Kubota Tractor M-110DTC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M-110DTC Tractor
Number of Pages: 491 Pages
Bloco Motor / Crankcase [Old Type]
Bloco Motor / Crankcase [New Type]
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head [Old Type]
Cabeca Motor / Cylinder Head [New Type]
Carreto / Gear Case [Old Type]
Carreto / Gear Case [New Type]
Tampa Cabeça / Head Cover
Bomba Oleo / Oil Pump
Fuel Pump Base / Fuel Pump Base
Breather [Old Type] / Breather [Old Type]
Breather [New Type] / Breather [New Type]
Valvula Descarga / Relief Valve
Radiador / Main Bearing Case
Piston E Cambota / Piston And Crankshaft [Ol D Type]
Piston E Cambota / Piston And Crankshaft [Ne W Type]
Volante Motor / Flywheel
Bomba Injectora / Injection Pump [Old Type]
Injection Pump [Component Parts] [Old Type] / Injection Pump [Component Parts] [Old Type]
Injection Pump [Component Parts] [New Type] / Injection Pump [Component Parts] [New Type]
Vela Pre Aquecimento / Nozzle Holder And Glo W Plug [Old Type]
Vela Pre Aquecimento / Nozzle Holder And Glo W Plug [New Type]
Suporte Bico [Peças Componentes] / Nozzle Ho Lder [Component Parts] [Old Type]
Fuel Control Motor / Fuel Control Motor
Filtro Gasoleo / Fuel Filter [Old Type]
Filtro Gasoleo / Fuel Filter [New Type]
Filtro Gasoleo[Peças Componentes] / Fuel Fil Ter [Component Parts]
Acessorios / Water Pump
Válvula E Veio Do Balanceiro / Valve And Roc Ker Arm
Filtro Ar / Air Cleaner [Eu]
Filtro Ar / Air Cleaner [Except [Eu]]
Filtro Ar [Peças Componentes] / Air Cleaner [Component Parts]
Pre-Cleaner [Except [Eu]] [Old Type] / Pre-C Leaner [Except [Eu]] [Old Type]
Pre-Cleaner [Except [Eu]] [New Type] / Pre-C Leaner [Except [Eu]] [New Type]
Tubo Aspiracao / Inlet Pipe
Escpae / Muffler [Old Type]
Escpae / Muffler [New Type]
Turbo Compressor (Componentes) / Turbo Charg Er [Component Parts] [Old Type]
Turbo Compressor (Componentes) / Turbo Charg Er [Component Parts] [New Type]
Tubo Oleo (Turbo) / Oil Pipe (Turbo Charger)
Base Da Bomba Hidráulica / Hydraulic Pump Ba Se
Kit De Juntas Superior (Tipo Antigo) / Upper Gasket Kit [Old Type]
Kit De Juntas Superior (Novo Tipo) / Upper G Asket Kit [New Type]
Kit Juntas Inferior / Lower Gasket Kit [Old Type]
Kit Juntas Inferior / Lower Gasket Kit [New Type]
Cabo Acelerador / Accelerator Wire
Fio De Paragem Do Motor / Engine Stop Wire
Deposito Combustivel (Drt) / Fuel Tank Rh
Deposito Combustivel (Esq) / Fuel Tank Lh
Tubo Combustivel / Fuel Pipe
Sedimenter / Sedimenter
Separador[Peças Componentes] / Separator [Component Parts]
Ventilador / Fan
Radiador / Water Pipe
Deposito R Eserva / Reserve Tank
Alternador / Alternator
Alternador [Peças Component Es] / Alternator [Component Parts] [Old Type]
Alternador [Peças Component Es] / Alternator [Component Parts] [New Type]
Motor Arranque / Starter
Motor Arranque [Componentes ] / Starter [Component Parts]
Interruptor/Sensor / Switch /Sensor 1 (Engine)
Interruptor/Sensor / Switch /Sensor 2 [Old Type]
