Kubota Tractor L1501DCN Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota L1501DCN Tractor
Number of Pages: 411 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Engranaje Caja / Gear Case
Culata Cubierta / Head Cover
Medidor Aceite / Dipstick
Volante / Flywheel
Combustible Arbol De Levas / Fuel Camshaft
Compensador / Balancer
Motor Parar Palanca / Engine Stop Lever
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Hidraulico Bomba Soporte / Hydraulic Pump Holder
Piezas Electricas Del Motor / Engine Electrical Parts
Palanca Del Acelerador / Accelerator Lever
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Interruptor/Sensor (Transmisión Caja) / Switch/Sensor (Transmission Case)
Conmutador/Sensor (Claxon/Combustible) / Switch/Sensor (Horn/Fuel)
Conmutador (Panel Bastidor) / Switch (Panel Frame)
Interruptor (Trasera) / Switch (Rear)
Conmutador (Panel Tablero) / Switch (Panel)
Rele / Relay
Ecu
Faro Delantero / Head Light
Intermitente Lampara / Winker Lamp
Cola Luz / Tail Light
Electrico Cableado (Adelante) [Antiguo] / Electrical Wiring (Front) [Old]
Electrico Cableado (Adelante) [Nuevo] / Electrical Wiring (Front) [New]
Electrico Cableado (Posterior) [Antiguo] / Electrical Wiring (Rear) [Old]
Electrico Cableado (Posterior) [Nuevo] / Electrical Wiring (Rear) [New]
Embrague / Clutch
Embrague Palanca / Clutch Lever
Caja Intermedia / Mid Case
Tdf Embrague Valvula [Componente Piezas] / Pto Clutch Valve [Component Parts]
Eje Principal / Main Shaft
Arbol Contrarrotante / Counter Shaft
Espiral Bisel Pinon / Spiral Bevel Pinion
Arbol Contrarrotante De Tdf / Pto Countershaft
Tdf Embrague / Pto Clutch
Tdf Embrague [Componente Piezas] / Pto Clutch [Component Parts]
Tdf Eje / Pto Shaft
Inversor Cambio Bifurcacion / Shuttle Shift Fork
Palanca De La Cambio De Engranaje / Range Gear Shift Lever
Freno Izquierdo / Brake Lh
Freno Derecho / Brake Rh
Varilla De Freno (Pedal De Freno) / Brake Rod (Brake Pedal)
Varilla De Freno (Leva De Freno) / Brake Rod (Brake Cam)
Freno De Mano (Soporte) / Hand Brake (Support)
Freno De Mano (Palanca) / Hand Brake (Lever)
Freno Pedal / Brake Pedal
Eje Impulsor De La Rueda Delantera / Front Wheel Drive Shaft
Diferencial (Anterior) / Differential (Front)
Eje De Engranaje Conico / Bevel Gear Shaft
Universal Junta / Universal Joint
Cilindro De Direccion [Componente Piezas] [Antiguo] / Steering Cylinder [Component Parts] [Old]
Cilindro De Direccion [Componente Piezas] [Nuevo] / Steering Cylinder [Component Parts] [New]
Regulador Valvula / Regulater Valve
Hidraulico Aceite Linea (Entrada) / Hydraulic Oil Line (Inlet)
Linea De Aceite Hidraulico (Impulsion) / Hydraulic Oil Line (Delivery)
Hidraulico Aceite Linea (Direccion) / Hydraulic Oil Line (Power Steering)
Tdf Hidraulico Aceite Linea / Hydraulic Oil Line (Pto)
Bloque De Salida Hidraulica / Hydraulic Outlet Block
Ascenso Brazo / Lift Arm
Distribuidor / Control Valve
3 Punto Cilindro Derecho / 3p Cylinder Rh
3 Punto Cilindro Izquierdo / 3p Cylinder Lh
3 Punto Cilindro [Componente Piezas] [Antiguo] / 3p Cylinder [Component Parts] [Old]
3 Punto Cilindro [Componente Piezas] [Nuevo] / 3p Cylinder [Component Parts] [New]
