Kubota Tractor L1501HST Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota L1501HST Tractor
Number of Pages: 381 Pages
Artículos Utilizados Frecuentemente [Ec] / Frequently Used Items [Ec]
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Engranaje Caja / Gear Case
Culata Cubierta / Head Cover
Medidor,Aceite / Dipstick
Volante / Flywheel
Combustible Arbol De Levas / Fuel Camshaft
Compensador / Balancer
Motor Parar Palanca / Engine Stop Lever
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Hidraulico Bomba Soporte / Hydraulic Pump Holder
Piezas Electricas Del Motor / Engine Electrical Parts
Palanca Del Acelerador / Accelerator Lever
Leva Auto De La Valvula Reguladora / Auto Throttle Cam
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Sensor (Transmisión Caja/ / Sensor (Transmission Case/Hst)
Conmutador/Sensor (Claxon/Combustible) / Switch/Sensor (Horn/Fuel)
Conmutador/Sensor (Wandplatterahmen/Pedal) / Switch/Sensor (Panel Frame/Pedal)
Conmutador (Trasera) / Switch (Rear)
Conmutador (Panel) / Switch (Panel)
Relé / Relay
Ecu
Faro Delantero [Ec] / Head Light [Ec]
Intermitente Lampara / Winker Lamp
Cola Luz / Tail Light
Luz Matricula / License Lamp
Electrico Cableado (Adelante) [Antiguo] / Electrical Wiring (Front) [Old]
Electrico Cableado (Adelante) [Nuevo] / Electrical Wiring (Front) [New]
Electrico Cableado (Trasero) [Antiguo] / Electrical Wiring (Rear) [Old]
Electrico Cableado (Trasero) [Nuevo] / Electrical Wiring (Rear) [New]
Embrague / Clutch
Embrague Palanca / Clutch Lever
Embrague Pedal / Clutch Pedal
Hst (Pistón Del Servo) [Componente Piezas] / Hst (Servo Piston) [Component Parts]
Hst (Regulador Del Servo) [Componente Piezas] / Hst (Servo Regulator) [Component Parts]
Hst (Válvula Solenoide) [Componente Piezas] / Hst (Solenoid Valve) [Component Parts]
Hst (Válvula De Alivio) [Componente Piezas] / Hst (Relief Valve) [Component Parts]
Hst (Bloque Cilindro) [Componente Piezas] / Hst (Cylinder Block) [Component Parts]
Hst (Puerto Bloque Cubierta) [Componente Piezas] / Hst (Port Block Cover) [Component Parts]
Hst (Bomba De Carga) [Componente Piezas] / Hst (Charge Pump) [Component Parts]
Hst (Eje De Entrada) [Componente Piezas] / Hst (Input Shaft) [Component Parts]
Caja Intermedia / Mid Case
Válvula De Embrague De La Tdf/Soporte De Cojinete / Pto Clutch Valve/Bearing Holder
Tdf Embrague Valvula [Componente Piezas] [Antiguo] / Pto Clutch Valve [Component Parts] [Old]
Tdf Embrague Valvula [Componente Piezas] [Nuevo] / Pto Clutch Valve [Component Parts] [New]
Arbol Contrarrotante / Counter Shaft
Espiral Bisel Pinon / Spiral Bevel Pinion
Arbol Contrarrotante De Tdf / Pto Countershaft
Tdf Embrague / Pto Clutch
Tdf Embrague [Componente Piezas] / Pto Clutch [Component Parts]
Tdf Eje / Pto Shaft
Velocidad Control Pedal / Speed Control Pedal
Freno Izquierdo / Brake Lh
Freno Derecho / Brake Rh
Freno Varilla (Freno Pedal) / Brake Rod (Brake Pedal)
Varilla De Freno (Leva De Freno) / Brake Rod (Brake Cam)
