Kubota Tractor M105GXDTSC24-3 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M105GXDTSC24-3 Tractor
Number of Pages: 397 Pages
Itens Uso Frequ Ente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhaust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Carreto / Gear Case
Piston/Cambota / Piston/Crankshaft
Compensador / Balancer
Volante Motor / Flywheel
Filtro Gasoleo / Fuel Filter
Common Rail / Common Rail
Radiador Oleo / Oil Cooler
Separador De Óleo [Peças Componentes] / Oil Separator [Component Parts]
Tubo Do Separador De Óleo / Oil Separator Pi Pe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Tur Bo Charger)
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [Component Parts]
Tubo De Entrada (Filtro De Ar) / Inlet Pipe (Air Cleaner)
Intercooler / Inter Cooler
Flange Filtro Ar E Valvula Acelarador / Air Cleaner Flange And Throttle Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Partículas Diesel / Diesel Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [ Peças Componentes] / Diesel Particulate Filter Muff Ler [Component Parts]
Suporte (Dpf) / Muffler Bracket (Dpf)
Tubo Pressao / Pressure Pipe
Panela Escape (Filtro Do Filtro De Partícula S Diesel) / Muffler Pipe (Diesel Particulate Filter )
Silenciador Da Redução Catalítica Seletiva / Selective Catalytic Reduction Muffler
Placa De Isolamento (Silenciador Da Redução Catalítica Seletiva) / Insulation Plate (Selective Catalytic Reduction Muffler)
Resguardo Da Redução Catalítica Seletiva / S Elective Catalytic Reduction Cover
Estrutura Da Redução Catalítica Seletiva / S Elective Catalytic Reduction Main Frame
Bomba Do Fluido De Escape De Diesel / Diesel Exhaust Fluid Pump
Depósito Do Fluido De Escape De Diesel / Die Sel Exhaust Fluid Tank
Depósito Do Fluido De Escape De Diesel [Peça S Componentes] / Diesel Exhaust Fluid Tank [Compone Nt Parts]
Componentes Electricos Motor (Sensor/Ecu) / Engine Electrical Parts (Sensor/Ecu)
Componentes Electricos Motor (Panela Escape) / Engine Electrical Parts (Muffler)
Diagmaster / Diagmaster
Suporte Deposito Combu Stivel / Fuel Tank Bracket
Suporte Do Depósito De Combustível / Fuel Tank Support
Deposito Combustivel ( Drt) / Fuel Tank Rh
Deposito Combustivel ( Esq) / Fuel Tank Lh
Tubo Combustivel (Depó Sito Do Fluido De Escape De Diesel De Respiro) / Fu El Pipe (Diesel Exhaust Fluid Breather)
Tubo Combustivel (Depo Sito Combustivel) / Fuel Pipe (Fuel Tank)
Tubo Do Combustível (E Nchimento Do Combustível) / Fuel Pipe (Fuel Filler)
Tubo Combustivel (Depo Sito Combustivel Respiro) / Fuel Pipe (Fuel Tank Br Eather)
Tubo Combustivel (Arre Fecedor Gasoleo) / Fuel Pipe (Fuel Cooler)
Arrefecedor Gasoleo / Fuel Cooler
Separador / Separator
Separador [Peças Compo Nentes] / Separator [Component Parts]
Bomba Gasoleo / Fuel P Ump
Bomba Gasoleo [Peças C Omponentes] / Fuel Pump [Component Parts]
Vent Oinha / Fan
Tubo Agua / Water Pipe
Radi Ador / Radiator
Depo Sito Reserva / Reserve Tank
Alternador / Alternat Or
Alternador [Peças Com Ponentes] / Alternator [Component Parts]
Motor Arranque / Star Ter
Motor Arranque [Peças Componentes] / Starter [Component Parts]
Interruptor/Sensor (B Loco Motor) / Switch/Sensor (Engine)
