Kubota Tractor M108SDTC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M108SDTC Tractor
Number of Pages: 434 Pages
Bloco Motor / Crankcase
Cabeca Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhaus T Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Carreto / Gear Case
Compensador / Balancer
Volante Motor / Flywheel
Filtro Gasoleo / Fuel Filter
Common Rail / Common Rail
Bomba Agua E Termostacto / Water Flange And Thermo Stat
Acessorios / Water Pump
Flange Valvula Egr / Egr Valve Flange
Colector Escape / Exhaust Manifold [Old]
Colector Escape / Exhaust Manifold [New]
Valvula Egr/Egr Refrigerador / Egr Valve And Egr C Ooler
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [Compo Nent Parts]
Escpae / Muffler
Tubo Oleo (Turbo) / Oil Pipe (Turbo Charger)
Intercooler / Inter Cooler
Radiador Oleo / Oil Cooler
Kit De Junta (Superior) / Upper Gasket Kit
Kit De Junta (Inferior) / Lower Gasket Kit
Componentes Electricos Motor / Engine Electrical P Arts
Diagmaster / Diagmaster
Deposito Combustivel (Drt) / Fuel Tank Rh
Deposito Combustivel (Esq) / Fuel Tank Lh
Tubo Combustivel / Fuel Pipe 1 (Front) [Old]
Tubo Combustivel / Fuel Pipe 1 (Front) [New]
Tubo Combustivel / Fuel Pipe 2 (Rear) [Old]
Tubo Combustivel / Fuel Pipe 2 (Rear) [New]
Tubo Combustivel / Fuel Pipe 3 (Fuel Cooler)
Arrefecedor Gasoleo / Fuel C Ooler
Separador / Separator [Old]
Separador / Separator [New]
Separador[Peças Componentes] / Separator [Component Parts] [Old]
Separador[Peças Componentes] / Separator [Component Parts] [New]
Ventilador / Fan
Tubo Agua / Water Pipe [Old]
Tubo Agua / Water Pipe [New]
Deposito R Eserva / Reserve Tank
Alternador / Alternator
Motor Arranque / Starter
Motor Arranque [Componentes ] / Starter [Component Parts]
Interruptor/Sensor (Bloco M Otor) / Switch/Sensor (Engine)
Interruptor / Sensor (Motor ) / Switch/Sensor
Interruptor/Sensor [Fr] [G] [Sp] [Pog] [Tur] / Switch/Sensor (Fuel/Housing) [F R] [G] [Sp] [Pog] [Tur]
Comutador / Cab Inner Switc H
Interruptor Principal / Mai N Switch/Lever Control Switch
Interruptor / Rele / Relay
Painel / Panel Board
Luzes Frente [Fr] [G] [Sp] [Pog] [Tur] / Head Light [Fr] [G] [Sp] [Pog] [Tur]
Farol Frente[Peças Componen Tes] [Fr] [G] [Sp] [Pog] [Tur] / Head Light [Compon Ent Parts] [Fr] [G] [Sp] [Pog] [Tur]
Luzes Frontais / Front Comb Ination Light
Luzes Trabalho [Fr] [G] [Sp ] [Pog] [Tur] / Working Light/Beacon Light [Fr] [G] [Sp] [Pog] [Tur]
Braco Traseiro / Rear Combi Nation Light
Ficha Reboque / Trailer Soc Ket
Luz Interior / Room Light
Alta Voz Radio [Fr] [G] [Sp ] [Pog] [Tur] / Radio Speaker [Fr] [G] [Sp] [Pog] [ Tur]
Depósito De Lavagem / Washe R Tank
Escova Limpa Vidros / Wiper
Cablagem Electrica (Crs) / Electrical Wiring (Crs) [Old]
Cablagem Electrica (Crs) / Electrical Wiring (Crs) [New]
Cablagem Eletrcia (Frente) / Electrical Wiring (Engine)
Cablagem Electrica / Electr Ical Wiring (Main)
Cablagem Electrica [Fr] [G] [Sp] [Pog] [Tur] / Electrical Wiring (Body) [Fr] [ G] [Sp] [Pog] [Tur]
Cabalagem Eletrica (Cabine) [Fr] [G] [Sp] [Pog] [Tur] / Electrical Wiring (Cab ) [Fr] [G] [Sp] [Pog] [Tur]
Valvula Inversor / S Huttle Valve
