Kubota Tractor L1501DT Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota L1501DT Tractor
Number of Pages: 206 Pages
Itens Usados F Requentemente [Ec] [Se] / Frequently Used Items [Ec ] [Se]
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Vareta Nivel E Guia / Dipstick
Volante Motor / Flywheel
Veio / Fuel Camshaft
Compensador / Balancer
Ponto Neutro / Idle Apparatus
Solenoide Paragem / Engine Stop Lever
Suporte Bico [Peças Componentes] / Nozzle Holder [C Omponent Parts]
Bomba Agua E Termostacto / Water Flange And Thermos Tat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Escpae / Muffler
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Char Ger)
Suporte De Bomba Hidraulico / Hydraulic Pump Holder
Componentes Electricos Motor / Engine Electrical Pa Rts
Alavanca Acelarador / Accelerator Lever
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo / Fuel Filter
Filtro Gasoleo [Peças Compone Ntes] / Fuel Filter [Component Parts]
Ventoinha / Fan
Tubo Agua / Water Pipe
Deposito Re Serva / Reserve Tank
Alternador [Peças Componente S] / Alternator [Component Parts]
Motor Arranque / Starter
Interruptor/Sensor (Bloco Mo Tor) / Switch/Sensor (Engine)
Interruptor/Sensor (Transmis São Carter ) / Switch/Sensor (Transmission Case)
Interruptor/Sensor (Buzina/C Ombustivel) / Switch/Sensor (Horn/Fuel)
Interruptor (Painel) / Switc H (Panel Frame)
Interruptor (Traseiros) / Sw Itch (Rear)
Interruptor (Painel ) / Switch (Panel)
Rele / Relay
Unidade Control Electrico / Ecu
Quadro Do Painel / Panel Boa Rd
Luzes Frente [Ec] [Se] [Tur] / Head Light [Ec] [Se] [Tur]
Lampada / Winker Lamp
Farol Traseiro / Tail Light
Farol Matricula / License La Mp
Ficha Reboque / Trailer Sock Et
Cablagem Electrica (Dianteir O) [Antigo] / Electrical Wiring (Front) [Old]
Cablagem Electrica (Dianteir O) [Novo] / Electrical Wiring (Front) [New]
Cablagem Electrica (Traseiro S) [Antigo] / Electrical Wiring (Rear) [Old]
Cablagem Electrica (Traseiro S) [Novo] / Electrical Wiring (Rear) [New]
Alavanca Da Embraiage M / Clutch Lever
Pedal Embraiagem / Cl Utch Pedal
Carter Embraiagem / C Lutch Housing
Caixa Intermedia / Mi D Case
Valvula Embraiagem Td F [Peças Componentes] / Pto Clutch Valve [Component Parts]
Caixa Da Transmissão / Transmission Case
Veio Primario / Main Shaft
Veio Secundario / Cou Nter Shaft
Veio Inversor / Shutt Le Shaft
Inversor / Reverse Sh Aft
Veio Gamas Velocidade S / Range Gear Shaft
Pinhao Espiral / Spir Al Bevel Pinion
Diferencial Traseiro / Rear Differential
Contraveio De Tdf / P To Countershaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf [Peças Componentes] / Pto Clutch [Component Parts]
Veio Principal Tdf / Pto Drive Shaft
Veio Tdf / Pto Shaft
Forqueta V Elocidades / Range Gear Shift Fork
Bloqueio D Iferencial De Forqueta / Differential Lock Shift Fo Rk
Alavanca V Elocidades / Main Gear Shift Lever
Alvanca In Versor / Shuttle Shift Lever
Gama Alava Nca De Velocidades / Range Gear Shift Lever
Alavanca D Upla Traccao / Front Wheel Drive Lever
Eixo Traseiro (Lado Esquer Do) / Rear Axle Lh
Eixo Traseiro (Lado Direit O) / Rear Axle Rh
Travao Esq / Brake Lh
Travao Drt / Brake Rh
Tirante Travao (Pedal Trav Ao) / Brake Rod (Brake Pedal)
Tirante Travao (Freio Cam) / Brake Rod (Brake Cam)
Travao Mao (Suporte) / Han D Brake (Support)
Travao Mao (Alavanca) / Ha Nd Brake (Lever)