Interruptor/Sensor (P Anela Escape) / Switch/Sensor (Muffler)
Sensor Da Redução Cat Alítica Seletiva (Bloco Motor) / Selective Catalyti C Reduction Sensor (Engine)
Sensor Da Redução Cat Alítica Seletiva (Corpo) / Selective Catalytic Redu Ction Sensor (Body)
Interruptor/Sensor / Switch/Sensor
Interruptor/Sensor (F Rente ) / Switch/Sensor (Front)
Interruptor/Sensor (C Orpo) [Ec] / Switch/Sensor (Body) [Ec]
Interruptor/Sensor (C Orpo) [Uk] / Switch/Sensor (Body) [Uk]
Interruptor/Sensor (T Raseira) / Switch/Sensor (Rear)
Interruptor (Operação ) / Switch (Operation)
Interruptor Principal / Main Switch/Lever Control Switch
Rele / Relay
Ecu (Bloco Motor) / E Cu (Engine)
Ecu (Corpo) / Ecu (Bo Dy)
Quadro Do Painel / Pa Nel Board
Conta Rotaçoes Tdf/Ve Locimetro / Pto Tachometer/Speedmeter
Painel Control / Cont Rol Panel
Painel Control [Peças Componentes] / Control Panel [Component Parts]
Luzes Frente [Ec] / H Ead Light [Ec]
Luzes Frente [Uk] / H Ead Light [Uk]
Lampada Cabeça [Peças Componentes] [Ec] / Head Light [Component Parts] [ Ec]
Lampada Cabeça [Peças Componentes] [Uk] / Head Light [Component Parts] [ Uk]
Luzes Frontais / Fron T Combination Light
Luzes Trabalho (Frent E) [Ec] / Working Light (Front) [Ec]
Luzes Trabalho (Frent E) [Uk] / Working Light (Front) [Uk]
Farois Trabalho (Tras Eiros) / Working Light (Rear)
Braco Traseiro / Rear Combination Light
Ficha Reboque / Trail Er Socket
Luz Interior / Room L Ight
Radio Cd E Columnas / Cd-Radio And Speaker
Escova / Wiper
Cablagem Electrica (C Rs) / Electrical Wiring (Crs)
Cablagem Electrica (S Cr) / Electrical Wiring (Scr)
Cablagem Electrica (M Otor) / Electrical Wiring (Engine)
Cablagem Electrica (L Uzes Frente) / Electrical Wiring (Head Light)
Cablagem Electrica (P Ainel) / Electrical Wiring (Panel)
Cablagem Electrica (T Raseira) / Electrical Wiring (Rear)
Cablagem Electrica (I Nterruptor 3p) / Electrical Wiring (3p Switch)
Cablagem Electrica (P Ainel Contrl) / Electrical Wiring (Control Panel)
Cablagem Electrica (B Raco) / Electrical Wiring (Armrest)
Cabalagem Eletrica (C Orpo) [Ec] / Electrical Wiring (Body) [Ec]
Cabalagem Eletrica (C Orpo) [Uk] / Electrical Wiring (Body) [Uk]
Cablagem Electrica (V Alvula Suspensão Frontal) / Electrical Wiring (Fron T Suspension Valve)
Cabalagem Eletrica (C Abine) [Ec] / Electrical Wiring (Cab) [Ec]
Cabalagem Eletrica (C Abine) [Uk] / Electrical Wiring (Cab) [Uk]
Carter Embraia Gem / Clutch Housing
Valvula Powers Hift / Power Shift Valve
Valvula Powers Hift (Corpo) [Peças Componentes] / Power Shift Valv E (Body) [Component Parts]
Valvula Powers Hift (Superior) [Peças Componentes] / Power Shift V Alve (Upper) [Component Parts]
Carter Embraia Gem Cambota (Inferior) / Clutch Housing Cover (Lowe R)
Caixa Intermed Ia / Mid Case
Caixa Velocida Des / Transmission Case
Carter Transmi Ssao [Ec] / Transmission Case Rear Cover [Ec]
Carter Transmi Ssao [Uk] / Transmission Case Rear Cover [Uk]
Carter Eixo Tr Aseiro Drt (Tipo Arco) / Rear Axle Case Rh
Carter Eixo Tr Aseiro Esq (Tipo Arco) / Rear Axle Case Lh
Disco Amortece Dor / Damper Disk
Pedal Embraiag Em / Clutch Pedal
Embraiagem / C Lutch Rod
Cobertura Fron Tal / Front Cover
Rolamento Supo Rte / Front Bearing Support
