Kubota Tractor Loader R420S Australia Parts Catalog
Type of Machine: Tractor Loader
Model: Kubota R420S Tractor Loader
Region: Australia
Number of Pages: 441 Pages
Frequently Used Items _ Frequently Used Items
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Cylinder Head
Engine _ Gear Case ## Note_Order By Part No.1g788-0402-4 And Ref.No.070 New Part(Set)
Engine _ Head Cover ## S.No._=19999 Loader
Engine _ Head Cover ## S.No._=20001 Loader
Engine _ Engine Bracket
Engine _ Main Bearing Case ## S.No._=3s1926
Engine _ Main Bearing Case ## S.No._=3u0001
Engine _ Camshaft And Idle Gear Shaft ## S.No._=Bbz999 S.No.;A_=Bbz999
Engine _ Camshaft And Idle Gear Shaft ## S.No._=Bc0001 S.No.;_=Bc0001
Engine _ Piston And Crankshaft ## S.No._=3t9999
Engine _ Piston And Crankshaft ## S.No._=3u0001 S.No.;_=3u0001
Engine _ Flywheel
Engine _ Fuel Camshaft And Governor Shaft
Engine _ Engine Stop Lever ## S.No._=20001 Loader
Engine _ Engine Stop Lever ## S.No.;A_=Bl0001
Engine _ Stop Solenoid
Engine _ Injection Pump ## Note_Order By Part No.14111-4241-0 & 1g896-9665-0 & Ref.No
Engine _ Governor ## S.No._=19999 Loader
Engine _ Governor ## Loader S.No.;A_=20001
Engine _ Speed Control Plate
Engine _ Boost Compensator ## S.No._=19999 Loader
Engine _ Alternator
Engine _ Alternator (Component Parts)
Engine _ Starter
Engine _ Starter (Component Parts)
Engine _ Water Flange And Thermostat ## S.No._=19999 Loader
Engine _ Water Flange And Thermostat ## S.No._=20001 Loader
Engine _ Water Pump ## S.No._=7fdz999 S.No.;_=7fdz999
Engine _ Water Pump ## S.No._=7fe0001 S.No.;_=7fe0001
Engine _ Water Pipe
Engine _ Radiator
Engine _ Valve And Rocker Arm ## Note 1_Order By Part No.1g897-1311-2 & Ref.No
Engine _ Turbo Charger ## S.No._=19999 Loader
Engine _ Turbo Charger ## S.No._=20001 Loader
Engine _ Oil Pipe (Turbo Charger) ## S.No._=19999 Loader
Engine _ Oil Pipe (Turbo Charger) ## Loader S.No.A_=20001
Engine _ Inlet Manifold ## S.No._=19999 Loader
Engine _ Inlet Manifold ## S.No._=20001 Loader
Engine _ Exhaust Manifold ## S.No._=19999 Loader
Engine _ Exhaust Manifold ## S.No._=20001 Loader
Engine _ Air Cleaner
Engine _ Muffler
Engine _ Oil Cooler
Engine _ Gasket Kit
Engine _ Drain Piping
Fuel System _ Fuel Piping
Fuel System _ Fuel Filter (Component Parts)
Fuel System _ Fuel Tank
Electrical System _ Battery
Electrical System _ Relay
Electrical System _ Switch And Meter
Electrical System _ Lamp
Electrical System _ Lamp ## [Canopy]
Transmission _ Mission Case
Transmission _ Front Axle Case
Transmission _ Front Differential Case
Transmission _ Planetary Gear (Front)
Transmission _ Rear Axle Case
Transmission _ Rear Differential Case
Transmission _ Planetary Gear (Rear)
Transmission _ Propeller Shaft
Wheel_Tire _ Wheel_Tire
Steering _ Steering Handle
Steering _ Hydraulic Oil Line (Steering)
Steering _ Streering Controller
Speed Change _ Accelerator Pedal
Speed Change _ Accelerator Cable
Brake _ Brake Pedal
Brake _ Brake Operation
Brake _ Brake Piping
Brake _ Brake
Hydraulic System _ Pump Housing
Hydraulic System _ LST Pump (Component Parts)
Hydraulic System _ LST Pump (Adapter)
Hydraulic System _ LST Pump (Relief Valve)
Hydraulic System _ LST Motor
Hydraulic System _ LST Motor (Component Parts)
Hydraulic System _ Control Valve ## [Without Auto Leveler]
Hydraulic System _ Control Valve ## [With Auto Leveler]
Hydraulic System _ Control Valve (Component Parts) ## [Without Auto Leveler]
Hydraulic System _ Control Valve (Component Parts) ## [With Auto Leveler]
Hydraulic System _ Spool Section (Lift)
Hydraulic System _ Spool Section (Tilt) ## [Without Auto Leveler]
Hydraulic System _ Spool Section (Tilt) ## [With Auto Leveler]
Hydraulic System _ Spool Section (S_P)
