Kubota Tractor M-120DTC Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M-120DTC Tractor
Number of Pages: 841 Pages
Bloque Motor [Tipo Antiguo] / Crankcase [Old Type]
Bloque Motor[Tipo Nuevo] / Crankcase [New Type]
Aceite Cacerola / Oil Pan
Culata [Tipo Antiguo] / Cylinder Head [Old Type]
Culata [Tipo Nuevo] / Cylinder Head [New Type]
Caja De Engranajes [Tipo Antiguo] / Gear Case [Old Type]
Caja De Engranajes [Tipo Nuevo] / Gear Case [New Type]
Culata Cubierta / Head Cover
Aceite Bomba / Oil Pump
Combustible Bomba Base / Fuel Pump Base
Respiradero [Tipo Antiguo] / Breather [Old Type]
Respiradero [Tipo Nuevo] / Breather [New Type]
Descarga Valvula / Relief Valve
Piston Y Ciguenal [Tipo Antiguo] / Piston And Crankshaft [Old Type]
Piston Y Ciguenal [Tipo Nuevo] / Piston And Crankshaft [New Type]
Volante / Flywheel
Bomba De Inyeccion [Tipo Antiguo] / Injection Pump [Old Type]
Bomba De Inyeccion [Tipo Nuevo] / Injection Pump [New Type]
Bomba De Inyeccion [Componentes] [Tipo Antiguo] / Injection Pump [Component Parts] [Old Type]
Bomba De Inyeccion [Componentes] [Tipo Nuevo] / Injection Pump [Component Parts] [New Type]
Portainyector Y Bujia De Calentamiento [Tipo Antiguo] / Nozzle Holder And Glow Plug [Old Type]
Tobera Soporte Y Bujia De Calentamiento Tapon / Nozzle Holder And Glow Plug [New Type]
Portainyector [Componentes] [Tipo Antiguo] / Nozzle Holder [Component Parts] [Old Type]
Combustible Control Motor / Fuel Control Motor
Filtro De Combustible [Tipo Antiguo] / Fuel Filter [Old Type]
Filtro De Combustible [Tipo Nuevo] / Fuel Filter [New Type]
Agua Bomba / Water Pump
Filtro De Aire [Ue] / Air Cleaner [Eu]
Filtro De Aire [Excepto [Ue]] / Air Cleaner [Except [Eu]]
Aire Limpiador[Componente Piezas] / Air Cleaner [Component Parts]
Prefiltro[Excepto[Ue]][Tipo Antiguo] / Pre-Cleaner [Except [Eu]] [Old Type]
Prefiltro[Excepto[Ue]][Tipo Nuevo] / Pre-Cleaner [Except [Eu]] [New Type]
Entrada Tubo / Inlet Pipe
Silenciador [Tipo Antiguo] / Muffler [Old Type]
Silenciador[Tipo Nuevo] / Muffler [New Type]
Turbocompresor [Componentes] [Tipo Antiguo] / Turbo Charger [Component Parts] [Old Type]
Turbocompresor [Componentes] [Tipo Nuevo] / Turbo Charger [Component Parts] [New Type]
Aceite Tubo(Turbo Cargador) / Oil Pipe (Turbo Charger)
Hidraulico Bomba Base / Hydraulic Pump Base
Kit De Juntas Superior [Tipo Antiguo] / Upper Gasket Kit [Old Type]
Kit De Juntas Superior [Tipo Nuevo] / Upper Gasket Kit [New Type]
Bajar Junta Kit / Lower Gasket Kit [Old Type]
Bajar Junta Kit / Lower Gasket Kit [New Type]
Mano Acelerador Palanca / Hand Accelerator Lever
Acelerador Cable / Accelerator Wire
Motor Parar Cable / Engine Stop Wire
Combustible Deposito Derecho / Fuel Tank Rh
Combustible Deposito Izquierdo / Fuel Tank Lh
Combustible Tubo / Fuel Pipe
Sedimentario / Sedimenter
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Alternador [Componentes] [Tipo Antiguo] / Alternator [Component Parts] [Old Type]
Alternador [Componentes] [Tipo Nuevo] / Alternator [Component Parts] [New Type]
Motor De Arranque / Starter
Conmutador/Sensor 1 (Motor) / Switch/Sensor 1 (Engine)
Conmutador/Sensor 2 [Tipo Antiguo] / Switch/Sensor 2 [Old Type]
Conmutador/Sensor 2 [Tipo Nuevo] / Switch/Sensor 2 [New Type]
