Kubota Tractor Loader R065 Australia Parts Catalog
Type of Machine: Tractor Loader
Model: Kubota R065 Tractor Loader
Region: Australia
Number of Pages: 385 Pages
Engine _ Crankcase
Engine _ Oil Pan
Engine _ Dipstick And Guide
Engine _ Cylinder Head
Engine _ Inlet Valve And Exhaust Valve
Engine _ Rocker Arm Shaft
Engine _ Head Cover
Engine _ Front Cover
Engine _ Piston And Crankshaft
Engine _ Flywheel
Engine _ Injection Pump Unit
Engine _ Injection Pump Housing
Engine _ Fuel Camshaft
Engine _ Governor
Engine _ Fork Lever (Governor)
Engine _ Restriction Adjusting Bolt
Engine _ Fuel Pipe
Engine _ Injection Pipe
Engine _ Alternator And Pulley
Engine _ Alternator (Component Parts)
Engine _ Starter
Engine _ Starter (Component Parts)
Engine _ Stop Solenoid
Engine _ Oil Switch And Sensor
Engine _ Water Pump
Engine _ Fan
Engine _ Inlet Manifold
Engine _ Exhaust Manifold
Engine _ Oil Cooler
Engine _ Water Pipe
Engine _ Radiator
Engine _ Reserve Tank
Engine _ Air Cleaner
Engine _ Muffler
Engine _ Engine Bracket
Engine _ Upper Gasket Kit
Engine _ Lower Gasket Kit
Fuel System _ Fuel Tank
Fuel System _ Fuel Pump And Piping 1
Fuel System _ Fuel Pump And Piping 2
Fuel System _ Fuel Filter (Component Parts)
Fuel System _ Water Separator (Component Parts)
Electrical System _ Battery
Electrical System _ Horn
Electrical System _ Relay
Electrical System _ Switch
Electrical System _ Meter
Electrical System _ Lamp (Front)
Electrical System _ Lamp (Rear)
Electrical System _ Wire Harness
Electrical System _ Starter Switch
Transmission _ Front Axle
Transmission _ Front Axle (Central Housing)
Transmission _ Front Axle (Differential)
Transmission _ Front Axle (Hub Reduction)
Transmission _ Rear Axle
Transmission _ Rear Axle (Central Housing)
Transmission _ Rear Axle (Differential)
Transmission _ Rear Axle (Hub Reduction)
Transmission _ Rear Axle (Brakes)
Transmission _ Rear Axle (Gear Box)
Transmission _ Propeller Shaft
Tire _ Wheel_Tire
Steering _ Steering
Steering _ Power Steering
Steering _ Power Steering (Component Parts)
Speed Change _ Accelerator Pedal
Speed Change _ Accelerator Cable
Brake _ Brake Pedal
Brake _ Brake Operation
Brake _ Brake Piping
Pump_Motor System _ Inching Rod
Pump_Motor System _ Pump Housing
Pump_Motor System _ LST Pump
Pump_Motor System _ LST Pump (Component Parts)
Pump_Motor System _ LST Pump (Adapter)
Pump_Motor System _ LST Pump (Relief Valve)
Pump_Motor System _ LST Motor
Pump_Motor System _ LST Motor (Component Parts)
Pump_Motor System _ Control Valve
Pump_Motor System _ Control Valve (Component Parts)
Pump_Motor System _ Priority Valve
Pump_Motor System _ Solenoid Valve
Pump_Motor System _ Oil Tank
Pump_Motor System _ Oil Cooler
Pump_Motor System _ Oil Filter
Control Lever _ Control Lever 1 (Shovel)
Control Lever _ Control Lever 2 (Shovel)
Control Lever _ Control Lever (Aux)
Front Attachments _ Lift Arm
Front Attachments _ Bell Crank
Front Attachments _ Bucket Link
Front Attachments _ Multi Coupler
Front Attachments _ Coupler Cylinder (Component Parts)
