Kubota Tractor M-120DTC Australia Parts Catalog
Model: Kubota M-120DTC Tractor
Region: Australia
Number of Pages: 751 Pages
Engine Crankcase [Old Type] ## S.No. =2z0571
Engine Crankcase [New Type] ## S.No. =3a0001
Engine Oil Pan
Engine Cylinder Head [Old Type] ## S.No. =2z0571
Engine Cylinder Head [New Type] ## S.No. =3a0001
Engine Gear Case [Old Type] ## S.No. =2z0571
Engine Gear Case [New Type] ## S.No. =3a0001
Engine Head Cover
Engine Oil Pump
Engine Fuel Pump Base
Engine Breather [Old Type] ## S.No. =2z0571
Engine Breather [New Type] ## S.No. =3a0001
Engine Relief Valve
Engine Main Bearing Case
Engine Camshaft And Idle Gear Shaft
Engine Piston And Crankshaft [Old Type] ## S.No. =2z0571
Engine Piston And Crankshaft [New Type] ## S.No. =3a0001
Engine Flywheel
Engine Injection Pump [Old Type] ## S.No. =2z0571
Engine Injection Pump [New Type] ## S.No. =3a0001
Engine Injection Pump [Component Parts] [Old Type] ## S.No. =2z0571
Engine Injection Pump [Component Parts] [New Type] ## S.No. =3a0001
Engine Nozzle Holder And Glow Plug [Old Type] ## S.No. =2z0571
Engine Nozzle Holder And Glow Plug [New Type] ## S.No. =3a0001
Engine Nozzle Holder [Component Parts] [Old Type] ## S.No. =2z0571
Engine Fuel Control Motor
Engine Fuel Filter [Old Type] ## S.No. =2z0571
Engine Fuel Filter [New Type] ## S.No. =3a0001
Engine Fuel Filter [Component Parts]
Engine Water Flange And Thermostat
Engine Water Pump
Engine Valve And Rocker Arm
Engine Inlet Manifold
Engine Exhaust Manifold
Engine Air Cleaner
Engine Air Cleaner [Component Parts]
Engine Pre-Cleaner [Old Type] ## S.No. =50621
Engine Pre-Cleaner [New Type] ## S.No. =50622
Engine Inlet Pipe
Engine Muffler [Old Type] ## S.No. =50621
Engine Muffler [New Type] ## S.No. =50622 [Note Order By Ref.No
Engine Turbo Charger
Engine Turbo Charger [Component Parts] [Old Type] ## S.No. =3q9655 S.No.; =3q9655
Engine Turbo Charger [Component Parts] [New Type] ## S.No. =3s0001
Engine Oil Pipe (Turbo Charger)
Engine Hydraulic Pump Base
Engine Upper Gasket Kit [Old Type] ## S.No. =2z0571
Engine Upper Gasket Kit [New Type] ## S.No. =3a0001
Engine Lower Gasket Kit [Old Type] ## S.No. =2z0571
Engine Lower Gasket Kit [New Type] ## S.No. =3a0001
Engine Hand Accelerator Lever
Engine Accelerator Pedal
Engine Accelerator Wire
Engine Engine Stop Wire
Fuel System Fuel Tank Rh
Fuel System Fuel Tank Lh
Fuel System Fuel Pipe
Fuel System Sedimenter
Fuel System Separator [Component Parts]
Cooling Water System Fan
Cooling Water System Water Pipe
Cooling Water System Radiator
Cooling Water System Reserve Tank
Electrical System Alternator
Electrical System Alternator [Component Parts] [Old Type] ## S.No. =50621
Electrical System Alternator [Component Parts] ## S.No. =50622
Electrical System Starter
Electrical System Starter [Component Parts]
Electrical System Battery
Electrical System Switch Sensor 1
Electrical System Switch Sensor 2 [Old Type] ## S.No. =69999
Electrical System Switch Sensor 2 [New Type] ## S.No. =70001
Electrical System Switch (Panel Board)
Electrical System Relay
Electrical System Panel Board
Electrical System Panel Board [Component Parts]
Electrical System 3-Point Hitch Control Panel
Electrical System 3-Point Hitch Control Panel [Component Parts]
Electrical System Lift Arm Sensor
Electrical System Accelerator Sensor [Old Type] ## S.No. =69999
Electrical System Accelerator Sensor [New Type] ## S.No. =70001
Electrical System Head Light
Electrical System Flasher Light [Old Type] ## S.No. =70707
Electrical System Flasher Light [New Type] ## S.No. =70708
Electrical System Work Light
Electrical System Rear Combination Light
Electrical System Radio Cassette
Electrical System Washer Tank
Electrical System Wiper [Old Type] ## S.No. =50924
Electrical System Wiper [New Type] ## S.No. =50925
Electrical System Electrical Wiring 1 [Old Type] ## S.No. =50621
Electrical System Electrical Wiring 1 [Old Type] ## S.No. =50622
Electrical System Electrical Wiring 1 [New Type] ## S.No. =70001