Interruptor/Sensor / Switch /Sensor 2 [New Type]
Interruptor / Switch (Cab)
Interruptor / Rele / Relay
Painel / Panel Board
Painel[Peças Componentes] / Panel Board [Component Parts]
Controle Terceiro Ponto / 3 -Point Hitch Control Panel
Controle Terceiro Ponto (Co Mponentes) / 3-Point Hitch Control Panel [Component Parts]
Lift Arm Sensor / Lift Arm Sensor
Sensor Acelerador (Antigo) / Accelerator Sensor [Old Type]
Sensor Acelerador (Novo) / Accelerator Sensor [New Type]
Farol Dianteiro / Head Ligh T
Flasher Light [Old Type] / Flasher Light [Old Type]
Flasher Light [New Type] / Flasher Light [New Type]
Luzes Trabalho / Work Light
Braco Traseiro / Rear Combi Nation Light
Ficha Reboque / Trailer Soc Ket
Rádio-Gravador / Radio Cass Ette
Depósito De Lavagem / Washe R Tank
Escova Limpa Vidros / Wiper [Old Type]
Cablagem Electrica / Electr Ical Wiring 1 [Old Type]
Cablagem Electrica / Electr Ical Wiring 1 [New Type]
Cablagem Electrica / Electr Ical Wiring 2 [New Type]
Cabalagem Eletrica(Cabine)[ Ec] [G] / Electrical Wiring (Cab) [Old Type]
Cabalagem Eletrica(Cabine)[ Ec] [G] / Electrical Wiring (Cab) [New Type]
Valvula Powershift / Power Shift Valve
Valvula Powershift[P Eças Componentes] / Power Shift Valve (Body) [Compo Nent Parts]
Valvula Powershift[P Eças Componentes] / Power Shift Valve (Upper) [Comp Onent Parts]
Carter Embraiagem / Clutch Housing Cover
Valvula Embraiagem T Df / Pto Clutch Valve
Valvula Embraiagem T Df[Peças Componentes] / Pto Clutch Valve [Component Parts]
Carter Transmissao / Transmission Case Rear Cover
Carter Eixo / Rear A Xle Case
Brake Case / Brake C Ase
Disco Amortecedor / Damper Disk
Bloqueio Diferencial / Clutch Pedal
Embraiagem / Clutch Rod
Suporte Carreto / Ge Ar Support
Veio Primario / Inpu T Shaft
Veio Inversor / Shut Tle Shaft
Primeira/Segunda Mud Ança / First/Second Shift Gear
Primeiro Veio / Firs T Shaft
Carreto Terceira/Qua Rta / Third/Fourth Shift Gear
Veio Secundario / Co Untershaft
Carreto Principal / Main Gear Shift Shaft And Range Gear Shaft
Veio Gamas Velocidad Es / Range Gear Shaft
Veio (Frente) / Driv E Shaft (Front)
Veio (Meio/Traseiro) / Drive Shaft (Middle/Rear)
Painel Lateral / Tra Nsmission Case Side Cover
Grupo Conico / Bevel Gear
Diferencial Traseiro / Differential Rear
Embraiagem Bloqueio Diferencial Traseiro / Rear Differential Lock Clutc H
Veio Tdf / Pto Prope Ller Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf[Peças Componentes] / Pto Clutch [Component Parts] [Old]
Embraiagem Tdf[Peças Componentes] / Pto Clutch [Component Parts] [New]
Tdf / Veio Tdf / Pto Drive Shaft
Embraiagem Hidraulic A (Bi Speed) / Hydraulic Clutch (Bi-Speed Turn)
Veio Bi-Speed / Bi-S Peed Turn Shaft
Forqueta Caixa / Creeper / Range Gear Shift Fork
Alavanca Velocidades / Main Gear Shift Lever
Alvanca Inversor / Shuttle Shift Lever [Old Type]
Alvanca Inversor / Shuttle Shift Lever [New Type]
Tirante Velocidades / Range Gear Shift Rod
Alavanca Embraiagem Tdf / Pto Clutch Lever