Posicion Control Palanca / Position Control Lever
Palanca De La Válvula De Control Auxiliar (Primera) / Auxiliary Control Valve Lever (1st)
Valvula Auxiliar Control [Componente Piezas] / Auxiliary Control Valve [Component Parts]
Auxiliar Control Valvula Acoplador / Auxiliary Control Valve Coupler
Varillaje Tercer Punto (Brazo Inf) / 3-Point Linkage (Lower Link)
Varillaje Tercer Punto (Tirante) / 3-Point Linkage (Lift Rod)
Barra De Remolque / Drawbar
Enganche Delantero / Front Hitch
Tdf Protector / Pto Protector
Soporte Delantero De Capo / Hood (Bonnet) Front Support
Capo / Hood (Bonnet) Upper
Articulacion Capo / Hood (Bonnet) Link
Cubierta Lateral Inferior / Side Cover Lower
Piastra Parzializzatore (Adelante) / Shutter Plate (Front)
Panel Bastidor / Panel Frame
Panel Inferior / Panel Cover
Guardabarros / Fender
Hoja De Piso / Floor Sheet
Peldano / Step
Cabina Bastidor / Cab Frame
Panel Cabina/Piso Estera / Cabin Panel/Floor Mat
Puerta / Door
Techo / Roof
Mat/Amortiguación De Sonido / Mat/Sound Absorber
Adelante Vidrio Y Lado Vidrio / Front Glass/Side Glass
Compuerta Trasero Vidrio / Rear Glass
Sol Visor / Sunvisor
Cabina (Lámpara De Faro Luminoso) / Cabin (Beacon Lamp)
Cabina (Trabajo Luz) / Cabin (Working Light)
Cabina (Arandela Deposito) / Cabin (Washer Tank)
Cabina (Relé/Fusible) / Cabin (Relay/Fuse)
Cabina (Etiquetaseguridad) / Cabin (Label)
Filtro Soporte / Filter Bracket
Condensador / Condenser
Compresor/Aire Acondicionador Manguito / Compressor/Air Conditioner Hose
Placa De Compresor / Compressor Plate
Rueda Delantera (29*12.00-15) / Front Wheel (29*12.00-15)
Rueda Delantera (8-16) / Front Wheel (8-16)
Rueda Delantera (9.5-16) / Front Wheel (9.5-16)
Rueda Trasera (13.6-28) / Rear Wheel (13.6-28)
Rueda Trasera (12.4-28-4pr) / Rear Wheel (12.4-28-4pr)
Rueda Trasera (475/65-D20) / Rear Wheel (475/65-D20)
Etiqueta 1 (Adelante) / Label 1 (Front)
Etiqueta 2 (Panel) / Label 2 (Panel)
Etiqueta 3 (Trasero) / Label 3 (Rear)
Posicion Control Palanca (Con El Esfuerzo) [Opcion] / Position Control Lever (With Draft) [Option]
Articulacion De Posicion (Con El Esfuerzo) [Opcion] / Position Control Link (With Draft) [Option]
Esfuerzo Y Posicion Control Palanca (Con El Esfuerzo) [Opcion] / Draft And Position Control Lever (With Draft) [Option]
Acoplamiento De Control De Esfuerzo (Con El Esfuerzo) [Opcion] / Draft Control Link (With Draft) [Option]
Distribuidor De Servicios Externos (Doble) [Opcion] / Auxiliary Control Valve (Double) [Option]
Válvula De Control Auxiliar (Flotante) [Opcion] / Auxiliary Control Valve (Floating) [Option]
Válvula De Control Auxiliar (Simple) [Opcion] / Auxiliary Control Valve (Single) [Option]
Palanca De La Válvula De Control Auxiliar (Segunda) [Opcion] / Auxiliary Control Valve Lever Kit (2nd) [Option]
Kit De Palanca De Distribuidor De Servicios Externos (Tercera) [Opcion] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Acoplador De La Válvula De Control Auxiliar (Segunda) [Opcion] / Auxiliary Control Valve Coupler (2nd) [Option]
Acoplador De La Válvula De Control Auxiliar (Tercera) [Opcion] / Auxiliary Control Valve Coupler (3rd) [Option]
