Kubota Tractor L1-552HST Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota L1-552HST Tractor
Number of Pages: 236 Pages
Itens Usados Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Vareta Nivel E Guia / Dipstick
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhau St Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Carreto / Gear Case
Arvore Cames E Veio / Camshaft And Idle Gear Shaf T
Compensador / Balancer
Volante Motor / Flywheel
Bomba De Abastecimento / Supply Pump
Bomba Gasoleo / Fuel Pump
Veio / Fuel Camshaft
Injector E Vela Aquecimento / Injector And Glow P Lug
Common Rail / Common Rail
Bomba Agua E Termostacto / Water Flange And Therm Ostat
Tubo Agua / Water Pipe
Bomba Agua / Water Pump
Linha De Óleo Hidráulico (Radiador Oleo) / Hydrau Lic Oil Line (Oil Cooler)
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [Comp Onent Parts]
Tubo Aspiracao / Inlet Pipe
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Partículas Diesel / Dies El Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [Peças Componentes] / Diesel Particulate Filter Muffler [ Component Parts]
Panela Escape Suporte Peças De Montagem / Muffler Bracket Mountingpart
Tubo Pressao / Pressure Pipe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Ch Arger)
Componentes Electricos Motor (Sensor) / Engine El Ectrical Parts (Sensor)
Componentes Electricos Motor (Panela Escape/Ecu) / Engine Electrical Parts (Muffler/Ecu)
Alavanca Acelarador / Accelerator Lever
Acelarador Automatico / Auto Throttle Cam
Deposito Combustivel Drt / Fuel Tank Rh
Deposito Combustivel Esq / Fuel Tank Lh
Tubo Do Combustível (Enchim Ento Do Combustível) / Fuel Pipe (Fuel Filter)
Tubo Combustivel (Separador /Bomba Gasoleo) / Fuel Pipe (Separator/Fuel Pump)
Tubo Combustivel (Arrefeced Or Gasoleo) / Fuel Pipe (Fuel Cooler)
Tubo Combustivel (Deposito Combustivel) / Fuel Pipe (Fuel Tank)
Filtro Gasoleo / Fuel Filte R
Filtro Gasoleo [Peças Compo Nentes] / Fuel Filter [Component Parts]
Separador / Separator
Arrefecedor Gasoleo / Fuel Cooler
Ventoinha / Fan
Alternador / Alternator
Alternador [Peças Componen Tes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Comp Onentes] / Starter [Component Parts]
Sensor (Motor) / Sensor (E Ngine)
Sensor (Panela Escape/Ecu) / Sensor (Muffler/Ecu)
Interruptor/Sensor (Bloco Motor/Capot) / Switch/Sensor (Engine/Bonnet)
Sensor (Caixa Da Transmiss Ão/Hst) / Sensor (Transmission Case/Hst)
Interruptor (Painel) / Swi Tch (Panel)
Interruptor/Sensor (Estrut Ura Do Painel) / Switch/Sensor (Panel Frame)
Interruptor/Sensor (Degrau /Deposito Combustivel/Guarda Lamas/Travao Mao) / Sw Itch/Sensor (Step/Fuel Tank/Fender/Hand Brake)
Relé / Relay
Unidade Control Electrico / Ecu
Painel / Panel
Luzes Frente / Head Light
Lampada / Winker Lamp
Farol Traseiro / Tail Ligh T
Ficha Reboque / Trailer So Cket
Cablagem Electrica (Motor) / Electrical Wiring (Engine)
Cablagem Electrica (Diante Iro) / Electrical Wiring (Front)
Cablagem Electrica (Trasei Ros) / Electrical Wiring (Rear)
Hst (Servo Pistão) [Peças Componentes] / Hst (Servo Piston) [Component Parts]
Hst (Servo Regulado R) [Peças Componentes] / Hst (Servo Regulator) [Com Ponent Parts]
