Kubota Tractor M105SDT Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M105SDT Tractor
Number of Pages: 350 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Volante Motor / Flywheel
Compensador / Balancer
Vela Pre Aquecimento / Nozzle Holder [Old Type]
Vela Pre Aquecimento / Nozzle Holder [New Type]
Caixa Da Bomba / Pump Housing
Alavanca Do Garfo (Governador) / Fork Lever (Govern Or)
Parafuso De Ajuste De Governador / Governor Adjusti Ng Bolt
Filtro Gasoleo / Fuel Filter
Bomba Agua E Termostacto / Water Flange And Thermos Tat
Acessorios / Water Pump
Válvula E Veio Do Balanceiro / Valve And Rocker Arm
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [Compon Ent Parts]
Escpae / Muffler
Actuador / Actuator
Tubo Oleo (Turbo) / Oil Pipe (Turbo Charger)
Intercooler / Inter Cooler
Deposito Combustivel / Lower Gasket Kit
Deposito Combustivel (Drt) / Fuel Tank Rh
Deposito Combustivel (Esq) / Fuel Tank Lh
Tubo Combustivel / Fuel Pipe
Separador / Separator
Separador[Peças Componentes] / Separator [Component Parts]
Radiador / Water Pipe
Deposito Re Serva / Reserve Tank
Alternador / Alternator
Alternador [Peças Componente S] / Alternator [Component Parts]
Motor Arranque / Starter
Interruptor / Sensor (Motor) / Switch/Sensor
Interruptor / Rele / Switch/ Relay
Interruptor / Switch (Panel Board)
Comutador / Switch
Interruptor Ar Condicionado / Air Conditioner Switch / Amplifier
Interruptor / Rele / Relay
Painel / Panel Board
Painel[Peças Componentes] / Panel Board [Component Parts]
Farol Dianteiro / Head Light
Luzes Frontais / Front Combi Nation Light
Luzes Trabalho / Work Light
Braco Traseiro / Rear Combin Ation Light / Reflector
Ficha Reboque / Trailer Sock Et
Luz Interior / Room Light
Alta Voz Radio / Radio Speak Er
Escova Limpa Vidros / Wiper
Cablagem Electrica (Motor) / Electrical Wiring (Engine)
Cablagem Electrica / Electri Cal Wiring (Main)
Cabalagem Eletrica(Cabine)[E C] [G] / Electrical Wiring (Cab) [Ec] [Fr] [Pog]
Cabalagem Eletrica(Cabine)[E C] [G] / Electrical Wiring (Cab) [Uk]
Carter Embraiagem / Clut Ch Housing
Shuttle Valve [Component Parts] / Shuttle Valve [Component Parts]
Clutch Housing Cover Upp Er / Dual Speed Valve / Clutch Housing Cover Upper / Dual Speed Valve
Carter Embraiagem / Clut Ch Housing Cover
Caixa Intermedia / Mid C Ase
Caixa Velocidades / Tran Smission Case
Carter Transmissao / Tra Nsmission Case Rear Cover [Ec] [Fr] [Pog]
Carter Transmissao / Tra Nsmission Case Rear Cover [Uk]
Carter Eixo / Rear Axle Case
Disco Amortecedor / Damp Er Disk
Bloqueio Diferencial / C Lutch Pedal
Cabo Embraiagem / Clutch Cable
Valvula (Inversor) / Val Ve Lever (Clutch/Shuttle)
Cobertura Frontal / Fron T Cover
Suporte Carreto / Gear S Upport
Veio Primario / Input Sh Aft
Veio Inversor / Shuttle Shaft
Primeira/Segunda Mudança / First/Second Shift Gear
Primeiro Veio / First Sh Aft
Carreto Terceira/Quarta / Third/Fourth Shift Gear
Veio Secundario / Counte Rshaft
Carreto Principal / Main Gear Shift Shaft And Range Gear Shaft
Veio Gamas Velocidades / Range Gear Shaft
Dual Speed Clutch / Dual Speed Clutch
Veio (Meio/Traseiro) / D Rive Shaft (Middle/Rear)
Painel Lateral / Transmi Ssion Case Side Cover
Grupo Conico / Bevel Gea R
Diferencial Traseiro / D Ifferential Rear
Veio Tdf / Pto Propeller Shaft
Embraiagem Tdf / Pto Clu Tch
Embraiagem Tdf[Peças Com Ponentes] / Pto Clutch [Component Parts] [Old]
Embraiagem Tdf[Peças Com Ponentes] / Pto Clutch [Component Parts] [New]
Valvula Embraiagem Tdf / Pto Clutch Valve
Valvula Embraiagem Tdf[P Eças Componentes] / Pto Clutch Valve [Component Pa Rts]
Veio Principal Tdf / Pto Drive Shaft [Ec] [Fr] [Pog]