Eixo Traseiro / Rear Axle
Alavanca Travao Mao / Par King Brake Lever
Pedal Travao / Brake Peda L
Pedal Bloqueio Diferencia L Traseiro / Rear Differential Lock Pedal
Travão De Estacionamento / Parking Brake
Deposito Oleo Travoes / B Rake Oil Tank
Cilindro Travao Principal [Peças Componentes] / Brake Master Cylinder [Compon Ent Parts]
Tubo Travao / Brake Pipe
Suporte Eixo Dianteiro / Front Axle Bracket [Eu]
Suporte Eixo Dianteiro / Front Axle Bracket [Except [Eu]]
Front Axle Support / F Ront Axle Support
Veio Frontal / Front P Ropeller Shaft
Caixa Diferencial Dian Teiro / Front Differential Case
Engrenagem Cónica (Dia Nteira) / Bevel Gear (Front)
Diferencial Dianteiro / Differential Front
Bloqueio Diferencial F Rente / Front Differential Lock Clutch
Caixas Engrenagens Con Ica(Drt) / Bevel Gear Case Rh [Eu]
Caixas Engrenagens Con Ica(Drt) / Bevel Gear Case Rh [Except [Eu]]
Caixas Engrenagens Con Ica(Esq) / Bevel Gear Case Lh [Eu]
Caixas Engrenagens Con Ica(Esq) / Bevel Gear Case Lh [Except[Eu]]
Carter Eixo / Front Ax Le Case
Grupo Conico / Differe Ntial Gear Shaft
Punho Volante / Steering Handle [Old Type]
Punho Volante / Steering Handle [New Type]
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção[Peças Componentes] / St Eering Controller [Component Parts]
Direcção Assistida / Tie Rod
Cilindro Direcção[Peças Componentes] / Steeri Ng Cylinder [Component Parts]
Bomba Hidraulico / Hydrauli C Pump
Bomba Hidraulico[Peças Comp Onentes] / Hydraulic Pump [Component Parts]
Hydraulic Pump (Steering) / Hydraulic Pump (Steering)
Hydraulic Pump (Steering) [ Component Parts] / Hydraulic Pump (Steering) [Compo Nent Parts]
Linha Aspiração / Hydraulic Pipe (Suction)
Tubo Oleo / Hydraulic Pipe (Delivery)
Valvula Travao Reboque / Tr Ailer Brake Valve
Valvula Segurança / Safety Valve
Circuito Oleo Hidraulico(Bi Speed) / Hydraulic Oil Line (Bi-Speed Turn/Rear Di Ff.)
Circuito Oleo Hidraulico(Di Ferencial Frente) / Hydraulic Oil Line (Front Diffe Rential)
Radiador Oleo / Oil Cooler [Old Type]
Radiador Oleo / Oil Cooler [New Type]
Circuito Oleo Radiador / Hy Draulic Oil Line (Oil Cooler)
Circuito Oleo Direcção / Hy Draulic Oil Line (Steering/Pto)
Tubo Direccao / Steering Ho Se (Delivery)
Cilindro Hidraulico / Hydra Ulic Cylinder
Braço De Elevação Hidráulic O / Hydraulic Lift Arm
Resguardo Cilindro Hidráuli Co / Hydraulic Cylinder Cover
Trinco / Lowerring Lock Lev Er
Draft Control Valve / Draft Control Valve
Ligação De Controlo Da Coni Cidade [Peças Componentes] / Draft Control Valve [C Omponent Parts]
Barra Deflectora (Suporte) / Detector Bar 1 (Bar/Bar Support)
Barra Deflectora / Detector Bar 2 (Draft Link)
Distribuidor Auxiliar / Aux Iliary Control Valve [Eu]
Distribuidor Auxiliar / Aux Iliary Control Valve [Except [Eu]]
Valvula Auxiliar [Peças Com Ponentes] / Auxiliary Control Valve (Scd/Fc) [Eu] [ Component Parts]
Distribuidor Auxiliar[Peças Componentes] / Auxiliary Control Valve (Fd) [Compo Nent Parts]
