Kubota Tractor M108SDTC Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M108SDTC Tractor
Number of Pages: 740 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Compensador / Balancer
Volante / Flywheel
Carril Comun / Common Rail
Agua Bomba / Water Pump
Beborde De Valvula De Egr / Egr Valve Flange
Escape Colector [Antiguo] / Exhaust Manifold [Old]
Escape Colector [Nuevo] / Exhaust Manifold [New]
Valvula De Egr Y Refrigerador De Egr / Egr Valve And Egr Cooler
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Intercooler / Inter Cooler
Kit De Juntas (Superior) / Upper Gasket Kit
Kit De Juntas (Inferior) / Lower Gasket Kit
Piezas Electricas Del Motor / Engine Electrical Parts
Diagmaster
Palanca De Acelerador De Mano / Hand Accelerator Lever
Deposito De Combustible Dcha / Fuel Tank Rh
Deposito De Combustible Izqd / Fuel Tank Lh
Combustible Tubo 1 (Adelante) [Antiguo] / Fuel Pipe 1 (Front) [Old]
Combustible Tubo 1 (Adelante) [Nuevo] / Fuel Pipe 1 (Front) [New]
Combustible Tubo 2 (Trasero) [Antiguo] / Fuel Pipe 2 (Rear) [Old]
Combustible Tubo 2 (Trasero) [Nuevo] / Fuel Pipe 2 (Rear) [New]
Combustble Tubo 3 (Refrigerador Del Combustible) / Fuel Pipe 3 (Fuel Cooler)
Separador [Antiguo] / Separator [Old]
Separador [Nuevo] / Separator [New]
Separador [Componente Piezas] [Antiguo] / Separator [Component Parts] [Old]
Separador [Componente Piezas] [Nuevo] / Separator [Component Parts] [New]
Ventilador / Fan
Manguitoagua [Antiguo] / Water Pipe [Old]
Manguitoagua [Nuevo] / Water Pipe [New]
Alternador / Alternator
Motor De Arranque / Starter
Conmutador/Sensor (Combustrible/Cubierta) [Fr] [G] [Sp] [Pog] [Tur] / Switch/Sensor (Fuel/Housing) [Fr] [G] [Sp] [Pog] [Tur]
Interruptor Interno Del Cabina / Cab Inner Switch
Interruptor Principal/Interruptor Del Mando / Main Switch/Lever Control Switch
Rele / Relay
Tablero Panel / Panel Board
Culata Luz [Fr] [G] [Sp] [Pog] [Tur] / Head Light [Fr] [G] [Sp] [Pog] [Tur]
Faro Delantero [Componente Piezas] [Fr] [G] [Sp] [Pog] [Tur] / Head Light [Component Parts] [Fr] [G] [Sp] [Pog] [Tur]
Adelante Combinacion Luz / Front Combination Light
Trabajo Luz/Luz Del Faro [Fr] [G] [Sp] [Pog] [Tur] / Working Light/Beacon Light [Fr] [G] [Sp] [Pog] [Tur]
Luces Combinadas Traseras / Rear Combination Light
Radio Altavoz [Fr] [G] [Sp] [Pog] [Tur] / Radio Speaker [Fr] [G] [Sp] [Pog] [Tur]
Limpiaparabrisas / Wiper
Electrico Cableado (Crs) [Antiguo] / Electrical Wiring (Crs) [Old]
Electrico Cableado (Crs) [Nuevo] / Electrical Wiring (Crs) [New]
Electrico Cableado (Motor) / Electrical Wiring (Engine)
Electrico Cableado (Principal) / Electrical Wiring (Main)
Electrical Cableado (Cuerpo) [Fr] [G] [Sp] [Pog] [Tur] / Electrical Wiring (Body) [Fr] [G] [Sp] [Pog] [Tur]
Cableado Electrico (Cabina) [Fr] [G] [Sp] [Pog] [Tur] / Electrical Wiring (Cab) [Fr] [G] [Sp] [Pog] [Tur]
Carcasa De Embrague / Clutch Housing
Inversor Valvula [Componente Piezas] / Shuttle Valve [Component Parts]
Embrague Carcasa Cubierta (Superior) / Clutch Housing Cover (Upper)
Embrague Carcasa Cubierta (Mas Bajo) / Clutch Housing Cover (Lower)
Caja Intermedia / Mid Case
