Kubota Tractor L1-522DT-EC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota L1-522DT-EC Tractor
Number of Pages: 253 Pages
Itens Usad Os Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Vareta Nivel E Guia / Dipstick
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exh Aust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Carreto / Gear Case
Arvore Cames E Veio / Camshaft And Idle Gear Sh Aft
Compensador / Balancer
Volante Motor / Flywheel
Bomba De Abastecimento / Supply Pump
Bomba Gasoleo / Fuel Pump
Veio / Fuel Camshaft
Injector E Vela Aquecimento / Injector And Glow Plug
Common Rail / Common Rail
Bomba Agua E Termostacto / Water Flange And The Rmostat
Tubo Agua / Water Pipe
Bomba Agua / Water Pump
Linha De Óleo Hidráulico (Radiador Oleo) / Hydr Aulic Oil Line (Oil Cooler)
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [Co Mponent Parts]
Tubo Aspiracao / Inlet Pipe
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Partículas Diesel / Di Esel Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [Peç As Componentes] / Diesel Particulate Filter Muffler [Component Parts]
Panela Escape Suporte Peças De Montagem / Muffl Er Bracket Mountingpart
Tubo Pressao / Pressure Pipe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Charger)
Componentes Electricos Motor (Sensor) / Engine Electrical Parts (Sensor)
Componentes Electricos Motor (Panela Escape/Ecu ) / Engine Electrical Parts (Muffler/Ecu)
Alavanca Acelarador / Accelerator Lever
Deposito Combustivel Drt / Fuel Tank Rh
Deposito Combustivel Esq / Fuel Tank Lh
Tubo Do Combustível (Ench Imento Do Combustível) / Fuel Pipe (Fuel Filter)
Tubo Combustivel (Separad Or/Bomba Gasoleo) / Fuel Pipe (Separator/Fuel Pump)
Tubo Combustivel (Arrefec Edor Gasoleo) / Fuel Pipe (Fuel Cooler)
Tubo Combustivel (Deposit O Combustivel) / Fuel Pipe (Fuel Tank)
Filtro Gasoleo / Fuel Fil Ter
Filtro Gasoleo [Peças Com Ponentes] / Fuel Filter [Component Parts]
Separador / Separator
Separador [Peças Componen Tes] / Separator [Component Parts]
Arrefecedor Gasoleo / Fue L Cooler
Ventoin Ha / Fan
Tubo Ag Ua / Water Pipe
Radiado R / Radiator
Deposit O Reserva / Reserve Tank
Alternador / Alternator
Alternador [Peças Compon Entes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Co Mponentes] / Starter [Component Parts]
Sensor (Motor) / Sensor (Engine)
Sensor (Panela Escape/Ec U) / Sensor (Muffler/Ecu)
Interruptor/Sensor (Bloc O Motor/Capot) / Switch/Sensor (Engine/Bonnet)
Interruptor/Sensor (Tran Smissão Carter ) / Switch/Sensor (Transmission Case )
Interruptor (Painel) / S Witch (Panel)
Interruptor/Sensor (Estr Utura Do Painel) / Switch/Sensor (Panel Frame)
Interruptor/Sensor (Degr Au/Deposito Combustivel/Guarda Lamas/Travao Mao) / Switch/Sensor (Step/Fuel Tank/Fender/Hand Brake)
Relé / Relay
Unidade Control Electric O / Ecu
Painel / Panel
Luzes Frente / Head Ligh T
Lampada / Winker Lamp
Farol Traseiro / Tail Li Ght
Farol Matricula / Licens E Lamp