Conmutador(Panel Tablero) / Switch (Panel Board)
Conmutador (Cabina) / Switch (Cab)
Rele / Relay
Tablero Panel / Panel Board
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
3-Punto Enganche Control Panel / 3-Point Hitch Control Panel
3-Punto Enganche Control Panel[Componente Piezas] / 3-Point Hitch Control Panel [Component Parts]
Ascenso Brazo Sensor / Lift Arm Sensor
Sensor De Acelerador [Tipo Antiguo] / Accelerator Sensor [Old Type]
Sensor De Acelerador [Tipo Nuevo] / Accelerator Sensor [New Type]
Culata Luz / Head Light
Luz Intermitente[Tipo Arco] / Flasher Light [Old Type]
Luz Intermitente[Tipo Arco] / Flasher Light [New Type]
Trabajo Luz / Work Light
Trasero Combinacion Luz / Rear Combination Light
Radio Cassette
Limpiaparabrisas [Tipo Antiguo] / Wiper [Old Type]
Limpiaparabrisas [Tipo Nuevo] / Wiper [New Type]
Cableado Electrico 1 [Tipo Antiguo] / Electrical Wiring 1 [Old Type]
Cableado Electrico 1 [Tipo Nuevo] / Electrical Wiring 1 [New Type]
Cableado Electrico 2 [Tipo Antiguo] / Electrical Wiring 2 [Old Type]
Cableado Electrico 2 [Tipo Nuevo] / Electrical Wiring 2 [New Type]
Cableado Electrico (Cabina) [Tipo Antiguo] / Electrical Wiring (Cab) [Old Type]
Cableado Electrico (Cabina) [Tipo Nuevo] / Electrical Wiring (Cab) [New Type]
Potencia Cambio Valvula / Power Shift Valve
Potencia Cambio Valvula(Carroceria)[Componente Piezas] / Power Shift Valve (Body) [Component Parts]
Potencia Cambio Valvula(Superior)[Componente Piezas] / Power Shift Valve (Upper) [Component Parts]
Embrague Carcasa Cubierta / Clutch Housing Cover
Intermedia Caja / Mid Case
Pto Embrague Valvula / Pto Clutch Valve
Pto Embrague Valvula [Componente Piezas] / Pto Clutch Valve [Component Parts]
Transmision Caja Trasero Cubierta / Transmission Case Rear Cover
Trasero Eje Caja / Rear Axle Case
Freno Caja / Brake Case
Embrague Varilla / Clutch Rod
Engranaje Soporte / Gear Support
Entrada Eje / Input Shaft
Inversor Eje / Shuttle Shaft
Primero/Segundo Cambio Engranaje / First/Second Shift Gear
Primero Eje / First Shaft
Tercero/Cuarto Cambio Engranaje / Third/Fourth Shift Gear
Arbol Contrarrotante / Countershaft
Principal Engranaje Cambio Eje Y Gama Engranaje Eje / Main Gear Shift Shaft And Range Gear Shaft
Accionar Eje(Adelante) / Drive Shaft (Front)
Accionar Eje(Medio/Trasero) / Drive Shaft (Middle/Rear)
Transmision Caja Lado Cubierta / Transmission Case Side Cover
Bisel Engranaje / Bevel Gear
Diferencial Trasero / Differential Rear
Trasero Diferencial Cerradura Embrague / Rear Differential Lock Clutch
Pto Helice Eje / Pto Propeller Shaft
Tdf Embrague / Pto Clutch
Embrague De Tdf [Componentes] [Tipo Nuevo] / Pto Clutch [Component Parts] [Old]
Pto Embrague [Componente Piezas] / Pto Clutch [Component Parts] [Old]
Pto Embrague [Componente Piezas] / Pto Clutch [Component Parts] [New]
Pto Accionar Eje / Pto Drive Shaft
Pto Eje / Pto Shaft
Hidraulico Embrague(Bi-Velocidad Girar) / Hydraulic Clutch (Bi-Speed Turn)
Bi-Velocidad Girar Eje / Bi-Speed Turn Shaft
Palanca De Cambio De Inversor [Tipo Antiguo] / Shuttle Shift Lever [Old Type]
Palanca De Cambio De Inversor [Tipo Nuevo] / Shuttle Shift Lever [New Type]
Gama Engranaje Cambio Varilla / Range Gear Shift Rod
Pto Embrague Palanca / Pto Clutch Lever
