Kubota Tractor L1501HST Parts Catalog EN DE
Language: German, English
Region: Germany, England
Model: Kubota L1501HST Tractor
Number of Pages: 387 Pages
L1501hst
Frequently Used Items Frequently Used Items Häufig Verwendete Elemente [Ec] Frequently
L1501hst Motor Engine Kurbelghaeuse Crankcase
L1501hst Motor Engine Oelwanne Oil Pan
L1501hst Motor Engine Zylinderkopf Cylinder Head
L1501hst Motor Engine Getriebe Gehaeuse Gear Case
L1501hst Motor Engine Deckel Oben Head Cover
L1501hst Motor Engine Oelmessstab Dipstick
L1501hst Motor Engine Hauptlagergehaeuse Main Bearing Case
L1501hst Motor Engine Nockenwelle Und Freilaufgetriebewelle Camshaft And Idle Gear
L1501hst Motor Engine Abstuetzung Rechts Vorne Piston And Crankshaft
L1501hst Motor Engine Schwungrad Flywheel
L1501hst Motor Engine Kraftstoff-Nockenwelle Fuel Camshaft
L1501hst Motor Engine Massennausgleich Balancer
L1501hst Motor Engine Freilaufapparat Idle Apparatus
L1501hst Motor Engine Motorabstellhebel Engine Stop Lever
L1501hst Motor Engine Einspritzenpumpe Injection Pump
L1501hst Motor Engine Regler Governor
L1501hst Motor Engine Geschwindigkeits-Regler Platte Speed Control Plate
L1501hst Motor Engine Duesenhalter Gluehkerze Nozzle Holder And Glow Plug
L1501hst Motor Engine Duesenhalter [Einzel-Teil] Nozzle Holder [Component Parts]
L1501hst Motor Engine Wasserflansch Und Thermostat Water Flange And Thermostat
L1501hst Motor Engine Wasserpumpe Water Pump
L1501hst Motor Engine Ventil Kipparmwelle Valve And Rocker Arm
L1501hst Motor Engine Einlasskruemmer Inlet Manifold
L1501hst Motor Engine Auspuffrummer Exhaust Manifold
L1501hst Motor Engine Luftfilter Air Cleaner
L1501hst Motor Engine Auspufftopf Muffler
L1501hst Motor Engine Turbineladung Turbo Charger
L1501hst Motor Engine Oelpomr (Turbineladung) Oil Pipe (Turbo Charger)
L1501hst Motor Engine Hydraulikpumpe Halter Hydraulic Pump Holder
L1501hst Motor Engine Elektrische Teile F. Motor Engine Electrical Parts
L1501hst Motor Engine Beschleunigung-Hebel Accelerator Lever
L1501hst Motor Engine Selbstdrossel-Nocken Auto Throttle Cam
L1501hst Brennstoff System Fuel System Kraftstofftank Fuel Tank
L1501hst Brennstoff System Fuel System Kraftstoffrohr Fuel Pipe
L1501hst Brennstoff System Fuel System Kraftstofffilter Fuel Filter
L1501hst Brennstoff System Fuel System Kraftstofffilter [Einzel-Teil] Fuel Filter [Component
L1501hst Abkuehlung System Cooling Water System Ventilator Fan
L1501hst Abkuehlung System Cooling Water System Wasserrohr Water Pipe
L1501hst Abkuehlung System Cooling Water System Kuehler Radiator
L1501hst Abkuehlung System Cooling Water System Reservebehalter Reserve
L1501hst Elektrisch System Electrical System Lichtmaschine Alternator
L1501hst Elektrisch System Electrical System Lichtmaschine [Einzel-Teil] Alternator [
L1501hst Elektrisch System Electrical System Anlasser Starter
L1501hst Elektrisch System Electrical System Anlasser [Einzel-Teil] Starter [Component
L1501hst Elektrisch System Electrical System Batterie Battery
L1501hst Elektrisch System Electrical System Schalter Sensor (Motor) Switch Sensor
Elektrisch System Electrical System Sensor (Getriebe Gehaeuse Hydrostat) Sensor (