Cablagem Electrica (Moto R) / Electrical Wiring (Engine)
Cablagem Electrica (Dian Teiro) / Electrical Wiring (Front)
Cablagem Electrica (Tras Eiros) / Electrical Wiring (Rear)
Embraiagem / Clut Ch
Alavanca Da Embra Iagem / Clutch Lever
Caixa Intermedia / Mid Case
Valvula Embraiage M Tdf / Pto Clutch Valve
Valvula Embraiage M Tdf [Peças Componentes] / Pto Clutch Valve [Compo Nent Parts]
Caixa Da Transmis São / Transmission Case
Veio Primario / M Ain Shaft
Veio Secundario / Countershaft
Veio Inversor / S Huttle Shaft
Inversor / Revers E Shaft
Veio Gamas Veloci Dades / Range Gear Shaft
Pinhao Espiral / Spiral Bevel Pinion
Diferencial Trase Iro / Rear Differential
Contraveio De Tdf / Pto Countershaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf [P Eças Componentes] / Pto Clutch [Component Parts]
Veio Principal Td F / Pto Drive Shaft
Veio Tdf / Pto Sh Aft
Forque Ta / Main Gear Shift Fork
Forqui Lha Inversor / Shuttle Shift Fork
Forque Ta Velocidades / Range Gear Shift Fork
Bloque Io Diferencial De Forqueta / Differential Lock Shif T Fork
Alavan Ca Velocidades / Main Gear Shift Lever
Alvanc A Inversor / Shuttle Shift Lever
Gama A Lavanca De Velocidades / Range Gear Shift Lever
Alavan Ca Dupla Traccao / Front Wheel Drive Lever
Eixo Traseiro Esq / Re Ar Axle Lh
Eixo Traseiro Drt / Re Ar Axle Rh
Travao Esq / Brake Lh
Travao Drt / Brake Rh
Tirante Do Travão (Ped Al Do Travão) / Brake Rod (Brake Pedal)
Tirante Do Travão (Cam E Do Travão) / Brake Rod (Brake Cam)
Travao Mao (Suporte) / Hand Brake (Support)
Travao Mao (Alavanca) / Hand Brake (Lever)
Pedal Travao / Brake P Edal
Veio Primario / Pro Peller Shaft
Veio Eixo / Front W Heel Drive Shaft
Caixa Do Diferencia L Dianteiro / Front Differential Case
Engrenagem Cónica ( Dianteira) / Bevel Gear (Front)
Diferencial (Diante Iro) / Differential (Front)
Carter Eixo Frente Esq / Front Axle Case Lh
Carter Eixo Frente Drt / Front Axle Case Rh
Veio Grupo Conico / Bevel Gear Shaft
Eixo Dianteiro / Fr Ont Axle
Pedal Inclinacao / Tilt Pedal
Junta Universal / Universal Joint
Distribuidor Direcção / Steering Controlle R
Rotula/Cilindro Direcção / Tie Rod/Steerin G Cylinder
Cilindro Direcção [Peças Componentes] / St Eering Cylinder [Component Parts]
Bomba Hidraulico / Hydra Ulic Pump
Valvula Reguladora / Reg Ulater Valve
Linha De Óleo Hidráulico (Entrada) / Hydraulic Oil Line (Inlet)
Linha De Óleo Hidráulico (Entrega/Bomba Hidráulica) / Hydraulic Oil Line (D Elivery/Hydraulic Pump)
Linha De Óleo Hidráulico (Entrega/Válvula Do Carregador) / Hydraulic Oil Li Ne (Delivery/Loader Valve)
Circuito Oleo (Direcção) / Hydraulic Oil Line (Steering)
Linha De Óleo Hidráulico (Tdf) / Hydraulic Oil Line (Pto)
Válvula Do Carregador / Loader Valve
Válvula De Saída Hidrául Ica [Peças Componentes] / Hydraulic Outlet Valve [C Omponent Parts]
Tubo Do Carregador Hidrá Ulico / Loader Pipe
Tampa Da Transmissão / T Ransmission Case Cover
Braco Hidraulico / Lift Arm
Alavanca / Feed Back Lev Er
Valvula Control / Contro L Valve