Freno De Mano (Soporte) / Hand Brake (Support)
Freno De Mano (Palanca) / Hand Brake (Lever)
Freno Pedal / Brake Pedal
Adelante Eje Bastidor [Ec] / Front Axle Frame [Ec]
Eje Impulsor De La Rueda Delantera / Front Wheel Drive Shaft
Diferencial (Anterior) / Differential (Front)
Eje De Engranaje Conico / Bevel Gear Shaft
Eje Delantero / Front Axle
Universal Junta / Universal Joint
Direccion Cilindro [Componente Piezas] [Antiguo] / Steering Cylinder [Component Parts] [Old]
Direccion Cilindro [Componente Piezas] [Nuevo] / Steering Cylinder [Component Parts] [New]
Hidraulico Aceite Linea (Entrada) / Hydraulic Oil Line (Inlet)
Hidraulico Aceite Linea (Impulsion) / Hydraulic Oil Line (Delivery)
Hidraulico Aceite Linea (Dirección Asistida) / Hydraulic Oil Line (Power Steering)
Hidraulico Aceite Linea (Tdf) / Hydraulic Oil Line (Pto)
Bloque De Salida Hidraulica / Hydraulic Outlet Block
Hidraulico Aceite Linea (Aceite Refrigerador) / Hydraulic Oil Line (Oil Cooler)
Ascenso Brazo / Lift Arm
3 Punto Cilindro Derecho / 3p Cylinder Rh
3 Punto Cilindro Izquierdo / 3p Cylinder Lh
3 Punto Cilindro [Componente Piezas] [Antiguo] / 3p Cylinder [Component Parts] [Old]
3 Punto Cilindro [Componente Piezas] [Nuevo] / 3p Cylinder [Component Parts] [New]
Posicion Control Palanca / Position Control Lever
Palanca De La Válvula De Control Auxiliar (Primera) [Ec] / Auxiliary Control Valve Lever (1st) [Ec]
Válvula De Control Auxiliar [Componente Piezas] [Ec] / Auxiliary Control Valve [Component Parts] [Ec]
Auxiliar Control Valvula Acoplador / Auxiliary Control Valve Coupler
Varillaje Tercer Punto (Brazo Inf) / 3-Point Linkage (Lower Link)
Varillaje Tercer Punto (Tirante) / 3-Point Linkage (Lift Rod)
Barra De Remolque / Drawbar
Puxo Dianteiro / Front Hitch
Tdf Protector / Pto Protector
Soporte Delantero De Capo / Hood (Bonnet) Front Support
Capo / Hood (Bonnet) Upper
Articulacion Capo / Hood (Bonnet) Link
Cubierta Lateral Inferior / Side Cover Lower
Piastra Parzializzatore (Adelante) / Shutter Plate (Front)
Panel Bastidor / Panel Frame
Protector / Shield
Panel Inferior / Panel Cover
Guardabarros / Fender
Hoja De Piso / Floor Sheet
Peldano / Step
Herramienta Caja / Tool Box
Arco De Seguridad [Antiguo] / Rops [Old]
Arco De Seguridad [Nuevo] / Rops [New]
Rueda Delantera (29*12.00-15) / Front Wheel (29*12.00-15)
Rueda Delantera (8-16) / Front Wheel (8-16)
Rueda Delantera (9.5-16) / Front Wheel (9.5-16)
Rueda Trasera(12.4-28-4pr) / Rear Wheel (12.4-28-4pr)
Rueda Trasera (13.6-28) / Rear Wheel (13.6-28)
Rueda Trasera (475/65-D20) / Rear Wheel (475/65-D20)
Etiqueta 1 (Adelante) / Label 1 (Front)
Etiqueta 2 (Panel) / Label 2 (Panel)
Etiqueta 3 (Trasero) / Label 3 (Rear)
Válvula De Control Auxiliar [Opcion] / Auxiliary Control Valve [Option]
Válvula De Control Auxiliar (Flotante) [Opcion] / Auxiliary Control Valve (Floating) [Option]
Válvula De Control Auxiliar (Simple) [Opcion] / Auxiliary Control Valve (Single) [Option]
