
Front Axle Chassis G10500 Front Axle Frame
Front Axle Chassis G11000 Front Axle Housing Bracket Front Axle
Front Axle Chassis G14000 Propeller Shaft Front Propeller
Front Axle Chassis G15000 Front Differential Housing Front Differential
Front Axle Chassis G16000 Bevel Gear (Front) Bevel Gear (
Front Axle Chassis G17000 Front Differential Differential Front
Front Axle Chassis G21500 Front Differential Lock Clutch Front Differential
Bevel Gear Case Note 090,150,180,190 New Part And Fig.No.G22500 Ref.No.010,030 New
Front Axle Chassis G22500 Front Axle Case
Front Axle Chassis G22700 Front Axle
Front Axle Chassis G23000 Differential Transmission Shaft Differential
Steering H11000 Steering Handle
Steering H12000 Slip Pedal Tilt Pedal
Steering H13000 Steering Joint
Steering H14000 Steering Control Steering Controller
H15001 Steering Control Component Parts Old Steering Controller Component Parts Old
H15002 Steering Control Component Parts New Steering Controller Component Parts New
Steering H16000 Rubber Rod Steering Cylinder Tie Rod Steering
H16501 Steering Cylinder Component Parts Old Steering Cylinder Component Parts Old Chassis
Parts Old Steering Cylinder Component Parts Old Chassis No.70001 To 72342 Note Order Fig.No.H16503
H16503 Steering Cylinder Component Parts New Chassis
Hydraulic System J13000 Hydraulic Pump
Hydraulic System J13501 Hydraulic Pump
Hydraulic System J13502 Hydraulic Pump
Hydraulic System J16000 Regulator Valve Regulater Valve
Hydraulic System J16500 Regulator Valve Component Parts Regulater Valve
Hydraulic System J21000 Hydraulic Pipe
Hydraulic System J22001 Hydraulic Oil Line (Feed) Old Hydraulic Pipe (Delivery) Old Chassis No.
Hydraulic System J22002 Hydraulic Oil Line (Feed) New Hydraulic Pipe (Delivery) New Chassis No.
Hydraulic System J22300 Hydraulic Pipe (Trailer Brake) Old Chassis
Hydraulic System J23500 Hydraulic Pipe
Hydraulic System J23701 Trailer Brake Valve Old Chassis No. 70212
Hydraulic System J23702 Trailer Brake Valve New Chassis No. 70213
Hydraulic System J26500 Pipe Oil Cooler
Hydraulic System J27300 Hydraulic Oil (Double Speed Valve) Hydraulic Oil Line (
Hydraulic System J27500 Hydraulic Pipe (Steering,PTO) Hydraulic Oil Line
Hydraulic System J28000 Steering Hose (Delivery) Steering Hose
Hydraulic System J30800 Hydraulic Cylinder Housing Hydraulic
Hydraulic System J31500 Lifting Arm Hydraulic Lift Arm
Hydraulic System J32000 Cover Hydraulic Cylinder
Hydraulic System J35500 Control Valve
Hydraulic System J35600 Control Valve Component Parts Control Valve
Hydraulic System J37800 Position (3-Point Remote) Control Lever Position (3p)
Hydraulic System J38000 Traction And Position Control Arm Draft And Position
Hydraulic System J38100 Traction And Position Control Arm Bracket Draft And Position
Hydraulic System J38200 Position And Draft
Hydraulic System J38400 Position ECcentric Position Glass
Hydraulic System J38600 Traction ECcentric Draft Cam
Hydraulic System J44501 Remote Control Valve (S D) (FD) Old Remote Control Valve (S D) (FD) Old Chassis
Hydraulic System J44502 Remote Control Valve (S D) (FD) New Remote Control Valve (S D) (FD) New Chassis
J44700 Remote Control Valve (S D) Component Parts Old Auxiliary Control Valve (S D) Component
J44801 Support Control Valve (FD) Component Parts Old Auxiliary Control Valve (FD) Component
J44802 Support Control Valve (FD) Component Parts Old Auxiliary Control Valve (FD) Component
J44803 Auxiliary Control Valve (FD) Component
Hydraulic System J45500 Support Control Valve Lever Auxiliary Control
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K10500 Top Link Bracket
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K11000 Top Link
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K12500 Bottom Link
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K13302 Stabilizer Fr G Sp Pog Tur
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K14000 Right Draw Shaft
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K14300 Left Draw Shaft
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L10500 Drawing Bar Bracket