Valvula Inversor [Pe Ças Componentes] / Shuttle Valve [Component Parts]
Carter Embraiagem Ca Mbota (Superior) / Clutch Housing Cover (Upper)
Carter Embraiagem / Clutch Housing Cover (Lower)
Caixa Intermedia / M Id Case
Carter Transmissao [ Fr] [G] [Sp] [Pog] [Tur] / Transmission Case Rear C Over [Fr] [G] [Sp] [Pog] [Tur]
Carter Eixo / Rear A Xle Case
Disco Amortecedor / Damper Disk
Bloqueio Diferencial / Clutch Pedal
Cabo Embraiagem / Cl Utch Cable
Valvula (Inversor) / Valve Lever (Clutch/Shuttle) [Old]
Valvula (Inversor) / Valve Lever (Clutch/Shuttle) [New]
Veio Primario / Inpu T Shaft
Veio Inversor / Shut Tle Shaft
Primeira/Segunda Mud Ança / First/Second Shift Gear
Primeiro Veio / Firs T Shaft
Carreto Terceira/Qua Rta / Third/Fourth Shift Gear
Veio Secundario / Co Untershaft
Carreto Principal / Main Gear Shift Shaft And Range Gear Shaft
Veio Gamas Velocidad Es / Range Gear Shaft
Dupla Embraiagem De Velocidades / Dual Speed Clutch
Veio (Frente) / Driv E Shaft (Front)
Veio (Meio/Traseiro) / Drive Shaft (Middle/Rear)
Grupo Conico / Bevel Gear
Diferencial Traseiro / Differential Rear
Veio Tdf / Pto Prope Ller Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf[Peças Componentes] / Pto Clutch [Component Parts] [Old]
Embraiagem Tdf[Peças Componentes] / Pto Clutch [Component Parts] [New]
Valvula Embraiagem T Df / Pto Clutch Valve
Valvula Embraiagem T Df[Peças Componentes] / Pto Clutch Valve [Component Parts]
Veio Principal Tdf [ Fr] [G] [Sp] [Pog] [Tur] / Pto Drive Shaft [Fr] [G] [Sp] [Pog] [Tur]
Veio Tdf [Fr] [G] [S P] [Pog] [Tur] / Pto Shaft [Fr] [G] [Sp] [Pog] [Tur ]
Embraiagem Hidraulic A (Bi Speed) / Hydraulic Clutch (Front Wheel Drive)
Forqueta Caixa / Creeper / Range Gear Shift Fork
Alavanca Velocidades / Main Gear Shift Lever
Tirante / Main Gear Shift Rod
Principa L De Transmissão Eixo Da Alavanca / Main Gear Shift Lever Shaft
Cabo Inv Ersor / Shuttle Cable
Alavanca Velocidades / Range Gear Shift Lever
Alavanca Embraiagem Tdf / Pto Clutch Lever
Alavanca Tdf [Fr] [G] [Sp] [Pog] [Tur] / Pto Gear Shift Lev Er [Fr] [G] [Sp] [Pog] [Tur]
Pedal Bloqueio Diferencia L Frente / Front Differential Lock Pedal
Pedal Bloqueio Diferencia L Traseiro / Rear Differential Lock Pedal
Eixo Traseiro / Rear Axle
Travão / Brake
Alavanca Travao Mao / Par King Brake Lever
Travão De Estacionamento / Parking Brake
Pedal Travao / Brake Peda L
Deposito Oleo Travoes / B Rake Oil Tank
Cilindro Travao Principal [Peças Componentes] / Brake Master Cylinder [Compon Ent Parts]
Tubo Travao / Brake Pipe
Suporte Eixo Dianteiro / Front Axle Bracket
Veio Frontal / Front P Ropeller Shaft
Engrenagem Cónica (Dia Nteira) / Bevel Gear (Front)
Diferencial Dianteiro / Differential Front
Bloqueio Diferencial F Rente / Front Differential Lock Clutch
Carter Grupo Conico / Bevel Gear Case
Carter Eixo / Front Ax Le Case
Grupo Conico / Differe Ntial Gear Shaft
Direcção Assistida / Direção Punho / Steering Handle
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção[Peças Componentes] / St Eering Controller [Component Parts] [Old]
Direcção Assistida / Tie Rod/Steering Cylinde R
