Kubota Tractor M105SDT Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M105SDT Tractor
Number of Pages: 615 Pages
Frequently Used Items
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Volante / Flywheel
Compensador / Balancer
Tobera Soporte Y Bujia De Calentamiento Tapon / Nozzle Holder [Old Type]
Tobera Soporte Y Bujia De Calentamiento Tapon / Nozzle Holder [New Type]
Bomba Carcasa / Pump Housing
Bifurcacion Palanca(Regulador) / Fork Lever (Governor)
Regulador Ajuste Tornillo / Governor Adjusting Bolt
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Entrada Tubo / Air Cleaner [Component Parts]
Silenciador / Muffler
Actuador / Actuator
Aceite Tubo(Turbo Cargador) / Oil Pipe (Turbo Charger)
Intercooler / Inter Cooler
Acelerador Palanca / Hand Accelerator Lever
Deposito De Combustible Dcha / Fuel Tank Rh
Deposito De Combustible Izqd / Fuel Tank Lh
Decantador / Separator
Separador (Componente Piezas) / Separator [Component Parts]
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador/Rele / Switch/Relay
Conmutador(Tablero De Instrumentos) / Switch (Panel Board)
Conmutador / Switch
Aire Acondicionador Conmutador/Amplificador / Air Conditioner Switch / Amplifier
Rele De Arranque / Relay
Tablero Panel / Panel Board
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Culata Luz / Head Light
Adelante Combinacion Luz / Front Combination Light
Trabajo Luz/Luz Del Faro / Work Light
Luces Combinadas Traseras / Rear Combination Light / Reflector
Radio Altavoz / Radio Speaker
Limpiaparabrisas / Wiper
Electrico Cableado (Motor/Capo(Capo)) / Electrical Wiring (Engine)
Electrico Cableado(Cuerpo) / Electrical Wiring (Main)
Cableado Electrico (Cabina) [Fr] [G] [Sp] [Pog] / Electrical Wiring (Cab) [Ec] [Fr] [Pog]
Cableado Electrico (Cabina) [Fr] [G] [Sp] [Pog] / Electrical Wiring (Cab) [Uk]
Carcasa De Embrague / Clutch Housing
Inversor Valvula[Componente Piezas] / Shuttle Valve [Component Parts]
Embrague Carcasa Cubierta / Clutch Housing Cover Upper / Dual Speed Valve
Caja Intermedia / Mid Case
Cubierta Trasera De Caja De Transmision [Fr] [G] [Sp] [Pog] / Transmission Case Rear Cover [Ec] [Fr] [Pog]
Cubierta Trasera De Caja De Transmision [Fr] [G] [Sp] [Pog] / Transmission Case Rear Cover [Uk]
Cable De Embrague / Clutch Cable
Valvula Palanca(Embrague/Inversor) / Valve Lever (Clutch/Shuttle)
Engranaje Soporte / Gear Support
Eje De Entrada / Input Shaft
Inversor Eje / Shuttle Shaft
Primero/Segundo Cambio Engranaje / First/Second Shift Gear
Primer Eje / First Shaft
Tercero/Cuarto Cambio Engranaje / Third/Fourth Shift Gear
Arbol Contrarrotante / Countershaft
Principal Engranaje Cambio Eje Y Gama Engranaje Eje / Main Gear Shift Shaft And Range Gear Shaft
Doble Velocidad Embrague / Dual Speed Clutch
Accionar Eje(Medio/Trasero) / Drive Shaft (Middle/Rear)
Lado Cubierta / Transmission Case Side Cover
Eje De Engranaje Diferencial / Bevel Gear
Trasero Diferencial / Differential Rear
Eje Propulsor De Tdf / Pto Propeller Shaft
Tdf Embrague / Pto Clutch
Embrague De Tdf[Componente Piezas][Tipo Nuevo] / Pto Clutch [Component Parts] [Old]
Pto Embrague [Componente Piezas] / Pto Clutch [Component Parts] [New]
Pto Embrague Valvula [Componente Piezas] / Pto Clutch Valve [Component Parts]
Eje Motor De Tdf [Uk] / Pto Drive Shaft [Ec] [Fr] [Pog]
Eje Motor De Tdf [Uk] / Pto Drive Shaft [Uk] [Old Type]
Eje Motor De Tdf [Uk] / Pto Drive Shaft [Uk] [New]
Pto Eje / Pto Shaft [Ec] [Fr] [Pog]
Pto Eje / Pto Shaft [Uk] [Old Type]
Pto Eje / Pto Shaft [Uk] [New Type]
Horquilla De Cambio Principal / Main Gear Shift Fork
Horquilla De Cambio De Gama / Range Gear Shift Fork
Diferencial Cerradura Cambio Bifurcacion / Rear Differential Lock Shift Fork
Palanca De Cambio Principal / Main Gear Shift Lever