Hydraulic System _ Solenoid Valve
Hydraulic System _ Oil Tank
Hydraulic System _ Oil Cooler
Hydraulic System _ Oil Filter
Control Lever _ Control Lever (Shovel)
Control Lever _ Control Lever (Shovel) (Component Parts)
Control Lever _ Control Lever (S_P) (Component Parts)
Front Attachments _ Shovel Arm ## [With Front Attachments]
Front Attachments _ Tilt Arm ## [With Front Attachments]
Front Attachments _ Bucket ## S.No._=20224 [With Front Attachments]
Front Attachments _ Bucket ## S.No._=20225 [With Front Attachments]
Oil Piping _ Hydraulic Oil Line (Suction)
Oil Piping _ Hydraulic Oil Line (Return) ## [With Back Hoe]
Oil Piping _ Hydraulic Oil Line (Oil Cooler)
Oil Piping _ Return Filter ## [With Back Hoe]
Oil Piping _ Return Filter ## [Without Back Hoe]
Oil Piping _ High Pressure Oil Line
Oil Piping _ Hydraulic Oil Line (Lift)
Oil Piping _ Hydraulic Oil Line (Tilt)
Oil Piping _ Hydraulic Oil Line (S_P)
Cylinder _ Lift Cylinder ## [With Front Attachments]
Cylinder _ Lift Cylinder Left (Component Parts) ## S.No._=20472 [With Front Attachments]
Cylinder _ Lift Cylinder Left (Component Parts) ## S.No._=20473 [With Front Attachments]
Cylinder _ Lift Cylinder Right (Component Parts) ## S.No._=20472 [With Front Attachments]
Cylinder _ Lift Cylinder Right (Component Parts) ## S.No._=20473 [With Front Attachments]
Cylinder _ Tilt Cylinder ## [With Front Attachments]
Cylinder _ Tilt Cylinder (Component Parts) ## S.No._=20472 [With Front Attachments]
Cylinder _ Tilt Cylinder (Component Parts) ## S.No._=20473 [With Front Attachments]
Cylinder _ Steering Cylinder
Cylinder _ Steering Cylinder (Component Parts) ## S.No._=20472 S.No.;_=20472
Cylinder _ Steering Cylinder (Component Parts) ## S.No._=20473 S.No.;_=20473
Cylinder _ Auto Leveler ## [With Front Attachments]
Main Frame _ Front Frame
Main Frame _ Frame Connection
Main Frame _ Rear Frame ## [With Back Hoe]
Main Frame _ Rear Frame ## [Without Back Hoe]
Hood_Bonnet _ Rear Fender
Hood_Bonnet _ Mud Guard
Hood_Bonnet _ Fender
Hood_Bonnet _ Hood
Hood_Bonnet _ Hood Lock
Hood_Bonnet _ Operation Stand
Hood_Bonnet _ Seat
Hood_Bonnet _ Seat (Component Parts)
Hood_Bonnet _ Sound Absorber
Hood_Bonnet _ Weight ## [Without Back Hoe]
Canopy _ Canopy
Labels _ Label
Accessories And Service Parts _ Accessories
Option _ Pre-Cleaner Kit [Option]
Back Hoe _ Lamp (Backhoe)
Back Hoe _ Outligger Control Lever _ Slide Lock
Back Hoe _ Operating Control Lever
Back Hoe _ Control Arm
Back Hoe _ Lock Rod
Back Hoe _ Control Cable
Back Hoe _ Stand
Back Hoe _ Cover
Back Hoe _ Slide Frame ## Note_Order By Ref.No.130 And Part No.R2421-9171-0(Set)
Back Hoe _ Swing Bracket
Back Hoe _ Boom
Back Hoe _ Arm
Back Hoe _ Bucket Link
Back Hoe _ Bucket
Back Hoe _ Out Ligger Cylinder
Back Hoe _ Swing Cylinder
Back Hoe _ Boom Cylinder
Back Hoe _ Arm Cylinder
Back Hoe _ Bucket Cylinder
Back Hoe _ Slide Lock Cylinder
Back Hoe _ Oil Piping Quick Coupler
Back Hoe _ Oil Piping Out Ligger
Back Hoe _ Oil Piping Slide Lock 1
Back Hoe _ Oil Piping Slide Lock 2
Back Hoe _ Oil Piping Boom
Back Hoe _ Oil Piping Arm
Back Hoe _ Oil Piping Bucket
Back Hoe _ Oil Piping Swing
Back Hoe _ Control Valve
Back Hoe _ Control Valve (Component Parts)
Back Hoe _ Control Valve Spool Section
Back Hoe _ Label
Region: Australia
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Flywheel
Engine _ Alternator
Engine _ Starter
Engine _ Water Pipe
Engine _ Radiator
Engine _ Muffler
Engine _ Oil Cooler
Engine _ Gasket Kit
Brake _ Brake Pedal
Brake _ Brake
Hood_Bonnet _ Hood
Hood_Bonnet _ Seat
Canopy _ Canopy
Labels _ Label
Back Hoe _ Lock Rod
Back Hoe _ Stand
Back Hoe _ Cover
Back Hoe _ Boom
Back Hoe _ Arm
Back Hoe _ Bucket
Back Hoe _ Label