Veio Principal Tdf / Pto Drive Shaft [Uk] [Old Type]
Veio Principal Tdf / Pto Drive Shaft [Uk] [New]
Veio Tdf / Pto Shaft [Ec ] [Fr] [Pog]
Veio Tdf / Pto Shaft [Uk ] [Old Type]
Forqueta Caixa / Creeper / Range Gear Shi Ft Fork
Alavanca / Rear Differential Lock Shift F Ork
Alavanca Velocidades / Main Gear Shift Le Ver
Tirante / Main Gear Shift Rod
Main Gear Shift Lever Shaft / Main Gear S Hift Lever Shaft
Cabo Inversor / Shuttle Cable
Alavanca Velocidades / Range Gear Shift L Ever
Alavanca Tdf / Pto Gear Shift Lever [Uk] [Old Type]
Alavanca Dupla Traccao / Front Wheel Driv E Lever
Eixo Traseiro / Rear Axle
Alavanca Travao Mao / Park Ing Brake Lever
Travão De Estacionamento / Parking Brake
Pedal Travao / Brake Pedal
Pedal Bloqueio Diferencial Traseiro / Rear Differential Lock Pedal
Deposito Oleo Travoes / Br Ake Oil Tank
Cilindro Travao Principal[ Peças Componentes] / Brake Master Cylinder [Compone Nt Parts]
Tubo Travao / Brake Pipe
Suporte Eixo Frente / F Ront Axle Frame
Suporte Eixo Dianteiro / Front Axle Bracket
Veio Frontal / Front Pr Opeller Shaft
Caixa Diferencial Diant Eiro / Front Differential Case
Engrenagem Cónica (Dian Teira) / Bevel Gear (Front)
Diferencial Dianteiro / Differential Front
Bloqueio Diferencial Fr Ente / Front Differential Lock Clutch
Carter Grupo Conico / B Evel Gear Case
Carter Eixo / Front Axl E Case
Grupo Conico / Differen Tial Gear Shaft
Direcção Assistida / Direção Punho / Steering Handle
Junta / Steering Joint
Distribuidor Direcção[Peças Componentes] / Ste Ering Controller [Component Parts]
Direcção Assistida / Tie Rod/Steering Cylinder
Cilindro Direcção[Peças Componentes] / Steerin G Cylinder [Component Parts]
Bomba Hidraulico / Hydraulic P Ump
Bomba Hidraulico[Peças Compone Ntes] / Hydraulic Pump [Component Parts]
Válvula Do Regulador / Regulat Er Valve
Valvula Reguladora[Peças Compo Nentes] / Regulater Valve [Component Parts]
Linha Aspiração / Hydraulic Pi Pe (Suction)
Tubo Oleo / Hydraulic Pipe (De Livery)
Tubo Hidraulico (Travao Reboqu E) / Hydraulic Pipe (Trailer Brake)
Tubo Hidraulico / Hydraulic Oi L Line
Valvula Travao Reboque / Trail Er Brake Valve
Radiador Oleo / Oil Cooler
Hydraulic Oil Line (Dual Speed Valve) / Hydraulic Oil Line (Dual Speed Valve)
Circuito Oleo Direcção / Hydra Ulic Oil Line (Steering/Pto)
Tubo Direccao / Steering Hose (Delivery)
Cilindro Hidraulico / Hydrauli C Cylinder
Braço De Elevação Hidráulico / Hydraulic Lift Arm
Hydraulic Cylinder Cover / Hyd Raulic Cylinder Cover
Valvula Control / Control Valv E [Component Parts]
Alavanca Control Posicao / Pos Ition(3p Remote) Control Lever
Acessorios / Draft And Positio N Control Lever
Draft And Position Control Lev Er Bracket / Draft And Position Control Lever Brack Et
Veio Posicao Esforço / Positio N And Draft Shaft
Position Cam / Position Cam
Draft Cam / Draft Cam
Distribuidor Auxiliar / Auxili Ary Control Valve [Old]
Distribuidor Auxiliar / Auxili Ary Control Valve [New]
Auxiliary Control Valve (S/D) [Component Parts] [Old] / Auxiliary Control Valve ( S/D) [Component Parts] [Old]
Valvula Auxiliar [Peças Compon Entes] / Auxiliary Control Valve (Fd) [Component Pa Rts] [Old]
Alavanca Valvula Auxiliar 1 Po S / Auxiliary Control Valve Lever
Parte S Uperior / Top Link Bracket
Ligacao Superior / Top Link
Ligacao Inferior / Lower Link [Old Type]
Ligacao Inferior / Lower Link [New Type]
Estabil Izador / Stabilizer
Estabil Izador(Drt) / Lift Rod Rh [Old Type]
Estabil Izador(Drt) / Lift Rod Rh [New Type]
Estabil Izador(Esq) / Lift Rod Lh [Old Type]
Estabil Izador(Esq) / Lift Rod Lh [New Type]
Barra / Drawbar Bracket [Except [G]]