Hst (Válvula Soleno Ide) [Peças Componentes] / Hst (Solenoid Valve) [Co Mponent Parts]
Hst (Válvula De Des Carga) [Peças Componentes] / Hst (Relief Valve) [Co Mponent Parts]
Hst (Bloco Do Cilin Dro) [Peças Componentes] / Hst (Cylinder Block) [Co Mponent Parts]
Hst (Suporte Neutro ) [Peças Componentes] / Hst (Port Block Cover) [Com Ponent Parts]
Hst (Bomba De Carga ) [Peças Componentes] / Hst (Charge Pump) [Componen T Parts]
Hst (Veio De Entrad A) [Peças Componentes] / Hst (Input Shaft) [Compone Nt Parts]
Caixa Intermedia / Mid Case
Válvula Da Embraiag Em Tdf/Fixador Do Rolamento / Pto Clutch Valve/Bear Ing Holder
Caixa Da Transmissã O / Transmission Case
Veio Secundario / C Ountershaft
Veio Gamas Velocida Des / Range Gear Shaft
Pinhao Espiral / Sp Iral Bevel Pinion
Contraveio De Tdf / Pto Countershaft
Embraiagem Tdf / Pt O Clutch
Embraiagem Tdf [Peç As Componentes] / Pto Clutch [Component Parts]
Veio Principal Tdf / Pto Drive Shaft
Veio Tdf / Pto Shaf T
Forqueta Velocidades / Range Gear Shift Fork
Bloqueio Diferencial De Forqueta / Differential Lock Shift Fork
Pedal Ac Elarador / Speed Control Pedal
Gama Ala Vanca De Velocidades / Range Gear Shift Lever
Eixo Traseiro Esq / Rear Axle Lh
Eixo Traseiro Drt / Rear Axle Rh
Travao Esq / Brake Lh
Travao Drt / Brake Rh
Tirante Do Travão (Pedal Do Travão) / Brake Rod (Brake Pedal)
Tirante Do Travão (Came Do Travão) / Brake Rod (Brake Cam)
Travao Mao (Suporte) / H And Brake (Support)
Travao Mao (Alavanca) / Hand Brake (Lever)
Veio Primario / Prope Ller Shaft
Veio Eixo / Front Whe El Drive Shaft
Caixa Do Diferencial Dianteiro / Front Differential Case
Engrenagem Cónica (Di Anteira) / Bevel Gear (Front)
Diferencial (Dianteir O) / Differential (Front)
Carter Eixo Frente Es Q / Front Axle Case Lh
Carter Eixo Frente Dr T / Front Axle Case Rh
Veio Grupo Conico / B Evel Gear Shaft
Eixo Dianteiro / Fron T Axle
Pedal Inclinacao / Tilt Pedal
Junta Universal / Universal Joint
Rotula/Cilindro Direcção / Tie Rod/Steering Cylinder
Cilindro Direcção [Peças Componentes] / Stee Ring Cylinder [Component Parts]
Bomba Hidraulico / Hydraul Ic Pump
Bomba Hidraulico [Peças Co Mponentes] / Hydraulic Pump [Component Parts]
Linha De Óleo Hidráulico ( Entrada) / Hydraulic Oil Line (Inlet)
Linha De Óleo Hidráulico ( Entrega/Bomba Hidráulica) / Hydraulic Oil Line (Del Ivery/Hydraulic Pump)
Linha De Óleo Hidráulico ( Entrega/Válvula Do Carregador) / Hydraulic Oil Line (Delivery/Loader Valve)
Circuito Oleo (Direcção) / Hydraulic Oil Line (Steering)
Linha De Óleo Hidráulico ( Tdf) / Hydraulic Oil Line (Pto)
Radiador Oleo / Oil Cooler
Linha De Óleo Hidráulico ( Radiador Oleo) / Hydraulic Oil Line (Oil Cooler)
Válvula Do Carregador / Lo Ader Valve
Válvula De Saída Hidráulic A [Peças Componentes] / Hydraulic Outlet Valve [Com Ponent Parts]
Tubo Do Carregador Hidrául Ico / Loader Pipe
Tampa Da Transmissão / Tra Nsmission Case Cover
Braco Hidraulico / Lift Ar M
Alavanca / Feed Back Lever
Valvula Control [Peças Com Ponentes] / Control Valve [Component Parts]
Valvula Verificação/Valvul A Segurança / Check Valve/Safety Valve
3p Cilindro Drt / 3p Cylin Der Rh