Veio Primario / Input Shaft
Veio Inversor / Shuttle Shaft
Primeira/Segun Da Mudança / First/Second Shift Gear
Primeiro Veio / First Shaft
Carreto Tercei Ra/Quarta / Third/Fourth Shift Gear
Veio Secundari O / Counter Shaft
Engrenagem Pri Ncipal/Veio Gamas Velocidades / Main Gear Shift Sha Ft/Range Gear Shaft
Veio Gamas Vel Ocidades (Frente) / Range Gear Shaft (Front)
Veio Gamas Vel Ocidades (Traseira) / Range Gear Shaft (Rear)
Veio (Frente) / Drive Shaft (Front)
Veio (Meio/Tra Seiro) / Drive Shaft (Middle/Rear)
Caixa De Mudan Ças Alta-Baixa / Hi-Lo Shift Case
Grupo Conico / Bevel Gear
Diferencial Tr Aseiro / Rear Differential
Veio Tdf / Pto Propeller Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf [Peças Componentes] / Pto Clutch [Component Parts]
Valvula Embrai Agem Tdf / Pto Clutch Valve
Valvula Embrai Agem Tdf [Peças Componentes] / Pto Clutch Valve [Co Mponent Parts]
Veio Principal Tdf [Ec] / Pto Drive Shaft [Ec]
Veio Principal Tdf [Uk] / Pto Drive Shaft [Uk]
Veio Tdf [Ec] / Pto Shaft [Ec]
Veio Tdf [Uk] / Pto Shaft [Uk]
Duplicador Vel Ocidade / Bi-Speed Turn Clutch (Bi-Speed Turn)
Veio Bi-Speed / Bi-Speed Turn Shaft
For Queta Velocidades / Range Gear Shift Fork
Alv Anca Tdf [Ec] / Pto Gear Shift Fork [Ec]
Ala Vanca Velocidades / Main Gear Shift Lever
Alv Anca Inversor / Shuttle Shift Lever
Cab O Embraiagem / Range Gear Shift Cable
Ala Vanca Tdf [Ec] / Pto Gear Shift Lever [Ec]
Pedal Bloqueio Dife Rencial Traseiro / Rear Differential Lock Pedal
Eixo Traseiro / Rea R Axle
Travão De Estaciona Mento / Parking Brake
Pedal Travao / Brak E Pedal
Cilindro Travao Pri Ncipal / Brake Master Cylinder
Cilindro Travao Pri Ncipal [Peças Componentes] / Master Cylinder [Compo Nent Parts]
Tubo Travao / Brake Pipe
Tubo Travao / Brake Master Cylinder Pipe
Suporte Eixo Fre Nte / Front Axle Bracket
Veio Primario [P Eças Componentes] / Mid Propeller Shaft [Component Parts]
Caixa Diferencia L Frente / Front Differential Case
Grupo Conico (Fr Ente) / Bevel Gear (Front)
Diferencial Fren Te / Differential Front
Caixas Engrenage Ns Conica Drt / Bevel Gear Case Rh
Caixas Engrenage Ns Conica Esq / Bevel Gear Case Lh
Carter Eixo Fren Te / Front Axle Case
Veio Carreto Dif Erencial / Differential Gear Shaft
Tampa Coluna Direccao / Steering Post C Over
Alavanca / Tilt Lever
Placa Telescopio / Telescope Lever
Distribuidor Direcção / Steering Contro Ller
Distribuidor Direcção [Peças Componente S] / Steering Controller [Component Parts]
Rotula/Cilindro Direcção / Tie Rod/Stee Ring Cylinder
Cilindro Direcção [Peças Componentes] / Steering Cylinder [Component Parts]
Bomba Hidraulico / Hy Draulic Pump
Bomba Hidraulico [Peç As Componentes] / Hydraulic Pump [Component Parts]
Valvula Reguladora / Regulater Valve
Valvula Reguladora [P Eças Componentes] / Regulater Valve [Component Part S]
Circuito Oleo Direcçã O (Sucção) / Hydraulic Oil Line (Suction)
Circuito Oleo Direcçã O (Entrega) / Hydraulic Oil Line (Delivery)
Carregador Dianteiro Tubo / Front Loader Pipe
Tubo Hidraulico / Hyd Raulic Oil Line
Valvula Travao Reboqu E / Trailer Brake Valve
Valvula Segurança / S Afety Valve
Circuito Oleo Hidraul Ico (Bi Speed) / Hydraulic Oil Line (Bi-Speed Turn/ Rear Diff.)