Varilla De Cambio Principal / Main Gear Shift Rod
Eje De Palanca De Cambio Principal / Main Gear Shift Lever Shaft
Inversor Cambio Palanca / Shuttle Shift Lever
Cable De Inversor / Shuttle Cable
Palanca De Embrague De Tdf / Pto Clutch Lever
Palanca De Cambio De Tdf / Pto Gear Shift Lever [Ec] [Fr] [Pog]
Palanca De Cambio De Tdf / Pto Gear Shift Lever [Uk] [Old Type]
Freno / Brake
Estacionamiento Freno / Parking Brake
Freno Pedal / Brake Pedal
Deposito De Aceite De Freno / Brake Oil Tank
Freno Maestro Cilindro [Componente Piezas] [Tipo Cabina] / Brake Master Cylinder [Component Parts]
Tubo De Freno / Brake Pipe
Soporte De Eje Delantero / Front Axle Bracket
Helice Eje / Front Propeller Shaft
Engranaje Conico(Anterior) / Bevel Gear (Front)
Embrague De Bloqueo De Diferencial Delantero / Front Differential Lock Clutch
Adelante Eje / Front Axle
Diferencial Eje Del Engranaje / Differential Gear Shaft
Direccion Controlador[Componente Piezas] / Steering Controller [Component Parts]
Direccion Varillaje / Tie Rod/Steering Cylinder
Valvula Reguladora / Regulater Valve
Regulador Valvula[Componente Piezas] / Regulater Valve [Component Parts]
Hidraulico Aceite Linea (Aspiracion) / Hydraulic Pipe (Suction)
Hidraulico Aceite Linea(Entrega) / Hydraulic Pipe (Delivery)
Hidraulico Tubo(Remolque Freno) / Hydraulic Pipe (Trailer Brake)
Pipa Hidraulica / Hydraulic Oil Line
Remolque Freno Valvula / Trailer Brake Valve
Linea De Aceite Hidraulico Radiador De Aceite / Oil Cooler
Hidraulico Aceite Linea (Valvula De Doble Velocidad)[Ec][Uk] / Hydraulic Oil Line (Dual Speed Valve)
Linea De Aceite Hidraulico(Direccion/Tdf)[Tipo Cabina] / Hydraulic Oil Line (Steering/Pto)
Latiguillo De Direccion(Impulsion)[Tipo Arco] / Steering Hose (Delivery)
Piston Hidraulico/Brazo De Elevacion / Hydraulic Lift Arm
Cubierta De Cilindro Hidraulico / Hydraulic Cylinder Cover
Coloque La Palanca De Mando (Distancia 3p) / Position(3p Remote) Control Lever
Palanca De Control De Esfuerzo Y Posicion / Draft And Position Control Lever
Esfuerzo Y Posicion Control Palanca Soporte / Draft And Position Control Lever Bracket
Posicion Y Esfuerzo Eje / Position And Draft Shaft
Posicion Leva / Position Cam
Esfuerzo Leva / Draft Cam
Alejado Contorol Valvula [Antiguo] / Auxiliary Control Valve [Old]
Distribuidor De Servicios Externos [Nuevo] / Auxiliary Control Valve [New]
Distribuidor De Servicios Externos (S/D) [Componente Piezas] [Antiguo] / Auxiliary Control Valve (S/D) [Component Parts] [Old]
Distribuidor De Servicios Externos (Fd) [Componente Piezas] [Antiguo] / Auxiliary Control Valve (Fd) [Component Parts] [Old]
Distribuidor De Servicios Externos (Fd) [Componente Piezas] [Nuevo] / Auxiliary Control Valve (Fd) [Component Parts] [New]
Palanca De Distribuidor De Servicios Externos / Auxiliary Control Valve Lever
Soporte De Tercer Punto / Top Link Bracket
Bajar Vinculo / Lower Link [Old Type]
Bajar Vinculo / Lower Link [New Type]
Estabilizador / Stabilizer
Varilla De Elevacion Dcha[Tipo Antiguo] / Lift Rod Rh [Old Type]
Varilla De Elevacion Dcha[Tipo Antiguo] / Lift Rod Rh [New Type]
Varilla De Elevacion Izqd[Tipo Nuevo] / Lift Rod Lh [Old Type]
Varilla De Elevacion Izqd[Tipo Nuevo] / Lift Rod Lh [New Type]
Ayudar Cilindro Soporte / Drawbar Bracket [Except [G]]
Protector De Eje De Tdf [Fr] [G] [Sp] [Pog] / Pto Shaft Protector [Ec] [Fr] [Pog]
Protector De Eje De Tdf [Fr] [G] [Sp] [Pog] / Pto Shaft Protector [Uk]
Capo / Hood(Bonnet) Upper
Tapa Lateral De Capo[Tipo Arco] / Hood(Bonnet) Side Cover
Soporte De Capo / Bonnet Support
Bastidor De Cabina [Ec] [Fr] [Pog] / Cab Frame [Ec] [Fr] [Pog]
Bastidor De Cabina [Ec] [Fr] [Pog] / Cab Frame [Uk]
Panel Frame
Adelante Vidrio / Front Glass
