Kubota Tractor L1-522DT-NEC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota L1-522DT-NEC Tractor
Number of Pages: 247 Pages
Itens Usa Dos Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Vareta Nivel E Guia / Dipstick
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Ex Haust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Carreto / Gear Case
Arvore Cames E Veio / Camshaft And Idle Gear S Haft
Compensador / Balancer
Volante Motor / Flywheel
Bomba De Abastecimento / Supply Pump
Bomba Gasoleo / Fuel Pump
Veio / Fuel Camshaft
Injector E Vela Aquecimento / Injector And Glo W Plug
Common Rail / Common Rail
Bomba Agua E Termostacto / Water Flange And Th Ermostat
Tubo Agua / Water Pipe
Bomba Agua / Water Pump
Linha De Óleo Hidráulico (Radiador Oleo) / Hyd Raulic Oil Line (Oil Cooler)
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Filtro Ar / Air Cleaner
Tubo Aspiracao / Inlet Pipe
Silenciador Do Filtro De Partículas Diesel / D Iesel Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [Pe Ças Componentes] / Diesel Particulate Filter Muffle R [Component Parts]
Panela Escape Suporte Peças De Montagem / Muff Ler Bracket Mountingpart
Tubo Pressao / Pressure Pipe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Charger)
Suporte De Bomba Hidraulico / Hydraulic Pump H Older
Componentes Electricos Motor (Sensor) / Engine Electrical Parts (Sensor)
Componentes Electricos Motor (Panela Escape/Ec U) / Engine Electrical Parts (Muffler/Ecu)
Alavanca Acelarador / Accelerator Lever
Deposito Combustivel Drt / Fuel Tank Rh
Deposito Combustivel Esq / Fuel Tank Lh
Tubo Do Combustível (Enc Himento Do Combustível) / Fuel Pipe (Fuel Filter)
Tubo Combustivel (Separa Dor/Bomba Gasoleo) / Fuel Pipe (Separator/Fuel Pump )
Tubo Combustivel (Arrefe Cedor Gasoleo) / Fuel Pipe (Fuel Cooler)
Tubo Combustivel (Deposi To Combustivel) / Fuel Pipe (Fuel Tank)
Filtro Gasoleo / Fuel Fi Lter
Filtro Gasoleo [Peças Co Mponentes] / Fuel Filter [Component Parts]
Separador / Separator
Separador [Peças Compone Ntes] / Separator [Component Parts]
Arrefecedor Gasoleo / Fu El Cooler
Ventoi Nha / Fan
Tubo A Gua / Water Pipe
Radiad Or / Radiator
Deposi To Reserva / Reserve Tank
Alternador / Alternator
Alternador [Peças Compo Nentes] / Alternator [Component Parts]
Motor Arranque / Starte R
Motor Arranque [Peças C Omponentes] / Starter [Component Parts]
Sensor (Motor) / Sensor (Engine)
Sensor (Panela Escape/E Cu) / Sensor (Muffler/Ecu)
Interruptor/Sensor (Blo Co Motor/Capot) / Switch/Sensor (Engine/Bonnet)
Interruptor/Sensor (Tra Nsmissão Carter ) / Switch/Sensor (Transmission Cas E)
Interruptor (Painel) / Switch (Panel)
Interruptor/Sensor (Est Rutura Do Painel) / Switch/Sensor (Panel Frame)
Interruptor/Sensor (Deg Rau/Deposito Combustivel/Guarda Lamas/Travao Mao) / Switch/Sensor (Step/Fuel Tank/Fender/Hand Brake)
Relé / Relay
Unidade Control Electri Co / Ecu
Painel / Panel
