Kubota Tractor L35 Australia Parts Catalog
Model: Kubota L35 Tractor
Region: Australia
Number of Pages: 347 Pages
Engine Crankcase
Engine Oil Pan
Engine Piston And Crankshaft ## Note Order By Ref.No.010 And 040 New Part.
Engine Main Bearing Case [Old Type] ## S.No. =9369 S.No.; =9369
Engine Main Bearing Case [New Type] ## S.No. =9370 S.No.; =9370
Engine Flywheel
Engine Cylinder Head
Engine Valve And Rocker Arm [Old Type] ## S.No. =3w0593 S.No.; =3w0593
Engine Valve And Rocker Arm [New Type] ## S.No. =3y0001 S.No.; =3y0001
Engine Nozzle Holder And Glow Plug
Engine Nozzle Holder [Component Parts]
Engine Cylinder Head Cover [Old Type] ## S.No. =3w0593 S.No.; =3w0593
Engine Cylinder Head Cover [New Type] ## S.No. =3y0001 S.No.; =3y0001
Engine Inlet Manifold
Engine Air Cleaner
Engine Exhaust Manifold And Muffler
Engine Camshaft
Engine Gear Case
Engine Water Pump
Engine Water Flange And Thermostat
Engine Fuel Camshaft
Engine Injection Pump
Engine Engine Stop Lever
Engine Speed Control Plate
Engine Governor
Engine Upper Gasket Kit
Engine Lower Gasket Kit
Engine Stop Selenoid And Engine Stop Wire
Engine Accelerator Lever
Engine Accelerator Linkage
Engine Accelerator Rod
Fuel System Fuel Tank
Fuel System Fuel Filter And Fuel Pipe
Fuel System Fuel Filter [Component Parts]
Cooling Water System Fan
Cooling Water System Water Pipe
Cooling Water System Radiator
Cooling Water System Reserve Tank
Electrical System Alternator
Electrical System Alternator [Component Parts]
Electrical System Starter
Electrical System Starter [Component Parts]
Electrical System Battery
Electrical System Switch
Electrical System Panel Board
Electrical System Panel Board [Component Parts]
Electrical System Light [Old Type] ## S.No. =72556 S.No.; =72556
Electrical System Light [New Type] ## S.No. =72557 S.No.; =72557
Electrical System Electrical Wiring [Old Type] ## S.No. =72556 S.No.; =72556
Electrical System Electrical Wiring [New Type] ## S.No. =72557 S.No.; =72557
Clutch Clutch
Clutch Clutch Lever
Clutch Clutch Pedal
Clutch Clutch Housing
Clutch Mid Case
Transmission Transmission Case
Transmission Main Shaft
Transmission Counter Shaft
Transmission Hydraulic Clutch
Transmission Shuttle Shaft
Transmission Range Gear Shaft
Transmission PTO Counter Shaft And One Way Clutch
Transmission PTO Shaft
Main Sp-Change Lever Main Gear Shift Lever
Main Sp-Change Lever Gst Shift Cover [Option]
Main Sp-Change Lever Main Gear Shift Fork
Main Sp-Change Lever Shuttle Gear Shift Lever
Main Sp-Change Lever Shuttle Gear Shift Fork
Main Sp-Change Lever Range Gear Shift Fork
Main Sp-Change Lever PTO Gear Shift Lever
Main Sp-Change Lever PTO Gear Shift Fork
Main Sp-Change Lever Spiral Bevel Pinion
Main Sp-Change Lever Rear Differential
Main Sp-Change Lever Defferential Lock Shift Fork
Rear Axle Rear Wheel Rear Axle
Rear Axle Rear Wheel Rear Wheel (15-19.5)
Brake Brake
Brake Brake Pedal ## Note Order By Ref.No.090 And 120 New Parts.
Brake Brake Rod
Front Axle Chassis Front Axle
Front Axle Chassis Front Axle Case
Front Axle Chassis Differential Gear Shaft
Front Axle Chassis Front Differential Case
Front Axle Chassis Propeller Shaft
Front Axle Chassis Front Wheel Drive Shaft
Front Axle Chassis Front Wheel Drive Lever
Front Axle Chassis Front Axle Frame
Front Rear Tire Front Wheel (27x10.5-15)
Steering Steering Linkage
Steering Steering Cylinder
Steering Steering Cylinder [Component Parts]
Steering Steering Controller
Steering Steering Handle
Hydraulic System Hydraulic Oil Line (Ps)
Hydraulic System Gst Valve
Hydraulic System Gst Valve [Gst Type] [Component Parts]
Hydraulic System Regulator Valve
Hydraulic System Hydraulic Pump
Hydraulic System Hydraulic Pump [Component Parts]
Hydraulic System Hydraulic Oil Line (Inlet)
Hydraulic System Hydraulic Oil Line (Delivery)
Hydraulic System Hydraulic Cylinder
Hydraulic System Lift Arm
Hydraulic System Control Valve
Hydraulic System Control Valve [Component Parts]
Hydraulic System Position Control Lever
Hydraulic System Feed Back Lever
Hydraulic System Directional Valve Lever
Hydraulic System 3-Point Linkage 1 (Lower Link)
Hydraulic System 3-Point Linkage 2 (Lift Rod)
Hydraulic System Top Link Holder And PTO Protector
Hood Bonnet Front Grille
Hood Bonnet Hood (Bonnet) And Side Cover
Hood Bonnet Shutter Plate
Hood Bonnet Panel Frame
Hood Bonnet Fender
Hood Bonnet Floor Seat
Hood Bonnet Seat
Hood Bonnet Reversible Seat Base [Component Parts]
Hood Bonnet Step
Hood Bonnet Main Frame
Rops Rops And Fops
Labels Label 1
Labels Label 2
Accessories Accessories And Service Parts