Drawing Bar Connection 3-Point Linkage Drawbar Hitch L17002 PTO Protective Fr G Sp Pog Tur PTO
Hood Bonnet M11000 Front Grille
Bonnet Bone Hood Bonnet M12000 Bone (Bonnet) Hood(Bonnet) Upper
Bonnet Bone Hood Bonnet M12700 Bone Side Cover Hood(Bonnet) Side Cover
Bonnet Bone Hood Bonnet M14000 Bone Support Bonnet Support
Bonnet Bone Hood Bonnet M14600 Correction Panel Rectification Panel
Cab N11000 Cab Frame Cab Frame
Cab N11700 Cover (Bonnet) Rear Hood(Bonnet) Rear
Cab N12000 Front Glass Front Glass
Cab N12500 Door (Right Side) Door Rh
Cab N13000 Door (Left Side) Door Lh
Cab N13500 Door Lock (Right Side) Door Lock Rh
Cab N14000 Door Lock (Left Side) Door Lock Lh
Cab N14600 Side Window (Right Side) Side Window Rh
Cab N14700 Side Window (Left Side) Side Window Lh
Cab N15000 Rear Window (Upper) Rear Window (Upper)
Cab N15500 Rear Window (Lower) Rear Window (Lower)
Cab N15800 Rearview Mirror
Cab N16000 Inner Ceiling Inner Roof
Cab N16500 Outer Roof
Cab N17002 Seat Fr G Sp Pog Tur A Type Seat Fr G Sp Pog Tur
Cab N17003 Seat Fr G Sp Pog Tur B Type Seat Fr G Sp Pog Tur
Cab N17500 Floor Mat
Cab N18000 Inspection Plate
Cab N21000 Fender Cover (Right Side) Fender Cover Rh
Cab N21500 Fender Cover (Left Side) Fender Cover Lh
Cab N22000 Pillar Cover
Cab N22500 Fender (Right Side) Fender Rh
Cabin Cab N23000 Fender (Left Side) Fender Lh
Cab N24000 Cab Bracket Front
Cab N24502 Cab Bracket Rear Fr G Sp Pog Tur Cab Bracket Rear Fr G Sp
Cab N25000 Tool Box
Air Conditioner P11500 Air Conditioner
Air Conditioner P13500 Air Conditioner Hose Drain Hose (Air Conditioner)
Air Conditioner P15000 Heater Hose
Air Conditioner P15500 Condenser
P15701 Air Conditioner Hose Condenser Hose Old Air Conditioner Hose Became Condenser Hose
P15702 Air Conditioner Hose Condenser Hose New
Air Conditioner P16000 Compressor
Air Conditioner P16500 Compressor Bracket Compressor Bracket
Labels S12005 Label 1 (Front) Sp Tur Label 1 (Front) Sp Tur
Labels S12006 Label 1 (Front) Pog Label 1 (Front) Pog
Labels S13005 Label 2 (Rear) Sp Tur Label 2 (Rear) Sp Tur
Labels S13006 Label 2 (Rear) Pog Label 2 (Rear) Pog
Parts T11002 Accessories And Service Parts Fr G Sp Pog Tur Accessories And Service Parts Fr G Sp
Separator Kit Option Separator Kit Option Chassis No. 70720 Note See Fig.No.A16103 For Components.
Option U10800 ECu Cover Kit Option ECu Cover Kit Option
Option U19000 Rear Wiper Kit Option Rear Wiper Kit Option
Option U25000 Cover Tank Fuel Kit Option Fuel Tank Cover Kit Option
Option U32100 Low Speed Kit 1 (Gearbox) Option Creep Speed Kit 1 (Gear
Option U32200 Low Speed Kit 2 (Gear Fork Lever) Option Creep Speed Kit 2 (Shift
Option U55200 80 Gear Kit Option 80 Inch Tread Kit Option
U70001 Support Control Valve Kit (SCD) Option Old Auxiliary Control Valve Kit (SCD) Option Old Chassis
U70002 Support Control Valve Kit (SCD) Option New Auxiliary Control Valve Kit (SCD) Option New Chassis
U70003 Support Control Valve Kit (FD) Option Old Auxiliary Control Valve Kit (FD) Option Old Chassis
U70004 Support Control Valve Kit (FD) Option New Auxiliary Control Valve Kit (FD) Option New Chassis
Option U70005 Support Control Valve Kit (SCD FC) Option Auxiliary Control Valve
Option U70006 Support Control Valve Kit (FC) Option Auxiliary Control Valve Kit
Control Valve (SCD) Component Parts Option Old Auxiliary Control Valve (SCD) Component Parts
Control Valve (FD) Component Parts Option New Auxiliary Control Valve (SCD) Component Parts
Control Valve (SCD FC) Component Parts Option Old Auxiliary Control Valve (SCD FC) Component Parts
Control Valve (SCD FC) Component Parts Option New Auxiliary Control Valve (SCD FC) Component Parts
Option U70505 Assist Control Valve Kit (FC) Component Parts Option Auxiliary Control Valve
Option U71000 Assist Control Valve Lever Kit (Third) Option Auxiliary Control Valve
Option U85100 Starting Assist Cylinder Kit (Right Side) Fr G Sp Pog Tur Option Assist Cylinder
Option U85200 Starting Assist Cylinder Kit (Left Side) Fr G Sp Pog Tur Option Assist Cylinder
U85500 Starting Assist Cylinder Component Parts Fr G Sp Pog Tur Option Assist Cylinder