Circuito Oleo Hidraul Ico (Diferencial Frente) / Hydraulic Oil Line (Fron T Differential)
Circuito Oleo Radiado R / Oil Cooler
Circuito Oleo Radiado R (Radiador Oleo) / Hydraulic Oil Line (Oil Cooler)
Circuito Oleo Direcçã O (Direcção/Tdf) / Hydraulic Oil Line (Steering/Pto )
Tubo Direccao (Entreg A) / Steering Hose (Delivery)
Valvula Da Suspensão Frontal / Front Suspension Valve
Valvula Da Suspensão Frontal (Valvula Descarga) [Peças Componentes] / Fr Ont Suspension Valve (Relief/Check) [Component Part S]
Valvula Da Suspensão Frontal (Segurança) [Peças Componentes] / Front Sus Pension Valve (Safety) [Component Parts]
Valvula Da Suspensão Frontal (Junta) [Peças Componentes] / Front Suspens Ion Valve (Joint) [Component Parts]
Tubo Da Suspensão Fro Ntal Valvula / Front Suspension Valve Hose
Cilindro Da Suspensão Frontal / Front Suspension Cylinder
Cilindro Da Suspensão Frontal [Peças Componentes] / Front Suspension Cyl Inder [Component Parts]
Valvula / Branch Flow Valve
Valvula [Peças Compon Entes] / Branch Flow Valve [Component Parts]
Caixa Cilindro Hidrau Lico / Hydraulic Cylinder Case
Casquilho Lampada / V Alve
Base Valvula / Valve Base
Braço De Elevação Hid Ráulico / Hydraulic Lift Arm
Valvula Descarga / Re Lief Valve/Check Valve
Trinco / Lowering Loc K Lever
Barra Deflectora (Bar Ra/Barra Suporte) / Detector Bar (Bar/Bar Support)
Barra Deflectora (Lig Ação) / Detector Bar (Draft Link)
Alavanca Control Posi Cao / Position Control Lever
Valvula Contol Automa Tico / Auto Control Valve
Valvula Control Autom Atico [Peças Componentes] / Auto Control Valve [Com Ponent Parts]
Auxiliar Do Válvula D E Controlo (Com Controlo De Fluxo) / Auxiliary Cont Rol Valve (With Fc) Mounting
Válvula De Controlo A Uxiliar (Com Controlo De Fluxo) / Auxiliary Control Valve (With Fc)
Auxiliar Do Válvula D E Controlo (Com Controlo De Fluxo) [Peças Component Es] / Auxiliary Control Valve (With Fc) Mounting [C Omponent Parts]
Auxiliar Do Válvula D E Controlo [Peças Componentes] (Scd Con Fc) / Auxil Iary Control Valve [Component Parts] (Scd With Fc)
Auxiliar Do Válvula D E Controlo [Peças Componentes] (Fd Con Fc) / Auxili Ary Control Valve [Component Parts] (Fd With Fc)
Auxiliar Do Válvula D E Controlo (Com Controlo De Fluxo) Tampa/Deposito R Eserva / Auxiliary Control Valve (With Fc) Cap/Rese Rve Tank
Auxiliar Do Alavanca De Válvula De Controlo (Com Controlo De Fluxo) / Au Xiliary Control Valve (With Fc)
Fluir Fio De Controle Da Auxiliar Do Valvula De Controlo / Auxiliary Con Trol Flow Control Wire
Cilindro Auxiliar De Elevacao Esq / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De Elevacao Drt / 3p-Lift Assist Cylinder Rh
Cilindro Auxiliar De Elevacao [Peças Componentes] / 3p-Lift Assist Cylin Der [Component Parts]
Parte Superior / Top Link Bracket
Ligacao Superior / Top Link
Ligacao Inferior / Lower Link
Estabilizador / Stabilizer
Estabilizador Drt / Lift Rod Rh
Estabilizador Esq / Lift Rod Lh
Proteccao Tdf [Uk] / Protector [Uk]
Capot (Superior/Isolador) / Hood (Bonne T) (Sound Absorber/Insulator)
Amortecedor Capot / Hood (Bonnet) Dampe R
