Kubota Tractor Loader R520S Australia Parts Catalog
Type of Machine: Tractor Loader
Model: Kubota R520S Tractor Loader
Region: Australia
Number of Pages: 156 Pages
Frequently Used Items _ Frequently Used Items
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Cylinder Head ## S.No._=19999 Loader
Engine _ Cylinder Head ## Loader S.No.B_=20001
Engine _ Gear Case ## Note_Order By Part No.1g788-0402-4 And Ref.No.070 New Part(Set)
Engine _ Head Cover
Engine _ Engine Bracket
Engine _ Main Bearing Case ## S.No._=3s4179
Engine _ Main Bearing Case ## S.No._=3u0001
Engine _ Piston And Crankshaft ## S.No._=3s4179
Engine _ Piston And Crankshaft ## S.No._=3u0001, Loader _=19999
Engine _ Piston And Crankshaft ## Loader S.No.B_=20001
Engine _ Flywheel
Engine _ Fuel Camshaft And Governor Shaft
Engine _ Engine Stop Lever ## S.No.;B_=Bkz999
Engine _ Engine Stop Lever ## S.No.;B_=Bl0001
Engine _ Stop Solenoid
Engine _ Injection Pump ## Loader S.No.;B_=19999
Engine _ Injection Pump ## Loader S.No.;B_=20001 Note_Order By Ref.No
Engine _ Governor ## S.No._=19999 Loader
Engine _ Governor ## Loader S.No.B_=20001
Engine _ Speed Control Plate ## S.No._=19999 Loader
Engine _ Speed Control Plate ## Loader S.No.B_=20001
Engine _ Nozzle Holder And Glow Plug ## Loader S.No.;B_=19999
Engine _ Nozzle Holder And Glow Plug ## Loader S.No.;B_=20001
Engine _ Alternator
Engine _ Alternator (Component Parts)
Engine _ Starter
Engine _ Starter (Component Parts)
Engine _ Water Pump ## S.No._=7fdz999 S.No.;_=7fdz999
Engine _ Water Pump ## S.No._=7fe0001 S.No.;_=7fe0001
Engine _ Water Pipe
Engine _ Radiator
Engine _ Valve And Rocker Arm ## Note_Order By Part No.1g897-1311-2 _ Ref.No
Engine _ Inlet Manifold
Engine _ Exhaust Manifold
Engine _ Air Cleaner
Engine _ Muffler
Engine _ Gasket Kit
Engine _ Gasket Kit
Engine _ Drain Piping
Fuel System _ Fuel Piping
Fuel System _ Fuel Filter (Component Parts)
Fuel System _ Fuel Tank
Electrical System _ Battery
Electrical System _ Relay
Electrical System _ Switch And Meter
Electrical System _ Lamp
Electrical System _ Lamp ## [Canopy]
Transmission _ Mission Case
Transmission _ Front Axle Case
Transmission _ Front Differential Case
Transmission _ Planetary Gear (Front)