Cilindro Direcção [Peças Componentes] / Steer Ing Cylinder [Component Parts] [Old]
Cilindro Direcção [Peças Componentes] / Steer Ing Cylinder [Component Parts] [New]
Bomba Hidraulico / Hydrauli C Pump
Bomba Hidraulico[Peças Comp Onentes] / Hydraulic Pump [Component Parts]
Válvula Do Regulador / Regu Later Valve
Valvula Reguladora [Peças C Omponentes] / Regulater Valve [Component Parts]
Tubo Hidraulico (Aspiração) / Hydraulic Pipe (Suction)
Tubo Hidraulico (Entrega) / Hydraulic Pipe (Delivery) [Old]
Tubo Hidraulico (Entrega) / Hydraulic Pipe (Delivery) [New]
Tubo Hidraulico (Travao Reb Oque) / Hydraulic Pipe (Trailer Brake) [Old]
Tubo Hidraulico / Hydraulic Pipe
Valvula Travao Reboque / Tr Ailer Brake Valve [Old]
Valvula Travao Reboque / Tr Ailer Brake Valve [New]
Tubo Oleo (Dual Speed) / Hy Draulic Oil Line (Dual Speed Valve)
Circuito Oleo Direcção / Hy Draulic Oil Line (Steering/Pto)
Tubo Direccao / Steering Ho Se (Delivery)
Caixa Hidraulico / Hydrauli C Cylinder Case
Braço De Elevação Hidráulic O / Hydraulic Lift Arm
Resguardo Cilindro Hidráuli Co / Hydraulic Cylinder Cover
Braco Hidraulico / Control Valve
Valvula Control / Control V Alve [Component Parts]
Alavanca Control Posicao / Position (3p Remote) Control Lever
Acessorios / Draft And Posi Tion Control Lever
Puxar E Posicionar Suporte De Alavanca De Controlo / Draft And Position Contro L Lever Bracket
Veio Posicao Esforço / Posi Tion And Draft Shaft
Excentrico Posicao / Positi On Cam
Puxar Came / Draft Cam
Distribuidor Auxiliar / Rem Ote Control Valve (S/D) (Fd) [Old]
Distribuidor Auxiliar / Rem Ote Control Valve (S/D) (Fd) [New]
Valvula Control Auxiliar (S /D) [Peças Componentes][Antiga] / Auxiliary Control Valve (S/D) [Component Parts] [Old]
Valvula Auxiliar [Peças Com Ponentes] / Auxiliary Control Valve (Fd) [Component Parts] [Old]
Valvula Auxiliar [Peças Com Ponentes] / Auxiliary Control Valve (Fd) [Component Parts] [New]
Alavanca Valvula Auxiliar 1 Pos / Auxiliary Control Valve Lever
Parte Superior / Top Link Bracket
Ligaca O Superior / Top Link
Ligaca O Inferior / Lower Link
Estabi Lizador [Fr] [G] [Sp] [Pog] [Tur] / Stabilizer [Fr] [G] [Sp] [Pog] [Tur]
Estabi Lizador(Drt) / Lift Rod Rh
Estabi Lizador(Esq) / Lift Rod Lh
Barra / Drawbar Bracket
Protec Cao Tdf [Fr] [G] [Sp] [Pog] [Tur] / Pto Shaft Prote Ctor [Fr] [G] [Sp] [Pog] [Tur]
Grelha Frontal / Front Grille
Capot Superior / Hood(Bonnet) Upper
Capot Lateral / Hood(Bonnet) Side Cover
Painel De Retificação / Rectification Panel
E Strutura Cabine / Cab Frame
C Apot Traseiro / Hood(Bonnet) Rear
P Orta(Drt) / Door Rh
P Orta(Esq) / Door Lh
T Rinco Porta(Drt) / Door Lock Rh
T Rinco Porta(Esq) / Door Lock Lh
L Ado Vidro (Drt) / Side Window Rh
L Ado Vidro (Esq) / Side Window Lh
V Idro Traseiro / Rear Window (Upper)
V Idro Traseiro / Rear Window (Lower)
E Spelho Rectrovisor / Rearview Mirror
T Ecto Interior / Inner Roof
T Ecto Abrir / Outer Roof
B Anco [Fr] [G] [Sp] [Pog] [Tur] / Seat [Fr] [G] [Sp] [Pog] [Tur] [A Type]
B Anco [Fr] [G] [Sp] [Pog] [Tur] / Seat [Fr] [G] [Sp] [Pog] [Tur] [B Type]
P Iso / Floor Mat
C Hapa Inspecção(Frente) / Inspection Plate
C Obertura Guarda Lamas(Drt) / Fender Cover Rh