Pto Engranaje Cambio Palanca / Pto Gear Shift Lever
Eje Trasero / Rear Axle
Freno Pedal / Brake Pedal
Trasero Diferencial Cerradura Pedal / Rear Differential Lock Pedal
Estacionamiento Freno / Parking Brake
Freno Aceite Deposito / Brake Oil Tank
Freno Maestro Cilindro[Componente Piezas] / Brake Master Cylinder [Component Parts]
Freno Tubo / Brake Pipe
Adelante Eje Soporte / Front Axle Bracket [Eu]
Adelante Eje Soporte / Front Axle Bracket [Except [Eu]]
Adelante Eje Soporte / Front Axle Support
Adelante Helice Eje / Front Propeller Shaft
Bisel Engranaje(Adelante) / Bevel Gear (Front)
Adelante Diferencial Cerradura Embrague / Front Differential Lock Clutch
Caja De Engranaje Conico Dcha [Ue] / Bevel Gear Case Rh [Eu]
Caja De Engranaje Conico Dcha [Excepto [Ue]] / Bevel Gear Case Rh [Except [Eu]]
Caja De Engranaje Conico Izqd [Ue] / Bevel Gear Case Lh [Eu]
Caja De Engranaje Conico Izqd [Excepto[Ue]] / Bevel Gear Case Lh [Except [Eu]]
Adelante Eje / Front Axle
Diferencial Eje Del Engranaje / Differential Gear Shaft
Mango De Direccion [Tipo Antiguo] / Steering Handle [Old Type]
Mango De Direccion [Tipo Nuevo] / Steering Handle [New Type]
Direccion Junta / Steering Joint
Direccion Controlador[Componente Piezas] / Steering Controller [Component Parts]
Atar Varilla / Tie Rod
Hidraulico Bomba(Direccion) / Hydraulic Pump (Steering)
Hidraulico Bomba(Direccion)[Componente Piezas] / Hydraulic Pump (Steering) [Component Parts]
Hidraulico Tubo(Aspiracion) / Hydraulic Pipe (Suction)
Hidraulico Tubo(Entrega) / Hydraulic Pipe (Delivery)
Remolque Freno Valvula / Trailer Brake Valve
Seguridad Valvula / Safety Valve
Hidraulico Aceite Linea(Bi-Velocidad Girar/Trasero Dfrncl) / Hydraulic Oil Line (Bi-Speed Turn/Rear Diff.)
Hidraulico Aceite Linea(Adelante Diferencial) / Hydraulic Oil Line (Front Differential)
Radiador De Aceite [Tipo Antiguo] / Oil Cooler [Old Type]
Radiador De Aceite [Tipo Nuevo] / Oil Cooler [New Type]
Hidraulico Aceite Linea(Aceite Refrigerador) / Hydraulic Oil Line (Oil Cooler)
Hidraulico Aceite Linea(Direccion/Pto) / Hydraulic Oil Line (Steering/Pto)
Direccion Manguito(Entrega) / Steering Hose (Delivery)
Hidraulico Ascenso Brazo / Hydraulic Lift Arm
Hidraulico Cilindro Cubierta / Hydraulic Cylinder Cover
Descenso Cerradura Palanca / Lowerring Lock Lever
Esfuerzo Control Valvula / Draft Control Valve
Esfuerzo Control Valvula[Componente Piezas] / Draft Control Valve [Component Parts]
Detector Barra 1(Barra/Barra Soporte) / Detector Bar 1 (Bar/Bar Support)
Detector Barra 2(Esfuerzo Vinculo) / Detector Bar 2 (Draft Link)
Distribuidor De Servicios Externos[Ue] / Auxiliary Control Valve [Eu]
Distribuidor De Servicios Externos[Excepto[Ue]] / Auxiliary Control Valve [Except [Eu]]
Distribuidor De Servicios Externos (Scd/Fc) [Ue] [Componentes] / Auxiliary Control Valve (Scd/Fc) [Eu] [Component Parts]
Distribuidor De Servicios Externos(Fd)[Componente Piezas] / Auxiliary Control Valve (Fd) [Component Parts]
Distribuidor De Servicios Externos (Scd) [Componentes] / Auxiliary Control Valve (Scd) [Component Parts]
Tubo De Distribuidor De Servicios Externos [Ue] / Auxiliary Control Valve Pipe [Eu]
Tubo De Distribuidor De Servicios Externos [Excepto [Ue]] / Auxiliary Control Valve Pipe [Except [Eu]]