Protecc Ao Tdf / Pto Shaft Protector [Ec] [Fr] [Pog]
Protecc Ao Tdf / Pto Shaft Protector [Uk]
Capot Superior / Hood(Bonnet) Upper
Capot Lateral / Hood(Bonnet) Side Cover
Estru Tura Cabine / Cab Frame [Ec] [Fr] [Pog]
Estru Tura Cabine / Cab Frame [Uk]
Kit L Impa Vidro Traseiros (Opcao) / Panel Frame
Vidro Frente E Traseiro / Front Glass
Porta (Drt) / Door Rh
Porta (Esq) / Door Lh
Trinc O Porta(Drt) / Door Lock Rh
Trinc O Porta(Esq) / Door Lock Lh
Lado Vidro / Side Window
Vidro Traseiro / Rear Window (Upper)
Rear Window (Lower) / Rear Window (Lower)
Espel Ho Rectrovisor / Rearview Mirror
Tecto Interior / Inner Roof
Tecto Abrir / Outer Roof
Banco / Seat [Ec] [Fr] [Pog]
Banco / Seat [Uk]
Piso / Floor Mat
Chapa Inspecção(Frente) / Inspection Plate
Cober Tura Gurada Lamas(Esq) / Fender Cover Lh
Pilla R Cover / Pillar Cover
Guard A Lamas(Drt) / Fender Rh
Guard A Lamas(Esquerda) / Fender Lh
Diant Eira Do Suporte Da Cabine / Cab Bracket Front
Supor Te Cabine(Traseiro) / Cab Bracket Rear / Reflector
Caixa Ferramenta / Tool Box
Air Condicionado / Air Conditio Ner
Tubo Ar Condicionado / Drain Ho Se (Air Conditioner)
Condesador / Condenser
Tubo Ar Condicionado/Tubo Conde Nsador / Air Conditioner Hose / Condenser Hose
Compressor / Compressor
Suporte Compressor / Compressor Bracket
Etiqueta 1 / Label 1 (Front)
Etiqueta 2 / Label 2 (Rear) [Ec] [Fr] [ Pog]
Etiqueta 2 / Label 2 (Rear) [Uk]
Acessorios / Accessories And Service Part S
Kit Limpa Vidro Traseiros (Opcao) / Rear Wiper Kit [Option]
Kit Cobertuta Deposito Gasoleo / Fuel Tank Cover Ki T [Option]
Kit Caixa Crepper(Opção) / Creep Speed Kit (Gear Ca Se) [Option]
Creep Speed Kit (Shift Fork/Lever) [Option] / Creep Speed Kit (Shift Fork/Lever) [Option]
Kit Conversao Tdf 540/1000 (Engrenagem Box)(Opção) / Pto(540/1000) Conversion Kit (Gear Case) [Option]
Kit Conversao Tdf 540/1000 (Engrenagem) (Opção) / P To(540/1000) Conversion Kit (Gear) [Option]
80" Kit (W/G No.M9783) (Opção) / 80 Inch Tread Kit [Option]
Auxiliary Control Valve Kit (Scd) [Option] [Old] / Auxiliary Control Valve Kit (Scd) [Option] [Old]
Auxiliary Control Valve Kit (Scd) [Option] [New] / Auxiliary Control Valve Kit (Scd) [Option] [New]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Con Trol Valve Kit (Fd) [Option] [Old]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Con Trol Valve Kit (Fd) [Option] [New]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Con Trol Valve Kit (Scd/Fc) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Con Trol Valve Kit (Fc) [Option]
Auxiliary Control Valve (Scd) [Component Parts] [Op Tion] [Old] / Auxiliary Control Valve (Scd) [Compon Ent Parts] [Option] [Old]
Auxiliary Control Valve (Scd) [Component Parts] [Op Tion] [New] / Auxiliary Control Valve (Scd) [Compon Ent Parts] [Option] [New]
Auxiliary Control Valve (Scd/Fc) [Component Parts] [Option] [Old] / Auxiliary Control Valve (Scd/Fc) [ Component Parts] [Option] [Old]
Auxiliary Control Valve (Scd/Fc) [Component Parts] [Option] [New] / Auxiliary Control Valve (Scd/Fc) [ Component Parts] [Option] [New]
Kit Distribuidor Serviços Externos[Peças Componente S][Opcao] / Auxiliary Control Valve (Fc) [Component Parts] [Option]
Kit Alavanca Serviços Externos[Opcao] / Auxiliary C Ontrol Valve Lever Kit (3rd) [Option]
Assist Cylinder Kit Rh [Option] / Assist Cylinder K It Rh [Option]
Assist Cylinder Kit Lh [Option] / Assist Cylinder K It Lh [Option]
Cilindro Auxiliar (Componentes) / Assist Cylinder [ Component Parts] [Option]
Carreto / Gear Case
Escpae / Muffler
Actuador / Actuator
Comutador / Switch
Banco / Seat [Uk]
Piso / Floor Mat