Pedal Travao / Brake Pedal
Quadro Eixo Frente [Se] / Front Axle Frame [Se]
Veio Eixo / Front Wheel Drive Shaft
Caixa Do Diferencial Di Anteiro / Front Differential Case
Engrenagem Cónica (Dian Teira) / Bevel Gear (Front)
Diferencial (Dianteiro) / Differential (Front)
Carter Eixo Frente Esqu Erda / Front Axle Case Lh
Carter Eixo Frente Dire Ita / Front Axle Case Rh
Veio Grupo Conico / Bev El Gear Shaft
Eixo Dianteiro / Front Axle
Pedal Inclinacao / Tilt Pedal
Junta Universal / Universal Joint
Distribuidor Direcção / Steering Controller
Rotula/Cilindro Direcção / Tie Rod/Steering Cy Linder
Cilindro Direcção [Peças Componentes] [Antigo] / Steering Cylinder [Component Parts] [Old]
Cilindro Direcção [Peças Componentes] [Novo] / Steering Cylinder [Component Parts] [New]
Bomba Hidraulico [Peças Comp Onentes] / Hydraulic Pump [Component Parts]
Valvula Reguladora / Regulat Er Valve
Linha De Óleo Hidráulico (En Trada) / Hydraulic Oil Line (Inlet)
Tubo Oleo (Entrega) / Hydrau Lic Oil Line (Delivery)
Tubo Oleo (Tdf) / Hydraulic Oil Line (Pto)
Bloco Saidas Hidraulico / Hy Draulic Outlet Block
Tampa Da Transmissão / Trans Mission Case Cover
Braco Hidraulico / Lift Arm
Alavanca / Feed Back Lever
Valvula Control / Control Va Lve
Valvula Control [Peças Compo Nentes] / Control Valve [Component Parts]
Valvula Segurança/Descarga V Alvula / Safety Valve/Relief Valve
3p Cilindro (Direito) [Se] [ Tur] / 3p Cylinder Rh [Se] [Tur]
3p Cilindro (Esquerdo) [Se] [Tur] / 3p Cylinder Lh [Se] [Tur]
3p Cilindro[Peças Componente S] [Antigo] / 3p Cylinder [Component Parts] [Old]
3p Cilindro[Peças Componente S] [Novo] / 3p Cylinder [Component Parts] [New]
Alavanca Control Posicao [Se ] [Tur] / Position Control Lever [Se] [Tur]
Controlposicao E Profundidad E [Se] [Tur] / Position And Draft Control Link [Se] [Tur]
Control Posiçáo [Se] [Tur] / Draft Control Lever [Se] [Tur]
Suporte Terceiro Ponto [Se] [Tur] / Top Link Holder [Se] [ Tur]
Ligação [Se] [Tur] / Top Link [Se] [Tur]
Ligação 3 Pontos (Ligação Inferior) [Se] / 3-Point Linkage (Lower Link) [Se]
Ligação 3 Pontos (Tirante De Elevação) [Ec] [Uk] [Se] / 3- Point Linkage (Lift Rod) [Ec] [Uk] [Se]
Barra R Eboque / Drawbar
Puxo Di Anteiro / Front Hitch
Protecc Ao Tdf [Se] [Tur] / Pto Protector [Se] [Tur]
Suporte Dianteiro Capot / Hood (Bonnet) Front Support
Articulacao Capot / Hood (Bonnet) Link
Tapa Lateral Baixa / Side Cover Lower
Placa Do Obturador (Dianteiro) / Shutter Plate (Front)
Estrutura Do Painel / Panel Frame
Protecção / Shield
Painel Inferior / Panel Cover
Guarda Lamas [Ec] [Uk] [Se] / Fender [Ec] [Uk] [Se]
Floor Sheet / Floor Sheet
Degrau [Ec] [Uk] [Se] / Step [Ec] [Uk] [Se]
Caixa Ferramenta [Se] [Tur] / Tool Box [Se] [T Ur]
Rop S (Estrutura De Protecção) [Se] [Tur] / Rops [Se] [ Tur]
Roda Frente (29*12.00-15) / Front Wh Eel (29*12.00-15)
Roda Frente (9.5-16) / Front Wheel ( 9.5-16)
Roda Traseira (13.6-28) / Rear Wheel (13.6-28)
Roda Traseira (475/65-D20) / Rear Wh Eel (475/65-D20)
Etiqueta 1 (Dianteiro) / Label 1 (Front)
Etiqueta 2 (Painel) / Label 2 (Panel)
Etiqueta 3 (Traseira) / Label 3 (Rear)
Acessor Ios E Peças Serviço / Accessories And Service Parts
Kit Farios Trabalho [Opção] / Working Light Kit [Op Tion]
Carreto / Gear Case
Escpae / Muffler
Ventoinha / Fan
Rele / Relay
Protecção / Shield