Acessorios / Auxiliary Cont Rol Valve (Scd) [Component Parts]
Tubo Da Válvula De Controlo Auxiliar / Auxiliary Control Valve Pipe [Eu]
Tubo Da Válvula De Controlo Auxiliar / Auxiliary Control Valve Pipe [Except [E U]]
Alavanca Valvula Auxiliar 1 Pos / Auxiliary Control Valve Lever [Eu]
Alavanca Valvula Auxiliar 1 Pos / Auxiliary Control Valve Lever [Except [Eu]]
Cilindro Auxiliar (Esquerdo ) / Assist Cylinder Lh [Old Type]
Cilindro Auxiliar (Esquerdo ) / Assist Cylinder Lh [New Type]
Cilindro Auxiliar (Direito) / Assist Cylinder Rh [Old Type]
Cilindro Auxiliar (Direito) / Assist Cylinder Rh [New Type]
Cilindro Auxiliar (Componen Tes) Antigo / Assist Cylinder [Component Parts] [Ol D Type]
Cilindro Auxiliar (Componen Tes) Novo Tipo / Assist Cylinder [Component Parts] [New Type]
Ligaca O Superior / Top Link [Eu] [Old Type]
Ligaca O Superior / Top Link [Eu] [New Type]
Ligaca O Superior / Top Link [Except [Eu]] [Old Type]
Ligaca O Superior / Top Link [Except [Eu]] [New Type]
Ligaca O Inferior / Lower Link [Eu] [Old Type]
Ligaca O Inferior / Lower Link [Except [Eu]] [Old Type]
Ligaca O Inferior / Lower Link [New Type]
Corren Te Seguranca / Check Chain
Estabi Lizador(Drt) / Lift Rod Rh [Eu] [New Type]
Estabi Lizador(Drt) / Lift Rod Rh [Except [Eu]] [Old Type]
Estabi Lizador(Drt) / Lift Rod Rh [Except [Eu]] [New Type]
Estabi Lizador(Esq) / Lift Rod Lh
Lift R Od Handle [Except [Eu]] / Lift Rod Handle [Except [ Eu]]
Barra Reboque / Drawbar
Capot Dianteiro / Hood(Bonnet) Front [Old Typ E]
Capot Dianteiro / Hood(Bonnet) Front [New Typ E]
Capot Superior / Hood(Bonnet) Upper [Eu] [Old Type]
Capot Superior / Hood(Bonnet) Upper [Eu] [New Type]
Capot Superior / Hood(Bonnet) Upper [Except [ Eu]] [Old Type]
Capot Superior / Hood(Bonnet) Upper [Except [ Eu]] [New Type]
Hood(Bonnet) Side Upper [Old Type] / Hood(Bon Net) Side Upper [Old Type]
Hood(Bonnet) Side Upper [New Type] / Hood(Bon Net) Side Upper [New Type]
Front Post/Rear Post / Front Post/Rear Post
Hood(Bonnet) Side Lower [Old Type] / Hood(Bon Net) Side Lower [Old Type]
Hood(Bonnet) Side Lower [New Type] / Hood(Bon Net) Side Lower [New Type]
Capot Traseiro / Hood(Bonnet) Rear
Front Fender [Eu] [Old Type] / Front Fender [ Eu] [Old Type]
Front Fender [Eu] [New Type] / Front Fender [ Eu] [New Type]
E Strutura Cabine / Cab Frame [Eu]
E Strutura Cabine / Cab Frame [Except [Eu]]
V Idro Frente E Traseiro / Front Glass
P Orta(Drt) / Door Rh
P Orta(Esq) / Door Lh
T Rinco Porta(Drt) / Door Lock Rh
T Rinco Porta(Esq) / Door Lock Lh
L Ado Vidro / Side Window
V Idro Traseiro / Rear Window
E Spelho Rectrovisor / Rearview Mirror [Eu]
E Spelho Rectrovisor / Rearview Mirror [Except [Eu]]
T Ecto Interior / Inner Roof
T Ejadilho Exterior / Outer Roof [Old Type]
T Ejadilho Exterior / Outer Roof [New Type]
B Anco / Seat [Except [Eu] [Gr]]
P Iso / Floor Mat [Old Type]
P Iso / Floor Mat [New Type]
C Hapa Inspecção(Frente) / Inspection Plate
T Ampa / Shift Lever Guide
