Kubota Tractor L1501DT Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota L1501DT Tractor
Number of Pages: 387 Pages
Artículos Utilizados Frecuentemente [Ec] [Se] / Frequently Used Items [Ec] [Se]
Artículos Utilizados Frecuentemente [Uk] / Frequently Used Items [Uk]
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Engranaje Caja / Gear Case
Culata Cubierta / Head Cover
Medidor,Aceite / Dipstick
Volante / Flywheel
Combustible Arbol De Levas / Fuel Camshaft
Compensador / Balancer
Motor Parar Palanca / Engine Stop Lever
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Hidraulico Bomba Soporte / Hydraulic Pump Holder
Piezas Electricas Del Motor / Engine Electrical Parts
Palanca Del Acelerador / Accelerator Lever
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador/Sensor (Transmisión Caja) / Switch/Sensor (Transmission Case)
Conmutador/Sensor (Claxon/Combustible) / Switch/Sensor (Horn/Fuel)
Conmutador (Panel Bastidor) / Switch (Panel Frame)
Conmutador (Trasera) / Switch (Rear)
Conmutador (Panel) / Switch (Panel)
Relé / Relay
Ecu
Faro Delantero [Ec] [Se] [Tur] / Head Light [Ec] [Se] [Tur]
Faro Delantero [Uk] / Head Light [Uk]
Intermitente Lampara / Winker Lamp
Cola Luz / Tail Light
Luz Matricula / License Lamp
Electrico Cableado (Adelante) [Antiguo] / Electrical Wiring (Front) [Old]
Electrico Cableado (Adelante) [Nuevo] / Electrical Wiring (Front) [New]
Electrico Cableado (Trasero) [Antiguo] / Electrical Wiring (Rear) [Old]
Electrico Cableado (Trasero) [Nuevo] / Electrical Wiring (Rear) [New]
Embrague / Clutch
Embrague Palanca / Clutch Lever
Caja Intermedia / Mid Case
Tdf Embrague Valvula [Componente Piezas] / Pto Clutch Valve [Component Parts]
Eje Principal / Main Shaft
Arbol Contrarrotante / Counter Shaft
Espiral Bisel Pinon / Spiral Bevel Pinion
Arbol Contrarrotante De Tdf / Pto Countershaft
Tdf Embrague / Pto Clutch
Tdf Embrague [Componente Piezas] / Pto Clutch [Component Parts]
Tdf Eje / Pto Shaft
Inversor Cambio Bifurcacion / Shuttle Shift Fork
Palanca De La Cambio De Engranaje / Range Gear Shift Lever
Trasero Eje Izquierdo / Rear Axle Rh
Freno Izquierdo / Brake Lh
Freno Derecho / Brake Rh
Freno Varilla (Freno Pedal) / Brake Rod (Brake Pedal)
Varilla De Freno (Leva De Freno) / Brake Rod (Brake Cam)
Freno De Mano (Soporte) / Hand Brake (Support)
Freno De Mano (Palanca) / Hand Brake (Lever)
Freno Pedal / Brake Pedal
Adelante Eje Bastidor [Ec] / Front Axle Frame [Ec]
Adelante Eje Bastidor [Uk] / Front Axle Frame [Uk]
Eje Impulsor De La Rueda Delantera / Front Wheel Drive Shaft
Diferencial (Anterior) / Differential (Front)
Eje De Engranaje Conico / Bevel Gear Shaft
Eje Delantero / Front Axle
Universal Junta / Universal Joint
Cilindro De Direccion [Componente Piezas] [Antiguo] / Steering Cylinder [Component Parts] [Old]
Cilindro De Direccion [Componente Piezas] [Nuevo] / Steering Cylinder [Component Parts] [New]
Regulador Valvula / Regulater Valve