Electrical System Electrical Wiring 2 [Old Type] ## S.No. =50621
Electrical System Electrical Wiring 2 [New Type] ## S.No. =50622
Electrical System Electrical Wiring (Cab) [Old Type] ## S.No. =50621
Electrical System Electrical Wiring (Cab) [New Type] ## S.No. =50622
Clutch Transmission Clutch Housing
Clutch Transmission Power Shift Valve
Clutch Transmission Power Shift Valve (Body) [Component Parts]
Clutch Transmission Power Shift Valve (Upper) [Component Parts]
Clutch Transmission Clutch Housing Cover
Clutch Transmission Mid Case
Clutch Transmission Transmission Case
Clutch Transmission PTO Clutch Valve
Clutch Transmission PTO Clutch Valve [Component Parts]
Clutch Transmission Transmission Case Rear Cover
Clutch Transmission Rear Axle Case
Clutch Transmission Brake Case ## Note Order By Ref.No.030 And 040 New Parts.
Clutch Transmission Damper Disk
Clutch Transmission Clutch Pedal
Clutch Transmission Clutch Rod
Clutch Transmission Front Cover
Clutch Transmission Gear Support
Clutch Transmission Input Shaft [Old Type] ## S.No. =50310
Clutch Transmission Input Shaft [New Type] ## S.No. =50311
Clutch Transmission Shuttle Shaft
Clutch Transmission First Second Shift Gear
Clutch Transmission First Shaft
Clutch Transmission Third Fourth Shift Gear
Clutch Transmission Countershaft
Clutch Transmission Main Gear Shift Shaft And Range Gear Shaft
Clutch Transmission Range Gear Shaft
Clutch Transmission Drive Shaft (Front)
Clutch Transmission Drive Shaft (Middle Rear)
Clutch Transmission Transmission Case Side Cover
Clutch Transmission Bevel Gear
Clutch Transmission Differential Rear
Clutch Transmission Rear Differential Lock Clutch
Clutch Transmission PTO Propeller Shaft
Clutch Transmission PTO Clutch ## Note Order By Ref.No.010 And Fig.No.D27000 Ref.No
Clutch Transmission PTO Clutch [Component Parts] [Old] ## S.No. =50763 [Note Order By Fig.No
Clutch Transmission PTO Clutch [Component Parts] [Old] ## S.No.50764 To 70711 [Note Order By Fig.No
Clutch Transmission PTO Clutch [Component Parts] [New] ## S.No. =70712 S.No.; =70712
Clutch Transmission PTO Drive Shaft
Clutch Transmission PTO Shaft
Clutch Transmission Hydraulic Clutch (Bi-Speed Turn)
Clutch Transmission Bi-Speed Turn Shaft
Speed Change Shift Fork Shift Lever Range Gear Shift Fork
Speed Change Shift Fork Shift Lever Main Gear Shift Lever
Speed Change Shift Fork Shift Lever Shuttle Shift Lever [Old Type] ## S.No. =69999
Speed Change Shift Fork Shift Lever Shuttle Shift Lever [New Type] ## S.No. =70001
Speed Change Shift Fork Shift Lever Range Gear Shift Rod
Speed Change Shift Fork Shift Lever PTO Clutch Lever
Rear Axle Brake Rear Axle
Rear Axle Brake Parking Brake Lever
Rear Axle Brake Brake Pedal
Rear Axle Brake Rear Differential Lock Pedal
Rear Axle Brake Brake Oil Tank
Rear Axle Brake Brake Master Cylinder [Component Parts]
Rear Axle Brake Brake Pipe
Front Axle Chassis Front Axle Bracket
Front Axle Chassis Front Axle Support
Front Axle Chassis Front Propeller Shaft
Front Axle Chassis Front Differential Case
Front Axle Chassis Bevel Gear (Front)
Front Axle Chassis Differential Front
Front Axle Chassis Front Differential Lock Clutch
Front Axle Chassis Bevel Gear Case Rh
Front Axle Chassis Bevel Gear Case Lh
Front Axle Chassis Front Axle Case
Front Axle Chassis Differential Gear Shaft
Steering Steering Handle [Old Type] ## S.No. =51172
Steering Steering Handle [New Type] ## S.No. =70001
Steering Tilt Pedal
Steering Steering Joint
Steering Steering Controller
Steering Steering Controller [Component Parts]
Steering Tie Rod
Steering Steering Cylinder [Component Parts]
Hydraulic System Hydraulic Pump
Hydraulic System Hydraulic Pump [Component Parts]
Hydraulic System Hydraulic Pump (Steering)
Hydraulic System Hydraulic Pump (Steering) [Component Parts]
Hydraulic System Hydraulic Pipe (Suction)
Hydraulic System Hydraulic Pipe (Delivery)
Hydraulic System Safety Valve
Hydraulic System Hydraulic Oil Line (Bi-Speed Turn Rear Diff.)
