Kubota Tractor L1501HST Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota L1501HST Tractor
Number of Pages: 225 Pages
Frequently Used Ite Ms [Ec] / Frequently Used Items [Ec]
Crankcase / Crankcase
Oil Pan / Oil Pan
Cylinder Head / Cylinder Head
Gear Case / Gear Case
Head Cover / Head Cover
Dipstick / Dipstick
Main Bearing Case / Main Bearing Case
Camshaft And Idle Gear Shaft / Camshaft And Idle Gear Shaft
Piston And Crankshaft / Piston And Crankshaft
Flywheel / Flywheel
Fuel Camshaft / Fuel Camshaft
Idle Apparatus / Idle Apparatus
Engine Stop Lever / Engine Stop Lever
Injection Pump / Injection Pump
Governor / Governor
Speed Control Plate / Speed Control Plate
Nozzle Holder And Glow Plug / Nozzle Holder And G Low Plug
Nozzle Holder [Component Parts] / Nozzle Holder [ Component Parts]
Water Flange And Thermostat / Water Flange And Th Ermostat
Water Pump / Water Pump
Valve And Rocker Arm / Valve And Rocker Arm
Inlet Manifold / Inlet Manifold
Exhaust Manifold / Exhaust Manifold
Air Cleaner / Air Cleaner
Muffler / Muffler
Turbo Charger / Turbo Charger
Oil Pipe (Turbo Charger) / Oil Pipe (Turbo Charge R)
Hydraulic Pump Holder / Hydraulic Pump Holder
Engine Electrical Parts / Engine Electrical Parts
Accelerator Lever / Accelerator Lever
Auto Throttle Cam / Auto Throttle Cam
Fuel Tank / Fuel Tank
Fuel Pipe / Fuel Pipe
Fuel Filter / Fuel Filter
Fuel Filter [Component Parts] / Fuel Fi Lter [Component Parts]
Fan / Fan
Water Pipe / Water Pi Pe
Radiator / Radiator
Reserve Tank / Reserv E Tank
Alternator / Alternator
Alternator [Component Parts ] / Alternator [Component Parts]
Starter / Starter
Starter [Component Parts] / Starter [Component Parts]
Battery / Battery
Switch/Sensor (Engine) / Sw Itch/Sensor (Engine)
Sensor (Transmission Case/H St) / Sensor (Transmission Case/Hst)
Switch/Sensor (Horn/Fuel) / Switch/Sensor (Horn/Fuel)
Switch/Sensor (Panel Frame/ Pedal) / Switch/Sensor (Panel Frame/Pedal)
Switch (Rear) / Switch (Rea R)
Switch (Panel) / Switch (Pa Nel)
Relay / Relay
Ecu / Ecu
Panel Board / Panel Board
Head Light [Ec] / Head Ligh T [Ec]
Winker Lamp / Winker Lamp
Tail Light / Tail Light
License Lamp / License Lamp
Trailer Socket / Trailer So Cket
Electrical Wiring (Front) [ Old] / Electrical Wiring (Front) [Old]
Electrical Wiring (Front) [ New] / Electrical Wiring (Front) [New]
Electrical Wiring (Rear) [O Ld] / Electrical Wiring (Rear) [Old]
Electrical Wiring (Rear) [N Ew] / Electrical Wiring (Rear) [New]
Clutch / Clutch
Clutch Lever / Clutch L Ever
Clutch Pedal / Clutch P Edal
Clutch Housing / Clutch Housing
Hst (Servo Piston) [Com Ponent Parts] / Hst (Servo Piston) [Component Parts ]
Hst (Servo Regulator) [ Component Parts] / Hst (Servo Regulator) [Component Parts]
Hst (Solenoid Valve) [C Omponent Parts] / Hst (Solenoid Valve) [Component Parts]
Hst (Relief Valve) [Com Ponent Parts] / Hst (Relief Valve) [Component Parts ]
Hst (Cylinder Block) [C Omponent Parts] / Hst (Cylinder Block) [Component Parts]
Hst (Port Block Cover) [Component Parts] / Hst (Port Block Cover) [Compone Nt Parts]
Hst (Charge Pump) [Comp Onent Parts] / Hst (Charge Pump) [Component Parts]
Hst (Input Shaft) [Comp Onent Parts] / Hst (Input Shaft) [Component Parts]
Mid Case / Mid Case
Pto Clutch Valve/Bearin G Holder / Pto Clutch Valve/Bearing Holder
Pto Clutch Valve [Compo Nent Parts] [Old] / Pto Clutch Valve [Component Par Ts] [Old]
Pto Clutch Valve [Compo Nent Parts] [New] / Pto Clutch Valve [Component Par Ts] [New]
Transmission Case / Tra Nsmission Case
Range Gear Shaft / Rang E Gear Shaft
Spiral Bevel Pinion / S Piral Bevel Pinion
Rear Differential / Rea R Differential
Pto Countershaft / Pto Countershaft
Pto Clutch / Pto Clutch
Pto Clutch [Component Parts] / Pto Clutch [Component Parts]
Pto Shaft / Pto Shaft
Range Gear Shift Fork / Range Gear Shift F Ork
Differential Lock Shift Fork / Differentia L Lock Shift Fork
Speed Control Pedal / Speed Control Pedal
Range Gear Shift Lever / Range Gear Shift Lever