Hidraulico Aceite Linea (Entrada) / Hydraulic Oil Line (Inlet)
Linea De Aceite Hidraulico (Impulsion) / Hydraulic Oil Line (Delivery)
Hidraulico Aceite Linea (Direccion) / Hydraulic Oil Line (Power Steering)
Hidraulico Aceite Linea (Tdf) / Hydraulic Oil Line (Pto)
Bloque De Salida Hidraulica / Hydraulic Outlet Block
Ascenso Brazo / Lift Arm
Distribuidor / Control Valve
3 Punto Cilindro (Lado Derecho) [Ec] [Uk] / 3p Cylinder Rh [Ec] [Uk]
3 Punto Cilindro (Lado Izquierdo) [Ec] [Uk] / 3p Cylinder Lh [Ec] [Uk]
3 Punto Cilindro [Componente Piezas] [Antiguo] / 3p Cylinder [Component Parts] [Old]
3 Punto Cilindro [Componente Piezas] [Nuevo] / 3p Cylinder [Component Parts] [New]
Posicion Control Palanca [Ec] [Uk] / Position Control Lever [Ec] [Uk]
Palanca De La Válvula De Control Auxiliar (Primera) [Ec] [Se] / Auxiliary Control Valve Lever (1st) [Ec] [Se]
Palanca De La Válvula De Control Auxiliar (Primera) [Uk] / Auxiliary Control Valve Lever (1st) [Uk]
Válvula De Control Auxiliar [Componente Piezas] [Ec] / Auxiliary Control Valve [Component Parts] [Ec]
Válvula De Control Auxiliar (Flotador) [Componente Piezas] [Uk] / Auxiliary Control Valve (Floating) [Component Parts] [Uk]
Auxiliar Control Valvula Acoplador [Ec] [Uk] / Auxiliary Control Valve Coupler [Ec] [Uk]
Varillaje Tercer Punto (Brazo Inf) / 3-Point Linkage (Lower Link)
Varillaje Tercer Punto (Tirante) [Ec] [Uk] [Se] / 3-Point Linkage (Lift Rod) [Ec] [Uk] [Se]
Barra De Remolque / Drawbar
Enganche Delantero / Front Hitch
Tdf Protector [Ec] [Uk] / Pto Protector [Ec] [Uk]
Soporte Delantero De Capo / Hood (Bonnet) Front Support
Capo / Hood (Bonnet) Upper
Articulacion Capo / Hood (Bonnet) Link
Cubierta Lateral Inferior / Side Cover Lower
Piastra Parzializzatore (Adelante) / Shutter Plate (Front)
Panel Bastidor / Panel Frame
Protector / Shield
Panel Inferior / Panel Cover
Guardabarros [Ec] [Uk] [Se] / Fender [Ec] [Uk] [Se]
Hoja De Piso / Floor Sheet
Floor Sheet
Peldano [Ec] [Uk] [Se] / Step [Ec] [Uk] [Se]
Herramienta Caja [Ec] [Uk] [Tur] / Tool Box [Ec] [Uk] [Tur]
Rops (Arco Seguridad) [Ec] [Uk] [Antiguo] / Rops [Ec] [Uk] [Old]
Rops (Arco Seguridad) [Se] [Tur] [Nuevo] / Rops [Se] [Tur] [New]
Rueda Delantera (29*12.00-15) / Front Wheel (29*12.00-15)
Rueda Delantera (9.5-16) / Front Wheel (9.5-16)
Rueda Trasera (13.6-28) / Rear Wheel (13.6-28)
Rueda Trasera (475/65-D20) / Rear Wheel (475/65-D20)
Etiqueta 1 (Adelante) / Label 1 (Front)
Etiqueta 2 (Panel) / Label 2 (Panel)
Etiqueta 3 (Trasero) / Label 3 (Rear)
Parachoques Delantero [Uk] [Opcion] / Front Bumper Kit [Uk] [Option]
Auxiliar Control Valvula [Opcion] / Auxiliary Control Valve [Option]
Válvula De Control Auxiliar (Flotante) [Opcion] / Auxiliary Control Valve (Floating) [Option]
Válvula De Control Auxiliar (Simple) [Opcion] / Auxiliary Control Valve (Single) [Option]
Volante / Flywheel
Ventilador / Fan
Relé / Relay
Ecu
Embrague / Clutch
Tdf Eje / Pto Shaft
Protector / Shield
Floor Sheet