Hydraulic System Hydraulic Oil Line (Front Differential)
Hydraulic System Oil Cooler [Old Type] ## S.No. =50621
Hydraulic System Oil Cooler [New Type] ## S.No. =50622
Hydraulic System Hydraulic Oil Line (Oil Cooler)
Hydraulic System Hydraulic Oil Line (Steering PTO)
Hydraulic System Steering Hose (Delivery)
Hydraulic System Hydraulic Cylinder
Hydraulic System Hydraulic Lift Arm
Hydraulic System Hydraulic Cylinder Cover
Hydraulic System Lowerring Lock Lever
Hydraulic System Draft Control Valve
Hydraulic System Draft Control Valve [Component Parts]
Hydraulic System Detector Bar 1 (Bar Bar Support) ## Note Order By Ref.No
Hydraulic System Detector Bar 2 (Draft Link)
Hydraulic System Auxiliary Control Valve
Hydraulic System Auxiliary Control Valve (Fd) [Component Parts]
Hydraulic System Auxiliary Control Valve (Scd) [Component Parts]
Hydraulic System Auxiliary Control Valve Pipe
Hydraulic System Auxiliary Control Valve Lever
Hydraulic System Assist Cylinder Lh [Old Type] ## S.No. =70008
Hydraulic System Assist Cylinder Lh [New Type] ## S.No. =70009
Hydraulic System Assist Cylinder Rh [Old Type] ## S.No. =70008
Hydraulic System Assist Cylinder Rh [New Type] ## S.No. =70009
Hydraulic System Assist Cylinder [Component Parts] [Old Type] ## S.No. =70008
Hydraulic System Assist Cylinder [Component Parts] [New Type] ## S.No. =70009
3-Point Linkage Drawbar Hitch Top Link
3-Point Linkage Drawbar Hitch Lower Link
3-Point Linkage Drawbar Hitch Check Chain
3-Point Linkage Drawbar Hitch Lift Rod Rh [Old Type] ## S.No. =50621
3-Point Linkage Drawbar Hitch Lift Rod Rh [New Type] ## S.No. =50622
3-Point Linkage Drawbar Hitch Lift Rod Lh
3-Point Linkage Drawbar Hitch Lift Rod Handle
3-Point Linkage Drawbar Hitch Swinging Drawbar [Old Type] ## S.No. =69999
3-Point Linkage Drawbar Hitch Swinging Drawbar [New Type] ## S.No. =70001
3-Point Linkage Drawbar Hitch PTO Shaft Protector [Old Type] ## S.No. =69999
3-Point Linkage Drawbar Hitch PTO Shaft Protector [New Type] ## S.No. =70001
Hood Bonnet Hood(Bonnet) Front [Old Type] ## S.No. =69999
Hood Bonnet Hood(Bonnet) Front [New Type] ## S.No. =70001
Hood Bonnet Hood(Bonnet) Upper [Old Type] ## S.No. =50621
Hood Bonnet Hood(Bonnet) Upper [New Type] ## S.No. =50622
Hood Bonnet Hood(Bonnet) Side Upper [Old Type] ## S.No. =69999
Hood Bonnet Hood(Bonnet) Side Upper [New Type] ## S.No. =70001
Hood Bonnet Front Post Rear Post
Hood Bonnet Hood(Bonnet) Side Lower [Old Type] ## S.No. =50621
Hood Bonnet Hood(Bonnet) Side Lower [New Type] ## S.No. =50622
Hood Bonnet Hood(Bonnet) Rear
Cab Cab Frame
Cab Front Glass
Cab Door Rh
Cab Door Lh
Cab Door Lock Rh
Cab Door Lock Lh
Cab Side Window
Cab Rear Window 1
Cab Rear Window 2
Cab Rearview Mirror [Old Type] ## S.No. =69999
Cab Rearview Mirror [New Type] ## S.No. =70001