L1501hst Elektrisch System Electrical System Schalter Sensor (Hupe Brennstoff) Switch
Elektrisch System Electrical System Schalter Sensor (Cadre De Panneau Pedal) Switch
L1501hst Elektrisch System Electrical System Schalter (Hinter) Switch (Rear)
L1501hst Elektrisch System Electrical System Schalter (Armaturenverkleidung) Switch
L1501hst Elektrisch System Electrical System Relais Relay
L1501hst Elektrisch System Electrical System Elektronische Steuereinheit Ecu
L1501hst Elektrisch System Electrical System Instrumentenbrett Verkleidung Panel
L1501hst Elektrisch System Electrical System Scheinwerfer [Ec] Head Light [Ec]
L1501hst Elektrisch System Electrical System Blinkerlicht Winker Lamp
L1501hst Elektrisch System Electrical System Hinter Licht Tail Light
L1501hst Elektrisch System Electrical System Lizenzlampe License Lamp
L1501hst Elektrisch System Electrical System Anhaengerkupplung Trailer Socket
L1501hst Elektrisch System Electrical System Elektrische Ausrustung (Vorder) Electrical
L1501hst Elektrisch System Electrical System Elektrische Ausrustung (Hinter) Electrical
L1501hst Kupplung Transmission Clutch Transmission Kupplung Clutch
L1501hst Kupplung Transmission Clutch Transmission Kupplungshebel Clutch
L1501hst Kupplung Transmission Clutch Transmission Kupplung-Pedal Clutch
L1501hst Kupplung Transmission Clutch Transmission Kupplung-Gehaeuse Clutch
Kupplung Transmission Clutch Transmission Hst (Servokolben) [Einzel-Teil] Hst (Servo
Kupplung Transmission Clutch Transmission Hst (Servoregler) [Einzel-Teil] Hst (Servo
Kupplung Transmission Clutch Transmission Hst (Solenoidventil) [Einzel-Teil] Hst (Solenoid
Kupplung Transmission Clutch Transmission Hst (Entlastungsventil) [Einzel-Teil] Hst (Relief
Kupplung Transmission Clutch Transmission Hst (Zylinder Block) [Einzel-Teil] Hst (Cylinder
Kupplung Transmission Clutch Transmission Hst (Portblockdeckel) [Einzel-Teil] Hst (Port Block
Kupplung Transmission Clutch Transmission Hst (Ladepumpe) [Einzel-Teil] Hst (Charge Pump)
Kupplung Transmission Clutch Transmission Hst (Antriebswelle) [Einzel-Teil] Hst (Input
L1501hst Kupplung Transmission Clutch Transmission Mittlere Gehaeuse Mid Case
Kupplung Transmission Clutch Transmission Pto-Kupplungsventil Lagerhalterung Pto Clutch
Transmission Zapfwellenschalthebel [Einzel-Teil] [Alter] Pto Clutch Valve [Component Parts]
Transmission Zapfwellenschalthebel [Einzel-Teil] [Neu] Pto Clutch Valve [Component Parts]
L1501hst Kupplung Transmission Clutch Transmission Getriebe-Gehaeuse Transmission
L1501hst Kupplung Transmission Clutch Transmission Vorgelege-Welle Counter
L1501hst Kupplung Transmission Clutch Transmission Drehzahlbereichswelle Range
L1501hst Kupplung Transmission Clutch Transmission Spiral-Antriebwelle Spiral Bevel
L1501hst Kupplung Transmission Clutch Transmission Hinterachsen-Differential Rear
L1501hst Kupplung Transmission Clutch Transmission Zw Vorgelegewelle Pto
L1501hst Kupplung Transmission Clutch Transmission Zapfwellekupplung Pto
Kupplung Transmission Clutch Transmission Zapfwellenkupplung [Einzel-Teil] Pto Clutch
L1501hst Kupplung Transmission Clutch Transmission Zapfwelle Pto Shaft