Cubierta Trasera De Caja De Transmision [Fr] [G] [Sp] [Pog] [Tur] / Transmission Case Rear Cover [Fr] [G] [Sp] [Pog] [Tur]
Embrague Cable / Clutch Cable
Valvula Palanca(Embrague/Inversor) [Antiguo] / Valve Lever (Clutch/Shuttle) [Old]
Valvula Palanca(Embrague/Inversor) [Nuevo] / Valve Lever (Clutch/Shuttle) [New]
Engranaje Soporte / Gear Support
Eje De Entrada / Input Shaft
Inversor Eje / Shuttle Shaft
Primero/Segundo Cambio Engranaje / First/Second Shift Gear
Primer Eje / First Shaft
Tercero/Cuarto Cambio Engranaje / Third/Fourth Shift Gear
Arbol Contrarrotante / Countershaft
Principal Engranaje Cambio Eje Y Gama Engranaje Eje / Main Gear Shift Shaft And Range Gear Shaft
Doble Velocidad Embrague / Dual Speed Clutch
Accionar Eje (Adelante) / Drive Shaft (Front)
Accionar Eje (Medio/Trasero) / Drive Shaft (Middle/Rear)
Caso De La Cambio De Hi-Lo / Hi-Lo Shift Case
Pto Embrague / Bevel Gear
Trasero Diferencial / Differential Rear
Eje Propulsor De Tdf / Pto Propeller Shaft
Tdf Embrague / Pto Clutch
Tdf Embrague [Componente Piezas] [Antiguo] / Pto Clutch [Component Parts] [Old]
Tdf Embrague [Componente Piezas] [Nuevo] / Pto Clutch [Component Parts] [New]
Pto Embrague Valvula / Pto Clutch Valve
Pto Embrague Valvula [Componente Piezas] / Pto Clutch Valve [Component Parts]
Eje Motor De Tdf [Fr] [G] [Sp] [Pog] [Tur] / Pto Drive Shaft [Fr] [G] [Sp] [Pog] [Tur]
Eje De Tdf [Fr] [G] [Sp] [Pog] [Tur] / Pto Shaft [Fr] [G] [Sp] [Pog] [Tur]
Embrague Hidraulico (Impulsion Delantera De La Rueda) / Hydraulic Clutch (Front Wheel Drive)
Horquilla De Cambio De Gama / Range Gear Shift Fork
Horquilla De Cambio De Bloqueo De Diferencial / Rear Differential Lock Shift Fork
Palanca De Cambio Principal / Main Gear Shift Lever
Eje De Palanca De Cambio Principal / Main Gear Shift Lever Shaft
Inversor Cambio Palanca / Shuttle Shift Lever
Inversor Cable / Shuttle Cable
Pto Embrague Palanca / Pto Clutch Lever
Palanca De Cambio De Tdf [Fr] [G] [Sp] [Pog] [Tur] / Pto Gear Shift Lever [Fr] [G] [Sp] [Pog] [Tur]
Pedal Delantero De La Cerradura Diferenciada / Front Differential Lock Pedal
Trasero Diferencial Cerradura Pedal / Rear Differential Lock Pedal
Freno / Brake
Estacionamiento Freno / Parking Brake
Freno Pedal / Brake Pedal
Freno Aceite Deposito / Brake Oil Tank
Tubo De Freno / Brake Pipe
Soporte De Eje Delantero / Front Axle Bracket
Eje Propulsor / Front Propeller Shaft
Engranaje Conico (Anterior) / Bevel Gear (Front)
Embrague De Bloqueo De Diferencial Delantero / Front Differential Lock Clutch
Adelante Eje / Front Axle
Diferencial Eje Del Engranaje / Differential Gear Shaft
Direccion Junta / Steering Joint
Direccion Controlador [Componente Piezas] [Antiguo] / Steering Controller [Component Parts] [Old]
Direccion Controlador [Componente Piezas] [Nuevo] / Steering Controller [Component Parts] [New]
Cilindro De Direccion [Componentes] [Antiguo] / Steering Cylinder [Component Parts] [Old]
Cilindro De Direccion [Componentes] [Nuevo] / Steering Cylinder [Component Parts] [New]
Valvula Reguladora / Regulater Valve
Regulador Valvula [Componente Piezas] / Regulater Valve [Component Parts]