3p Cilindro(Esq) / 3p Cyli Nder Lh
3p Cilindro [Peças Compone Ntes] / 3p Cylinder [Component Parts]
Alavanca Control Posicao / Position Control Lever
Alavanca Da Válvula De Con Trolo Auxiliar / Auxiliary Control Lever
Válvula De Controlo Auxili Ar (Flutuante) [Peças Componentes] / Auxiliary Cont Rol Valve (Floating) [Component Parts]
Acoplamento Valvulas Servi Ços Externos / Auxiliary Control Valve Coupler
Ligac Ao Superior / Top Link
Ligac Ao Inferior / Lower Link
Tiran Te / Lift Rod
Puxo Dianteiro / Front Hitch
Prote Ccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Suporte Dianteiro Capot / Hood (Bonnet) Fron T Support
Tapa Lateral Baixa / Side Cover Lower
Placa / Shutter Plate
(Capot Superior) Absorvedor Som E Isolador / Hood (Bonnet) Sound Absorber And Insulator
Estrutura Do Painel / Panel Frame
Protecção / Shield
Painel Inferior / Panel Cover
Guarda Lamas / Fender
Piso / Floor Sheet
Degrau / Step
Caixa Ferramenta / Tool Box
A Rco / Rops
Roda Frente (29*12.00-15) / Front Wheel (29*12.00-15)
Roda Frente (8-16) / Front Wheel ( 8-16)
Roda Frente (9.5-16) / Front Wheel (9.5-16)
Roda Traseira (12.4-28-4pr) / Rear Wheel (12.4-28-4pr)
Roda Traseira (13.6-28) / Rear Whe El (13.6-28)
Roda Traseira (475/65-D20) / Rear Wheel (475/65-D20)
Etiqueta (Dianteiro) / Label (Front)
Decalcomania (Painel) / Label (Panel)
Etiqueta (Traseiros) / Label (Rear)
Acess Orios E Peças Serviço / Accessories And Service Par Ts
Kit Farios Trabalho [Opção] / Working Light Kit [ Option]
Apoio Frente [Opção] / Front Bumper Kit [Option]
Kit De Controlo Da Conicidade (Alavanca De Contro Lo Da Posição) [Opção] / Draft Control Kit (Positio N Control Lever) [Option]
Kit De Controlo Da Conicidade (Ligação De Control O Da Posição) [Opção] / Draft Control Kit (Position Control Link) [Option]
Kit De Controlo Da Conicidade (Alavanca De Contro Lo Da Conicidade) [Opção] / Draft Control Kit (Draf T Control Lever) [Option]
Kit De Controlo Da Conicidade (Suporte Terceiro P Onto) [Opção] / Draft Control Kit (Top Link Holder) [Option]
Kit De Alavanca Multifunções (Alavanca) [Opção] / Multifunction Lever Kit (Lever) [Option]
Controlador [Peças Componentes] [Opção] / Control Ler [Component Parts] [Option]
Kit De Alavanca Multifunções (Cablagem) [Opção] / Multifunction Lever Kit (Cable) [Option]
Válvula De Controlo Auxiliar (Duplicado) [Opção] / Auxiliary Control Valve (Double) [Option]
Válvula De Controlo Auxiliar (Flutuante) [Opção] / Auxiliary Control Valve (Floating) [Option]
Válvula De Controlo Auxiliar (Singelo) [Opção] / Auxiliary Control Valve (Single) [Option]
Alavanca Da Válvula De Controlo Auxiliar (2ª) [Op Ção] / Auxiliary Control Valve Lever Kit (2nd) [Opt Ion]
Auxiliar Do Alavanca De Válvula De Controlo Kit ( 3ª) [Opção] / Auxiliary Control Valve Lever Kit (3r D) [Option]
Acoplador Da Válvula De Controlo Auxiliar (2ª) [O Pção] / Auxiliary Control Valve Coupler (2nd) [Opti On]
Acoplador Da Válvula De Controlo Auxiliar (3ª) [O Pção] / Auxiliary Control Valve Coupler (3rd) [Opti On]
Carreto / Gear Case
Ventoinha / Fan
Relé / Relay
Painel / Panel
Tiran Te / Lift Rod
Protecção / Shield
Piso / Floor Sheet
Degrau / Step
A Rco / Rops