Valvula Control [Peças C Omponentes] / Control Valve [Component Parts]
Valvula Verificação/Valv Ula Segurança / Check Valve/Safety Valve
3p Cilindro Drt / 3p Cyl Inder Rh
3p Cilindro Esq / 3p Cyl Inder Lh
3p Cilindro [Peças Compo Nentes] / 3p Cylinder [Component Parts]
Alavanca Control Posicao / Position Control Lever
Alavanca Da Válvula De C Ontrolo Auxiliar / Auxiliary Control Lever
Válvula De Controlo Auxi Liar (Flutuante) [Peças Componentes] / Auxiliary Co Ntrol Valve (Floating) [Component Parts]
Acoplamento Valvulas Ser Viços Externos / Auxiliary Control Valve Coupler
Lig Acao Superior / Top Link
Lig Acao Inferior / Lower Link
Bar Ra Reboque / Drawbar
Pux O Dianteiro / Front Hitch
Grelha Frontal / Front Grille
Suporte Dianteiro Capot / Hood (Bonnet) Fr Ont Support
Tapa Lateral Baixa / Side Cover Lower
(Capot Superior) Absorvedor Som E Isolador / Hood (Bonnet) Sound Absorber And Insulator
Estrutura Do Painel / Panel Frame
Protecção / Shield
Painel Inferior / Panel Cover
Guarda Lamas / Fender
Piso / Floor Sheet
Degrau / Step
Arco / Rops
Roda Frente (29*12.00-15) / Fron T Wheel (29*12.00-15)
Roda Frente (8-16) / Front Wheel (8-16)
Roda Traseira (12.4-28-4pr) / Re Ar Wheel (12.4-28-4pr)
Roda Traseira (13.6-28) / Rear W Heel (13.6-28)
Roda Traseira (475/65-D20) / Rea R Wheel (475/65-D20)
Etiqueta (Dianteiro) / Label (Front)
Decalcomania (Painel) / Label (Panel)
Etiqueta (Traseiros) / Label (Rear)
Ace Ssorios E Peças Serviço / Accessories And Service P Arts
Kit Farios Trabalho [Opção] / Working Light Kit [Option]
Apoio Frente [Opção] / Front Bumper Kit [Option ]
Kit De Controlo Da Conicidade (Alavanca De Cont Rolo Da Posição) [Opção] / Draft Control Kit (Posit Ion Control Lever) [Option]
Kit De Controlo Da Conicidade (Ligação De Contr Olo Da Posição) [Opção] / Draft Control Kit (Positi On Control Link) [Option]
Kit De Controlo Da Conicidade (Alavanca De Cont Rolo Da Conicidade) [Opção] / Draft Control Kit (Dr Aft Control Lever) [Option]
Kit De Controlo Da Conicidade (Suporte Terceiro Ponto) [Opção] / Draft Control Kit (Top Link Holde R) [Option]
Kit De Alavanca Multifunções (Alavanca) [Opção] / Multifunction Lever Kit (Lever) [Option]
Controlador [Peças Componentes] [Opção] / Contr Oller [Component Parts] [Option]
Kit De Alavanca Multifunções (Cablagem) [Opção] / Multifunction Lever Kit (Cable) [Option]
Válvula De Controlo Auxiliar (Duplicado) [Opção ] / Auxiliary Control Valve (Double) [Option]
Válvula De Controlo Auxiliar (Flutuante) [Opção ] / Auxiliary Control Valve (Floating) [Option]
Válvula De Controlo Auxiliar (Singelo) [Opção] / Auxiliary Control Valve (Single) [Option]
Alavanca Da Válvula De Controlo Auxiliar (2ª) [ Opção] / Auxiliary Control Valve Lever Kit (2nd) [O Ption]
Auxiliar Do Alavanca De Válvula De Controlo Kit (3ª) [Opção] / Auxiliary Control Valve Lever Kit ( 3rd) [Option]
Acoplador Da Válvula De Controlo Auxiliar (2ª) [Opção] / Auxiliary Control Valve Coupler (2nd) [Op Tion]