Hidraulico Tubo (Aspiracion) / Hydraulic Pipe (Suction)
Hidraulico Tubo (Impulsion) [Antiguo] / Hydraulic Pipe (Delivery) [Old]
Hidraulico Tubo (Impulsion) [Nuevo] / Hydraulic Pipe (Delivery) [New]
Hidraulico Tubo (Remolque Freno) [Antiguo] / Hydraulic Pipe (Trailer Brake) [Old]
Hidraulico Tubo / Hydraulic Pipe
Remolque Freno Valvula [Antiguo] / Trailer Brake Valve [Old]
Remolque Freno Valvula [Nuevo] / Trailer Brake Valve [New]
Radiador De Aceite / Oil Cooler
Hidraulico Aceite Linea (Valvula De Doble Velocidad) / Hydraulic Oil Line (Dual Speed Valve)
Linea De Aceite Hidraulico(Direccion/Tdf) / Hydraulic Oil Line (Steering/Pto)
Latiguillo De Direccion (Impulsion) / Steering Hose (Delivery)
Hidraulico Ascenso Brazo / Hydraulic Lift Arm
Cubierta De Cilindro Hidraulico / Hydraulic Cylinder Cover
Coloque La Palanca De Mando (Distancia 3p) / Position (3p Remote) Control Lever
Palanca De Control De Esfuerzo Y Posicion / Draft And Position Control Lever
Esfuerzo Y Posicion Control Palanca Soporte / Draft And Position Control Lever Bracket
Posicion Y Esfuerzo Eje / Position And Draft Shaft
Posicion Leva / Position Cam
Esfuerzo Leva / Draft Cam
Alejado Control Valvula (S/D) (Fd) [Antiguo] / Remote Control Valve (S/D) (Fd) [Old]
Alejado Control Valvula (S/D) (Fd) [Nuevo] / Remote Control Valve (S/D) (Fd) [New]
Distribuidor De Servicios Externos (S/D) [Componente Piezas] [Antguo] / Auxiliary Control Valve (S/D) [Component Parts] [Old]
Distribuidor De Servicios Externos (Fd) [Componente Piezas] [Antiguo] / Auxiliary Control Valve (Fd) [Component Parts] [Old]
Distribuidor De Servicios Externos (Fd) [Componente Piezas] [Nuevo] / Auxiliary Control Valve (Fd) [Component Parts] [New]
Auxiliar Control Valvula Palanca / Auxiliary Control Valve Lever
Soporte De Tercer Punto / Top Link Bracket
Bajar Vinculo / Lower Link
Estabilizador [Fr] [G] [Sp] [Pog] [Tur] / Stabilizer [Fr] [G] [Sp] [Pog] [Tur]
Varilla De Elevacion Izqd / Lift Rod Lh
Ayudar Cilindro Soporte / Drawbar Bracket
Protector De Eje De Tdf [Fr] [G] [Sp] [Pog] [Tur] / Pto Shaft Protector [Fr] [G] [Sp] [Pog] [Tur]
Capo (Capo) Superior / Hood(Bonnet) Upper
Tapa Lateral De Capo / Hood(Bonnet) Side Cover
Capo Soporte / Bonnet Support
Bastidor De Cabina / Cab Frame
Capo(Capo)Trasero / Hood(Bonnet) Rear
Adelante Vidrio / Front Glass
Puerta Derecho / Door Rh
Puerta Izqd / Door Lh
Cerradura De Puerta Izqd / Door Lock Lh
Lado Ventana Derecho / Side Window Rh
Lado Ventana Izquierdo / Side Window Lh
Trasero Ventana (Superior) / Rear Window (Upper)
Trasero Ventana (Bajar) / Rear Window (Lower)
Techo Interior / Inner Roof
Externo Techo / Outer Roof
Asiento [Fr] [G] [Sp] [Pog] [Tur] [Tipo De A] / Seat [Fr] [G] [Sp] [Pog] [Tur] [A Type]
Asiento [Fr] [G] [Sp] [Pog] [Tur] [Tipo De B] / Seat [Fr] [G] [Sp] [Pog] [Tur] [B Type]
Alfombrilla De Piso / Floor Mat
Placa De Inspeccion / Inspection Plate
Cubierta De Guardabarros Dcha / Fender Cover Rh
Cubierta De Guardabarros Izqd / Fender Cover Lh
Cubierta De Montante / Pillar Cover
Guardabarros / Fender Rh
Guardabarros Izqd / Fender Lh
Soporte Posterior De Cabina [Fr] [G] [Sp] [Pog] [Tur] / Cab Bracket Rear [Fr] [G] [Sp] [Pog] [Tur]