Oil Piping _ Oil Piping (Suction)
Oil Piping _ Oil Piping (Travel)
Oil Piping _ Oil Piping (Bucket)
Oil Piping _ Oil Piping (Steering)
Oil Piping _ Oil Piping (Multi Coupler)
Oil Piping _ Oil Piping (Clamp)
Oil Piping _ Oil Piping (Return)
Oil Piping _ Oil Piping (Pump_Motor)
Oil Piping _ Oil Piping (Lift)
Oil Piping _ Oil Piping (Aux) ## S.No._=10985 S.No.;_=10985
Oil Piping _ Oil Piping (Aux) ## S.No._=10986 S.No.;_=10986
Cylinder _ Lift Cylinder
Cylinder _ Lift Cylinder Left (Component Parts)
Cylinder _ Lift Cylinder Right (Component Parts)
Cylinder _ Bucket Cylinder
Cylinder _ Bucket Cylinder (Component Parts)
Cylinder _ Steering Cylinder
Cylinder _ Steering Cylinder (Component Parts)
Frame _ Front Frame
Frame _ Frame Connection
Frame _ Floor Frame
Frame _ Rear Frame
Frame _ Arch Frame
External_Upholstery _ Fender (Rear)
External_Upholstery _ Fender (Side Lh)
External_Upholstery _ Fender (Side Rh)
External_Upholstery _ Fender (Front)
External_Upholstery _ Cover (Rh)
External_Upholstery _ Bonnet
External_Upholstery _ Step ## [Canopy]
External_Upholstery _ Step ## [Cabin]
External_Upholstery _ Seat ## [Canopy]
External_Upholstery _ Seat ## [Cabin]
External_Upholstery _ Seat (Component Parts) ## [Canopy]
External_Upholstery _ Seat (Component Parts) ## [Cabin]
External_Upholstery _ Sound Absorber 1
External_Upholstery _ Sound Absorber 2
External_Upholstery _ Lining ## [Cabin]
External_Upholstery _ Weight
Operator's Platform _ Canopy
Operator's Platform _ Cabin (Body)
Operator's Platform _ Cabin (Door)
Operator's Platform _ Cabin (Wiper Motor)
Operator's Platform _ Cabin (Window 1)
Operator's Platform _ Cabin (Window 2)
Operator's Platform _ Cabin (Inner Roof)
Operator's Platform _ Cabin (Accessory)
Operator's Platform _ Cabin (Electrical Wiring)
Operator's Platform _ Cabin (Seal)
Operator's Platform _ Washer Tank
Operator's Platform _ Air Conditioner Unit
Operator's Platform _ Air Conditioner Hose
Operator's Platform _ Duct
Operator's Platform _ Air Filter
Operator's Platform _ Compressor
Operator's Platform _ Condenser
Operator's Platform _ Condenser Hose
Labels _ Label
Accessories _ Accessories
Option _ Kit Lamp Rear ## [Canopy]
Option _ Kit Lamp Rear ## [Cabin]
Option _ Kit Lamp Front ## [Canopy]
Option _ Tool Box [Option]
Option _ Fork [Option]
Option _ Bucket [Option]
Option _ Bucket,Hydraulic 4in1 [Option]
Option _ Rotating Beacon [Option] ## [Canopy]
Option _ Rotating Beacon [Option] ## [Cabin]
Option _ Pipe-Break Valve_Lift Cylinders
Option _ Pipe-Break Valve_Bucket Cylinder
Option _ Pedal Rh.
Option _ Kit Shockabsorber
Option _ Valve Shockabsorber (Component Parts)
Region: Australia
Engine _ Crankcase
Engine _ Oil Pan
Engine _ Head Cover
Engine _ Flywheel
Engine _ Governor
Engine _ Fuel Pipe
Engine _ Starter
Engine _ Water Pump
Engine _ Fan
Engine _ Oil Cooler
Engine _ Water Pipe
Engine _ Radiator
Engine _ Muffler
Tire _ Wheel_Tire
Steering _ Steering
Brake _ Brake Pedal
Frame _ Front Frame
Frame _ Floor Frame
Frame _ Rear Frame
Frame _ Arch Frame
Labels _ Label
Option _ Pedal Rh.