Front Wheel Drive Lever / Front Wheel Driv E Lever
Rear Axle Lh / Rear Axle Lh
Rear Axle Rh / Rear Axle Rh
Brake Lh / Brake Lh
Brake Rh / Brake Rh
Brake Rod (Brake Pedal) / Brake Rod (Brake Pedal)
Brake Rod (Brake Cam) / Brake R Od (Brake Cam)
Hand Brake (Support) / Hand Bra Ke (Support)
Hand Brake (Lever) / Hand Brake (Lever)
Brake Pedal / Brake Pedal
Front Axle Frame [Ec] / F Ront Axle Frame [Ec]
Propeller Shaft / Propell Er Shaft
Front Wheel Drive Shaft / Front Wheel Drive Shaft
Front Differential Case / Front Differential Case
Bevel Gear (Front) / Beve L Gear (Front)
Differential (Front) / Di Fferential (Front)
Front Axle Case Lh / Fron T Axle Case Lh
Front Axle Case Rh / Fron T Axle Case Rh
Bevel Gear Shaft / Bevel Gear Shaft
Front Axle / Front Axle
Steering Wheel / Steering Wheel
Tilt Pedal / Tilt Pedal
Universal Joint / Universal Joint
Steering Controller / Steering Controller
Tie Rod/Steering Cylinder / Tie Rod/Steering Cylinder
Steering Cylinder [Component Parts] [Old] / S Teering Cylinder [Component Parts] [Old]
Hydraulic Pump / Hydraulic Pu Mp
Hydraulic Pump [Component Par Ts] / Hydraulic Pump [Component Parts]
Hydraulic Oil Line (Delivery) / Hydraulic Oil Line (Delivery)
Hydraulic Oil Line (Power Ste Ering) / Hydraulic Oil Line (Power Steering)
Hydraulic Oil Line (Pto) / Hy Draulic Oil Line (Pto)
Hydraulic Outlet Block / Hydr Aulic Outlet Block
Oil Cooler / Oil Cooler
Hydraulic Oil Line (Oil Coole R) / Hydraulic Oil Line (Oil Cooler)
Lift Arm / Lift Arm
Feed Back Lever / Feed Back L Ever
Control Valve / Control Valve
Control Valve [Component Part S] / Control Valve [Component Parts]
Safety Valve/Relief Valve / S Afety Valve/Relief Valve
3p Cylinder Rh / 3p Cylinder Rh
3p Cylinder Lh / 3p Cylinder Lh
3p Cylinder [Component Parts] [Old] / 3p Cylinder [Component Parts] [Old]
3p Cylinder [Component Parts] [New] / 3p Cylinder [Component Parts] [New]
Position Control Lever / Posi Tion Control Lever
Auxiliary Control Valve Lever (1st) [Ec] / Auxiliary Control Valve Lever (1st) [ Ec]
Auxiliary Control Valve [Comp Onent Parts] [Ec] / Auxiliary Control Valve [Compon Ent Parts] [Ec]
Auxiliary Control Valve Coupl Er / Auxiliary Control Valve Coupler
Top Link / Top Link
3-P Oint Linkage (Lower Link) / 3-Point Linkage (Lower Link)
3-P Oint Linkage (Lift Rod) / 3-Point Linkage (Lift Rod )
Dra Wbar / Drawbar
Fro Nt Hitch / Front Hitch
Pto Protector / Pto Protector
Front Grille / Front Grille
Hood (Bonnet) Front Support / Hood (Bon Net) Front Support
Hood (Bonnet) Upper / Hood (Bonnet) Upp Er
Hood (Bonnet) Link / Hood (Bonnet) Link
Side Cover Lower / Side Cover Lower
Shutter Plate (Front) / Shutter Plate ( Front)
Panel Frame / Panel Frame
Shield / Shield
Panel Cover / Panel Cover
Fender / Fender
Floor Sheet / Floor Sheet
Step / Step
Tool Box / Tool Box
Ro Ps [Old] / Rops [Old]
Front Wheel (29*12.00-15) / Fro Nt Wheel (29*12.00-15)
Front Wheel (8-16) / Front Whee L (8-16)
Front Wheel (9.5-16) / Front Wh Eel (9.5-16)
Rear Wheel (12.4-28-4pr) / Rear Wheel (12.4-28-4pr)
Rear Wheel (13.6-28) / Rear Whe El (13.6-28)
Rear Wheel (475/65-D20) / Rear Wheel (475/65-D20)
Label 1 (Front) / Label 1 (Front)
Label 2 (Panel) / Label 2 (Panel)
Label 3 (Rear) / Label 3 (Rear)
Acc Essories And Service Parts / Accessories And Servic E Parts
Working Light Kit [Option] / Working Light Kit [O Ption]
Auxiliary Control Valve [Option] / Auxiliary Cont Rol Valve [Option]
Auxiliary Control Valve (Floating) [Option] / Aux Iliary Control Valve (Floating) [Option]
Auxiliary Control Valve (Single) [Option] / Auxil Iary Control Valve (Single) [Option]
Oil Pan / Oil Pan
Dipstick / Dipstick
Flywheel / Flywheel
Governor / Governor
Muffler / Muffler
Fan / Fan
Radiator / Radiator
Starter / Starter
Battery / Battery
Relay / Relay
Ecu / Ecu
Clutch / Clutch
Mid Case / Mid Case
Brake Lh / Brake Lh
Brake Rh / Brake Rh
Lift Arm / Lift Arm
Top Link / Top Link
Dra Wbar / Drawbar
Shield / Shield
Fender / Fender
Step / Step
Tool Box / Tool Box