Caja De Herramientas / Tool Box
Manguera De Vaciado(Aire Acondicionado) / Drain Hose (Air Conditioner)
Condensador / Condenser
Aire Acondicionador Manguito/Condensador Manguito [Antiguo] / Air Conditioner Hose / Condenser Hose [Old]
Aire Acondicionador Manguito/Condensador Manguito [Nuevo] / Air Conditioner Hose / Condenser Hose [New]
Compresor / Compressor
Soporte De Compresor / Compressor Bracket
Etiqueta 1 (Delantero) [Fr] / Label 1 (Front) [Fr]
Etiquetta 2 (Trasero) [Fr] / Label 2 (Rear) [Fr]
Accesorios Y Servicio Piezas [Fr] [G] [Sp] [Pog] [Tur] / Accessories And Service Parts [Fr] [G] [Sp] [Pog] [Tur]
Separador [Opcion] / Separator Kit [Option]
Ecu Cubierta Kit [Opcion] / Ecu Cover Kit [Option]
Trasero Limpiaparabrisas Kit [Opcion] / Rear Wiper Kit [Option]
Combustible Deposito Cubierta Kit [Opcion] / Fuel Tank Cover Kit [Option]
Marcha Muy Lenta Velocidad Kit 1 (Engranaje Caja) [Opcion] / Creep Speed Kit 1 (Gear Case) [Option]
Marcha Muy Lenta Velocidad Kit 2 (Cambio Bfrccn/Plnc) [Opcion] / Creep Speed Kit 2 (Shift Fork/Lever) [Option]
80 Pulgada Ancho De Via Kit [Opcion] / 80 Inch Tread Kit [Option]
Kit De Distribuidor De Servicios Externos (Scd) [Opcion] [Antiguo] / Auxiliary Control Valve Kit (Scd) [Option] [Old]
Kit De Distribuidor De Servicios Externos (Scd) [Opcion] [Nuevo] / Auxiliary Control Valve Kit (Scd) [Option] [New]
Kit De Distribuidor De Servicios Externos (Fd) [Opcion] [Antiguo] / Auxiliary Control Valve Kit (Fd) [Option] [Old]
Kit De Distribuidor De Servicios Externos (Fd) [Opcion] [Nuevo] / Auxiliary Control Valve Kit (Fd) [Option] [New]
Kit De Distribuidor De Servicios Externos (Scd/Fc) [Opcion] / Auxiliary Control Valve Kit (Scd/Fc) [Option]
Kit De Distribuidor De Servicios Externos (Fc) [Opcion] / Auxiliary Control Valve Kit (Fc) [Option]
Distribuidor De Servicios Externos (Scd) [Componente Piezas] [Opcion] [Antiguo] / Auxiliary Control Valve (Scd) [Component Parts] [Option] [Old]
Distribuidor De Servicios Externos (Scd) [Componente Piezas] [Opcion] [Nuevo] / Auxiliary Control Valve (Scd) [Component Parts] [Option] [New]
Distribuidor De Servicios Externos (Scd/Fc) [Componente Piezas] [Opcion] [Antiguo] / Auxiliary Control Valve (Scd/Fc) [Component Parts] [Option] [Old]
Distribuidor De Servicios Externos (Scd/Fc) [Componente Piezas] [Opcion] [Nuevo] / Auxiliary Control Valve (Scd/Fc) [Component Parts] [Option] [New]
Distribuidor De Servicios Externos (Fc) [Componente Piezas] [Opcion] / Auxiliary Control Valve (Fc) [Component Parts] [Option]
Kit De Palanca De Distribuidor De Servicios Externos (Tercero) [Opcion] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Ayuder Cilindro Kit Derecho [Fr] [G] [Sp] [Pog] [Tur] [Opcion] / Assist Cylinder Kit Rh [Fr] [G] [Sp] [Pog] [Tur] [Option]
Ayuder Cilindro Kit Izquierdo [Fr] [G] [Sp] [Pog] [Tur] [Opcion] / Assist Cylinder Kit Lh [Fr] [G] [Sp] [Pog] [Tur] [Option]
Ayuder Cilindro [Componente Piezas] [Fr] [G] [Sp] [Pog] [Tur] [Opcion] / Assist Cylinder [Component Parts] [Fr] [G] [Sp] [Pog] [Tur] [Option]
Volante / Flywheel
Diagmaster
Ventilador / Fan
Rele / Relay
Freno / Brake