S Hift Lever Guide Post / Shift Lever Guide Post
C Obertura Do Guarda-Lamas / Fender Cover
G Uarda Lamas(Drt) / Fender Rh
G Uarda Lamas(Esquerda) / Fender Lh
B Alustrade / Balustrade
D Ianteira Do Suporte Da Cabine / Cab Bracket Front
S Uporte Cabine Traseiro / Cab Bracket Rear
Comando Ar Condicionado (Antig O) / Air Conditioner Controller [Old Type]
Comando Ar Condicionado (Novo) / Air Conditioner Controller [New Type]
Air Condicionado / Air Conditi Oner
Tubo Ar Condicionado / Air Con Ditioner Duct
Blower Motor [Old Type] / Blow Er Motor [Old Type]
Blower Motor [New Type] / Blow Er Motor [New Type]
Condesador / Condenser [Eu] [O Ld Type]
Condesador / Condenser [Eu] [N Ew Type]
Condesador / Condenser [Except [Eu]] [Old Type]
Condesador / Condenser [Except [Eu]] [New Type]
Compressor / Compressor [Old T Ype]
Compressor / Compressor [New T Ype]
Suporte Compressor / Compresso R Bracket [Old Type]
Suporte Compressor / Compresso R Bracket [New Type]
Tubo Do Ar Condicionado / Air Conditioner Pipe
Mangueira De Drenagem / Drain Hose
Etiqueta 1 / Label 1 [Old Type]
Etiqueta 1 / Label 1 [New Type]
Etiqueta 2 / Label 2 [Old Type]
Etiqueta 2 / Label 2 [New Type]
Acessorios / Accessories And Service Par Ts
Pre-Cleaner Kit [Eu] [Option] [Old Type] / Pre-Cle Aner Kit [Eu] [Option] [Old Type]
Pre-Cleaner Kit [Eu] [Option] [New Type] / Pre-Cle Aner Kit [Eu] [Option] [New Type]
Kit Sendor Acelerador (Opção) / Accelerator Sensor Kit [Option]
Desempanador (Opcao) / Rear Defogger Kit [Option]
Kit Caixa Crepper(Opção) / Creep Speed Kit 1 (Gear Case) [Option]
Forqueta Caixa / Creeper / Creep Speed Kit 2 (Shif T Fork/Lever) [Option]
Apoio[Opcao] / Front Bumper Kit [Eu] [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Co Ntrol Valve Kit (Scd) (3rd) [Except [Eu]] [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Co Ntrol Valve Kit (Fd) (3rd) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Co Ntrol Valve Kit (Scd) (4th) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Co Ntrol Valve Kit (Scd/Fc) (4th) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Co Ntrol Valve Kit (Fd) (4th) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Co Ntrol Valve Kit (Fc) [Option]
Kit Distribuidor Serviços Externos[Peças Component Es][Opcao] / Auxiliary Control Valve (Scd) [Compone Nt Parts] [Option]
Kit Distribuidor Serviços Externos[Peças Component Es][Opcao] / Auxiliary Control Valve (Scd/Fc) [Comp Onent Parts] [Option]
Kit Distribuidor Serviços Externos[Peças Component Es][Opcao] / Auxiliary Control Valve (Fd) [Componen T Parts] [Option]
Kit Distribuidor Serviços Externos[Peças Component Es][Opcao] / Auxiliary Control Valve (Fc) [Componen T Parts] [Option]
Kit Alavanca Serviços Externos[Opcao] / Auxilairy Control Valve Lever Kit (3rd) [Option]
Kit Alavanca Serviços Externos[Opcao] / Auxilairy Control Valve Lever Kit (4th) [Option]
Front Fender Kit [Except [Eu]] [Option] / Front F Ender Kit [Except [Eu]] [Option]