Schaltgabel Schalthebel Speed Change Shift Fork Shift Lever Fourchette Fur Differentialsperre
L1501hst Getriebe Schaltgabel Schalthebel Speed Change Shift Fork Shift Lever Fahpedal Speed
Getriebe Schaltgabel Schalthebel Speed Change Shift Fork Shift Lever Drehzahlbereichshebel
Getriebe Schaltgabel Schalthebel Speed Change Shift Fork Shift Lever Vorderrad Fahrhebel
L1501hst Hinterradachse Bremse Rear Axle Brake Hinterradachse Links Rear Axle
L1501hst Hinterradachse Bremse Rear Axle Brake Hinterradachse Rechts Rear Axle
L1501hst Hinterradachse Bremse Rear Axle Brake Bremse Links Brake Lh
L1501hst Hinterradachse Bremse Rear Axle Brake Bremse Rechts Brake Rh
L1501hst Hinterradachse Bremse Rear Axle Brake Bremsstange (Bremspedal) Brake Rod (
L1501hst Hinterradachse Bremse Rear Axle Brake Bremsstange (Bremsnocke) Brake Rod
L1501hst Hinterradachse Bremse Rear Axle Brake Handbremse (Traeger) Hand Brake (
L1501hst Hinterradachse Bremse Rear Axle Brake Handbremse (Hebel) Hand Brake (
L1501hst Hinterradachse Bremse Rear Axle Brake Bremspedal Brake Pedal
L1501hst Vorderachse Rahmen Front Axle Chassis Vorderachse-Rahmen [Ec] Front Axle
L1501hst Vorderachse Rahmen Front Axle Chassis Propellerwelle Propeller
L1501hst Vorderachse Rahmen Front Axle Chassis Vorderantriebswelle Front Wheel
L1501hst Vorderachse Rahmen Front Axle Chassis Vorn Differential Gehaeuse Front
L1501hst Vorderachse Rahmen Front Axle Chassis Antriebskegelrad (Vorder) Bevel Gear
L1501hst Vorderachse Rahmen Front Axle Chassis Differential (Vorder) Differential
L1501hst Vorderachse Rahmen Front Axle Chassis Vorderachse-Gehaeuse Links Front
L1501hst Vorderachse Rahmen Front Axle Chassis Vorderachse-Gehaeuse Rechts Front
L1501hst Vorderachse Rahmen Front Axle Chassis Diff.Getriebewelle Bevel Gear
L1501hst Vorderachse Rahmen Front Axle Chassis Vorderachse Front Axle
L1501hst Lenkung Steering Lenkrad Steering Wheel
L1501hst Lenkung Steering Lenkradverstellpedal Tilt Pedal
L1501hst Lenkung Steering Universalgelent Universal Joint
L1501hst Lenkung Steering Hilfskraftlenkung Steering Controller
L1501hst Lenkung Steering Verbindungssatange Lenkungszylinder Tie Rod Steering
Lenkungszylinder [Einzel-Teil] [Alter] Steering Cylinder [Component Parts] [Old] ## S.Nr. =
Lenkungszylinder [Einzel-Teil] [Neu] Steering Cylinder [Component Parts] [New] ## S.Nr. =
L1501hst Hydraulik System Hydraulic System Hydraulikpumpe Hydraulic Pump
L1501hst Hydraulik System Hydraulic System Hydraulikpumpe [Einzel-Teil] Hydraulic Pump [
L1501hst Hydraulik System Hydraulic System Hydraulik-Kreislauf (Meeresarm) Hydraulic
L1501hst Hydraulik System Hydraulic System Hydraulik-Kreislauf (Zuleitung) Hydraulic Oil
Hydraulik System Hydraulic System Hydraulik-Kreislauf (Servolenkung) Hydraulic Oil
L1501hst Hydraulik System Hydraulic System Hydraulik-Kreislauf (Zapfwelle) Hydraulic
L1501hst Hydraulik System Hydraulic System Hudraulik-Block Hydraulic Outlet
L1501hst Hydraulik System Hydraulic System Oelkuehler Oil Cooler
L1501hst Hydraulik System Hydraulic System Hydraulik-Kreislauf (Oelkuehler) Hydraulic Oil
L1501hst Hydraulik System Hydraulic System Getriebe-Gehaeusedecken Transmission