Trico Capot / Bonnet Lock
Estrutura Capot / Bonnet Frame
Capot Inferior (Direito) / Hood (Bonnet ) Side Lower Rh
Capot Inferior (Esquerdo) / Hood (Bonne T) Side Lower Lh
Estrutura Cabine [Ec] / Cab Frame [Ec]
Estrutura Cabine [Uk] / Cab Frame [Uk]
Vidro Frente / Front Glass
Porta (Direito) / Door Rh
Porta (Esquerdo) / Door Lh
Trinco Porta (Direito) / Door Lock Rh
Vidro Traseiro / Rear Window
Tejadilho / Sun Roof
Espelho Rectrovisor [Uk] / Rearview Mirror [Uk ]
Tecto Interior / Inner Roof
Tecto Abrir / Outer Roof
Banco / Seat
Banco [Peças Componentes] / Seat [Component Pa Rts]
Apoio Braço / Armrest
Banco Passageiro / Instructional Seat
Tapete Do Piso / Floor Mat
Isolante / Soundproof Material
Banco Tapete / Seat Mat
Chapa Inspecção (Frente) / Inspection Plate (F Ront)
Chapa Inspecção (Traseira) / Inspection Plate (Rear)
Cobertura Gurada Lamas (Esquerdo) / Fender Cov Er Lh
Guarda Lamas (Direito) / Fender Rh
Guarda Lamas (Esquerda) / Fender Lh
Suporte Cabine (Frente) / Cab Bracket Front
Suporte Cabine (Traseira) / Cab Bracket Rear
Caixa Ferramenta / Tool Box
Air Condicionado / Air C Onditioner
Cuberto Tubo Air Condici Onado / Air Conditioner Duct Cover
Tubo Ar Condicionado (Fr Ente) / Air Conditioner Duct (Front)
Conduta Do Ar Condiciona Do (Traseira) / Air Conditioner Duct (Rear)
Modo Caixa / Mode Case
Entradas Ar Painel Instr Umentos / Dashboard Air Outlets
Circulaçao Ar Interior / Inner Air Recirculation
Tubo Aquecimento / Heate R Hose
Condesador / Condenser
Tubo Ar Condicionado/Tub O Condensador / Air Conditioner Hose/Condenser Hose
Compressor / Compressor
Suporte Compressor / Com Pressor Bracket
Etiqueta (Traseira/Cabine) / Label (Rear/ Cab)
Acessorios / Acc Essories And Service Parts
Kit Farios Trabalho [Opção] / Working Light Kit [Option]
Kit Farios Trabalho (Trseiros) [Opcao] / Wor King Light Kit (Rear) [Option]
Kit Farios Trabalho (Led) [Opção] / Working Light Kit (Led) [Option]
Kit Farios Trabalho (Trseiros) (Led) [Opcao] / Working Light Kit (Rear) (Led) [Option]
Desempanador [Opção] / Rear Defogger Kit [Op Tion]
Kit Cobertuta Deposito Gasoleo [Opção] / Fue L Tank Cover Kit [Option]
Crepper Kit (Caica De Carretos) [Opção] / Cr Eep Speed Kit (Gear Case) [Option]
Crepper Kit (Forqueta ) [Opção] / Creep Spee D Kit (Shift Fork) [Option]
Crepper Kit (Alavanca) [Opção] / Creep Speed Kit (Lever) [Option]
Kit Conversao Tdf (540/540e) (Engrenagem) [O Pção] / Pto (540/540e) Conversion Kit (Gear) [Optio N]
Auxiliar Do Válvula De Controlo Kit (Scd Con Fc) [Opção] / Auxiliary Control Valve Kit (Scd Wit H Fc) [Option]
Auxiliar Do Válvula De Controlo Kit (Fd Con Fc) [Opção] / Auxiliary Control Valve Kit (Fd With Fc) [Option]
Auxiliar Do Alavanca De Válvula De Controlo Kit (Com Controlo De Fluxo) (Terceiro) [Opção] / Au Xiliary Control Valve Kit (With Fc) (3rd) [Option]
Auxiliar Do Alavanca De Válvula De Controlo Kit (Com Controlo De Fluxo) (Quarto) [Opção] / Auxi Liary Control Valve Kit (With Fc) (4th) [Option]
Protetor De Para-Sol [Opção] / Sunshade Shie Ld Kit [Option]
Carreto / Gear Case
Vent Oinha / Fan
Rele / Relay
Escova / Wiper
Banco / Seat