Palanca De Distribuidor De Servicios Externos[Ue] / Auxiliary Control Valve Lever [Eu]
Palanca De Distribuidor De Servicios Externos[Excepto[Ue]] / Auxiliary Control Valve Lever [Except [Eu]]
Ayudar Cilindro Izquierdo [Uk] / Assist Cylinder Lh [Old Type]
Cilindro Auxiliar Izqd [Tipo Nuevo] / Assist Cylinder Lh [New Type]
Ayudar Cilindro Derecho [Uk] / Assist Cylinder Rh [Old Type]
Ayudar Cilindro Derecho / Assist Cylinder Rh [New Type]
Ayudar Cilindro [Componente Piezas] / Assist Cylinder [Component Parts] [Old Type]
Cilindro Auxiliar [Componentes] [Tipo Nuevo] / Assist Cylinder [Component Parts] [New Type]
Tercer Punto [Ue] [Tipo Antiguo] / Top Link [Eu] [Old Type]
Tercer Punto [Ue] [Tipo Nuevo] / Top Link [Eu] [New Type]
Tercer Punto [Excepto [Ue]] [Tipo Antiguo] / Top Link [Except [Eu]] [Old Type]
Tercer Punto [Excepto [Ue]] [Tipo Nuevo] / Top Link [Except [Eu]] [New Type]
Barra De Tiro [Ue] [Tipo Antiguo] / Lower Link [Eu] [Old Type]
Barra De Tiro [Excepto [Ue]] [Tipo Antiguo] / Lower Link [Except [Eu]] [Old Type]
Barra De Tiro [Tipo Nuevo] / Lower Link [New Type]
Varilla De Elevacion Dcha [Ue] [Tipo Antiguo] / Lift Rod Rh [Eu] [Old Type]
Varilla De Elevacion Dcha [Ue] [Tipo Nuevo] / Lift Rod Rh [Eu] [New Type]
Varilla De Elevacion Dcha [Excepto [Ue]] [Tipo Antiguo] / Lift Rod Rh [Except [Eu]] [Old Type]
Varilla De Elevacion Dcha [Excepto [Ue]] [Tipo Nuevo] / Lift Rod Rh [Except [Eu]] [New Type]
Mango De Tirante De Elevacion [Excepto [Ue]] / Lift Rod Handle [Except [Eu]]
Barra De Remolque / Drawbar
Capo Anterior[Tipo Antiguo] / Hood(Bonnet) Front [Old Type]
Capo Anterior [Tipo Nuevo] / Hood(Bonnet) Front [New Type]
Capo Superior [Ue] [Tipo Antiguo] / Hood(Bonnet) Upper [Eu] [Old Type]
Capo Superior [Ue] [Tipo Nuevo] / Hood(Bonnet) Upper [Eu] [New Type]
Capo Superior [Excepto [Ue]] [Tipo Antiguo] / Hood(Bonnet) Upper [Except [Eu]] [Old Type]
Capo Superior [Excepto [Ue]] [Tipo Nuevo] / Hood(Bonnet) Upper [Except [Eu]] [New Type]
Capo Lateral Superior [Tipo Antiguo] / Hood(Bonnet) Side Upper [Old Type]
Capo Lateral Superior [Tipo Nuevo] / Hood(Bonnet) Side Upper [New Type]
Adelante Poste/Trasero Poste / Front Post/Rear Post
Capo Lateral Inferior [Tipo Antiguo] / Hood(Bonnet) Side Lower [Old Type]
Capo Lateral Inferior [Tipo Nuevo] / Hood(Bonnet) Side Lower [New Type]
Capo(Capo)Trasero / Hood(Bonnet) Rear
Guardabarros Delantero[Ue][Tipo Antiguo] / Front Fender [Eu] [Old Type]
Bastidor De Cabina [Ue] / Cab Frame [Eu]
Bastidor De Cabina [Excepto [Ue]] / Cab Frame [Except [Eu]]
Adelante Vidrio / Front Glass
Puerta Derecho / Door Rh
Puerta Izqd / Door Lh
Cerradura De Puerta Izqd / Door Lock Lh
Lado Ventana / Side Window
Trasero Ventana / Rear Window
Vista Posterior Espejo / Rearview Mirror [Eu]
Vista Posterior Espejo / Rearview Mirror [Except [Eu]]
Interno Techo / Inner Roof
Techo Exterior [Tipo Antiguo] / Outer Roof [Old Type]
Techo Exterior [Tipo Nuevo] / Outer Roof [New Type]
Asiento [Excepto [Ue] [Gr]] / Seat [Except [Eu] [Gr]]
Alfombrilla De Piso [Tipo Antiguo] / Floor Mat [Old Type]
Alfombrilla De Piso [Tipo Nuevo] / Floor Mat [New Type]
Inspeccion Placa / Inspection Plate
Cambio Palanca Guia / Shift Lever Guide
Cambio Palanca Guia Poste / Shift Lever Guide Post
Guardabarros Cubierta / Fender Cover