Cab Inner Roof
Cab Outer Roof [Old Type] ## S.No. =50621
Cab Outer Roof [New Type] ## S.No. =50622
Cab Seat [Old Type] ## S.No. =50710
Cab Floor Mat [Old Type] ## S.No. =50621
Cab Floor Mat [New Type] ## S.No. =50622
Cab Inspection Plate
Cab Shift Lever Guide
Cab Shift Lever Guide Post
Cab Fender Cover
Cab Fender Rh
Cab Fender Lh
Cab Balustrade
Cab Cab Bracket Front
Cab Cab Bracket Rear
Cab Tool Box
Air Conditioner Air Conditioner Controller [Old Type] ## S.No. =50621
Air Conditioner Air Conditioner Controller [New Type] ## S.No. =50622
Air Conditioner Air Conditioner Duct
Air Conditioner Blower Motor [Old Type] ## S.No. =50621
Air Conditioner Blower Motor [New Type] ## S.No. =50622
Air Conditioner Condenser [Old Type] ## S.No. =50621 S.No.; =50621
Air Conditioner Condenser [New Type] ## S.No. =50622 S.No.; =50622
Air Conditioner Compressor [Old Type] ## S.No. =50621
Air Conditioner Compressor [New Type] ## S.No. =50622 [Note Order By Ref.No
Air Conditioner Compressor Bracket [Old Type] ## S.No. =50621
Air Conditioner Compressor Bracket [New Type] ## S.No. =50622
Air Conditioner Air Conditioner Pipe
Air Conditioner Drain Hose
Front Rear Tire Front Wheel Disk
Front Rear Tire Rear Wheel Disk
Labels Label 1 [Old Type] ## S.No. =69999
Labels Label 1 [New Type] ## S.No. =70001
Labels Label 2 [Old Type] ## S.No. =69999
Labels Label 2 [New Type] ## S.No. =70001
Accessories Accessories And Service Parts
Option Accelerator Sensor Kit [Option]
Option Trailer Socket Kit [Option]
Option Rear Defogger Kit [Option]
Option Creep Speed Kit 1 (Gear Case) [Option]
Option Creep Speed Kit 2 (Shift Fork Lever) [Option]
Option Auxiliary Control Valve Kit (Scd)(3rd) [Option]
Option Auxiliary Control Valve Kit (Fd)(3rd) [Option]
Option Auxiliary Control Valve Kit (Scd)(4th) [Option]
Option Auxiliary Control Valve Kit (Scd Fc)(4th) [Option]
Option Auxiliary Control Valve Kit (Fd)(4th) [Option]
Option Auxiliary Control Valve Kit (Fc) [Option]
Option Auxiliary Control Valve (Scd) [Component Parts] [Option]
Option Auxiliary Control Valve (Scd Fc) [Component Parts] [Option]
Option Auxiliary Control Valve (Fd) [Component Parts] [Option]
Option Auxiliary Control Valve (Fc) [Component Parts] [Option]
Option Auxilairy Control Valve Lever Kit (3rd) [Option]
Option Auxilairy Control Valve Lever Kit (4th) [Option]
Option Swinging Drawbar Kit [Option]
Region: Australia
Engine Oil Pan
Engine Head Cover
Engine Oil Pump
Engine Relief Valve
Engine Flywheel
Engine Water Pump
Engine Air Cleaner
Engine Inlet Pipe
Steering Tilt Pedal
Steering Tie Rod
Cab Cab Frame
Cab Front Glass
Cab Door Rh
Cab Door Lh
Cab Door Lock Rh
Cab Door Lock Lh
Cab Side Window
Cab Rear Window 1
Cab Rear Window 2
Cab Inner Roof
Cab Fender Cover
Cab Fender Rh
Cab Fender Lh
Cab Balustrade
Cab Tool Box