L1501hst Hydraulik System Hydraulic System Hubarm Lift Arm
L1501hst Hydraulik System Hydraulic System Wirken Sie Hebel Rueck Feed Back
L1501hst Hydraulik System Hydraulic System Regelungsventil Control Valve
L1501hst Hydraulik System Hydraulic System Regelungsventil [Einzel-Teil] Control Valve [
L1501hst Hydraulik System Hydraulic System Sicherheitsventil Ueberdruckventil Safety
L1501hst Hydraulik System Hydraulic System p Zylinder Rechte Seitep Cylinder
L1501hst Hydraulik System Hydraulic System p Zylinder Linke Seitep Cylinder
L1501hst Hydraulik System Hydraulic System p-Zylinder [Einzel-Teil]P Cylinder [Component
L1501hst Hydraulik System Hydraulic System Positions-Steuerhebel Position Control
Hydraulik System Hydraulic System Hilfssteuerventilhebel (1st) [Ec] Auxiliary Control
Hydraulik System Hydraulic System Zusatzsteuerventile [Einzel-Teil] [Ec] Auxiliary Control
L1501hst Hydraulik System Hydraulic System Hydraulik-Kuppler Auxiliary Control Valve
Anhangerkupplung Anhangerku Vorderanhangung-Point Linkage Drawbar Hitch -Punkt Gestaenge (
L1501hst Motorhaube Hood Bonnet Vorder-Gitter Front Grille
L1501hst Motorhaube Hood Bonnet Motorhaubetragen Hood (Bonnet) Front Support
L1501hst Motorhaube Hood Bonnet Motorhaube Obere Hood (Bonnet) Upper
L1501hst Motorhaube Hood Bonnet Motorhaubeglied Hood (Bonnet) Link
L1501hst Motorhaube Hood Bonnet Seitenabdeckung Unten Side Cover Lower
L1501hst Motorhaube Hood Bonnet Verschlussplatte (Vorn) Shutter Plate (Front)
L1501hst Motorhaube Hood Bonnet Wandplatterahmen Panel Frame
L1501hst Motorhaube Hood Bonnet Schild Shield
L1501hst Motorhaube Hood Bonnet Tafeldecken Panel Cover
L1501hst Motorhaube Hood Bonnet Kotfluegel Fender
L1501hst Motorhaube Hood Bonnet Aufboden Floor Sheet
L1501hst Motorhaube Hood Bonnet Tritt Step
L1501hst Motorhaube Hood Bonnet Werkzeugkasten Tool Box
Sicherheitsrahmen Rops Sicherheitsrahmen [Alter] Rops [Old] ## S.Nr. =30916 S.No.; =30916 S.
Sicherheitsrahmen Rops Sicherheitsrahmen [Neu] Rops [New] ## S.Nr. =30917 S.No.; =30917 S.
L1501hst Vorder Hinter Reifen Front Rear Tire Vorderrad (292.00-15) Front Wheel (29
L1501hst Vorder Hinter Reifen Front Rear Tire Vorderrad (8-16) Front Wheel (8-
L1501hst Vorder Hinter Reifen Front Rear Tire Vorderrad (9.5-16) Front Wheel (9.5-
L1501hst Vorder Hinter Reifen Front Rear Tire Hinterrad(12.4-28-4pr) Rear Wheel (12.4-
L1501hst Vorder Hinter Reifen Front Rear Tire Hinterrad (13.6-28) Rear Wheel (13.6-
L1501hst Vorder Hinter Reifen Front Rear Tire Hinterrad (475 65-D20) Rear Wheel (475
L1501hst Aufkleber Labels Aufkleber (Vorder) Label (Front)
L1501hst Aufkleber Labels Aufkleber (Armaturenverkleidung) Label (Panel)
L1501hst Aufkleber Labels Aufkleber (Hinten) Label (Rear)
L1501hst Option Option Arbeitsschinwerfer [Option] Working Light Kit [Option]
L1501hst Option Option Hilfssteuerventil [Option] Auxiliary Control Valve [Option]
L1501hst Option Option Hilfssteuerventil (Frei) [Option] Auxiliary Control Valve (Floating)
L1501hst Option Option Hilfssteuerventil (Einzig) [Option] Auxiliary Control Valve (Single)
L1501hst
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