Luzes Frente / Head Lig Ht
Lampada / Winker Lamp
Farol Traseiro / Tail L Ight
Farol Matricula / Licen Se Lamp
Cablagem Electrica (Mot Or) / Electrical Wiring (Engine)
Cablagem Electrica (Dia Nteiro) / Electrical Wiring (Front)
Cablagem Electrica (Tra Seiros) / Electrical Wiring (Rear)
Embraiagem / Clu Tch
Alavanca Da Embr Aiagem / Clutch Lever
Carter Embraiage M / Clutch Housing
Valvula Embraiag Em Tdf / Pto Clutch Valve
Valvula Embraiag Em Tdf [Peças Componentes] / Pto Clutch Valve [Comp Onent Parts]
Caixa Da Transmi Ssão / Transmission Case
Veio Primario / Main Shaft
Veio Secundario / Countershaft
Veio Inversor / Shuttle Shaft
Inversor / Rever Se Shaft
Veio Gamas Veloc Idades / Range Gear Shaft
Pinhao Espiral / Spiral Bevel Pinion
Diferencial Tras Eiro / Rear Differential
Contraveio De Td F / Pto Countershaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf [ Peças Componentes] / Pto Clutch [Component Parts]
Veio Principal T Df / Pto Drive Shaft
Veio Tdf / Pto S Haft
Forqu Eta / Main Gear Shift Fork
Forqu Ilha Inversor / Shuttle Shift Fork
Forqu Eta Velocidades / Range Gear Shift Fork
Bloqu Eio Diferencial De Forqueta / Differential Lock Shi Ft Fork
Alava Nca Velocidades / Main Gear Shift Lever
Alvan Ca Inversor / Shuttle Shift Lever
Gama Alavanca De Velocidades / Range Gear Shift Lever
Alava Nca Dupla Traccao / Front Wheel Drive Lever
Eixo Traseiro Esq / R Ear Axle Lh
Eixo Traseiro Drt / R Ear Axle Rh
Travao Esq / Brake Lh
Travao Drt / Brake Rh
Tirante Do Travão (Pe Dal Do Travão) / Brake Rod (Brake Pedal)
Tirante Do Travão (Ca Me Do Travão) / Brake Rod (Brake Cam)
Travao Mao (Suporte) / Hand Brake (Support)
Travao Mao (Alavanca) / Hand Brake (Lever)
Pedal Travao / Brake Pedal
Veio Primario / Pr Opeller Shaft
Veio Eixo / Front Wheel Drive Shaft
Caixa Do Diferenci Al Dianteiro / Front Differential Case
Engrenagem Cónica (Dianteira) / Bevel Gear (Front)
Diferencial (Diant Eiro) / Differential (Front)
Carter Eixo Frente Esq / Front Axle Case Lh
Carter Eixo Frente Drt / Front Axle Case Rh
Eixo Dianteiro / F Ront Axle
Pedal Inclinacao / Tilt Pedal
Junta Universal / Universal Joint
Distribuidor Direcção / Steering Controll Er
Rotula/Cilindro Direcção / Tie Rod/Steeri Ng Cylinder
Cilindro Direcção [Peças Componentes] / S Teering Cylinder [Component Parts]
Bomba Hidraulico / Hydr Aulic Pump
Valvula Reguladora / Re Gulater Valve
Linha De Óleo Hidráulic O (Entrada) / Hydraulic Oil Line (Inlet)
Linha De Óleo Hidráulic O (Entrega) / Hydraulic Oil Line (Delivery)
Circuito Oleo (Direcção ) / Hydraulic Oil Line (Steering)
Linha De Óleo Hidráulic O (Tdf) / Hydraulic Oil Line (Pto)
Bloco Saidas Hidraulico / Hydraulic Outlet Block
Tampa Da Transmissão / Transmission Case Cover
Braco Hidraulico / Lift Arm
Valvula Control [Peças Componentes] / Control Valve [Component Parts]
3p Cilindro Drt / 3p Cy Linder Rh
3p Cilindro Esq / 3p Cy Linder Lh
