Kubota Tractor Loader R520 Australia Parts Catalog
Type of Machine: Tractor Loader
Model: Kubota R520 Tractor Loader
Region: Australia
Number of Pages: 333 Pages
Engine _ Crankcase
Engine _ Oil Pan
Engine _ Piston_Crankshaft
Engine _ Main Bearing Case
Engine _ Camshaft
Engine _ Cylinder Head
Engine _ Valve_Rocker Arm
Engine _ Cylinder Head Cover
Engine _ Gear Case
Engine _ Inlet Manifold
Engine _ Exhaust Manifold
Engine _ Nozzle Holder_Glowplug
Engine _ Fuel Camshaft
Engine _ Injection Pump
Engine _ Engine Stop Lever
Engine _ Speed Control Plate
Engine _ Governor
Engine _ Water Pump
Engine _ Waterflange_Thermostat
Engine _ Fan_Alternator
Engine _ Alternator [Component Parts]
Engine _ Flywheel_Starter
Engine _ Starter [Component Parts]
Engine _ Engine Bracket
Engine _ S052-2 Air Cleaner [Old Type]
Engine _ S052-3 Air Cleaner [New Type] ## [Ktl,Kcl;S.No.;A_=10304,B_=10251] [Kta]
Engine _ S053-2 Muffler
Option _ S052-4 Air Cleaner [Option]
Fuel System _ Solenoid
Fuel System _ Fuel Tank
Fuel System _ Fuel Pipe
Fuel System _ Sedimenter
Fuel System _ Fuel Filter
Cooling Water System _ Radiator
Cooling Water System _ Water Pipe
Electrical System _ Battery
Electrical System _ Meter
Electrical System _ Switch
Electrical System _ Light
Electrical System _ Lamp
Electrical System _ Turn Signal
Electrical System _ Tail Lamp
Electrical System _ Electrical Wiring ## Note_Order By Ref.No.020 New Part, Fig.No.S063 Ref
Transmission _ Mission Case
Transmission _ Front Axle Case
Transmission _ Front Differential Case
Transmission _ Planetary Gear (Front)
Transmission _ Rear Axle Case
Transmission _ Rear Differential Case
Transmission _ Planetary Gear (Rear)
Transmission _ Propeller Shaft
Wheel_Tire _ S081-2 Wheel_Tire
Steering _ Steering Handle
Steering _ Hydraulic Oil Line (Steering)
Steering _ Accelerator Support
Steering _ Steering Controller
Steering _ S086-1 Steering Controller [Component Parts] [Old Type] ## S.No._=10262
Steering _ S086-2 Steering Controller [Component Parts] [New Type] ## S.No._=10263
Steering _ Priority Valve
Brake _ Brake Pedal
Brake _ Brake Operation
Brake _ Brake Piping
Brake _ Brake
Pump_Motor System _ Pump Housing
Pump_Motor System _ Drain Piping
Pump_Motor System _ LST Pump
Pump_Motor System _ LST Pump [Component Parts]
Pump_Motor System _ Piston Pump [Component Parts]
Pump_Motor System _ Rotary [Component Parts]
Pump_Motor System _ Cylinder [Component Parts]
Pump_Motor System _ Rotary Cover [Component Parts]
Pump_Motor System _ High Pressure Valve [Component Parts]
Pump_Motor System _ Low Pressure Valve [Component Parts]
Pump_Motor System _ Section Control [Component Parts]
Pump_Motor System _ Da Valve [Component Parts]
Pump_Motor System _ Gear Pump
Pump_Motor System _ Sealkit (LST Pump) [Component Parts]
Pump_Motor System _ LST Pump (Relief Valve)
Pump_Motor System _ LST Motor
Pump_Motor System _ LST Motor [Component Parts]
Pump_Motor System _ Control [Component Parts]
Pump_Motor System _ Seal Kit (LST Motor)
Pump_Motor System _ Control Valve
Pump_Motor System _ Control Valve [Component Parts]
Pump_Motor System _ Spool Section (1)
Pump_Motor System _ S117-1 Spool Section (2)
Pump_Motor System _ S117-2 Spool Section (3)
Pump_Motor System _ Solenoid Valve
Pump_Motor System _ Oil Tank
Pump_Motor System _ Oil Filter
Pump_Motor System _ Oil Coller
Pump_Motor System _ Hydraulic Oil Line (Suction)
Pump_Motor System _ Hydraulic Oil Line (Oil Cooler)
Pump_Motor System _ Hydraulic Oil Line (Return)
Pump_Motor System _ Return Filter
Pump_Motor System _ High Pressure Oil Line
Pump_Motor System _ Oil Piping Return
Control Lever _ Control Lever (Shovel)
Control Lever _ Control Lever (Shovel) [Component Parts]
Control Lever _ Control Lever (Sp) [Component Parts]
Front Attachments _ Shovel Arm
Front Attachments _ Tilt Arm
Front Attachments _ S133-3 Bucket
Cylinder _ Lift Cylinder
Cylinder _ S135-2 Lift Cylinder Left [Component Parts]
Cylinder _ S136-2 Lift Cylinder Right [Component Parts]
Cylinder _ Tilt Cylinder
Cylinder _ S138-2 Tilt Cylinder [Component Parts]
Cylinder _ Auto Leveler [With Kta]
Cylinder _ Steering Cylinder
Cylinder _ S141-2 Steering Cylinder [Component Parts]
Oil Piping _ Hydraulicoil Line (Lift)
Oil Piping _ Hydraulic Oil Line (Tilt)
Oil Piping _ S145-2 Hydraulic Oil Line (Sp)
Main Frame _ Front Frame
Main Frame _ Frame Connection
Main Frame _ Rear Frame
Main Frame _ Wight
Hood_Bonnet _ Rear Fender
Hood_Bonnet _ Mud Guad
Hood_Bonnet _ Seat
Hood_Bonnet _ Hood
Hood_Bonnet _ Hood Lock
Hood_Bonnet _ Sound Absorber
Hood_Bonnet _ Operation Stand
Hood_Bonnet _ Fender
Operator's Platform _ Rops
Labels _ Label
Accessories _ Accessories And Service Parts
Region: Australia
Engine _ Crankcase
Engine _ Oil Pan
Engine _ Camshaft
Engine _ Gear Case
Engine _ Governor
Engine _ Water Pump
Brake _ Brake Pedal
Brake _ Brake
Main Frame _ Wight
Hood_Bonnet _ Seat
Hood_Bonnet _ Hood
Labels _ Label