C Obertura Gurada Lamas(Esq) / Fender Cover Lh
R Esguardo Coluna / Pillar Cover
G Uarda Lamas(Drt) / Fender Rh
G Uarda Lamas(Esquerda) / Fender Lh
D Ianteira Do Suporte Da Cabine / Cab Bracket Front
S Uporte Cabine(Traseiro) [Fr] [G] [Sp] [Pog] [Tur] / Cab Bracket Rear [Fr] [G] [Sp] [Pog] [Tur]
C Aixa Ferramenta / Tool Box
Air Condicionado / Air Conditi Oner
Tubo Ar Condicionado / Drain H Ose (Air Conditioner)
Condesador / Condenser
Tubo Ar Condicionado/Tubo Cond Ensador / Air Conditioner Hose / Condenser Hose [Ol D]
Tubo Ar Condicionado/Tubo Cond Ensador / Air Conditioner Hose / Condenser Hose [Ne W]
Compressor / Compressor
Suporte Compressor / Compresso R Bracket
Etiqueta 1 [Sp] [Tur] / Label 1 (Front) [Sp] [T Ur]
Etiqueta 1 / Label 1 (Front) [Pog]
Etiqueta 2 [Sp] [Tur] / Label 2 (Rear) [Sp] [Tu R]
Etiqueta 2 [Pog] / Label 2 (Rear) [Pog]
Acessorios [Fr] [G] [S P] [Pog] [Tur] / Accessories And Service Parts [Fr] [G] [Sp] [Pog] [Tur]
Separador Kit [Opção] / Separator Kit [Option]
Ecu Resguardo Kit [Opção] / Ecu Cover Kit [Option]
Kit Limpa Vidro Traseiros [Opção] / Rear Wiper Kit [Option]
Kit Cobertuta Deposito Gasoleo [Opção] / Fuel Tank Cover Kit [Option]
Kit Caixa Crepper [Opção] / Creep Speed Kit 1 (Gea R Case) [Option]
Forqueta Caixa / Creeper [Opção] / Creep Speed Kit 2 (Shift Fork/Lever) [Option]
80" Kit (W/G No.M9783) [Opção] / 80 Inch Tread Kit [Option]
Kit Valvula Control Auxiliar (Scd) [Opção] / Auxil Iary Control Valve Kit (Scd) [Option] [Old]
Kit Valvula Control Auxiliar (Scd) [Opção] / Auxil Iary Control Valve Kit (Scd) [Option] [New]
Kit Valvula Control Auxiliar (Fd) [Opção] / Auxili Ary Control Valve Kit (Fd) [Option] [Old]
Kit Valvula Control Auxiliar (Fd) [Opção] / Auxili Ary Control Valve Kit (Fd) [Option] [New]
Kit Valvula Control Auxiliar (Scd/Fc) [Opção] / Au Xiliary Control Valve Kit (Scd/Fc) [Option]
Kit Valvula Control Auxiliar (Fc) [Opção] / Auxili Ary Control Valve Kit (Fc) [Option]
Valvula Control Auxiliar (Scd) [Peças Componentes] [Opção] [Antiga] / Auxiliary Control Valve (Scd) [ Component Parts] [Option] [Old]
Valvula Control Auxiliar (Fd) [Peças Componentes] [Opção] [Nova] / Auxiliary Control Valve (Scd) [Com Ponent Parts] [Option] [New]
Valvula Control Auxiliar (Scd/Fc) [Peças Component Es] [Opção] [Antiga] / Auxiliary Control Valve (Scd /Fc) [Component Parts] [Option] [Old]
Valvula Control Auxiliar (Scd/Fc) [Peças Component Es] [Opção] [Nova] / Auxiliary Control Valve (Scd/F C) [Component Parts] [Option] [New]
Kit Distribuidor Serviços Externos (Fc) [Peças Com Ponentes] [Opção] / Auxiliary Control Valve (Fc) [C Omponent Parts] [Option]
Kit Alavanca Serviços Externos [Opção] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Cilindro Auxiliar Kit (Direito) [Fr] [G] [Sp] [Pog ] [Tur] [Opção] / Assist Cylinder Kit Rh [Fr] [G] [ Sp] [Pog] [Tur] [Option]
Cilindro Auxiliar Kit (Esquerdo) [Fr] [G] [Sp] [Po G] [Tur] [Opção] / Assist Cylinder Kit Lh [Fr] [G] [Sp] [Pog] [Tur] [Option]
Cilindro Auxiliar [Peças Componentes] [Fr] [G] [Sp ] [Pog] [Tur] [Opção] / Assist Cylinder [Component Parts] [Fr] [G] [Sp] [Pog] [Tur] [Option]