3p Cilindro [Peças Comp Onentes] / 3p Cylinder [Component Parts]
Alavanca Control Posica O / Position Control Lever
Alavanca Da Válvula De Controlo Auxiliar / Auxiliary Control Lever
Válvula De Controlo Aux Iliar (Flutuante) [Peças Componentes] / Auxiliary C Ontrol Valve (Floating) [Component Parts]
Acoplamento Valvulas Se Rviços Externos / Auxiliary Control Valve Coupler
Li Gacao Superior / Top Link
Li Gacao Inferior / Lower Link
Ti Rante / Lift Rod
Ba Rra Reboque / Drawbar
Pu Xo Dianteiro / Front Hitch
Pr Oteccao Tdf / Pto Protector
Suporte Dianteiro Capot / Hood (Bonnet) F Ront Support
Tapa Lateral Baixa / Side Cover Lower
Placa / Shutter Plate
(Capot Superior) Absorvedor Som E Isolado R / Hood (Bonnet) Sound Absorber And Insulator
Estrutura Do Painel / Panel Frame
Protecção / Shield
Painel Inferior / Panel Cover
Guarda Lamas / Fender
Piso / Floor Sheet
Degrau / Step
Caixa Ferramenta / Tool Box
Arco / Rops
Roda Frente (29*12.00-15) / Fro Nt Wheel (29*12.00-15)
Roda Frente (8-16) / Front Whee L (8-16)
Roda Frente (9.5-16) / Front Wh Eel (9.5-16)
Roda Traseira (12.4-28-4pr) / R Ear Wheel (12.4-28-4pr)
Roda Traseira (13.6-28) / Rear Wheel (13.6-28)
Roda Traseira (475/65-D20) / Re Ar Wheel (475/65-D20)
Etiqueta (Dianteiro) / Label (Front)
Decalcomania (Painel) / Label (Panel)
Etiqueta (Traseiros) / Label (Rear)
Ac Essorios E Peças Serviço / Accessories And Service Parts
Kit Farios Trabalho [Opção] / Working Light Ki T [Option]
Apoio Frente [Opção] / Front Bumper Kit [Optio N]
Kit De Controlo Da Conicidade (Alavanca De Con Trolo Da Posição) [Opção] / Draft Control Kit (Posi Tion Control Lever) [Option]
Kit De Controlo Da Conicidade (Ligação De Cont Rolo Da Posição) [Opção] / Draft Control Kit (Posit Ion Control Link) [Option]
Kit De Controlo Da Conicidade (Alavanca De Con Trolo Da Conicidade) [Opção] / Draft Control Kit (D Raft Control Lever) [Option]
Kit De Controlo Da Conicidade (Suporte Terceir O Ponto) [Opção] / Draft Control Kit (Top Link Hold Er) [Option]
Controlador [Peças Componentes] [Opção] / Cont Roller [Component Parts] [Option]
Kit De Alavanca Multifunções (Cablagem) [Opção ] / Multifunction Lever Kit (Cable) [Option]
Válvula De Controlo Auxiliar (Duplicado) [Opçã O] / Auxiliary Control Valve (Double) [Option]
Válvula De Controlo Auxiliar (Flutuante) [Opçã O] / Auxiliary Control Valve (Floating) [Option]
Válvula De Controlo Auxiliar (Singelo) [Opção] / Auxiliary Control Valve (Single) [Option]
Alavanca Da Válvula De Controlo Auxiliar (2ª) [Opção] / Auxiliary Control Valve Lever Kit (2nd) [ Option]
Auxiliar Do Alavanca De Válvula De Controlo Ki T (3ª) [Opção] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Acoplador Da Válvula De Controlo Auxiliar (3ª) [Opção] / Auxiliary Control Valve Coupler (3rd) [O Ption]
Carreto / Gear Case
Ventoi Nha / Fan
Relé / Relay
Painel / Panel
Ti Rante / Lift Rod
Protecção / Shield
Piso / Floor Sheet
Degrau / Step
Arco / Rops