Puerta Derecho / Door Rh
Puerta Izqd / Door Lh
Cerradura De Puerta Izqd / Door Lock Lh
Lado Vidrio / Side Window
Trasero Ventana (Superior) [Tipo Cabina] / Rear Window (Upper)
Trasero Ventana (Baje) [Tipo Cabina] / Rear Window (Lower)
Techo Interior / Inner Roof
Externo Techo / Outer Roof
Asiento / Seat [Ec] [Fr] [Pog]
Asiento / Seat [Uk]
Alfombrilla De Piso / Floor Mat
Placa De Inspeccion / Inspection Plate
Cubierta De Guardabarros Dcha / Fender Cover Rh
Cubierta De Guardabarros Izqd / Fender Cover Lh
Cubierta De Montante / Pillar Cover
Guardabarros / Fender Rh
Guardabarros Izqd / Fender Lh
Soporte Posterior De Cabina / Cab Bracket Rear / Reflector
Caja De Herramientas / Tool Box
Aire Acondicionado / Air Conditioner
Manguera De Vaciado(Aire Acondicionado)[Tipo Cabina] / Drain Hose (Air Conditioner)
Condensador / Condenser
Aire Acondicionador Manguito/Condensador Manguito / Air Conditioner Hose / Condenser Hose
Compresor / Compressor
Soporte De Compresor / Compressor Bracket
Etiqueta 1 (Delantero) [Fr] / Label 1 (Front)
Etiquetta 2 (Panel) [Ec] [Uk] / Label 2 (Rear) [Ec] [Fr] [Pog]
Etiquetta 2 (Panel) [Ec] [Uk] / Label 2 (Rear) [Uk]
Trasero Limpiaparabrisas Kit(W/G No L8446a)[Cabina Tipo][Opcion] / Rear Wiper Kit [Option]
Combustible Deposito Cubierta Kit[Opcion] / Fuel Tank Cover Kit [Option]
Marcha Muy Lenta Velocidad Kit (Engranaje Caja) [Opcion] / Creep Speed Kit (Gear Case) [Option]
Marcha Muy Lenta Velocidad Kit (Cambio Bfrccn/Plnc) [Opcion] / Creep Speed Kit (Shift Fork/Lever) [Option]
Pto(540/1000)Conversion Kit(Engranaje Caja)[Opcion] / Pto(540/1000) Conversion Kit (Gear Case) [Option]
Pto(540/1000)Conversion Kit(Engranaje)[Opcion] / Pto(540/1000) Conversion Kit (Gear) [Option]
80 Pulgada Ancho De Via Kit[Opcion] / 80 Inch Tread Kit [Option]
Kit De Distribuidor De Servicios Externos (Scd) [Opcion] [Antiguo] / Auxiliary Control Valve Kit (Scd) [Option] [Old]
Kit De Distribuidor De Servicios Externos (Scd) [Opcion] [Nuevo] / Auxiliary Control Valve Kit (Scd) [Option] [New]
Kit De Distribuidor De Servicios Externos (Fd) [Opcion] [Antiguo] / Auxiliary Control Valve Kit (Fd) [Option] [Old]
Kit De Distribuidor De Servicios Externos (Fd) [Opcion] [Nuevo] / Auxiliary Control Valve Kit (Fd) [Option] [New]
Kit De Distribuidor De Servicios Externos (Fc) [Opcion] / Auxiliary Control Valve Kit (Scd/Fc) [Option]
Kit De Distribuidor De Servicios Externos (Fc) [Opcion] / Auxiliary Control Valve Kit (Fc) [Option]
Distribuidor De Servicios Externos (Scd) [Componente Piezas] [Opcion] [Antiguo] / Auxiliary Control Valve (Scd) [Component Parts] [Option] [Old]
Distribuidor De Servicios Externos (Scd) [Componente Piezas] [Opcion] [Nuevo] / Auxiliary Control Valve (Scd) [Component Parts] [Option] [New]
Distribuidor De Servicios Externos (Scd/Fc) [Componente Piezas] [Opcion] [Antiguo] / Auxiliary Control Valve (Scd/Fc) [Component Parts] [Option] [Old]
Distribuidor De Servicios Externos (Scd/Fc) [Componente Piezas] [Opcion] [Nuevo] / Auxiliary Control Valve (Scd/Fc) [Component Parts] [Option] [New]
Distribuidor De Servicios Externos (Fc) [Componente Piezas] [Opcion] / Auxiliary Control Valve (Fc) [Component Parts] [Option]
Kit De Palanca De Distribuidor De Servicios Externos (Tercero) [Tipo Arco] [Opcion] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Ayuder Cilindro Kit Derecho [Fr] [G] [Sp] [Pog] [Opcion] / Assist Cylinder Kit Rh [Option]
Ayuder Cilindro Kit Izquierdo [Fr] [G] [Sp] [Pog] [Opcion] / Assist Cylinder Kit Lh [Option]
Ayuder Cilindro [Componente Piezas] [Fr] [G] [Sp] [Pog] [Opcion] / Assist Cylinder [Component Parts] [Option]
Volante / Flywheel
Actuador / Actuator
Ventilador / Fan
Conmutador / Switch
Freno / Brake
Panel Frame
Asiento / Seat [Uk]