Guardabarros Izquierdo / Fender Lh
Barandilla / Balustrade
Herramienta Caja / Tool Box
Controlador De Aire Acondicionado [Tipo Antiguo] / Air Conditioner Controller [Old Type]
Controlador De Aire Acondicionado [Tipo Nuevo] / Air Conditioner Controller [New Type]
Aire Acondicionador Conducto / Air Conditioner Duct
Motor Del Ventilador [Tipo Antiguo] / Blower Motor [Old Type]
Motor Del Ventilador [Tipo Nuevo] / Blower Motor [New Type]
Condensador [Ue] [Tipo Antiguo] / Condenser [Eu] [Old Type]
Condensador [Ue] [Tipo Nuevo] / Condenser [Eu] [New Type]
Condensador [Excepto [Ue]] [Tipo Antiguo] / Condenser [Except [Eu]] [Old Type]
Condensador [Excepto [Ue]] [Tipo Nuevo] / Condenser [Except [Eu]] [New Type]
Compresor [Tipo Antiguo] / Compressor [Old Type]
Compresor[Tipo Nuevo] / Compressor [New Type]
Soporte De Compresor [Tipo Antiguo] / Compressor Bracket [Old Type]
Soporte De Compresor [Tipo Nuevo] / Compressor Bracket [New Type]
Aire Acondicionador Tubo / Air Conditioner Pipe
Vaciar Manguito / Drain Hose
Etiqueta 1 [Tipo Antiguo] / Label 1 [Old Type]
Etiqueta 1 [Tipo Nuevo] / Label 1 [New Type]
Etiqueta 2 (Viejo) / Label 2 [Old Type]
Etiqueta 2 (Nuevo) / Label 2 [New Type]
Kit De Prefiltro[Ue][Opcion][Tipo Antiguo] / Pre-Cleaner Kit [Eu] [Option] [Old Type]
Kit De Prefiltro[Ue][Opcion][Tipo Nuevo] / Pre-Cleaner Kit [Eu] [Option] [New Type]
Accelerator Sensor Kit [Option]
Trasero Desempanador Kit[Opcion] / Rear Defogger Kit [Option]
Marcha Muy Lenta Velocidad Kit 1(Engranaje Caja)[Opcion] / Creep Speed Kit 1 (Gear Case) [Option]
Marcha Muy Lenta Velocidad Kit 2(Cambio Bfrccn/Plnc)[Op] / Creep Speed Kit 2 (Shift Fork/Lever) [Option]
Adelante Parachoques Kit[Opcion] / Front Bumper Kit [Eu] [Option]
Auxiliar Control Valvula Kit[Opcion] / Auxiliary Control Valve Kit (Scd) (3rd) [Except [Eu]] [Option]
Kit De Distribuidor De Servicios Externos(Fd)(Tercero)[Opcion] / Auxiliary Control Valve Kit (Fd) (3rd) [Option]
Auxiliar Control Valvula Kit[Opcion] / Auxiliary Control Valve Kit (Scd) (4th) [Option]
Auxiliar Control Valvula Kit[Opcion] / Auxiliary Control Valve Kit (Scd/Fc) (4th) [Option]
Kit De Distribuidor De Servicios Externos(Fd)(Cuarto)[Opcion] / Auxiliary Control Valve Kit (Fd) (4th) [Option]
Auxiliar Control Valvula Kit[Opcion] / Auxiliary Control Valve Kit (Fc) [Option]
Distribuidor De Servicios Externos (Scd) [Componentes] [Opcion] / Auxiliary Control Valve (Scd) [Component Parts] [Option]
Distribuidor De Servicios Externos (Scd/Fc) [Componentes] [Opcion] / Auxiliary Control Valve (Scd/Fc) [Component Parts] [Option]
Distribuidor De Servicios Externos(Fd)[Componente Piezas][Opcion] / Auxiliary Control Valve (Fd) [Component Parts] [Option]
Distribuidor De Servicios Externos (Fc) [Componentes] [Opcion] / Auxiliary Control Valve (Fc) [Component Parts] [Option]
Kit De Palanca De Distribuidor De Servicios Externos (Tercero) [Opcion] / Auxilairy Control Valve Lever Kit (3rd) [Option]
Kit De Palanca De Distribuidor De Servicios Externos (Cuarto) [Opcion] / Auxilairy Control Valve Lever Kit (4th) [Option]
Kit De Guardabarros Delantero[Excepto[Ue]][Opcion] / Front Fender Kit [Except [Eu]] [Option]
Volante / Flywheel
Ventilador / Fan
Rele / Relay
Radio Cassette
Pto Eje / Pto Shaft
